NPPN161BFCN-RC
NPPN161BFCN-RC
    SULLINS
    CONNHEADER.079"16POS
NPPN161BFCN-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 642 INITIAL RELEASE 6/14/2005 TT B 1126 UPDATE SPECIFICATIONS ADD POSI. 2 & 3, UPDATE P/N CODING, VIEWS, TOLERANCE BLOCK, TOLERANCE +/-.05 FOR CC. WAS +/- .5, AND +/-.10 FOR 'A' WAS +/-.05 9/12/2006 MV C F 1811 1/10/2009 F JH E E .017 0.44 .094 2.40 D D .059 1.50 .173 4.40 .094±.008 2.40±0.20 .020±.002 0.50±0.05 C .008±.002 0.20±0.05 .079±.002 2.00±0.05 C A±.008 [ .20] B±.014 [ .35] A±.004 [ 0.10] 02-20, 0.20mm MAX. 21-40, 0.30mm MAX. .079±.002 2.00±0.05 .031±.002 0.80±0.05 B A B NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: GOLD FLASH OVERALL. 4. CURRENT RATING: 1 AMP. 5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 6. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 7. DIELECTRIC WITHSTANDING: AC 500V. 8. OPERATING TEMPERATURE: -40° C TO +105° C. 9. *PROCESSING TEMP.: 260° C FOR 10 SECS MAX. RECOMMENDED PCB LAYOUT UNLESS OTHERWISE SPECIFIED: Pb *INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME. 8 7 6 DIMENSIONS ARE IN INCHES[MM] TOLERANCES: ANGULAR: 5 .X= .012 [.30] .XX= .008 [.20] .XXX= .006 [.15] SURFACE FINISH: 63 Ra REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT 5 4 DRAWN NAME 1/10/09 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. HEADER, FEMALE 2mm CC, 1 ROW, ST NPPNxx1BFCN-RC SIZE DWG. NO. C INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 DATE REV 10483 SCALE: 16:1 2 C SHEET 1 OF 1 1 FILE NAME: Z:\COMPONENTS\Taiwan\10483, NPPNxx1BFCN-RC PRINT: 3/4/2009 A
NPPN161BFCN-RC
物料型号:NPPNxx1BFCN-RC 器件简介:该器件为排针排母,绝缘材料为尼龙6T,符合UL 94V-0标准。
引脚分配:提供3至40个位置,每个位置有1至2个接触点。
参数特性:接触材料为磷青铜,接触镀层为金闪镀,额定电流1安培,绝缘电阻最小5000兆欧,接触电阻最大20毫欧,耐电压AC 500V,工作温度范围-40°C至+105°C。
功能详解:该排针排母适用于电路连接,具有高绝缘性和良好的导电性。
应用信息:适用于需要电路连接的各种应用,如电子设备、测试设备等。
封装信息:尺寸和公差按照ANSI Y14.5M-1994标准,表面处理为63 Ra,去毛刺和锐边,最大0.010英寸。
NPPN161BFCN-RC 价格&库存
很抱歉,暂时无法提供与“NPPN161BFCN-RC”相匹配的价格&库存,您可以联系我们找货
