8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
G
2517
H
2673
DESCRIPTION
DATE
ADD NOTE 10 MATING PARTS
02/08/2012
UPDATE OPERATING TEMP, TAIL LENGTH
TOLERANCE, PCB LAYOUT FOR TOP/BOTTEM ENTRY 09/14/2012
BY
LH
LH
F
F
B
PIN 1
LEFT
E
E
.087 2.20
.050 1.27
.100 2.54
A
LPPB_ _1NFSC-RC
(STANDARD)
.050 1.27
PIN 1
LEFT
.028 0.70
B
D
D
.016 0.40
.173 4.40
.028 0.70
(NOT REQ'D
FOR TOP ENTRY)
.087 2.20
PIN 1
RIGHT
RECOMMENDED PCB LAYOUT
LPPB_ _1NFSC-RC
LPPB_ _1NFSD-RC
(OPPOSITE BEND, APPLICABLE ON EVEN PIN COUNTS)
.018 0.45
.081 2.05
C
.067 1.70
.100 2.54
A
.177 4.50
C
.100 2.54
.183 4.65
.050 1.27
.004[0.10]
A
B
A
.006 0.15
02-20, 0.20mm MAX.
21-50, 0.30mm MAX.
PIN 1
RIGHT
NOTES:
1. INSULATOR MATERIAL: L.C.P. , UL 94V-0, COLOR: BLACK.
*PROCESSING TEMPERATURE = 260° C FOR 10 SECS MAX.
2. CONTACT MATERIAL: PHOSPHOR BRONZE
3. PLATING: .000030" ~ .000050" NICKEL UNDERPLATED, GOLD FLASH OVERALL.
4. OPERATING TEMPERATURE: -40°C TO +125° C.
5. INSULATION RESISTANCE: 5000 MEGA OHMS MIN.
6. CONTACT RESISTANCE: 20 MILLI OHMS MAX.
7. DIELECTRIC WITHSTANDING: 500V AC.
8. CURRENT RATING: 1 AMP.
9. MATES WITH SULLINS .050 [1.27] CONTACT CENTER MALE HEADER SERIES.
(.016 [0.40] SQUARE POSTS)
Pb
7
6
RoHS COMPLIANT
5
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .012 [.3]
.XXX= .008 [.20]
.XXXX= .0040 [.100]
DRAWN
B
LPPB_ _1NFSD-RC
DATE
NAME
01/20/2009 JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER FEMALE .050" [1.27mm] PITCH, 1 ROW,
SMT TOP/BOTTOM ENTRY
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 8:1
3
.067 1.70
.028 0.70
.028 0.70
(NOT REQ'D FOR
TOP ENTRY)
*INDICATED TEMPERATURE AND TIME IS FOR COMPONENT
INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED,
PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR
DOES NOT EXCEED INDICATED TEMPERATURE AND TIME.
8
.173 4.40
.122±.006 3.10±0.15
2
LPPB_ _1NFS_-RC
DWG. NO.
10965
SHEET 1 OF 1
1
REV
H
FILE NAME: 10965, LPPB_ _1NFS_-RC
A
很抱歉,暂时无法提供与“LPPB101NFSD-RC”相匹配的价格&库存,您可以联系我们找货
