NPPN142AFCN-RC
NPPN142AFCN-RC
    SULLINS
    CONNHEADER.079"28POS
NPPN142AFCN-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO E 2515 F 3120 DATE REMOVE CONTACT DEPTH TOLERANCE & ADD "REF.", ADD 01/16/2012 NOTE 10 MATING PARTS. UPDATE PROCESSING TEMPERATURE FOR NYLON 6T MATERIAL AND CURRENT RATING TO 2 AMPS (WAS 1 04/15/2015 AMP), ADD VIEW FOR POSITIONS 27 TO 40 F E DESCRIPTION BY LH LH F E FOR POSITIONS 27 TO 40 B±.014 [ 0.35] .079±.002 2.00±0.05 .157 4.00 D D .057 1.45 REF. .169 4.30 .094±.008 2.40±0.20 .020±.002 0.50±0.05 .079±.002 2.00±0.05 C C .008±.002 0.20±0.05 .079±.004 2.00±0.10 A±.008 [ 0.20] 02-20, 0.20mm MAX. 21-40, 0.30mm MAX. A±.004 [ .10] .031 0.80 .079 2.00 B A B NOTES: 1. INSULATOR MATERIAL: NYLON 6T, UL 94V-0, COLOR: BLACK. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: .000030"-.000050" MIN NICKEL UNDERPLATE, GOLD FLASH OVERALL. 4. CURRENT RATING: 2 AMP. 5. VOLTAGE RATING: 150V AC/DC. 6. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 7. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 8. DIELECTRIC WITHSTANDING: 500V AC. 9. OPERATING TEMPERATURE: -40 C TO +105 C 10.PROCESSING TEMP.: WAVE/MANUAL SOLDERING ONLY. 11.MATES WITH SULLINS .079 [2.00] CONTACT CENTER MALE HEADER SERIES. (.020 [0.50] SQUARE POSTS) .079 2.00 RECOMMENDED PCB LAYOUT Pb RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] TOLERANCES: ANGULAR: DECIMALS .X= .012 [.30] .XX= .008 [.20] .XXX= .006 [.15] DRAWN DATE NAME 01/10/2009 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE HEADER, FEMALE 2mm CC, 2 ROWS, ST PART NUMBER SIZE C CAGE CODE 54453 SCALE: 8:1 3 2 NPPNxx2AFCN-RC DWG. NO. 10497 SHEET 1 OF 1 1 REV F FILE NAME: 10497, NPPNxx2AFCN-RC A
NPPN142AFCN-RC 价格&库存
很抱歉,暂时无法提供与“NPPN142AFCN-RC”相匹配的价格&库存,您可以联系我们找货
