NPPC072KFMP-RC
NPPC072KFMP-RC
    SULLINS
    CONNHEADER.100"14POS
NPPC072KFMP-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY L 2829 ADD INSULATOR MATERIAL 'LCP' OPTION 12/10/2014 LH M 3963 UPDATE GENERAL TOL IN TITLE BOX & NOTE 8, UPGRADE NYLON MTL (FROM 6T TO 9T) 1/3/2019 JH F F E E A .004[ 0.10] C .004[ 0.10] .039±.002 1.00±0.05 .100±.002 2.54±0.05 B .012[ 0.30] .061±.002 1.56±0.05 A .008 [ 0.20] D D .100±.002 2.54±0.05 .290±.004 7.37±0.10 .100±.002 2.54±0.05 .100 2.54 C .040 1.02 .024(w) X .010(t) [0.60 X 0.25] 2 X .047 1.20 MIN OPTIONAL RECOMMENDED PCB LAYOUT .197±.006 5.00±0.15 .020 0.50 C .092 2.33 .280 7.10 C .008 [ 0.20] B 2X A 7 6 OPTIONAL SEE PART NUMBER CODING .270±.012 6.85±0.30 B .037±.004 0.95±0.10 NOTES: 02-20, .008[0.20] MAX. 1. INSULATOR MATERIAL: SEE PART NUMBER CODING, UL 94V-0 21-30, .012[0.30] MAX. 2. CONTACT MATERIAL: PHOSPHOR BRONZE 31-40, .016[0.40] MAX. 3. CONTACT PLATING: SEE PART NUMBER CODING 4. CURRENT RATING: 3 AMPS 5. VOLTAGE RATING: 250V AC 6. INSULATOR RESISTANCE: 5000 MEGOHMS MIN 7. CONTACT RESISTANCE: 20 MILLIOHMS MAX 8. DIELECTRIC WITHSTANDING: 1000 VAC 9. OPERATING TEMPERATURE: SEE PART NUMBER CODING 10.PROCESSING TEMP.: SEE PART NUMBER CODING 11.MATES WITH SULLINS .100 [2.54] CONTACT CENTER MALE HEADER SERIES (.025 [0.64] SQUARE POSTS) 8 .049 1.25 .295±.010 7.50±0.25 5 Pb RoHS COMPLIANT 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 12/04/2008 JH TOLERANCES: ANGULAR: 5 DECIMALS .XX= .012 [.3] .XXX= .008 [.20] .XXXX= .0039 [.100] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C 54453 2 A xPxCxx2KFMx-RC CAGE CODE SCALE: 6:1 3 HEADER FEMALE, 2.54mm CC, 2 ROWS, SMT DWG. NO. 10488 SHEET 1 OF 1 1 REV M FILE NAME: 10488, xPxCxx2KFMx-RC
NPPC072KFMP-RC
1. 物料型号:文档中提到了型号编码规则,例如“xPxCxx2KFMx-RC”,但未提供具体的型号名称。
2. 器件简介:文档中没有直接提供器件的简介,但提供了一些技术规格和参数。
3. 引脚分配:文档列出了不同位置的引脚间距,例如02/04位置的引脚间距为0.100英寸(2.54毫米),03/06位置的引脚间距为0.200英寸(5.08毫米),以此类推。
4. 参数特性: - 绝缘材料的工作温度范围为-40°C至+105°C。 - 处理温度为260°C,最大持续时间为10秒。 - 引脚镀层包括镀锡、镀金等不同选项。 - 电流额定值为3安培,电压额定值为250V交流电。 - 绝缘电阻至少为5000兆欧姆。 - 接触电阻最大为20毫欧姆。 - 耐电压为1000伏交流电。
5. 功能详解:文档中没有提供详细的功能解释,但列出了技术规格和一些操作参数。
6. 应用信息:文档中没有明确提供应用信息,但根据技术规格可以推断该器件可能用于需要电气连接和信号传输的应用。
7. 封装信息:文档提供了一些封装相关的尺寸信息,例如引脚间距、绝缘体尺寸等。
NPPC072KFMP-RC 价格&库存
很抱歉,暂时无法提供与“NPPC072KFMP-RC”相匹配的价格&库存,您可以联系我们找货
