SFM850-NPPC-D08-SM-BK
    SULLINS
    CONNHEADER.100"16POS
SFM850-NPPC-D08-SM-BK 数据手册
8 7 4 5 6 1 2 3 REVISIONS F REV. ECO. NO DESCRIPTION DATE BY A 2399 INITIAL RELEASE 07/18/2011 GC B 3090 UPGRADE INSULATOR MATERIAL NYLON 9T(WAS NYLON 6T) 10/29/2014 LH C 3522 UPDATE FRONT VIEW, ADD WARP TOLERANCE AND 09/06/2016 SMT TAIL COPLANAR TOLERANCE ON DRAWING LH F B .021 0.54 E E .100 2.54 .100 2.54 A .197 5.00 D D .154 3.90 .335 8.50 .344 8.75 .004[0.10] 02 - 25 POSITIONS .005[0.12] 26 - 40 POSITIONS 2X .051 1.30 .039±.004 1.00±0.10 .010 0.25 .264 6.70 OPTIONAL, SEE PART NUMBER CODING C C 03 - 10, 0.10mm MAX. 11 - 25, 0.20mm MAX. 26 - 40, 0.30mm MAX. C A .039 [1.00] .100 2.54 .039 [1.00] .075 1.90 (NOT REQ'D FOR USE AS TOP ENTRY) .100 2.54 B A NOTES: 1. INSULATOR MATERIAL: NYLON 9T, UL 94V-0, COLOR: BLACK 2. CONTACT MATERIAL: PHOSPHOR BRONZE 3. CONTACT PLATING: .000030" - .000050"NICKEL UNDERPLATE, GOLD FLASH OVERALL 4. CURRENT RATING: 3 AMPS 5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 6. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 7. DIELECTRIC WITHSTANDING: 1000 V AC 8. OPERATING TEMPERATURE: -40°C TO +105°C 9. *PROCESSING TEMP.: 230° C MAX FOR 60 SECONDS (260° C MAX FOR 10 SECONDS) 10. FOR TOP/BOTTOM ENTRY 11. CONSULT FACTORY FOR THE MATE IF BEING USED AS BOTTOM ENTRY B 2X .047±.004 1.20±0.10 OPTIONAL, SEE PART NUMBER CODING Pb * (INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME.) 8 7 6 .303 7.70 RoHS COMPLIANT 5 4 C RECOMMENDED PCB LAYOUT UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] TOLERANCES: ANGULAR: 1 DECIMALS .XX= .012 [.3] .XXX= .008 [.20] .XXXX= .0040 [.100] DRAWN DATE NAME 07/18/11 GC THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE HEADER FEMALE, .100 CC, T/B ENTRY PART NUMBER SIZE C 54453 SCALE: 4:1 3 2 SFM850-NPPC-D_ _-S_-BK CAGE CODE DWG. NO. 11811 SHEET 1 OF 1 1 REV C FILE NAME: 11811, SFM850-NPPC-D_ _-S_-BK A
SFM850-NPPC-D08-SM-BK 价格&库存
很抱歉,暂时无法提供与“SFM850-NPPC-D08-SM-BK”相匹配的价格&库存,您可以联系我们找货
