NPPN112GFNS-RC
NPPN112GFNS-RC
    SULLINS
    CONNHEADER.079"22POS
NPPN112GFNS-RC 数据手册
Headers .079” [2.00 mm] Contact Centers, Female Headers, Straight/Right Angle/SMT SPECIFICATIONS • • • • 2 Amps current rating UL Flammability Rating: 94V-0 Insulator Material: Black Nylon Contact Material: Phosphor Bronze READOUT DUAL (2) SINGLE (1) QUAD (4) TERMINATION TYPE B P/N CODE A STRAIGHT Headers TAIL ROWS TERMINATION TYPE A B TAIL BFC 1 STRAIGHT .173ˮ [4.40] .094ˮ [2.40] .094ˮ [2.40] AFC 2 STRAIGHT .169ˮ [4.30] .157ˮ [4.00] .094ˮ [2.40] AFE 2 STRAIGHT .169ˮ [4.30] .157ˮ [4.00] .110ˮ [2.80] EFC 4 STRAIGHT .250ˮ [6.35] .315ˮ [8.00] .094ˮ [2.40] P/N CODE ROWS TERMINATION TYPE A B TAIL FGG 1 RIGHT ANGLE .169ˮ [4.30] .110ˮ [2.80] .122ˮ [3.10] FJF 2 RIGHT ANGLE .283ˮ [7.20] .191ˮ [4.85] .118ˮ [3.00] P/N CODE ROWS TERMINATION TYPE A B TAIL TAIL B RIGHT ANGLE A B A SMT BFL 1 SMT .181ˮ [4.60] .094ˮ [2.40] .157ˮ [4.00] BHL 1 SMT .169ˮ [4.30] .094ˮ [2.40] .157ˮ [4.00] GFN 2 SMT .110ˮ [2.80] .165ˮ [4.20] .228ˮ [5.80] 2 SMT GHN Refer to Mounting Style FFK TAIL Replaced by GFN .173ˮ [4.40] .157ˮ [4.00] .228ˮ [5.80] MOUNTING STYLE PIN 1 PIN 1 PIN 1 Straight or Right Angle (N) 106 Single Row SMT, Pin 1 Left (C) PIN 1 Single Row SMT, Pin 1 Right (D) Guide Post Dual Row SMT, Without Guide Posts (S) Dual Row SMT, With Guide Posts (P) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Headers .079” [2.00 mm] Contact Centers, Female Headers, Straight/Right Angle/SMT PART NUMBER OPTIONS NP P N 40 1 BFC N - RC RoHS COMPLIANT Consult Factory For Modifications MATERIALS (INSULATOR/CONTACT) NP = Nylon /Phosphor Bronze CONTACT FINISH - RoHS Compliant Contact Surface Termination P = Gold Flash Gold Flash (For 1 and 2 Rows) R = .000020” Gold .000100” Tin (For 4 Rows) Consult factory for other plating options. CONTACT CENTERS N = .079” [2.00 mm] NUMBER OF POSITIONS Positions Termination Available 2 Thru 40 = AFC, AFE, BFL, FFK, FGG, FJF, GFN 3 Thru 40 = BFC, BHL 5 Thru 30 = EFC NUMBER OF ROWS (Opposite Page) 1 = One Row 2 = Two Rows 4 = Four Rows DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. .059[1.50] A B SINGLE READOUT, STRAIGHT TAIL SHOWN .057 [1.45] .020[0.50] X .008[0.20] (FITS .031[0.80] HOLE) A B DUAL READOUT, STRAIGHT TAIL SHOWN .079[2.00] B .072[1.82] .250[6.35] .094[2.40] .079[2.00] .020[0.50] SQ. (FITS .031[0.80] HOLE) A QUAD READOUT, STRAIGHT TAIL SHOWN (SOLDER AREA) TERMINATION TYPE (Opposite Page) AFC = Thru Hole Top Entry AFE = Thru Hole Top Entry/Closed Bottom BFC = Thru Hole Top Entry EFC = Thru Hole Top Entry FGG = R/A Top Entry FJF = R/A Top Entry BFL = SMT Top Entry FFK = SMT Top Entry BHL, GFN = SMT Top/Bottom Entry GHN = SMT Replaced by GFN NUMBER OF CONTACTS SINGLE/DUAL/ QUAD 02/04/NA 03/06/NA 04/08/NA 05/10/20 06/12/24 07/14/28 08/16/32 09/18/36 10/20/40 11/22/44 12/24/48 13/26/52 14/28/54 15/30/60 16/32/64 17/34/68 18/36/72 19/38/76 20/40/80 21/42/84 22/44/88 23/46/92 24/48/96 25/50/100 26/52/104 27/54/108 28/56/112 29/58/116 30/60/120 31/62/NA 32/64/NA 33/66/NA 34/68/NA 35/70/NA 36/72/NA 37/74/NA 38/76/NA 39/78/NA 40/80/NA CENTER TO CENTER LENGTH [A] OVERALL LENGTH [B]** in mm in mm 0.079 2.00 0.157 4.00 0.157 0.236 0.315 0.394 0.472 0.551 0.630 0.709 0.787 0.866 0.945 1.024 1.102 1.181 1.260 1.339 1.417 1.496 1.575 1.654 1.732 1.811 1.890 1.969 2.047 2.126 2.205 2.283 2.362 2.441 2.520 2.598 2.677 2.756 2.835 2.913 2.992 3.071 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 44.00 46.00 48.00 50.00 52.00 54.00 56.00 58.00 60.00 62.00 64.00 66.00 68.00 70.00 72.00 74.00 76.00 78.00 0.236 0.315 0.394 0.472 0.551 0.630 0.709 0.787 0.866 0.945 1.024 1.102 1.181 1.260 1.339 1.417 1.496 1.575 1.654 1.732 1.811 1.890 1.969 2.047 2.126 2.205 2.283 2.362 2.441 2.520 2.598 2.677 2.756 2.835 2.913 2.992 3.071 3.150 6.00 8.00 10.00 12.00 14.00 16.00 18.00 20.00 22.00 24.00 26.00 28.00 30.00 32.00 34.00 36.00 38.00 40.00 42.00 44.00 46.00 48.00 50.00 52.00 54.00 56.00 58.00 60.00 62.00 64.00 66.00 68.00 70.00 72.00 74.00 76.00 78.00 80.00 Headers .020 [0.50] X .008[0.20] (FITS .031[0.80] HOLE) .079[2.00] MOUNTING STYLE N = No Mounting C = SMT, Single row female, pin 1 Left D = SMT, Single row female, pin 1 Right P = Surface mount with guide Posts S = Surface mount without guide Posts ** Dimension 'B' as shown are for 'FFK', Consult factory for other termination. www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 107
NPPN112GFNS-RC
物料型号:文档中列出了多种型号的Female Headers,包括BFC、AFC、AFE、EFC、FGG、FJF、BFL、BHL、GFN、FFK等。
器件简介:这些是Sullins品牌的Female Headers,具有不同的行数、终止类型和安装方式。
引脚分配:文档提供了不同型号的Female Headers的引脚分配,包括单行(SINGLE)、双行(DUAL)和四行(QUAD)。
参数特性:这些Female Headers具有2安培的电流额定值,UL可燃性等级94V-0,绝缘材料为黑色尼龙,接触材料为磷青铜。
功能详解:文档中描述了不同的安装方式,如直插式(Straight)、直角式(Right Angle)和表面贴装式(SMT),以及是否带有定位柱(Guide Posts)。
应用信息:这些Female Headers适用于多种电子设备和电路板的连接需求。
封装信息:文档提供了详细的尺寸信息,包括接触中心距离、整体长度等,尺寸单位有英寸和毫米两种表示方式。
NPPN112GFNS-RC 价格&库存
很抱歉,暂时无法提供与“NPPN112GFNS-RC”相匹配的价格&库存,您可以联系我们找货
