8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
E
2515
F
3120
DATE
REMOVE CONTACT DEPTH TOLERANCE & ADD "REF.", ADD 01/16/2012
NOTE 10 MATING PARTS.
UPDATE PROCESSING TEMPERATURE FOR NYLON 6T
MATERIAL AND CURRENT RATING TO 2 AMPS (WAS 1
04/15/2015
AMP), ADD VIEW FOR POSITIONS 27 TO 40
F
E
DESCRIPTION
BY
LH
LH
F
E
B±.014 [ 0.35]
.079±.002 2.00±0.05
.157 4.00
D
D
.057 1.45 REF.
.169 4.30
.094±.008 2.40±0.20
.020±.002 0.50±0.05
.079±.002 2.00±0.05
C
C
.008±.002 0.20±0.05
.079±.004 2.00±0.10
A±.008 [ 0.20]
02-20, 0.20mm MAX.
21-40, 0.30mm MAX.
A±.004 [ .10]
.031 0.80
.079 2.00
B
A
B
NOTES:
1. INSULATOR MATERIAL: NYLON 6T, UL 94V-0, COLOR: BLACK.
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
3. CONTACT PLATING: .000030"-.000050" MIN NICKEL UNDERPLATE, GOLD FLASH OVERALL.
4. CURRENT RATING: 2 AMP.
5. VOLTAGE RATING: 150V AC/DC.
6. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
7. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
8. DIELECTRIC WITHSTANDING: 500V AC.
9. OPERATING TEMPERATURE: -40 C TO +105 C
10.PROCESSING TEMP.: WAVE/MANUAL SOLDERING ONLY.
11.MATES WITH SULLINS .079 [2.00] CONTACT CENTER MALE HEADER SERIES.
(.020 [0.50] SQUARE POSTS)
.079 2.00
RECOMMENDED PCB LAYOUT
Pb
RoHS COMPLIANT
8
7
6
5
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
TOLERANCES:
ANGULAR:
DECIMALS
.X= .012 [.30]
.XX= .008 [.20]
.XXX= .006 [.15]
DRAWN
DATE
NAME
01/10/2009 JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER, FEMALE 2mm CC, 2 ROWS, ST
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 8:1
3
2
NPPNxx2AFCN-RC
DWG. NO.
10497
SHEET 1 OF 1
1
REV
F
FILE NAME: 10497, NPPNxx2AFCN-RC
A
很抱歉,暂时无法提供与“NPPN182AFCN-RC”相匹配的价格&库存,您可以联系我们找货
