NPPN131FGGN-RC
NPPN131FGGN-RC
    SULLINS
    CONNHEADER.079"13POS
NPPN131FGGN-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS F REV. ECO. NO DESCRIPTION DATE BY A 611 INITIAL RELEASE 6/15/2005 TT B 733 UPDATE SIDE VIEW 9/19/2005 TT C 1936 UPDATE DWG VIEWS, P/N CODING & DIM 'B' 3/23/2009 JH F E E .110±.008 2.80±0.20 .063±.008 1.60±0.20 D D .079±.002 2.00±0.05 .020 0.50 A±.010[ 0.25] B±.012[ 0.30] .122±.012 3.10±0.30 .047 1.20 REF. C .169 4.30 C .181±.012 4.60±0.30 .008 0.20 02-20, 0.20mm MAX. 21-40, 0.30mm MAX. A±.004[ 0.10] .079±.002 2.00±0.05 B A NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: GOLD FLASH OVERALL. 4. CURRENT RATING: 1 AMP. 5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 6. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 7. DIELECTRIC WITHSTANDING: AC 500V. 8. OPERATING TEMPERATURE: -40° C TO +105° C. 9. *PROCESSING TEMP.: 260° C FOR 10 SECS MAX. RECOMMENDED PCB LAYOUT UNLESS OTHERWISE SPECIFIED: Pb *INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURE MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME. 8 7 B .031±.002 0.80±0.05 6 DIMENSIONS ARE IN INCHES[MM] TOLERANCES: ANGULAR: 5 .X= .012 [.30] .XX= .008 [.20] .XXX= .006 [.15] SURFACE FINISH: 63 Ra REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT 5 4 DRAWN NAME 3/23/2009 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. HEADER FEMALE, 2mm CC, 1 ROW, RA NPPNxx1FGGN-RC SIZE DWG. NO. C INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 DATE REV 10490 SCALE: 4:1 2 C SHEET 1 OF 1 1 FILE NAME: Z:\COMPONENTS\Taiwan\ECO PENDING TAIWAN\1936\10490, NPPNxx1FGGN-RC PRINT: 4/1/2009 A
NPPN131FGGN-RC 价格&库存
很抱歉,暂时无法提供与“NPPN131FGGN-RC”相匹配的价格&库存,您可以联系我们找货
