REVISION AE
NOTES:
DO NOT
SCALE FROM
THIS PRINT
CLP-1XX-XX-X-DH-XX
1. C REPRESENTS A CRITICAL DIMENSION.
2. ALL DIMENSION TO BE SYMMETRICAL ABOUT CENTERLINE
WITHIN ±.002[.05] UNLESS OTHERWISE STATED.
3. POSITONS -05 THRU -50 ARE TO BE PACKAGED IN TUBES.
4. MIN CONTACT RETENTION FORCE: 1LB.
5. TAILS TO ARE TO BE SHEARED. MAX BURR, ORIENTED AWAY
FROM CUSTOMER'S P.C.B. ONLY, TO BE .0045[.114].
6. MAX CUT FLASH: .015 IN NON-CRITICAL AREAS; NO CUT
FLASH TO BE PRESENT IN CRITICAL AREAS AS SHOWN
7. MOLD STEEL CAPABLE OF -02 & -03 POSITION (-A OPTION),
BUT NOT ENG'G APPROVED.
8. FIRST AND LAST PIN OF EACH ROW TO BE FLUSH TO .003[0.08] BELOW BODY.
9. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE PACKAGED
ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES)
FOUND ON WWW.SAMTEC.COM.
10. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL,
BASED ON OPTIONS SELECTED.
2 MAX SWAY
(EITHER DIRECTION)
OPTION
-TR: TAPE AND REEL PACKAGING
(SEE NOTE 9)
-A: ALIGNMENT PIN (USE CLP-XX-DH-A
BODIES MUST BE MODLED TO POSTION)
(AVAILABLE ON POSITIONS -04 THRU -50)
(SEE NOTE 7)
-FR: FULL REEL QTY. TAPE & REEL
(SEE NOTE 10)
LEAD STYLE
-02: SURFACE MOUNT
PLATING
3µ" FLASH SELECTIVE GOLD IN CONTACT
AREA, MATTE TIN ON TAIL
-L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT
-FM: 3µ" FLASH SELECTIVE GOLD IN CONTACT
-LM: 10µ" LIGHT SELECTIVE GOLD IN CONTACT
-F:
BODY SPECIFICATION
-DH: DOUBLE HORIZONTAL
NON-CRITICAL AREA
(SEE NOTE 6)
(NO OF POS -1) EQ SPACES @.0500[1.270] REF
CLP-XX-DH-X
"A"
.050 1.27
REF
No. OF POSITIONS PER ROW
-02 THRU -50
.120 3.05 REF
(NO OF POS x .05000[1.270]) + .017[0.43]±.008[0.20]
04
.030 0.76 REF
02
.135 3.43 REF
C 90°+1°
- 3°
C
.0420 1.07
C-70-05-X
SEE TABLE 1
'C'
.025 0.64
.050 1.27 REF
"A"
.030 0.76 REF
CRITICAL AREA
(SEE NOTE 6)
.180±.010 4.57±0.25
(SEE NOTE 5)
.060 1.52 REF
(NO OF POS -2) x .050[1.27] REF
C-70-04-X
SECTION "A"-"A"
'B'
BACK VIEW
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
.003 0.08 C
(SEE NOTE 8)
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01[0.3]
2
.XXX: .005[0.13]
.XXXX: .0020[0.051]
DETAIL 'B'
SCALE 8 : 1
MATERIAL:
C .003 0.08
(SEE NOTE 8)
DETAIL 'C'
SCALE 8 : 1
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 4:1
INSULATOR: LCP, UL 94 VO, COLOR: BLACK
CONTACT: PHOS BRONZE
F:\DWG\MISC\MKTG\CLP-1XX-XX-X-DH-XX-MKT.SLDDRW
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
LOW PROFILE .050 X .050 DOUBLE ROW ASM
DWG. NO.
CLP-1XX-XX-X-DH-XX
BY: PURVIS
11-29-1995
SHEET 1 OF 2
REVISION AE
.472 12.00
REF
POSITION 1
.945 24.00
REF
"B"
"B"
-DH NO OPTION
PT-1-24-02-37
(TUBE USES (2) TP-12)
USER DIRECTION OF UNREELING
-TR: TAPE & REEL VIEW
(SCALE 2:1)
WITH -A OPTION
PT-1-24-01-62
PACKAGING TUBE VIEW
(SCALE 6:1)
PROPRIETARY NOTE
SHEET SCALE: 4:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
CLP-1XX-XX-X-DH-XX
BY: PURVIS
11-29-1995
SHEET 2 OF 2
很抱歉,暂时无法提供与“CLP-104-02-L-DH-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 850+14.71804850+1.91064
- 1700+13.839431700+1.79659
- 国内价格 香港价格
- 1+26.947211+3.49819
- 10+22.9008710+2.97291
- 100+19.46377100+2.52672
- 国内价格
- 1+20.81160
- 10+20.26080
- 30+19.90440
