8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
L
2829
ADD INSULATOR MATERIAL 'LCP' OPTION
12/10/2014
LH
M
3963
UPDATE GENERAL TOL IN TITLE BOX & NOTE 8,
UPGRADE NYLON MTL (FROM 6T TO 9T)
1/3/2019
JH
F
F
E
E
A .004[ 0.10]
C .004[ 0.10]
.039±.002 1.00±0.05
.100±.002 2.54±0.05
B .012[ 0.30]
.061±.002 1.56±0.05
A .008 [ 0.20]
D
D
.100±.002 2.54±0.05
.290±.004 7.37±0.10
.100±.002 2.54±0.05
.100 2.54
C
.040 1.02
.024(w) X .010(t)
[0.60 X 0.25]
2 X .047 1.20 MIN
OPTIONAL
RECOMMENDED PCB LAYOUT
.197±.006 5.00±0.15
.020 0.50
C
.092 2.33
.280 7.10
C .008 [ 0.20]
B
2X
A
7
6
OPTIONAL
SEE PART NUMBER CODING
.270±.012 6.85±0.30
B
.037±.004 0.95±0.10
NOTES:
02-20, .008[0.20] MAX.
1. INSULATOR MATERIAL: SEE PART NUMBER CODING, UL 94V-0
21-30, .012[0.30] MAX.
2. CONTACT MATERIAL: PHOSPHOR BRONZE
31-40, .016[0.40] MAX.
3. CONTACT PLATING: SEE PART NUMBER CODING
4. CURRENT RATING: 3 AMPS
5. VOLTAGE RATING: 250V AC
6. INSULATOR RESISTANCE: 5000 MEGOHMS MIN
7. CONTACT RESISTANCE: 20 MILLIOHMS MAX
8. DIELECTRIC WITHSTANDING: 1000 VAC
9. OPERATING TEMPERATURE: SEE PART NUMBER CODING
10.PROCESSING TEMP.: SEE PART NUMBER CODING
11.MATES WITH SULLINS .100 [2.54] CONTACT CENTER MALE HEADER SERIES
(.025 [0.64] SQUARE POSTS)
8
.049 1.25
.295±.010 7.50±0.25
5
Pb
RoHS COMPLIANT
4
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
12/04/2008 JH
TOLERANCES:
ANGULAR:
5
DECIMALS
.XX= .012 [.3]
.XXX= .008 [.20]
.XXXX= .0039 [.100]
THE INFORMATION HEREIN CONTAINS
PROPRIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
SIZE
C
54453
2
A
xPxCxx2KFMx-RC
CAGE CODE
SCALE: 6:1
3
HEADER FEMALE, 2.54mm CC,
2 ROWS, SMT
DWG. NO.
10488
SHEET 1 OF 1
1
REV
M
FILE NAME: 10488, xPxCxx2KFMx-RC
很抱歉,暂时无法提供与“NPTC142KFMS-RC”相匹配的价格&库存,您可以联系我们找货
