SSW-106-02-F-D-RA
SSW-106-02-F-D-RA
    SAMTEC(申泰)
    弯插,P=2.54mm
    间距:2.54MM 弯插
SSW-106-02-F-D-RA 数据手册
SSW-1XX-XX-XXX-X-XX-XXX-XX REVISION CI No OF POSITIONS -01 THRU -50 (-P OPTION: 36 POS MAX) DO NOT SCALE FROM THIS PRINT LEAD STYLE (SEE TABLE 1) -01 THRU -06 (STD. INS. FORCE) -21 THRU -24 (LOW INS. FORCE) OPTION -LL: LOCKING LEAD (SEE FIG 4, SHT 2) (N/A IN SINGLE ROW, 1 & 2 POSITION) POLARIZING OPTION INDICATE POS, SEE FIG 3, SHT 3 OPTION -RA: RIGHT ANGLE (SEE FIG 2, SHT 2) PLATING SPECIFICATION (STYLE -01 & -21 N/A) -N: NOTCH (SEE FIG 6, SHT 3) -G: 20µ" GOLD IN CONTACT AREA, (ONLY AVAILABLE IN -D ROW) 3µ" GOLD ON TAIL (ONLY AVAILABLE IN 5, 7, 8, 10, 12, -T: MATTE TIN CONTACT AND TAIL 13, 15, 17, 20, 25, 32, 36 POSITIONS) (CONTACT -21 THRU -24 N/A) (USE NSW-XX-D-N-XX BODY, -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, SEE TABLE 6) MATTE TIN ON TAIL -H: 30µ" HEAVY GOLD IN CONTACT AREA, ROW SPECIFICATION 3µ" GOLD ON TAIL -E: 50µ" EXTRA HEAVY GOLD IN CONTACT AREA, -S: SINGLE 3µ" GOLD ON TAIL -D: DOUBLE (CONTACT -01 & -02 STRAIGHT ONLY) -T: TRIPLE -F: 3µ" FLASH SELECTIVE GOLD IN CONTACT AREA, -P: SINGLE MATTE TIN ON TAIL -Q: TRIPLE WITH ONLY OUTER 2 ROWS -STL: 30µ" SELECTIVE GOLD IN CONTACT AREA, FILLED TIN/LEAD (90/10 ± 5%) TAIL .295 7.493 -TL: TIN/LEAD (90/10 ± 5%) CONTACT AND TAIL (AVAILABLE ONLY ON LEAD STYLES -01) REF -TM: MATTE TIN CONTACT AND TAIL (CONTACT -21 THRU -24 N/A) -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -FM: 3µ" FLASH GOLD SELECTIVE IN CONTACT AREA, MATTE TIN ON TAIL -L: 10µ" LIGHT SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL .200 5.08 .050 1.27 REF ((No OF POS x .100[2.54]) + .020[0.51] .010[0.25]) 60° .095 2.41 REF SEE NOTE 10 .0110 0.280 REF .245 6.22 'A' 2 MAX SWAY (EITHER DIRECTION) .295 7.493 REF .195 4.95 REF SEE NOTE 8 .335 8.51 DETAIL 'A' SCALE 4 : 1 NOTES: .095 2.41 REF "B" C .031 0.79 X .016[0.41] REF (TYP) 1. C REPRESENTS A CRITICAL DIMENSION. 2. MAXIMUM CUT FLASH: .015[0.38] WITH NO FLASH BELOW STANDOFFS OR IN CONTACT HOLES. 3. MINIMUM CONTACT PUSHOUT FORCE: 1.5 LBS 4. MAXIMUM ALLOWABLE BOW: .003[0.08] INCH/INCH 5. NOTE DELETED. 6. MAXIMUM ALLOWABLE VARIATION BETWEEN ROWS: .010[0.25] 7. "END WALLS" AFTER CUTTING SHOULD BE .020±.003 [0.51±0.08]. 8. NOTCH ON -P-RA & -D-RA-N OPTIONS TO BE ORIENTED AS SHOWN. 9. SHEAR LOCATION TO BE WITHIN .001[0.03] OF THE BREAK OFF CENTER LOCATION. 10. SHEAR LOCATION TO BE WITHIN .001[0.03] OF THE BREAK OFF CENTER LOCATION FOR MACHINE FILL. 11. LEAD STYLE X2 (SINGLE AND DOUBLE) -RA's TO BE LAYER PACKAGED. ALL OTHER -RA LEAD STYLES: UNDER 5 POSITION TO BE LAYER PACKAGED, 5 AND UP TO BE PACKAGED IN TUBES. 12. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM -Q -S -P .100 2.54 C "G" -D-N -D .200 5.08 FIG 1 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS .XX: .01 [0.3] .XXX: .005 [0.13] ANGLES 2 * PROPRIETARY NOTE F:\DWG\MISC\MKTG\SSW-1XX-XX-XXX-X-XX-XXX-XX-MKT.SLDDRW SHEET SCALE: 2:1 -T * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. MATERIAL: DO NOT SCALE DRAWING INSULATOR: -S, -D, -D-N: VECTRA E130i, COLOR: BLACK UL94 V0 -P, -T: PCT, COLOR: BLACK UL94 V0 CONTACT: PHOSPHOR BRONZE, SPRING TEMPER ALLOY 511 OR 510 (TENSILE STRENGTH 90-100 KSI) (YEILD STRENGTH @ 2% OFFSET 88-98 KSI) PER MIL-B-13501 THICKNESS: .0160±.001 [0.635±0.03] C .100 2.54 ±"G" 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: ASSEMBLY, SOCKET STRIP .016 X .031 TAIL DWG. NO. SSW-1XX-XX-XXX-X-XX-XXX-XX BY: PURVIS 06/12/1987 SHEET 1 OF 3 REVISION CI SEE NOTE 8 C SEE NOTE 8 C .06 1.524 90° -P-RA -S-RA "C" (SEE TABLE 2, SHEET 1) C "D" C .100 2.54 C .200 5.08 C .100 2.54 C "E" -D-RA-N "F" C -T-RA -D-RA FIG 2 RIGHT ANGLE OPTION ALL OPTIONS DIFFERENT AS SHOWN, OTHERWISE SAME AS -S-RA 01 CL CL 01 CL CL .04 1.0 -S 01 -D -D-N CRIMP LOCATIONS -T 01 CL CL 01 CL -D-LL -S-LL ODD POSITIONS = CRIMP LOCATION 01 IN-PROCESS -T-LL R.0560 1.422 (TYP) R.0320 0.813 (TYP) CL +0.13 .008+-.005 .000 0.20 0.00 C (TYP) .04 1.0 -S -D 01 -D-N CRIMP LOCATIONS -T 01 -S-RA-LL CRIMP DETAIL ALL CONFIGURATIONS -D-RA-LL EVEN POSITIONS = CRIMP LOCATION -T-RA-LL FIG 4 LOCKING LEAD OPTION ALL OPTIONS SAME AS -S-XX-LL UNLESS OTHERWISE SHOWN * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\SSW-1XX-XX-XXX-X-XX-XXX-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: ASSEMBLY, SOCKET STRIP .016 X .031 TAIL DWG. NO. SSW-1XX-XX-XXX-X-XX-XXX-XX BY: PURVIS 06/12/1987 SHEET 2 OF 3 REVISION CI SSW-1XX-04-XXX-S-RA SSW-1XX-24-XXX-S-RA SSW-1XX-03-XXX-S-RA SSW-1XX-23-XXX-S-RA SSW-1XX-03-XXX-D-RA SSW-1XX-23-XXX-D-RA SSW-1XX-03-XXX-D-RA-N SSW-1XX-23-XXX-D-RA-N SEE NOTE 8 01 50 SSW-1XX-XX-XXX-T-RA SSW-1XX-XX-XXX-Q-RA -S, -P, -S-RA & -P-RA 100 02 99 01 FIG 5 PACKAGING VIEWS (SEE NOTE 11) -D, -D-RA .050 1.27 REF 01 99 02 100 .190 4.83 REF .245 6.22 REF NSW-XX-D-N-XX (SEE TABLE 6) -D-N, -D-RA-N 150 03 FIG 6 NOTCH OPTION DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 * 148 01 -T, -Q, -T-RA & -Q-RA FIG 3 POLARIZATION LOCATION (INSERT PK-15-N INTO SPECIFIED POSITION & BREAK OFF TAB) (-RA OPTION SHOWN FOR ORIENTATION PURPOSE ONLY) F:\DWG\MISC\MKTG\SSW-1XX-XX-XXX-X-XX-XXX-XX-MKT.SLDDRW PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: ASSEMBLY, SOCKET STRIP .016 X .031 TAIL DWG. NO. SSW-1XX-XX-XXX-X-XX-XXX-XX BY: PURVIS 06/12/1987 SHEET 3 OF 3
SSW-106-02-F-D-RA
1. 物料型号:文档描述了多种型号的SSW-1XX系列插座条,包括不同的配置选项,如锁定引脚、直角引脚等。
2. 器件简介:文档提供了插座条的一般描述,但没有提供具体的器件功能或应用场景。
3. 引脚分配:文档详细列出了不同引脚样式的规格,包括引脚间距、引脚长度等。
4. 参数特性:包括了引脚材料、厚度、最大允许弯曲、剪切位置等参数。
5. 功能详解:文档中没有提供具体的功能详解,但提到了不同的配置选项,如不同的引脚样式、极化选项、缺口选项等。
6. 应用信息:文档没有明确提供应用信息,但根据组件的描述,可以推断它可能用于电子设备的信号传输或电源分配。
7. 封装信息:文档提供了封装的详细规格,包括引脚的镀层类型,如金、锡、选择性金等。
SSW-106-02-F-D-RA 价格&库存
很抱歉,暂时无法提供与“SSW-106-02-F-D-RA”相匹配的价格&库存,您可以联系我们找货
SSW-106-02-F-D-RA
  • 1+15.022971+1.94322
  • 50+13.9527750+1.80479
  • 100+11.84966100+1.53276
  • 500+10.53300500+1.36245
  • 1000+7.864411000+1.01726
  • 2000+7.466772000+0.96583
库存:1070
SSW-106-02-F-D-RA
    • 1+16.01640
    • 10+13.25160
    • 30+11.52360
    • 102+9.75240
    库存:106
