SFH31-NPPB-D27-SP-BK
    SULLINS
    CONNHEADER.050"54POS
SFH31-NPPB-D27-SP-BK 数据手册
Headers .050” [1.27 mm] Contact Centers, Shrouded (Box) Headers/Straight/Right Angle/SMT With or Without Post- SBH Series Mates with SFH31 series (See opposite page) SPECIFICATIONS • Polarizing Notch • Operating Temperature: -40°C to +105°C • Processing Temperature: 230°C Max. for 60 seconds, (260°C Max. for 10 seconds) • UL Flammability Rating: 94V-0 • Voltage Rating: 20 milli Ohms Max. • Current Rating: 1 Amp • Dielectric Withstanding: 500 VAC • Insulation Resistance: 1000 Megohms PART NUMBER OPTIONS SBH31 - N B P B - D 10 - ST - BK SERIES SBH31 = Box Header, .050” [1.27 mm] Contact Centers by .050” [1.27 mm] Row Spacing INSULATOR MATERIAL N = Nylon L = LCP CONTACT MATERIAL B = Brass CONTACT FINISH - RoHS Compliant P = Gold Flash Overall CONTACT CENTERS B = .050” [1.27 mm] COLOR BK = Black TERMINATION TYPE ST = Straight RA = Right Angle SM = Surface Mount SP = Surface Mount with Guide Posts NUMBER OF CONTACT POSITIONS (Pins per Row) 03 thru 50 NUMBER OF ROWS D = Dual Row DIMENSIONS For complete drawings, go to www.sullinscorp.com or e-mail techsupport@sullinscorp.com Headers Dimensions in [ ] are in millimeters, all others are in inches. .094[2.40] .050[1.27] .050[1.27] STRAIGHT (ST) Example P/N: SBH31-NBPB-D20-ST-BK .094[2.40] .132[3.35] .211[5.35] .220[5.60] .157[4.00] .213[5.40] .050[1.27] RIGHT ANGLE (RA) Example P/N: SBH31-NBPB-D20-RA-BK .050[1.27] Refer to Termination Type .016[0.40] SQ. .220[5.60] .217[5.50] SURFACE MOUNT (SM) Example P/N: SBH31-NBPB-D20-SM-BK Ø .047[1.20] Ø .031[0.80] Surface Mount with Posts (SP) Only .220[5.60] 2X .039[1.00] .217[5.50] SURFACE MOUNT with Posts (SP) Example P/N: SBH31-NBPB-D20-SP-BK 96 www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com
1. 物料型号:SBH31系列,包括不同配置的型号,如SBH31-NBPB-D20-ST-BK(直插式)和SBH31-NBPB-D20-RA-BK(直角式)等。
2. 器件简介:SBH31系列是带外壳的盒式连接器,具有0.050英寸[1.27毫米]的接触中心,有直插式、直角式、表面贴装等多种类型。
3. 引脚分配:文档中提到了不同型号的引脚数量,例如D20表示双排各20个引脚。
4. 参数特性: - 工作温度:-40°C至+105°C - 加工温度:最高230°C,持续60秒 - UL阻燃等级:94V-0 - 电压等级:最大20毫欧姆 - 电流等级:1安培 - 介质耐压:500 VAC - 绝缘电阻:1000兆欧姆
5. 功能详解:文档中提到了极性槽设计,以及符合RoHS标准的金闪整体接触表面处理。
6. 应用信息:适用于需要极性识别和电气连接的应用场合。
7. 封装信息:提供了不同封装类型的详细尺寸,例如直插式、直角式和表面贴装型,并附有尺寸图。
SFH31-NPPB-D27-SP-BK 价格&库存
很抱歉,暂时无法提供与“SFH31-NPPB-D27-SP-BK”相匹配的价格&库存,您可以联系我们找货
