SFM210-LPPE-D13-SM-BK 数据手册
8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
A
1910
B
2518
C
2620
D
3121
F
DESCRIPTION
DATE
INITIAL RELEASE
2/5/2009
ADD REF. TO CONTACT POINT DIST, ADD NOTE 12 01/19/2012
MATING PARTS
UPDATE GUIDE POST TOLERANCE, REMOVED
06/20/2012
CHAMFER ON TAIL
UPDATE 2 POSITION 'B' DIMENSION AND 'S'
12/31/2014
PLATING DESCRIPTION
BY
JH
LH
F
LH
LH
E
E
B
1.00 .039
D
D
1.00 .039
0.30 .012
A
2.50 .098
0.70 .028
2.10 .083
2.20 .087
0.70 .028
C
0.10 .004
0.40±0.10 .016±.004 , 2X
C
02-20, 0.20mm MAX.
21-50, 0.30mm MAX.
3.90 .154
OPTIONAL
A
1.00 .039
0.60 .024
C
0.60 .024
(NOT REQ'D FOR USE
AS TOP ENTRY)
B
A
1.00 .039
NOTES:
1. INSULATOR MATERIAL: L.C.P, UL 94V-0, BLACK COLOR
2. CONTACT MATERIAL: PHOSPHOR BRONZE
3. CONTACT PLATING: SEE PART NUMBER CODING
4. CURRENT RATING: 1 AMP
5. INSULATOR RESISTANCE: 1000 MEGA OHMS MIN
6. CONTACT RESISTANCE: 20 MILLI OHMS MAX
7. DIELECTRIC WITHSTANDING: AC 300V
8. OPERATING TEMPERATURE: -40°C TO +125°C
9. PROCESSING TEMP.: 260°C FOR 10 SECONDS MAX
(INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR.
HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS
APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED
INDICATED TEMPERATURE AND TIME.)
10. FOR TOP/BOTTOM ENTRY
11. CONSULT FACTORY FOR THE MATE IF BEING USED AS BOTTOM ENTRY
12. MATES WITH SULLINS 1.00[.039] CONTACT CENTER SMH MALE HEADER SERIES
(0.30[.012] SQUARE POSTS)
8
7
6
2X
1.70 .067
0.60±0.08 .024±.003
(OPTIONAL,
FOR GUIDE POSTS)
RoHS COMPLIANT
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN MM[INCHES]
DATE
NAME
02/08/2009
JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TOLERANCES:
ANGULAR:
DECIMALS
.X= .3 [.012]
.XX= .20 [.008]
.XXX= .100 [.0040]
TITLE
HEADER, FEMALE 1mm CC, 2 ROWS, SMT
PART NUMBER
SIZE
C
4
3
2
SFM210-LP_E-D_ _-S_-BK
CAGE CODE
54453
SCALE: 10:1
5
B
C
RECOMMENDED PCB LAYOUT
DRAWN
Pb
4.60 .181
DWG. NO.
11200
REV
D
SHEET 1 OF 1
1
FILE NAME: Z:\ECO PENDING\3121, S PLATING\DWG 11200-D, SFM210-LP_E-D_ _-S_-BK PRELIMINARY\11200, SFM210-LP_E-D_ _-S_-BK PRINT: 1/22/2015
A
SFM210-LPPE-D13-SM-BK 价格&库存
很抱歉,暂时无法提供与“SFM210-LPPE-D13-SM-BK”相匹配的价格&库存,您可以联系我们找货
