SFM210-LPPE-D13-SP-BK
    SULLINS
    CONNHEADER1MM26POS
SFM210-LPPE-D13-SP-BK 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO A 1910 B 2518 C 2620 D 3121 F DESCRIPTION DATE INITIAL RELEASE 2/5/2009 ADD REF. TO CONTACT POINT DIST, ADD NOTE 12 01/19/2012 MATING PARTS UPDATE GUIDE POST TOLERANCE, REMOVED 06/20/2012 CHAMFER ON TAIL UPDATE 2 POSITION 'B' DIMENSION AND 'S' 12/31/2014 PLATING DESCRIPTION BY JH LH F LH LH E E B 1.00 .039 D D 1.00 .039 0.30 .012 A 2.50 .098 0.70 .028 2.10 .083 2.20 .087 0.70 .028 C 0.10 .004 0.40±0.10 .016±.004 , 2X C 02-20, 0.20mm MAX. 21-50, 0.30mm MAX. 3.90 .154 OPTIONAL A 1.00 .039 0.60 .024 C 0.60 .024 (NOT REQ'D FOR USE AS TOP ENTRY) B A 1.00 .039 NOTES: 1. INSULATOR MATERIAL: L.C.P, UL 94V-0, BLACK COLOR 2. CONTACT MATERIAL: PHOSPHOR BRONZE 3. CONTACT PLATING: SEE PART NUMBER CODING 4. CURRENT RATING: 1 AMP 5. INSULATOR RESISTANCE: 1000 MEGA OHMS MIN 6. CONTACT RESISTANCE: 20 MILLI OHMS MAX 7. DIELECTRIC WITHSTANDING: AC 300V 8. OPERATING TEMPERATURE: -40°C TO +125°C 9. PROCESSING TEMP.: 260°C FOR 10 SECONDS MAX (INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME.) 10. FOR TOP/BOTTOM ENTRY 11. CONSULT FACTORY FOR THE MATE IF BEING USED AS BOTTOM ENTRY 12. MATES WITH SULLINS 1.00[.039] CONTACT CENTER SMH MALE HEADER SERIES (0.30[.012] SQUARE POSTS) 8 7 6 2X 1.70 .067 0.60±0.08 .024±.003 (OPTIONAL, FOR GUIDE POSTS) RoHS COMPLIANT UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MM[INCHES] DATE NAME 02/08/2009 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TOLERANCES: ANGULAR: DECIMALS .X= .3 [.012] .XX= .20 [.008] .XXX= .100 [.0040] TITLE HEADER, FEMALE 1mm CC, 2 ROWS, SMT PART NUMBER SIZE C 4 3 2 SFM210-LP_E-D_ _-S_-BK CAGE CODE 54453 SCALE: 10:1 5 B C RECOMMENDED PCB LAYOUT DRAWN Pb 4.60 .181 DWG. NO. 11200 REV D SHEET 1 OF 1 1 FILE NAME: Z:\ECO PENDING\3121, S PLATING\DWG 11200-D, SFM210-LP_E-D_ _-S_-BK PRELIMINARY\11200, SFM210-LP_E-D_ _-S_-BK PRINT: 1/22/2015 A
SFM210-LPPE-D13-SP-BK 价格&库存
很抱歉,暂时无法提供与“SFM210-LPPE-D13-SP-BK”相匹配的价格&库存,您可以联系我们找货
