LPPB341NFSC-RC
LPPB341NFSC-RC
    SULLINS
    34 位 接头 连接器 0.050"(1.27mm) 表面贴装 金
LPPB341NFSC-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO G 2517 H 2673 DESCRIPTION DATE ADD NOTE 10 MATING PARTS 02/08/2012 UPDATE OPERATING TEMP, TAIL LENGTH TOLERANCE, PCB LAYOUT FOR TOP/BOTTEM ENTRY 09/14/2012 BY LH LH F F B PIN 1 LEFT E E .087 2.20 .050 1.27 .100 2.54 A LPPB_ _1NFSC-RC (STANDARD) .050 1.27 PIN 1 LEFT .028 0.70 B D D .016 0.40 .173 4.40 .028 0.70 (NOT REQ'D FOR TOP ENTRY) .087 2.20 PIN 1 RIGHT RECOMMENDED PCB LAYOUT LPPB_ _1NFSC-RC LPPB_ _1NFSD-RC (OPPOSITE BEND, APPLICABLE ON EVEN PIN COUNTS) .018 0.45 .081 2.05 C .067 1.70 .100 2.54 A .177 4.50 C .100 2.54 .183 4.65 .050 1.27 .004[0.10] A B A .006 0.15 02-20, 0.20mm MAX. 21-50, 0.30mm MAX. PIN 1 RIGHT NOTES: 1. INSULATOR MATERIAL: L.C.P. , UL 94V-0, COLOR: BLACK. *PROCESSING TEMPERATURE = 260° C FOR 10 SECS MAX. 2. CONTACT MATERIAL: PHOSPHOR BRONZE 3. PLATING: .000030" ~ .000050" NICKEL UNDERPLATED, GOLD FLASH OVERALL. 4. OPERATING TEMPERATURE: -40°C TO +125° C. 5. INSULATION RESISTANCE: 5000 MEGA OHMS MIN. 6. CONTACT RESISTANCE: 20 MILLI OHMS MAX. 7. DIELECTRIC WITHSTANDING: 500V AC. 8. CURRENT RATING: 1 AMP. 9. MATES WITH SULLINS .050 [1.27] CONTACT CENTER MALE HEADER SERIES. (.016 [0.40] SQUARE POSTS) Pb 7 6 RoHS COMPLIANT 5 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] TOLERANCES: ANGULAR: 1 DECIMALS .XX= .012 [.3] .XXX= .008 [.20] .XXXX= .0040 [.100] DRAWN B RECOMMENDED PCB LAYOUT LPPB_ _1NFSD-RC DATE NAME 01/20/2009 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE HEADER FEMALE .050" [1.27mm] PITCH, 1 ROW, SMT TOP/BOTTOM ENTRY PART NUMBER SIZE C CAGE CODE 54453 SCALE: 8:1 3 .067 1.70 .028 0.70 .028 0.70 (NOT REQ'D FOR TOP ENTRY) *INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME. 8 .173 4.40 .122±.006 3.10±0.15 2 LPPB_ _1NFS_-RC DWG. NO. 10965 SHEET 1 OF 1 1 REV H FILE NAME: 10965, LPPB_ _1NFS_-RC A
LPPB341NFSC-RC
物料型号:LPPB 1NFS-RC
器件简介:文档中没有提供具体的器件简介信息。
引脚分配:文档提供了两种类型的引脚分配,分别是LPPB 1NFSC-RC(标准)和LPPB 1NFSD-RC(相反弯曲,适用于偶数引脚数量)。引脚分配包括从2到50的引脚数量,每个引脚之间的距离有详细的英寸和毫米规格。
参数特性: - 绝缘材料:液晶聚合物,UL 94V-0,颜色:黑色。 - 处理温度:最高260°C,持续时间不超过10秒。 - 接触材料:磷青铜,镀镍0.0003"至0.0005",表面闪金。 - 工作温度:-40°C至+125°C。 - 绝缘电阻:最小5000兆欧。 - 接触电阻:最大20毫欧。 - 耐电压:500V交流电。 - 电流额定值:1安培。
功能详解:文档中没有提供具体的功能详解信息。
应用信息:该连接器与Sullins Electronics的.050"[1.27mm]接触中心公头系列兼容。
封装信息:文档提供了推荐的PCB布局信息,包括引脚1的位置和尺寸公差。
LPPB341NFSC-RC 价格&库存
很抱歉,暂时无法提供与“LPPB341NFSC-RC”相匹配的价格&库存,您可以联系我们找货
