W78C032C40PL
W78C032C40PL
    NUVOTON(新唐)
    LCC44
    W78C032C40PL
W78C032C40PL 数据手册
W78C32C/W78C032C DATA SHEET 8-BIT MICROCONTROLLER Table of Contents1. GENERAL DESCRIPTION.......................................................................................................... 2 2. FEATURES ................................................................................................................................. 2 3. PIN CONFIGURATIONS ............................................................................................................. 3 4. PIN DESCRIPTION ..................................................................................................................... 4 5. FUNCTIONAL DESCRIPTION .................................................................................................... 6 5.1 TIMERS 0, 1, AND 2 ....................................................................................................... 6 5.2 CLOCK ............................................................................................................................ 6 5.2.1 5.2.2 5.3 POWER MANAGEMENT ............................................................................................... 6 5.3.1 5.3.2 5.3.3 6. 8. 9. 10. IDLE MODE ...................................................................................................................... 6 POWER-DOWN MODE ................................................................................................... 7 RESET ............................................................................................................................. 7 ELECTRICAL CHARACTERISTICS ........................................................................................... 8 6.1 ABSOLUTE MAXIMUM RATINGS ................................................................................. 8 6.2 D.C. CHARACTERISTICS .............................................................................................. 8 6.3 A.C. CHARACTERISTICS .............................................................................................. 9 6.3.1 6.3.2 6.3.3 6.3.4 6.3.5 7. CRYSTAL OSCILLATOR ................................................................................................. 6 EXTERNAL CLOCK ......................................................................................................... 6 CLOCK INPUT WAVEFORM ........................................................................................... 9 PROGRAM FETCH CYCLE ........................................................................................... 10 DATA READ CYCLE ...................................................................................................... 10 DATA WRITE CYCLE .................................................................................................... 11 PORT ACCESS CYCLE ................................................................................................. 11 TIMING waveformS ................................................................................................................... 12 7.1 PROGRAM FETCH CYCLE ......................................................................................... 12 7.2 DATA READ CYCLE..................................................................................................... 12 7.3 DATA WRITE CYCLE ................................................................................................... 13 7.4 PORT ACCESS CYCLE ............................................................................................... 13 TYPICAL APPLICATION CIRCUIT ........................................................................................... 14 8.1 USING EXTERNAL PROGRAM MEMORY AND CRYSTAL........................................ 14 8.2 EXPANDED EXTERNAL DATA MEMORY AND OSCILLATOR .................................. 15 PACKAGE DIMENSIONS ......................................................................................................... 16 9.1 40-PIN DIP .................................................................................................................... 16 9.2 44-PIN PLCC ................................................................................................................ 16 9.3 44-PIN QFP .................................................................................................................. 17 REVISION HISTORY ................................................................................................................ 18 -1- Publication Release Date: December 4, 2006 Revision A6 W78C32C/W78C032C 1. GENERAL DESCRIPTION The W78C032C microcontroller supplies a wider frequency range than most 8-bit microcontrollers on the market. It is compatible with the industry standard 80C32 microcontroller series. The W78C032C contains four 8-bit bidirectional parallel ports, three 16-bit timer/counters, and a serial port. These peripherals are supported by a six-source, two-level interrupt capability. There are 256 bytes of RAM, and the device supports ROMless operation for application programs. The W78C032C microcontroller has two power reduction modes, idle mode and power-down mode, both of which are software selectable. The idle mode turns off the processor clock but allows for continued peripheral operation. The power-down mode stops the crystal oscillator for minimum power consumption. The external clock can be stopped at any time and in any state without affecting the 1.processor. 2. FEATURES                8-bit CMOS microcontroller Fully static design Low standby current at full supply voltage DC-40 MHz operation 256 bytes of on-chip scratchpad RAM ROMless operation 64K bytes program memory address space 64K bytes data memory address space Four 8-bit bidirectional ports Three 16-bit timer/counters One full duplex serial port Boolean processor Six-source, two-level interrupt capability Built-in power management Packages: − Lead Free (RoHS) DIP 40: W78C032C40DL − Lead Free (RoHS) PLCC 44: W78C032C40PL − Lead Free (RoHS) PQFP 44: W78C032C40FL -2- W78C32C/W78C032C 3. PIN CONFIGURATIONS 40-Pin DIP T2, P1.0 T2EX, P1.1 P1.2 P1.3 P1.4 P1.5 P1.6 P1.7 RST RXD, P3.0 TXD, P3.1 INT0, P3.2 INT1, P3.3 T0, P3.4 T1, P3.5 WR, P3.6 RD, P3.7 XTAL2 XTAL1 Vss 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 22 21 44-Pin PLCC INT0, P3.2 INT1, P3.3 T0, P3.4 T1, P3.5 A T D 2 0 , , P P 1 V 0 . N C . 0 C C 0 A D 1 , P 0 . 1 A D 2 , P 0 . 2 P 3 . 7 , / R D EA ALE PSEN P2.7, A15 P2.6, A14 P2.5, A13 P2.4, A12 P2.3, A11 P2.2, A10 P2.1, A9 P2.0, A8 X T A L 2 X V N P T S C 2 A S . L 0 1 , A 8 P 2 . 1 , A 9 P 2 . 2 , A 1 0 P 2 . 3 , A 1 1 T 2 E X , P P P P 1 1 1 1 . . . . 4 3 2 1 A D 3 , P 0 . 3 6 5 4 3 2 1 44 43 42 41 40 7 39 8 38 9 37 10 36 11 35 12 34 13 33 14 32 15 31 16 30 29 17 18 19 20 21 22 23 24 25 26 27 28 P 3 . 6 , / W R P0.0, AD0 P0.1, AD1 P0.2, AD2 P0.3, AD3 P0.4, AD4 P0.5, AD5 P0.6, AD6 P0.7, AD7 44-Pin QFP T 2 E X , P P P P 1 1 1 1 . . . . 4 3 2 1 P1.5 P1.6 P1.7 RST RXD, P3.0 NC TXD, P3.1 Vcc P1.5 P1.6 P1.7 RST P0.4, AD4 P0.5, AD5 P0.6, AD6 P0.7, AD7 EA NC ALE PSEN P2.7, A15 P2.6, A14 P2.5, A13 RXD, P3 0 NC TXD, INT0, P3 2 INT1, P3T0, 3 P3.4 T1, P3.5 P 2 . 4 , A 1 2 A D 0 , P 0 . 0 A D 1 , P 0 . 1 A D 2 , P 0 . 2 A D 3 , P 0 . 3 44 43 42 41 40 39 38 37 36 35 34 33 32 31 3 30 4 29 5 28 6 27 7 8 26 9 25 10 24 11 23 12 13 14 15 16 17 18 19 20 21 22 1 2 P 3 . 6 , / W R -3- T 2 , P 1 V . N C 0 C C P 3 . 7 , / R D X T A L 2 X V N P T S C 2 A S . L 0 1 , A 8 P 2 . 1 , A 9 P 2 . 2 , A 1 0 P 2 . 3 , A 1 1 P0.4, AD4 P0.5, AD5 P0.6, AD6 P0.7, AD7 EA NC ALE PSEN P2.7, A15 P2.6, A14 P2.5, A13 P 2 . 4 , A 1 2 Publication Release Date: December 4, 2006 Revision A6 W78C32C/W78C032C 4. PIN DESCRIPTION P0.0−P0.7 Port 0, Bits 0 through 7. Port 0 is a bidirectional I/O port. This port also provides a multiplexed low order address/data bus during accesses to external memory. P1.0−P1.7 Port 1, Bits 0 through 7. Port 1 is a bidirectional I/O port with internal pull-ups. Pins P1.0 and P1.1 also serve as T2 (Timer 2 external input) and T2EX (Timer 2 capture/reload trigger), respectively. P2.0−P2.7 Port 2, Bits 0 through 7. Port 2 is a bidirectional I/O port with internal pull-ups. This port also provides the upper address bits for accesses to external memory. P3.0−P3.7 Port 3, Bits 0 through 7. Port 3 is a bidirectional I/O port with internal pull-ups. All bits have alternate functions, which are described below: PIN ALTERNATE FUNCTION P3.0 RXD Serial Receive Data P3.1 TXD Serial Transmit Data P3.2 INT0 External Interrupt 0 P3.3 INT1 External Interrupt 1 P3.4 T0 Timer 0 Input P3.5 T1 Timer 1 Input P3.6 WR Data Write Strobe P3.7 RD Data Read Strobe EA External Address Input, active low. This pin forces the processor to execute out of external ROM. This pin should be kept low for all W78C032C operations. RST Reset Input, active high. This pin resets the processor. It must be kept high for at least two machine cycles in order to be recognized by the processor. ALE Address Latch Enable Output, active high. ALE is used to enable the address latch that separates the address from the data on Port 0. ALE runs at 1/6th of the oscillator frequency. A single ALE pulse is skipped during external data memory accesses. ALE goes to a high state during reset with a weak pull-up. -4- W78C32C/W78C032C PSEN Program Store Enable Output, active low. PSEN enables the external ROM onto the Port 0 address/data bus during fetch and MOVC operations. PSEN goes to a high state during reset with a weak pull-up. XTAL1 Crystal 1. This is the crystal oscillator input. This pin may be driven by an external clock. XTAL2 Crystal 2. This is the crystal oscillator output. It is the inversion of XTAL1. VSS, VCC Power Supplies. These are the chip ground and positive supplies. -5- Publication Release Date: December 4, 2006 Revision A6 W78C32C/W78C032C 5. FUNCTIONAL DESCRIPTION The W78C032C architecture consists of a core controller surrounded by various registers, four general purpose I/O ports, 256 bytes of RAM, three timer/counters, and a serial port. The processor supports 111 different instruction and references both a 64K program address space and a 64K data storage space. 5.1 Timers 0, 1, and 2 Timers 0, 1, and 2 each consist of two 8-bit data registers. These are called TL0 and TH0 for Timer 0, TL1 and TH1 for Timer 1, and TL2 and TH2 for Timer 2. The TCON and TMOD registers provide control functions for timers 0, 1. The T2CON register provides control functions for Timer 2. RCAP2H and RCAP2L are used as reload/capture registers for Timer 2. The operations of Timer 0 and Timer 1 are the same as in the W78C31. Timer 2 is a special feature of the W78C032C: it is a 16-bit timer/counter that is configured and controlled by the T2CON register. Like Timers 0 and 1, Timer 2 can operate as either an external event counter or as an internal timer, depending on the setting of bit C/T2 in T2CON. Timer 2 has three operating modes: capture, autoreload, and baud rate generator. The clock speed at capture or auto-reload mode is the same as that of Timers 0 and 1. 5.2 Clock The W78C032C is designed to be used with either a crystal oscillator or an external clock. Internally, the clock is divided by two before it is used. This makes the W78C032C relatively insensitive to duty cycle variations in the clock. 5.2.1 Crystal Oscillator The W78C032C incorporates a built-in crystal oscillator. To make the oscillator work, a crystal must be connected across pins XTAL1 and XTAL2. In addition, a load capacitor must be connected from each pin to ground, and a resistor must also be connected from XTAL1 to XTAL2 to provide a DC bias when the crystal frequency is above 24 MHz. 5.2.2 External Clock An external clock should be connected to pin XTAL1. Pin XTAL2 should be left unconnected. The XTAL1 input is a CMOS-type input, as required by the crystal oscillator. As a result, the external clock signal should have an input one level of greater than 3.5 volts. 5.3 5.3.1 Power Management Idle Mode The idle mode is entered by setting the IDL bit in the PCON register. In the idle mode, the internal clock to the processor is stopped. The peripherals and the interrupt logic continue to be clocked. The processor will exit idle mode when either an interrupt or a reset occurs. -6- W78C32C/W78C032C 5.3.2 Power-down Mode When the PD bit of the PCON register is set, the processor enters the power-down mode. In this mode all of the clocks, including the oscillator are stopped. The only way to exit power-down mode is by a reset. 5.3.3 Reset The external RESET signal is sampled at S5P2. To take effect, it must be held high for at least two machine cycles while the oscillator is running. An internal trigger circuit in the reset line is used to deglitch the reset line when the W78C032C is used with an external RC network. The reset logic also has a special glitch removal circuit that ignores glitches on the reset line. During reset, the ports are initialized to FFH, the stack pointer to 07H, PCON (with the exception of bit 4) to 00H, and all of the other SFR registers except SBUF to 00H. SBUF is not reset. -7- Publication Release Date: December 4, 2006 Revision A6 W78C32C/W78C032C 6. ELECTRICAL CHARACTERISTICS 6.1 Absolute Maximum Ratings PARAMETER SYMBOL MIN. MAX. UNIT VCC−VSS -0.3 +7.0 V Input Voltage VIN VSS -0.3 VCC +0.3 V Operating Temperature TA 0 70 °C Storage Temperature TST -55 +150 °C DC Power Supply Note: Exposure to conditions beyond those listed under Absolute Maximum Ratings may adversely affect the life and reliability of the device. 6.2 D.C. Characteristics VCC−VSS = 5V ±10%, TA = 25° C, FOSC = 20 MHz unless otherwise specified. PARAMETER SYM. TEST CONDITIONS Operating Voltage VDD - Operating Current IDD IIDLE Idle Current Power Down Current IPWDN SPECIFICATION UNIT MIN. TYP. MAX. 4.5 5 5.5 V No load VDD = 5.5V - - 30 mA Idle mode VDD = 5.5V - - 6 mA Power-down mode VDD = 5.5V - - 50 µA -75 - +10 µA - +184 +350 µA Input Current P1, P3 IIN1 VDD = 5.5V VIN = 0V or VDD Input Current (*2) RST IIN2 VDD = 5.5V VIN = VDD Input Leakage Current (*1) P0 ILK VDD = 5.5V 0V
W78C032C40PL 价格&库存
很抱歉,暂时无法提供与“W78C032C40PL”相匹配的价格&库存,您可以联系我们找货
