2020-YWY
2020-YWY
    CURTISINDUSTRIES
    20 电路 0.438"(11.12mm) 阻隔块 连接器, 螺钉
2020-YWY 数据手册
Series 2000 .4375" (11.11mm) Center-to-Center Spacing Features: .652 (15,87) .062 (1,57) .234 (5,94) .062 (1,57) YWY wire-wrap terminal INTERNAL TERMINAL DESIGNATIONS 2000-Y W .652 .652 (15,87) wire clamp (15,87) .652 (15,87) .062 (1,57) BARRIER STYLE .062 .062 (1,57) (1,57) YSY solder terminal .652 .652 (15,87) (15,87) .062 (1,57) .062 (1,57) .062 (1,57) * Other materials available – contact factory or your local representative for additional information. .652 .234 (15,87) (5,94) 3/4 ST single solder lug .062 (1,57) .234 (5,94) 062 1,57) 30 www.curtisind.com .062 (1,57) Recognized .062 under the Components Program of .234 Underwriters (1,57) Laboratories, Inc. Standard 1059, (5,94) Guide No. XCFR2, File No. E62557. Guide No. 22.2 No. 158, Report No. LR39186-1. COMPLIES WITH IEC 947-7-1 Series 2000 Dimensions Y printer circuit terminal .062 (1,57) printed circuit board design with .062" x .031" solderable tin-plated pin .652 2000-YSY solder pin .062 (15,87) .062 .234 2000-YWY .234 wire wrap (1,57) (1,57) (5,94) (5,94) .062 EXTERNAL TERMINAL DESIGNATIONS (1,57) 2000 screw teminal with No. 6-32 plated steel* screw accepting up to No. 10AWG wire 2000-ST solderable tin-plated double solder tab 2000-3/4ST solderable tin-plated single solder tab 2000-W wire clamp captivated to a No. 6-32 plated steel screw .180 (4,57) ST double solder lug 1.125 (28,57) .875 (22,22) Dual Row Series 2000 Variations O.D. M.D. .437 Typ. (11,11) .185 Dia. Holes (4) (4,69) .422 (10,71) 1.60 (40,64) 062 ,57) • Flexible Hi-Temp Thermoplastic Terminal Blocks – Self-extinguishing types which resist breakage and other damage (conform to UL94V-0). • Terminal Flexibility – Ideal for surface mount, sub-panel or chassis connections in electronic/electrical circuit applications. One thru 26 terminals. • Economical Closed-Back Design – No need for costly insulation strip. • Broad Wire Range – No. 6-32 external twin screws, UL recognized for No. 22AWG to No. 10AWG. Variations include double solder lug, single solder lug, wire wrap, solder pin and printed circuit pin. • UL/CSA Electrical Ratings – UL 30A/1100V RMS (1/3 breakdown voltage), CSA rating: 20A/300. • Recognition and Listing – Various terminal types are UL recognized and CSA certified. .031 (.787) .312 (7,93) 6-32 Terminal .120 Dia. Mtfg. Holes (4) Screw (3,05) .500 .375 Max. Lug Access (12,7) (9,52) Curtis Industries A Division of Powers Holdings, Inc. Specifications subject to change. Dimensions are shown for reference purposes only. Specifications: 2-11 Terminals .079 Dia. (No. 47 Drill) 12 Terminals and Over .093 Dia. (No. 42 Drill) .437 Typ. (11,11) 2000 Series terminal blocks are ordered by listing a composite number made up of the model designation in which the last two digits indicate the number of poles required for the application. Example: A 2000 10-terminal block becomes stock number 2010. Suffixes are used as follows: ST denotes double solder lug 3/4ST denotes single solder lug Y denotes printed circuit pin YSY solder pin YWY wire wrap W wire clamp The 2010 described above, with double solder lug mounting on 7/16" centers thus converts to stock number 2010-ST. To specify quick-connect terminals, simply add the style number required. (See accessories.) May be purchased factoryassembled or as customer-installed accessory. Number of Terminals Mounting Dimensions Inches Metric (mm) Overall Dimensions Inches Metric (mm) 1 .875 22.22 1.235 2 1.312 33.33 1.672 42.48 3 1.750 44.45 2.110 53.59 4 2.187 55.56 2.547 64.70 5 2.625 66.67 2.985 75.81 6 3.062 77.78 3.422 86.93 7 3.500 88.90 3.860 98.04 8 3.937 100.01 4.297 109.15 9 4.375 111.12 4.735 120.26 10 4.812 122.23 5.172 131.38 11 5.250 133.35 5.610 142.49 12 5.687 144.46 6.047 153.60 13 6.125 155.57 6.485 164.71 14 6.562 166.68 6.922 175.83 15 7.000 177.80 7.360 186.94 16 7.437 188.91 7.797 198.05 17 7.875 200.02 8.235 209.16 18 8.312 211.13 8.672 220.28 19 8.750 222.25 9.110 231.39 20 9.187 233.36 9.547 242.50 9.625 244.47 9.985 253.61 21 31.36 22 10.062 255.58 10.422 264.73 23 10.500 266.70 10.860 275.84 24 10.938 277.83 11.299 286.77 25 11.376 288.95 11.736 298.09 26 11.814 300.08 12.174 309.22 BARRIER STYLE PC BOARD DRILLING DIMENSIONS How to Order Dual Row Center-to-Center Spacing: .4375" (11.11mm) Wire Range: Up to No. 10AWG (CSA requires use of lugs on wire larger than No. 16AWG.) No. of Terminals: 1 thru 26 Voltage Rating: CSA – 300V UL – 150V – General Industrial 250V – Commercial Appliance 300V – Limited Energy Industrial Tightening Torque: Wire Clamp and Wire Binding Screw 12 in.-lbs. Current Rating: UL: 30 amps CSA: 20 amps Housing: Material Polyphenylene Oxide Continuous Use Temp. (UL Index) 110°C (230°F) Flammability Rating 94V-0 Water Absorption (24 hrs. % wt. gain) .06% Chemical Resistance Resistant to inorganic bases and acids. For organic substances contact factory for specific resistance. Breakdown Voltage: Terminal - Terminal 4,400V Typ. Terminal - Ground 7,700V Typ. Note: Specifications contained herein are subject to change without notice Dimensions Shown are ± 0.030" Dimensions are in inches and millimeters unless otherwise specified. Values in parentheses are metric equivalents. Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 31 Series 1500/2000 Accessories .806 (20,47) QUICK-CONNECT TERMINALS 1500/2000 – Available with .187" x .202" quick-connect tabs for 1500 series; .250" x .032" for 2000 series. Nine styles . . . tin-plated brass tabs held in place by terminal screws. Up to six terminations per pole. To order, specify: 1500 Series:  Part No. TB11-19 2000 Series:  Part No. TB31-39 90° 90% TB13 Part(1500) No. TB13 TB33 (2000) Last digit of part number corresponds to previous style numbers. See Table A, Dim. 3 (2) .250 (6,35) 1.392 (35,36) See Table A, Dim 1 1.00 (25,4) .125 (3,18) .031 (,787) .399 45° TB14Part (1500) No. TB14 1.570 45% Dual Row TB34 (2000) .589 (14,96) .250 (6,35) .187 (4,75) See Table A, Dim. 2 .156 (0) Dia. Hole Part No. TB11 90° 90% 45% Part No. TB15 TB15 (1500) .422 .300±.003 .312 .156 2X ÿ .062 .125 .031 90% .184 .150 Part (1500) No. TB16 TB16 TB36 (2000) + .005 .367 - .003 1.197 .250 .031 .156 1.318 90° .625 .088 .088 TB35 (2000) .994 (25,25) 1.672 .312 1.224 1.049 (26,64) 45° TB11 (1500) BARRIER STYLE .960 .150 See Table A Dim. 4 TB31 (2000) .150 (3,81) TB37 (2000) 1.307 (33,2) TB12 (1500) 45° .243 (6,17) .826 (20,98) Part No. TB17 TB17 (1500) .955 (24,26) Part No. TB12 45° No. TB18 TB18Part (1500) 1.099 45% TB38 (2000) 1.481 45% .727 (18,47) .960 .268 90° .831 90% Part No. TB19 TB32 (2000) 32 www.curtisind.com TB19 (1500) Curtis Industries A Division of Powers Holdings, Inc. TB39 (2000) Specifications subject to change. Dimensions are shown for reference purposes only. MARKING STRIPS 1500/2000 Pre-punched black fiber . . . mounts under block. May be imprinted to customer specifications. To order, specify: 1500 Series – Part No. 247A10-1 thru 22 2000 Series – Part No. 247A11-1 thru 22 1500/2000 – Wire clamp captivated to No. 6-32 screw eliminates need for lugs. 1500 Series – Part No. 058525700 2000 Series – Part No. 058526700 Part No. 68240100 Dual Row Wire Clamp Part No. 68245100 Terminal Block Jumpers COVERS 1500/2000 – Rigid .030" thick self-extinguishing vinyl. Complete with spring clips for attaching to mounting positions. To order, specify: 1500 Series – Part No. 247B24-1 thru 26 terminals 2000 Series – Part No. 247B25-1 thru 26 terminals Dimensions are in inches and millimeters unless otherwise specified. Values in parentheses are metric equivalents. 2000 – Plated brass in two styles. Types 267A28 is designed to jump two adjacent terminals as it is channeled to cross over the barrier top. “Rooster comb” design of Type 267A42 permits connections of two to 18 poles. To order, specify: Part No. 267A42 (plus no. of poles) Example: 267A42-18 Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 BARRIER STYLE 1500 – Jumper is constructed of plated brass. “Rooster comb” design permits connections of two to 10 poles. To order, specify: Part No. 278-A11 (plus no. of poles) Example: 278A11-10 Part No. 68240100 (Holes) or 68245100 (slots) (2-pole jumper for 1500 only) 33
2020-YWY
物料型号:文档中提到的是Curtis Industries生产的Series 2000系列端子,中心间距为0.4375英寸(11.11mm)。
器件简介:Series 2000系列端子具有灵活的高温热塑性端子,这些端子是自熄型的,能够抵抗断裂和其他损坏(符合UL94V-0标准)。它们适用于电子/电气电路应用中的表面安装、子面板或底盘连接。
引脚分配:端子可以配置1至26个端子,具有广泛的导线范围,从22AWG到10AWG。
参数特性:端子具有UL/CSA电气等级,UL 30A/1100V RMS(1/3击穿电压),CSA等级为20A/300V。多种端子类型具有UL认可和CSA认证。
功能详解:文档中详细描述了内部端子和外部端子的不同设计,例如2000-Y是用于印刷电路板设计的,具有0.062" x 0.031"可焊锡的镀锡引脚;2000-ST是可焊锡的镀锡双焊片;2000-W是固定在No.6-32镀钢结构上的线夹。
应用信息:Series 2000端子适用于需要灵活端子配置和广泛导线范围的电子和电气应用。
封装信息:文档提供了详细的尺寸信息,包括外径、中径、制造孔等,以及符合IEC 947-7-1标准的Series 2000尺寸。
2020-YWY 价格&库存
很抱歉,暂时无法提供与“2020-YWY”相匹配的价格&库存,您可以联系我们找货
