N78E055APG
N78E055APG
    NUVOTON(新唐)
    LCC44
    N78E055APG
N78E055APG 数据手册
Nuvoton 8-bit 8051-based Microcontroller N78E059A/N78E055A Data Sheet N78E059A/N78E055A Data Sheet CONTENTS 1. DESCRIPTION .................................................................................................................................................. 4 2. FEATURES ....................................................................................................................................................... 5 3. BLOCK DIAGRAM ............................................................................................................................................ 7 4. PIN CONFIGURATIONS ................................................................................................................................... 8 5. MEMORY ORGANIZATION ............................................................................................................................ 14 5.1 Internal Program Memory ................................................................................................................. 14 5.2 External Program Memory ................................................................................................................ 16 5.3 Internal Data Memory ....................................................................................................................... 17 5.4 On-chip XRAM .................................................................................................................................. 19 5.5 External Data Memory ...................................................................................................................... 19 5.6 On-chip Non-volatile Data Flash ....................................................................................................... 20 6. SPECIAL FUNCTION REGISTER (SFR) ....................................................................................................... 22 7. GENERAL 80C51 SYSTEM CONTROL ......................................................................................................... 25 8. AUXILIARY RAM (XRAM) ............................................................................................................................... 29 9. I/O PORT STRUCTURE AND OPERATION .................................................................................................. 31 10. TIMERS/COUNTERS.................................................................................................................................... 35 10.1 Timer/Counters 0 and 1 .................................................................................................................. 35 10.1.1 Mode 0 (13-bit Timer) ...................................................................................................... 37 10.1.2 Mode 1 (16-bit Timer) ...................................................................................................... 38 10.1.3 Mode 2 (8-bit Auto-reload Timer) .................................................................................... 38 10.1.4 Mode 3 (Two Separate 8-bit Timers) ............................................................................... 39 10.2 Timer/Counter 2 .............................................................................................................................. 40 10.2.1 Capture Mode .................................................................................................................. 43 10.2.2 Auto-reload Mode ............................................................................................................ 43 10.2.3 Baud Rate Generator Mode ............................................................................................ 44 10.2.4 Clock-out Mode................................................................................................................ 45 11. WATCHDOG TIMER ..................................................................................................................................... 46 11.1 Function Description of Watchdog Timer ........................................................................................ 46 11.2 Applications of Watchdog Timer ..................................................................................................... 48 12. POWER DOWN WAKING-UP TIMER .......................................................................................................... 49 12.1 Function Description of Power Down Waking-up Timer ................................................................. 49 12.2 Applications of Power Down Waking-up Timer............................................................................... 50 13. SERIAL PORT ............................................................................................................................................... 52 13.1 Mode 0 ............................................................................................................................................ 54 13.2 Mode 1 ............................................................................................................................................ 56 13.3 Mode 2 ............................................................................................................................................ 58 13.4 Mode 3 ............................................................................................................................................ 60 13.5 Baud Rate ....................................................................................................................................... 62 13.6 Multiprocessor Communication....................................................................................................... 63 14. SERIAL PERIPHERAL INTERFACE (SPI) ................................................................................................... 65 14.1 Features .......................................................................................................................................... 65 14.2 Function Description ....................................................................................................................... 65 14.3 Control Registers of SPI ................................................................................................................. 68 14.4 Operating Modes ............................................................................................................................ 70 14.4.1 Master mode .................................................................................................................... 70 14.4.2 Slave Mode ...................................................................................................................... 70 14.5 Clock Formats and Data Transfer ................................................................................................... 71 -2- Publication Release Date: March 11, 2010 Revision: V2.0 14.6 Slave Select Pin Configuration ....................................................................................................... 73 14.7 Mode Fault Detection ...................................................................................................................... 74 14.8 Write Collision Error ........................................................................................................................ 74 14.9 Overrun Error .................................................................................................................................. 74 14.10 SPI Interrupts ................................................................................................................................ 75 15. PULSE WIDTH MODULATOR (PWM) ......................................................................................................... 76 16. TIMED ACCESS PROTECTION (TA)........................................................................................................... 80 17. INTERRUPT SYSTEM .................................................................................................................................. 82 17.1 Priority Level Structure .................................................................................................................... 88 17.2 Interrupt Latency ............................................................................................................................. 90 18. IN SYSTEM PROGRAMMING (ISP) ............................................................................................................. 91 18.1 ISP Procedure ................................................................................................................................. 91 18.2 ISP Commands ............................................................................................................................... 94 18.3 User Guide of ISP ........................................................................................................................... 94 18.4 ISP Demo Code .............................................................................................................................. 95 19. POWER SAVING MODES ............................................................................................................................ 99 19.1 Idle Mode ........................................................................................................................................ 99 19.2 Power Down Mode ........................................................................................................................ 100 20. CLOCK SYSTEM ........................................................................................................................................ 102 20.1 12T/6T mode ................................................................................................................................. 102 20.2 External Clock Source .................................................................................................................. 104 20.3 On-chip RC Oscillator ................................................................................................................... 104 21. POWER MONITORING .............................................................................................................................. 105 21.1 Power-on Detection ...................................................................................................................... 105 21.2 Brown-out Detection ..................................................................................................................... 105 22. RESET CONDITIONS ................................................................................................................................. 109 22.1 Power-on Reset ............................................................................................................................ 110 22.2 Brown-out Reset ........................................................................................................................... 110 22.3 RST Pin Reset .............................................................................................................................. 110 22.4 Watchdog Timer Reset ................................................................................................................. 111 22.5 Software Reset.............................................................................................................................. 111 22.6 Boot Select .................................................................................................................................... 112 22.7 Reset State ................................................................................................................................... 113 23. AUXILIARY FEATURES ............................................................................................................................. 115 24. CONFIG BYTES .......................................................................................................................................... 116 25. INSTRUCTION SET .................................................................................................................................... 119 26. ELECTRICAL CHARACTERISTICS ........................................................................................................... 123 26.1 Absolute Maximum Ratings .......................................................................................................... 123 26.2 DC Electrical Characteristics ........................................................................................................ 123 26.3 AC Electrical Characteristics ......................................................................................................... 129 27. PACKAGES ................................................................................................................................................. 133 28. DOCUMENT REVISION HISTORY ............................................................................................................ 137 -3- Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet 1. DESCRIPTION N78E059A/N78E055A is an 8-bit microcontroller, which has an in-system programmable Flash supported. The instruction set of N78E059A/N78E055A is fully compatible with the standard 8051. N78E059A/N78E055A contains 32k/16k bytes of main Flash APROM, in which the contents of the main program code can be updated by parallel Programmer/Writer or In System Programming (ISP) method which enables on-chip firmware updating. There is an additional 2.5k bytes called LDROM for ISP function. N78E059A/N78E055A has 4k bytes of Data Flash which is accessed with ISP. N78E059A/N78E055A provides 256 bytes of SRAM, 1k bytes of auxiliary RAM (XRAM), four 8-bit bi-directional and bit-addressable I/O ports, an additional 8-bit bi-directional and bitaddressable port P4 for LQPF-48 package (PLCC-44 and PQFP-44 just have low nibble 4 bits of P4 and DIP40 does not have this additional P4), three 16-bit Timers/Counters, one UART, five PWM output channels, and one SPI. These peripherals equip with 11-source with 4-level priority interrupts capability. To facilitate programming and verification, the Flash inside the N78E059A/N78E055A allows the Program Memory to be programmed and read electronically. Once the code confirms, the user can lock the code for security. N78E059A/N78E055A is built in a precise on-chip RC oscillator of 22.1184MHz/11.0592MHz selected by CONFIG setting, factory trimmed to ±1% at room temperature. N78E059A/N78E055A provides additional power monitoring detection such as power-on and Brown-out detection. It stabilizes the power-on/off sequence for a high reliability system design. N78E059A/N78E055A microcontroller operation consumes a very low power. Two economic power modes to reduce power consumption, Idle mode and Power Down mode. Both of them are software selectable. The Idle mode turns off the CPU clock but allows continuing peripheral operation. The Power Down mode stops the whole system clock for minimum power consumption. -4- Publication Release Date: March 11, 2010 Revision: V2.0 2. FEATURES  Fully static design 8-bit CMOS microcontroller.  Wide supply voltage of 2.4V to 5.5V and wide frequency from 4MHz to 40MHz.  12T mode compatible with the tradition 8051 timing.  6T mode supported for double performance.  On-chip RC oscillator of 22.1184MHz/11.0592MHz, trimmed to ±1% at room temperature for the precise system clock.  32k/16k bytes Flash APROM for the application program.  2.5k bytes Flash LDROM for ISP code.  4k bytes Data Flash.  In-System-Programmable (ISP) built in. ISP Erasing or programming supports wide operating voltage 3.0V~5.5V.  Flash 10,000 writing cycle endurance. Greater than 10 years data retention under 85℃.  256 bytes of on-chip RAM.  1024 bytes of on-chip auxiliary RAM (XRAM).  64k bytes Program Memory address space and 64k bytes Data Memory address space.  Maximum five 8-bit general purpose I/O ports pin-to-pin compatible with standard 8051, additional INT2 and INT3 on packages except DIP-40.  Three 16-bit Timers/Counters.  One dedicate timer for Power Down mode waking-up.  One full-duplex UART port.  Five pulse width modulated (PWM) output channels.  One SPI communication port.  11-source, 4-priority-level interrupts capability.  Programmable Watchdog Timer.  Power-on reset.  Brown-out detection interrupt and reset, 4-level selected.  Supports software reset function.  Built-in power management with Idle mode and Power Down mode. -5- Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet  Code lock for data security.  Much lower power consumption than other standard 8051 productions.  Industrial temperature grade, -40℃~85℃.  Strong ESD, EFT immunity.  Development Tool: – Parallel Programmer/Writer. – Nuvoton 8-bit Microcontroller ISP Writer.  Package: Part Number APROM Data Flash N78E059ADG 32k bytes 4k bytes Package 40-pin DIP N78E059APG 44-pin PLCC N78E059AFG 44-pin PQFP N78E059ALG 48-pin LQFP N78E055ADG 16k bytes 4k bytes 40-pin DIP N78E055APG 44-pin PLCC N78E055AFG 44-pin PQFP N78E055ALG 48-pin LQFP -6- Publication Release Date: March 11, 2010 Revision: V2.0 3. BLOCK DIAGRAM Figure 3–1 shows the functional block diagram of N78E059A/N78E055A. It gives the outline of the device. The user can find all the device‟s peripheral functions in the diagram. Brownout and low voltage detection VDD VSS 12T 80C51 CPU RST 2.5k Bytes LDROM Flash Serial Port (UART) 4k Bytes Data Flash SPI 256 Bytes Internal RAM PWM 1024 Bytes XRAM (Auxiliary RAM) P0[7:0] P1[7:0] P2[7:0] P3[7:0] P4[7:0] 8 8 8 8 8 I/O Port, P0 8-bit Internal Bus 32k/16k Bytes APROM Flash Timer0 Timer 1 Timer 2 T0 (P3.4) T1 (P3.5) T2 (P1.0) T2EX (P1.1) TXD (P3.1) RXD (P3.0) SS (P1.4) MOSI (P1.5) MISO (P1.6) SPCLK (P1.7) 5 PWM0~PWM4 (P1.3~P1.7) INT0 (P3.2) INT1 (P3.3) INT2 (P4.3) INT3 (P4.2) External Interrupt Watchdog Timer Power Down Waking-up Timer I/O Port, P1 8 8 I/O Port, P2 External Memory Bus Interface I/O Port, P3 AD[7:0] (P0[7:0]) A[15:8] (P2[7:0]) ALE PSEN WR (P3.6) RD (P3.7) I/O Port, P4 System Clock Power Management XTAL1 XTAL2 Oscillating Circuit 12T/6T Divider On-chip RC Oscillator Figure 3–1. N78E059A/N78E055A Function Block Diagram -7- Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet 4. PIN CONFIGURATIONS T2, P1.0 1 40 VDD T2EX, P1.1 2 39 P0.0, AD0 P1.2 3 38 P0.1, AD1 PWM0, P1.3 4 37 P0.2, AD2 SS, PWM1, P1.4 5 36 P0.3, AD3 6 35 P0.4, AD4 7 34 P0.5, AD5 SPCLK, PWM4, P1.7 8 33 P0.6, AD6 RST 9 32 P0.7, AD7 31 EA RXD, P3.0 10 DIP 40-pin MOSI, PWM2, P1.5 MISO, PWM3, P1.6 TXD, P3.1 11 30 ALE INT0, P3.2 12 29 PSEN INT1, P3.3 13 28 P2.7, A15 T0, P3.4 14 27 P2.6, A14 T1, P3.5 15 26 P2.5, A13 WR, P3.6 16 25 P2.4, A12 RD, P3.7 17 24 P2.3, A11 XTAL2 18 23 P2.2, A10 XTAL1 19 22 P2.1, A9 VSS 20 21 P2.0, A8 Figure 4–1. Pin Assignment of DIP 40-Pin AD0, P0.0 AD1, P0.1 AD2, P0.2 AD3, P0.3 43 42 41 40 1 44 INT3, P4.2 2 VDD T2, P1.0 3 5 4 6 P1.2 PWM0, P1.3 T2EX, P1.1 SS, PWM1, P1.4 MOSI, PWM2, P1.5 7 39 P0.4, AD4 MISO, PWM3, P1.6 8 38 P0.5, AD5 SPCLK, PWM4, P1.7 9 37 P0.6, AD6 RST 10 36 P0.7, AD7 35 EA 34 P4.1 RXD, P3.0 11 INT2, P4.3 12 TXD, P3.1 13 33 ALE INT0, P3.2 14 32 PSEN INT1, P3.3 15 31 P2.7, A15 T0, P3.4 16 30 P2.6, A14 T1, P3.5 17 29 P2.5, A13 PLCC 44-pin 27 28 P2.1, A9 P2.2, A10 P2.3, A11 P2.4, A12 VSS 26 XTAL1 25 22 XTAL2 P2.0, A8 21 P3.7, RD P4.0 20 P3.6, WR 24 19 23 18 Figure 4–2. Pin Assignment of PLCC 44-Pin -8- Publication Release Date: March 11, 2010 Revision: V2.0 SS, PWM1, P1.4 PWM0, P1.3 P1.2 T2EX, P1.1 T2, P1.0 INT3, P4.2 VDD AD0, P0.0 AD1, P0.1 AD2, P0.2 AD3, P0.3 44 43 42 41 40 39 38 37 36 35 34 MOSI, PWM2, P1.5 1 33 P0.4, AD4 MISO, PWM3, P1.6 2 32 P0.5, AD5 SPCLK, PWM4, P1.7 3 31 P0.6, AD6 RST 4 30 P0.7, AD7 RXD, P3.0 5 29 EA INT2, P4.3 6 28 P4.1 TXD, P3.1 7 27 ALE INT0, P3.2 8 26 PSEN INT1, P3.3 9 25 P2.7, A15 T0, P3.4 10 24 P2.6, A14 T1, P3.5 11 23 P2.5, A13 PQFP 44-pin 18 19 20 21 22 P4.0 P2.0, A8 P2.1, A9 P2.2, A10 P2.3, A11 P2.4, A12 VSS 17 16 XTAL1 XTAL2 15 14 P3.7, RD P3.6, WR 13 12 Figure 4–3. Pin Assignment of PQFP 44-Pin P4.4 SS, PWM1, P1.4 PWM0, P1.3 P1.2 T2EX, P1.1 T2, P1.0 INT3, P4.2 VDD AD0, P0.0 AD1, P0.1 AD2, P0.2 AD3, P0.3 48 47 46 45 44 43 42 41 40 39 38 37 MOSI, PWM2, P1.5 1 36 P4.7 MISO, PWM3, P1.6 2 35 P0.4, AD4 SPCLK, PWM4, P1.7 3 34 P0.5, AD5 RST 4 33 P0.6, AD6 RXD, P3.0 5 32 P0.7, AD7 INT2, P4.3 6 31 EA TXD, P3.1 7 30 P4.1 INT0, P3.2 8 29 ALE INT1, P3.3 9 28 PSEN T0, P3.4 10 27 P2.7, A15 T1, P3.5 11 26 P2.6, A14 P4.5 12 25 P2.5, A13 LQFP 48-pin P2.4, A12 P4.6 P2.3, A11 24 P2.2, A10 23 22 P2.1, A9 VSS 21 XTAL1 P2.0, A8 17 XTAL2 20 16 P3.7, RD 19 15 P3.6, WR P4.0 14 18 13 Figure 4–4. Pin Assignment of LQFP 48-Pin -9- Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Table 4–1. Pin Description Pin number Alternate Function Symbol DIP 19 PLCC PQFP LQFP 21 15 16 Type 1 XTAL1 [1] Description 2 CRYSTAL1: This is the input pin to the internal inverting amplifier. The system clock is from external crystal or resonator when FOSC (CONFIG3.1) is logic 1 I by default. (ST) A 0.1μF capacitor is recommended to be added on XTAL1 pin to gain the more precise frequency of the internal RC oscillator frequency if it is selected as the system clock source. 18 20 14 15 XTAL2 O CRYSTAL2: This is the output pin from the internal inverting amplifier. It emits the inverted signal of XTAL1. While on-chip RC oscillator is used, float XTAL2 pin always. 40 44 38 41 VDD P POWER SUPPLY: Supply voltage VDD for operation. 20 22 16 17 VSS P GROUND: Ground potential. I EXTERNAL ACCESS ENABLE: To force EA low will make the CPU execute the external Program Memory. The address and data will be presented on the bus P0 and P2. If the EA pin is high, CPU will fetch internal code unless the Program Counter addresses the area out of the internal Program Memory. This will make CPU run external Program Memory continuously. EA possesses reset lock. After all reset, the EA state will be latched and any state change of this pin after reset will not switch between internal and external Program Memory execution. The user should take care of this pin from floating but connecting to VDD directly if internal Program Memory is used. O ADDRESS LATCH ENABLE: ALE is used to enable the address latch that separates the address from the [2] data on Port 0. ALE runs at 1/6 of the Fosc . An ALE pulse is omitted always. The user can turn ALE off by setting ALEOFF (AUXR.0) to reduce EMI. Setting ALEOFF will just make ALE activating only during external memory access through a MOVC or MOVX instruction. ALE will stay high in other conditions. O PROGRAM STORE ENABLE: PSEN strobes the external Program Memory. When internal Program Memory access is performed, there will be no PSEN strobe signal output from this pin. 31 30 29 9 35 33 32 10 29 27 26 4 31 29 28 4 EA ALE PSEN RST RESET: RST pin is a Schmitt trigger input pin for hardware device reset. A high on this pin for two maI chine-cycles while the system clock is running will (ST) reset the device. RST pin has an internal pull-down resistor allowing power-on reset by simply connecting - 10 - Publication Release Date: March 11, 2010 Revision: V2.0 Table 4–1. Pin Description Pin number Alternate Function Symbol DIP PLCC PQFP LQFP Type 1 [1] Description 2 an external capacitor to VDD. 39 43 37 40 P0.0 AD0 38 42 36 39 P0.1 AD1 37 41 35 38 P0.2 AD2 36 40 34 37 P0.3 AD3 35 39 33 35 P0.4 AD4 D, I/O PORT0: Port 0 is an 8-bit open-drain port by default. Via setting P0UP (P0OR.0), P0 will switch as weakly D, I/O pulled up internally. P0 has an alternative function as AD[7:0] while exD, I/O ternal memory accessing. During the external D, I/O memory access, P0 will output high will be internal strong pulled-up rather than weak pull-up in order to D, I/O drive out high byte address for external devices. 34 38 32 34 P0.5 AD5 D, I/O 33 37 31 33 P0.6 AD6 D, I/O 32 36 30 32 P0.7 AD7 D, I/O 1 2 40 43 P1.0 T2 I/O 2 3 41 44 P1.1 T2EX I/O 3 4 42 45 P1.2 4 5 43 46 P1.3 PWM0 5 6 44 47 P1.4 PWM1 SS I/O 6 7 1 1 P1.5 PWM2 MOSI I/O 7 8 2 2 P1.6 PWM3 MISO I/O 8 9 3 3 P1.7 PWM4 SPCLK I/O 21 24 18 19 P2.0 A8 I/O 22 25 19 20 P2.1 A9 I/O 23 26 20 21 P2.2 A10 I/O 24 27 21 22 P2.3 A11 I/O 25 28 22 23 P2.4 A12 I/O 26 29 23 25 P2.5 A13 I/O 27 30 24 26 P2.6 A14 I/O 28 31 25 27 P2.7 A15 I/O PORT1: Port 1 is an 8-bit quasi bi-directional I/O port. Its multifunction pins are for T2, T2EX, PWM0~PWM4, SS , MOSI, MISO, and SPCLK. I/O I/O - 11 - PORT2: Port 2 is an 8-bit quasi bi-directional I/O port. It has an alternative function as A[15:8] while external memory accessing. During the external memory access, P2 will output high will be internal strong pulled-up rather than weak pull-up in order to drive out high byte address for external devices. Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Table 4–1. Pin Description Pin number Alternate Function Symbol DIP PLCC PQFP LQFP Type 1 [1] Description 2 10 11 5 5 P3.0 RXD I/O 11 13 7 7 P3.1 TXD I/O 12 14 8 8 P3.2 INT0 I/O 13 15 9 9 P3.3 INT1 I/O 14 16 10 10 P3.4 T0 I/O 15 17 11 11 P3.5 T1 I/O 16 18 12 13 P3.6 WR I/O 17 19 13 14 P3.7 RD I/O - 23 17 18 P4.0 I/O - 34 28 30 P4.1 I/O - 1 39 42 P4.2 INT3 I/O - 12 6 6 P4.3 INT2 I/O - - - 48 P4.4 I/O - - - 12 P4.5 I/O - - - 24 P4.6 I/O - - - 36 P4.7 I/O PORT3: Port 3 is an 8-bit quasi bi-directional I/O port. Its multifunction pins are for RXD, TXD, INT0 , INT1 , T0, T1, WR , and RD . [3] PORT4 : Port 4 is an 8-bit quasi bi-directional I/O port. It also possesses bit-addressable feature as P0~P3. P4.2 and P4.3 are alternative function pins of INT3 and INT2 . [1] I/O type description. I: input, O: output, I/O: quasi bi-direction, D: open-drain, P: power pins, ST: Schmitt trigger. [2] While switching to 6T mode, ALE will run at 1/3 of Fosc. [3] A full 8-bit P4 is just on LQPF-48 package. PLCC-44 and PQFP-44 just have low nibble 4 bits of P4. DIP-40 does not have this additional P4. - 12 - Publication Release Date: March 11, 2010 Revision: V2.0 The application circuit is shown below. The user is recommended follow the circuit enclosed by gray blocks to achieve the most stable and reliable operation of MCU especially in a noisy power environment for a healthy EMS immunity. If internal RC oscillator is used as the system clock, a 0.1μF capacitor should be added to gain a precise RC frequency. 10μF RST VDD VDD 0.1μF 10kΩ C1 0.1μF EA XTAL1 10μF as close to MCU as possible R XTAL2 VSS GND N78E059A/ N78E055A C2 as close to the power source as possible Figure 4–5. Application Circuit for Execution of Internal Program Code with External Crystal Crystal Frequency R C1 4MHz~33MHz Without 33MHZ~40MHz 5kΩ~10kΩ C2 Depend on crystal specifications 10μF RST VDD VDD 0.1μF 10kΩ 0.1μF EA XTAL1 as close to MCU as possible 0.1μF XTAL2 as close to MCU as possible 10μF VSS GND N78E059A/ N78E055A as close to the power source as possible Figure 4–6. Application Circuit for Execution of Internal Program Code with Internal RC Oscillator - 13 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet 5. MEMORY ORGANIZATION A standard 8051 based MCU divides the memory into two different sections, the Program Memory and the Data Memory. The Program Memory is used to store the instruction codes, whereas the Data Memory is used to store data or variations during the program execution. Data Memory occupies a separate address space from Program Memory. In N78E059A/N78E055A, there are 256 bytes of internal scratch-pad RAM and up to 64k bytes of memory space for external Data Memory. The MCU generates the 16-bit or 8-bit addresses, read and write strobe signals ( RD and WR , respectively) during external Data Memory access. For many applications which need more internal RAM, N78E059A/N78E055A possesses on-chip 1k bytes of RAM (called XRAM) accessed by MOVX instruction. The whole embedded flash is divided into 4 banks, APROM for storage of user‟s program code, Data Flash for parameter data storage, LDROM for ISP program and CONFIG bytes. Each bank is accumulated page by page and the page size is 256 bytes. The flash control unit supports Page Erase, Byte Program, and Byte Read modes. The external writer tools though specific I/O pins and the internal ISP (In System Programming) function both can perform these modes. 5.1 Internal Program Memory Program Memory is the one, which stores the program codes to execute, as shown in Figure 5–1. While EA pin is pulled high and after any reset, the CPU begins execution from location 0000H where should be the starting point of the user‟s application code. To service the interrupts, the interrupt service locations (called interrupt vectors) should be located in the Program Memory. Each interrupt is assigned with a fixed location in the Program Memory. The interrupt causes the CPU to jump to that location with where it commences execution of the interrupt service routine (ISR). External Interrupt 0, for example, is assigned to location 0003H. If External Interrupt 0 is going to be used, its service routine must begin at location 0003H. If the interrupt is not going to be used, its service location is available as general purpose Program Memory. The interrupt service locations are spaced at an interval of 8 bytes: 0003H for External Interrupt 0, 000BH for Timer 0, 0013H for External Interrupt 1, 001BH for Timer 1, etc. If an interrupt service routine is short enough (as is often the case in control applications), it can reside entirely within that 8-byte interval. However longer service routines should use a JMP instruction to skip over subsequent interrupt locations if other interrupts are in use. N78E059A/N78E055A provides two internal Program Memory bank APROM and LDROM. Although they both behave the same as the standard 8051 Program Memory, they play different rules according to their ROM - 14 - Publication Release Date: March 11, 2010 Revision: V2.0 size. The APROM on N78E059A/N78E055A is 32k/16k-byte size. The user‟s main program code is normally put inside. All instructions are fetched for execution from this area. The MOVC instruction can also read this flash memory region. N78E059A/N78E055A supports the other individual Program Memory bank called LDROM besides APROM. The main function of LDROM is to store the ISP application program. User may develop the ISP in LDROM for updating APROM content. The program in APROM can also re-program LDROM. For ISP details and configuration bit setting related with APROM and LDROM, see Section 18. “IN SYSTEM PROGRAMMING (ISP)” on page 91. Note that because APROM and LDROM are hardware individual blocks, consequently if CPU reboots from LDROM, CPU will automatically re-vectors Program Counter 0000H to the LDROM start address. Therefore, CPU accounts the LDROM as an independent Program Memory and all interrupt vectors are independent from APROM. FFFFH FFFFH [2] 7FFFH/3FFFH 0000H APROM 09FFH 0000H [2] LDROM Internal Program Memory EA = 1, BS = 0[1] EA = 1, BS = 1 0000H External Program Memory EA = 0 [1] EA is the state of EA pin after power-on reset. BS is bit 1 of CHPCON. [2] While execution beyond the top boundary of internal Program Memory, CPU will switch to external Program Memory to continue. Figure 5–1. N78E059A/N78E055A Program Memory Structure - 15 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet 5.2 External Program Memory N78E059A/N78E055A is a 16-bit address-width CPU. It can address 64k-byte program code. Besides the internal Program Memory, the external additional Program Memory is also can be used. The external program addressing will be executed under cases below, 1. The PC (Program Counter) value is beyond the boundary size address of APROM or LDROM while EA pin is pulled high during power on. The CPU will continue to fetch the external Program Memory. 2. While EA pin is pulled low during power on period, The CPU will run totally 64k-byte code externally. While the external mode is running, the P0 and P2 will produce address and data signals to fetching external Program Memory. In this case, P0 and P2 cannot be general purpose I/O anymore. PSEN will also toggle out to strobe the external Program Memory. For the hardware circuit for external program execution, see Figure 5– 2. Program Memory Interface. For security EA pin state will be locked after power on. The user cannot switch the program running internally or externally by EA after power on. The other design for data security is MOVC lock enable (MOVCL, CONFIG0.2). While this bit is set 0, The external Program Memory code is inhibited to read internal APROM or LDROM contents through MOVC instruction. P0 N78E059A/ N78E055A 8 External Program Memory Data[7:0] 8 P0 LATCH ALE Address[7:0] 8 P2 Address[15:8] PSEN OE EA P0 Figure 5–2. Program Memory Interface - 16 - Publication Release Date: March 11, 2010 Revision: V2.0 5.3 Internal Data Memory Figure 5–3 shows the internal and external Data Memory spaces available on N78E059A/N78E055A. Internal Data Memory can be divided into three blocks. They are the lower 128 bytes of RAM, the upper 128 bytes of RAM, and the 128 bytes of SFR space. Internal Data Memory addresses are always 8-bit wide, which implies an address space of only 256 bytes. Direct addressing higher than 7FH will access the special function registers (SFRs) space and indirect addressing higher than 7FH will access the upper 128 bytes of RAM. Although the SFR space and the upper 128 bytes of RAM share the same logic address, 80H through FFH, actually they are physically separate entities. Direct addressing to distinguish with the higher 128 bytes of RAM can only access these SFRs. Sixteen addresses in SFR space are both byte and bit-addressable. The bit-addressable SFRs are those whose addresses end in 0H or 8H. The lower 128 bytes of internal RAM are present in all 8051 devices. The lowest 32 bytes are grouped into 4 banks of 8 registers. Program instructions call these registers as R0 through R7. Two bits RS0 and RS1 in the Program Status Word (PSW[3:4]) select which Register Bank is used. This benefits more efficiency of code space, since register instructions are shorter than instructions that use direct addressing. The next 16 bytes above the Register Banks (byte-address 20H through 2FH) form a block of bit-addressable memory space (bitaddress 00H through 7FH). The 8051 instruction set includes a wide selection of single-bit instructions, and the 128 bits in this area can be directly addressed by these instructions. The bit addresses in this area are 00H through 7FH. All bytes in the lower 128-byte space can be accessed by either direct or indirect addressing. Indirect addressing can only access the upper 128. Another application implemented with the whole block of internal 256-byte RAM is for the stack. This area is selected by the Stack Pointer (SP), which stores the address of the top of the stack. Whenever a JMP, CALL or interrupt is invoked, the return address is placed on the stack. There is no restriction as to where the stack can begin in the RAM. By default however, the Stack Pointer contains 07H at reset. The user can then change this to any value desired. The SP will point to the last used value. Therefore, the SP will be incremented and then address saved onto the stack. Conversely, while popping from the stack the contents will be read first, and then the SP is decreased. - 17 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet 00H FFFFH FFH 80H 7FH 00H Upper 128 bytes internal RAM (indirect addressing) SFR (direct addressing) [2] 3FFH Lower 128 bytes internal RAM (direct or indirect addressing) 000H 1k bytes Auxiliary RAM (XRAMEN[1]= 1) External Data Memory (XRAMEN = 0) 0000H [1] XRAMEN is bit 4 of CHPCON. XRAM is enabled after any reset. [2] If XRAMEN is 1 yet the address over 3FFH, CPU will use external data memory above 400H. Figure 5–3. N78E059A/N78E055A Data Memory Structure FFH FFH Indirect Accessing RAM 80H 7FH Direct or Indirect Accessing RAM 30H 2FH 2EH 2DH 2CH 2BH 2AH 29H 28H 27H 26H 25H 24H 23H 22H 21H 20H 1FH 18H 17H 10H 0FH 08H 07H 7F 77 6F 67 5F 57 4F 47 3F 37 2F 27 1F 17 0F 07 7E 76 6E 66 5E 56 4E 46 3E 36 2E 26 1E 16 0E 06 7D 75 6D 65 5D 55 4D 45 3D 35 2D 25 1D 15 0D 05 7C 74 6C 64 5C 54 4C 44 3C 34 2C 24 1C 14 0C 04 7B 73 6B 63 5B 53 4B 43 3B 33 2B 23 1B 13 0B 03 7A 72 6A 62 5A 52 4A 42 3A 32 2A 22 1A 12 0A 02 79 71 69 61 59 51 49 41 39 31 29 21 19 11 09 01 78 70 68 60 58 50 48 40 38 30 28 20 18 10 08 00 Register Bank 3 Register Bank 2 Register Bank 1 Register Bank 0 00H 00H Figure 5–4. 256 bytes Internal RAM Addressing - 18 - Publication Release Date: March 11, 2010 Revision: V2.0 5.4 On-chip XRAM N78E059A/N78E055A provides additional on-chip auxiliary RAM called XRAM to enlarge RAM space. The 1024 bytes of XRAM (000H to 3FFH) are indirectly accessed by move external instruction MOVX. For details, see Section 8. “AUXILIARY RAM (XRAM)” on page 29. 5.5 External Data Memory Access to external Data Memory can use either a 16-bit address (using „MOVX @DPTR‟) or an 8-bit address (using „MOVX @Ri‟, i = 0 or 1). For another 1k-byte XRAM exists, remember the bit XRAMEN (CHPCON.4) should be cleared as logic 0 in order to access the range of 000H to 3FFH address of the external Data Memory. 16-bit addresses are often used to access up to 64k bytes of external RAM. Whenever a 16-bit address is used, P0, P2, P3.7 and P3.6 serve as the low byte address/data, the high byte address, RD strobe and WR strobe signals respectively. Meanwhile the pins listed above cannot be used as general purpose I/O during external Data Memory access. 8-bit addresses are often used in conjunction with one or more other I/O lines to page the RAM. For example, if a 1k-byte external RAM is used, Port 0 serves as a multiplexed address/data bus to the RAM, and 2 pins of Port 2 are used to page the RAM. The CPU generates RD and WR (alternate functions of P3.7 and P3.6) to strobe the memory. In 8-bit addressing mode, P2 pins other than the two pins for RAM paging are free for general purpose I/O usage. This will facilitate P2 application. Of course, the user may use any other I/O lines instead of P2 to page the RAM. In all cases, the low byte of the address is time-multiplexed with the data byte on Port 0. ALE (Address Latch Enable) should be used to capture the address byte into an external latch. The address byte is valid at the negative transition of ALE. Then, in a write cycle, the data byte to be written appears on Port 0 just before WR is activated, and remains there until after WR is deactivated. In a read cycle, the incoming byte is accepted at Port 0 just before the read strobe is deactivated. During any access to external memory, the CPU writes 0FFH to the Port 0 latch (P0 in SFRs), thus obliterating whatever information the Port 0 SFR may have been holding. - 19 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet P0 N78E059A/ N78E055A 8 External Data Memory Data[7:0] 8 LATCH P0 ALE Address[7:0] 8 P2 Address[15:8] RD OE WR WE Figure 5–5. Data Memory Interface 5.6 On-chip Non-volatile Data Flash N78E059A/N78E055A additionally has Data Flash. The Data Flash is non-volatile so that it remains its content even after the power is off. Therefore, in general application the user can write or read data which rules as parameters or constants. Be aware of Data Flash writing endurance of 10,000 cycles. By the software path, the Data Flash can be accessed only through ISP mode. Note that the erasing or writing of Data Flash should not operates under VDD 3.0V for ISP limitation. For Data Flash accessing with ISP, please see Section 18. “IN SYSTEM PROGRAMMING (ISP)” on page 91 for details. For the design for security, ISP is invalid while external Program Memory executes. The Data Flash, therefore, cannot be accessed with external memory code. Of course the Data Flash can be accessed via hardware with parallel Programmer/Writer. The Data Flash size is fixed as 4k-byte size on N78E059A/N78E055A. - 20 - Publication Release Date: March 11, 2010 Revision: V2.0 0000H FFFFH Data Flash F000H 7FFFH/3FFFH APROM 0000H Figure 5–6. N78E059A/N78E055A Data Flash - 21 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet 6. SPECIAL FUNCTION REGISTER (SFR) The N78E059A/N78E055A uses Special Function Registers (SFRs) to control and monitor peripherals and their modes. The SFRs reside in the register locations 80~FFH and are accessed by direct addressing only. Some of the SFRs are bit-addressable. This is very useful in cases where users would like to modify a particular bit directly without changing other bits. Those which are bit-addressable SFRs end their addresses as 0H or 8H. N78E059A/N78E055A contains all the SFRs presenting in the standard 8051. However some additional SFRs are built in. Therefore, some of unused bytes in the original 8051 have been given new functions. The SFRs is listed as below. Table 6–1. N78E059A/N78E055A Special Function Registers Mapping F8 - - - - - - - - FF F0 B - - SPCR SPSR SPDR - - F7 E8 - - - - - - - - EF E0 ACC - - - - - - - E7 D8 P4 PWMP PWM0 PWM1 PWMCON0 PWM2 PWM3 - DF D0 PSW - - - - - - - D7 C8 T2CON T2MOD RCAP2L RCAP2H TL2 TH2 PWMCON1 PWM4 CF C0 XICON - - - - - - TA C7 B8 IP - IPH EIPH EIP EIE - - BF B0 P3 - - - - - - - B7 A8 IE - WDCON PDCON PMC - ISPFD ISPCN AF A0 P2 XRAMAH - - ISPTRG - ISPAL ISPAH A7 98 SCON SBUF - - - - - CHPCON 9F 90 P1 - - - - - RSR - 97 88 TCON TMOD TL0 TL1 TH0 TH1 AUXR - 8F 80 P0 SP DPL DPH - - P0OR PCON 87 In Bold - bit-addressable reserved Note that the reserved SFR addresses must be kept in their own initial states. Users should never change their values. - 22 - Publication Release Date: March 11, 2010 Revision: V2.0 Table 6–2. N78E059A/N78E055A SFR Descriptions and Reset Values Symbol Definition Address F5H F4H F3H F0H E0H DEH DDH DCH DBH DAH D9H P4 Port 4 D8H PSW Program status word D0H PWM4 PWMCON1 TH2 TL2 CFH CEH CDH CCH CBH 0000 0000b T2MOD PWM4 duty PWM control 1 Timer 2 high byte Timer 2 low byte Timer 2 reload/capture high byte Timer 2 reload/capture low byte Timer 2 mode Reset Value 0000 0000b SPIF WCOL SPIOVF MODF DISMODF 0000 0000b SSOE SPIEN LSBFE MSTR CPOL CPHA SPR1 SPR0 0 0 0 0 0 0 0 0 b (F7) (F6) (F5) (F4) (F3) (F2) (F1) (F0) 0000 0000b (E7) (E6) (E5) (E4) (E3) (E2) (E1) (E0) 0000 0000b 0000 0000b 0000 0000b PWM3OE PWM2OE PWM3EN PWM2EN PWM1OE PWM0OE PWM1EN PWM0EN 0 0 0 0 0 0 0 0 b 0000 0000b 0000 0000b 0000 0000b (DF) (DE) (DD) (DC) (DB) (DA) (D9) (D8) 1111 1111b INT 3 INT 2 (D7) (D6) (D5) (D4) (D3) (D2) (D1) (D0) 0000 0000b CY AC F0 RS1 RS0 OV F1 P 0000 0000b PWM4OE PWM4EN 0 0 0 0 0 0 0 0 b 0000 0000b 0000 0000b T2CON Timer 2 control C8H TA Timed access protection C7H RCAP2L XICON External interrupt control CAH (CE) (CD) (CC) (CB) (CA) T2OE (C9) (C8) TF2 EXF2 RCLK TCLK EXEN2 TR2 C / T2 CP / RL 2 C0H (C7) PX3 (C6) EX3 (C4) IE3 (C4) IT3 (C3) PX2 (C2) EX2 (C1) IE2 (C0) 1IT2 0000 0000b BDH - - - - - EBOD EPDT ESPI 0000 0000b BCH - - - - - PBOV PPDT PSPI 0000 0000b C9H IPH IP Interrupt priority B8H P3 Port 3 B0H ISPCN ISPFD ISP flash control ISP flash data AFH AEH EIP EIPH 0000 0000b (CF) Extensive interrupt enable Extensive interrupt priority Extensive interrupt priority high Interrupt priority high EIE LSB [2] SPI data SPI status SPI control B register Accumulator PWM3 duty PWM2 duty PWM control 0 PWM1 duty PWM0 duty PWM period RCAP2H MSB [1] SPDR SPSR SPCR B ACC PWM3 PWM2 PWMCON0 PWM1 PWM0 PWMP 0000 0000b 0000 0000b 0000 0000b BBH - - - - - PBODH PPDTH PSPIH 0000 0000b BAH PX3H (BF) (B7) PX2H (BE) (B6) PT2H (BD) PT2 (B5) PSH (BC) PS (B4) PT1H (BB) PT1 (B3) PX1H (BA) PX1 (B2) PT0H (B9) PT0 (B1) PX0H (B8) PX0 (B0) 0000 0000b RD ISPA17 WR ISPA16 T1 FOEN T0 FCEN INT1 FCTRL3 INT 0 FCTRL2 TXD FCTRL1 0000 0000b 1111 1111b RXD FCTRL0 0 0 0 0 0 0 0 0 b 0000 0000b [6] PMC [3] PDCON Power monitoring control ACH BODEN - - BORST Power Down waking-up timer control ABH PDTEN PDTCK PDTF - [4] BOF - LPBOD - PPS2 PPS1 BOS [5] Power-on , X X X X X 0 0 Xb Brown-out, XXXX 100Xb Others, XXXX 000Xb PPS0 0000 0000b [6] Watchdog Timer control AAH WDTEN WDCLR - WIDPD WDTRF WPS2 WPS1 WPS0 Power-on , X000 0000b Watchdog, X00U 1U U U b Others, X00U UUUUb IE Interrupt enable A8H (AF) EA (AE) - (AD) ET2 (AC) ES (AB) ET1 (AA) EX1 (A9) ET0 (A8) EX0 0000 0000b ISPAH ISPAL ISP address high byte ISP address low byte ISP trigger Auxiliary RAM address high byte A7H A6H A4H WDCON ISPTRG [3] [3] XRAMAH P2 Port 2 - - - - - - A1H - - - - - - A0H (A7) A15 (A6) A14 (A5) A13 (A4) A12 (A3) A11 (A2) A10 - 23 - - ISPGO 0000 0000b 0000 0000b 0000 0000b XRAMAH.1 XRAMAH.0 0 0 0 0 0 0 0 0 b (A1) A9 (A0) A8 1111 1111b Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Table 6–2. N78E059A/N78E055A SFR Descriptions and Reset Values Symbol Definition Address MSB LSB [1] [2] Reset Value [6] [3] Chip control 9FH SBUF Serial buffer 99H SCON Serial control 98H CHPCON RSR Reset status register 96H P1 Port 1 90H Software , 0001 00U0b Others, 0001 00X0b 0000 0000b SWRST ISPF LDUEN XRAMEN - - BS ISPEN (9F) SM0 (9E) SM1 (9D) SM2 (9C) REN (9B) TB8 (9A) RB8 (99) TI (98) RI 0000 0000b Power-on, 0000 0000b Brown-out, 0000 010Ub Software, 0000 0U01b Others, 0000 0U0Ub - - - - - BORF - SWRF (97) PWM4 (96) PWM3 (95) PWM2 (94) PWM1 (93) PWM0 (92) (91) T2EX (90) T2 SPCLK - MISO - MOSI - SS - - - - GATE (8F) TF1 C/T (8E) TR1 M1 (8D) TF0 M0 (8C) TR0 GATE (8B) IE1 C/T (8A) IT1 M1 (89) IE0 AUXR TH1 TH0 TL1 TL0 TMOD Auxiliary register Timer 1 high byte Timer 0 high byte Timer 1 low byte Timer 0 low byte Timer 0 and 1 mode 8EH 8DH 8CH 8BH 8AH 89H TCON Timer 0 and 1control 88H PCON Power control 87H SMOD - - POF GF1 GF0 PD P0OR DPH DPL SP P0 option register Data pointer high byte Data pointer low byte Stack pointer 86H 83H 82H 81H - - - - - - - P0 Port 0 80H (87) A7 (86) A6 (85) A5 (84) A4 (83) A3 (82) A2 (81) A1 1111 1111b ALEOFF 0 0 0 0 0 0 0 0 b 0000 0000b 0000 0000b 0000 0000b 0000 0000b M0 0000 0000b (88) 0000 0000b IT0 Power-on, 0001 0000b IDL Others, 000U 0000b P0UP 0 0 0 0 0 0 0 0 b 0000 0000b 0000 0000b 0000 0111b (80) 1111 1111b A0 [1] ( ) item means the bit address in bit-addressable SFRs. [2] Reset value symbol description. 0: logic 0, 1: logic 1, U: unchanged, X: see [4] ~ [7]. [3] These SFRs have TA protected writing. [4] BOF has different power-on reset value according to CBODEN (CONFIG2.7) and CBORST (CONFIG2.4). See Table 21–1. BOF Reset Value. [5] BOS is a read-only flag decided by VDD level while Brown-out detection is enabled. [6] These SFRs have bits which are initialized after specified reset by loading certain bits in CONFIG bytes. See Section 24. “CONFIG BYTES” on page 116 for details. Note that bits marked in “-“ must be kept in their own initial states. Users should never change their values. - 24 - Publication Release Date: March 11, 2010 Revision: V2.0 7. GENERAL 80C51 SYSTEM CONTROL A or ACC – Accumulator (bit-addressable) 7 6 5 4 ACC.7 ACC.6 ACC.5 ACC.4 r/w r/w r/w r/w Address: E0H 3 ACC.3 r/w 2 ACC.2 r/w 1 0 ACC.1 ACC.0 r/w r/w reset value: 0000 0000b Bit Name Description 7:0 ACC[7:0] Accumulator. The A or ACC register is the standard 8051 accumulator for arithmetic operation. B – B Register (bit-addressable) 7 6 5 B.7 B.6 B.5 r/w r/w r/w Address: F0H 4 B.4 r/w 3 B.3 r/w 2 B.2 r/w 1 0 B.1 B.0 r/w r/w reset value: 0000 0000b Bit Name Description 7:0 B[7:0] B register. The B register is the other accumulator of the standard 8051. It is used mainly for MUL and DIV operations. SP – Stack Pointer 7 6 5 4 3 2 1 0 SP[7:0] r/w Address: 81H reset value: 0000 0111b Bit Name Description 7:0 SP[7:0] Stack pointer. The Stack Pointer stores the scratch-pad RAM address where the stack begins. It is incremented before data is stored during PUSH or CALL instructions. Note that the default value of SP is 07H. It causes the stack to begin at location 08H. DPL – Data Pointer Low Byte 7 6 5 4 3 2 1 0 DPL[7:0] r/w Address: 82H reset value: 0000 0000b Bit Name Description 7:0 DPL[7:0] Data pointer low byte. This is the low byte of the standard 8051 16-bit data pointer. DPL combined with DPH serve as a 16-bit data pointer DPTR to address non-scratch-pad memory or Program Memory. - 25 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet DPH – Data Pointer High Byte 7 6 5 4 3 2 1 0 DPH[7:0] r/w Address: 83H reset value: 0000 0000b Bit Name Description 7:0 DPH[7:0] Data pointer high byte. This is the high byte of the standard 8051 16-bit data pointer. DPH combined with DPL serve as a 16-bit data pointer DPTR to address non-scratch-pad memory or Program Memory. PSW – Program Status Word (bit-addressable) 7 6 5 4 CY AC F0 RS1 r/w r/w r/w r/w Address: D0H 3 RS0 r/w 2 OV r/w 1 0 F1 P r/w r reset value: 0000 0000b Bit Name Description 7 CY Carry flag. For a adding or subtracting operation, CY will be set when the previous operation resulted in a carry-out from or a borrow-in to the Most Significant bit, otherwise cleared. If the previous operation is MUL or DIV, CY is always 0. CY is affected by DA A instruction which indicates that if the original BCD sum is greater than 100. For a CJNE branch, CY will be set if the first unsigned integer value is less than the second one. Otherwise, CY will be cleared. 6 AC Auxiliary carry. Set when the previous operation resulted in a carry-out from or a borrow-in to the th 4 bit of the low order nibble, otherwise cleared. 5 F0 User flag 0. The general purpose flag that can be set or cleared by the user. 4 RS1 3 RS0 Register Bank selecting bits. These two bits select one of four banks in which R0~R7 locate. RS1 RS0 Register Bank RAM Address 0 0 0 00~07H 0 1 1 08~0FH 1 0 2 10~17H 1 1 3 18~1FH - 26 - Publication Release Date: March 11, 2010 Revision: V2.0 Bit Name Description 2 OV Overflow flag. OV is used for a signed character operands. For a ADD or ADDC instruction, OV will be set if there is a carry out of bit 6 but not out of bit 7, or a carry out of bit 7 but not bit 6. Otherwise, OV is cleared. OV indicates a negative number produced as the sum of two positive operands or a positive sum from two negative operands. For a SUBB, OV is set if a borrow is needed into bit6 but not into bit 7, or into bit7 but not bit 6. Otherwise, OV is cleared. OV indicates a negative number produced when a negative value is subtracted from a positive value, or a positive result when a positive number is subtracted from a negative number. For a MUL, if the product is greater than 255 (00FFH), OV will be set. Otherwise, it is cleared. For a DIV, it is normally 0. However, if B had originally contained 00H, the values returned in A and B will be undefined. Meanwhile, the OV will be set. 1 F1 User flag 1. The general purpose flag that can be set or cleared by the user via software. 0 P Parity flag. Set to 1 to indicate an odd number of ones in the accumulator. Cleared for an even number of ones. It performs even parity check. Table 7–1. Instructions that affect flag settings Instruction ADD CY [1] X OV AC Instruction CY X X CLR C 0 ADDC X X X CPL C X SUBB X X X ANL C, bit X MUL 0 X ANL C, /bit X DIV 0 X ORL C, bit X DA A X ORL C, /bit X RRC A X MOV C, bit X RLC A X CJNE X SETB C 1 OV AC [1] X indicates the modification depends on the result of the instruction. - 27 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet PCON – Power Control 7 6 5 4 3 2 1 0 SMOD POF GF1 GF0 PD IDL r/w r/w r/w r/w r/w r/w Address: 87H reset value: see Table 6–2. N78E059A/N78E055A SFR Descriptions and Reset Values Bit Name Description 3 GF1 General purpose flag 1. The general purpose flag that can be set or cleared by the user. 2 GF0 General purpose flag 0. The general purpose flag that can be set or cleared by the user. - 28 - Publication Release Date: March 11, 2010 Revision: V2.0 8. AUXILIARY RAM (XRAM) N78E059A/N78E055A provides additional on-chip 1k-byte RAM called XRAM to enlarge the RAM space. It occupies the address space from 000H through 3FFH. The XRAM is enabled after all resets. The 1024 bytes of XRAM are indirectly accessed by move external instruction MOVX @DPTR or MOVX @Ri along with XRAMAH. (If XRAM is enabled, MOVX @Ri cannot be used to access external RAM anymore.) This block of XRAM shares the same logic address of 000H through 3FFH with the external RAM. A DPTR value given larger than 03FFH will map to the external RAM no matter of the value of bit XRAMEN (CHPCON.4). If the user would like to access contents within 000H to 3FFH address of the off-chip external XRAM, the XRAMEN bit should be cleared as logic 0. (Note that CHPCON is a TA writing protected SFR.) When the XRAM is accessed, the address fetching signal will not emit via P0, P2, WR , and RD . Note that the stack pointer cannot locate in any part of XRAM. CHPCON – Chip Control (TA protected) 7 6 5 4 3 2 1 0 SWRST ISPF LDUEN XRAMEN BS ISPEN w r/w r/w r/w r/w r/w Address: 9FH reset value: see Table 6–2. N78E059A/N78E055A SFR Descriptions and Reset Values Bit Name 4 XRAMEN XRAMAH – XRAM 7 Address: A1H Description XRAM enable. 0 = Disable on-chip XRAM. 1 = Enable on-chip XRAM. (The default value after all resets.) Address High Byte 6 5 - Bit Name 7:2 - 1:0 XRAMAH[1:0] 4 - 3 - 2 - 1 0 XRAMAH.1 XRAMAH.0 r/w r/w reset value: 0000 0000b Description Reserved. XRAM address high byte. To set the XRAM high byte address. This setting works along with MOV @Ri instructions. The demo codes are listed below. XRAM demo code: MOV MOV MOV MOVX XRAMAH,#01H R0,#23H A,#5AH @R0,A ;write #5AH to XRAM with address @0123H. MOV MOV XRAMAH,#01H R0,#23H ;read from XRAM with address @0123H. - 29 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet MOVX A,@R0 MOV MOV MOVX DPTR,#0123H A,#5BH @DPTR,A ;write #5BH to XRAM with address @0123H. MOV MOVX DPTR,#0123H A,@DPTR ;read from XRAM with address @0123H. - 30 - Publication Release Date: March 11, 2010 Revision: V2.0 9. I/O PORT STRUCTURE AND OPERATION N78E059A/N78E055A has maximum five 8-bit width, bit-addressable ports P0~P4. The configuration of P1~P4 is the quasi bi-directional I/O. This type rules as both input and output. When the port outputs a logic high, it is weakly driven, allowing an external device to pull the pin low. When the pin is pulled low, it is driven strongly and able to sink a large current. In the quasi bi-directional I/O structure, there are three pull-up transistors. Each of them serves different purposes. One of these pull-ups, called the “very weak” pull-up, is turned on whenever the port latch contains a logic 1. The “very weak” pull-up sources a very small current that will pull the pin high if it is left floating. A second pull-up, called the “weak” pull-up, is turned on when the outside port pin itself is at a logic 1 level. This pull-up provides the primary source current for a quasi bi-directional pin that is outputting a 1. If a pin that has a logic 1 on it is pulled low by an external device, the “weak” pull-up turns off, and only the “very weak” pull-up remains on. In order to pull the pin low under these conditions, the external device has to sink enough current (larger than ITL) to overcome the “weak” pull-up and make the voltage on the port pin below its input threshold (lower than VIL). The third pull-up is the “strong” pull-up. This pull-up is used to speed up low-to-high transitions on a quasi bidirectional port pin when the port latch changes from a logic 0 to a logic 1. When this occurs, the strong pull-up turns on for two-peripheral-clock time in order to pull the port pin high quickly. Then it turns off and “weak: pullup continues remaining the port pin high. The quasi bi-directional port structure is shown as below. VDD 2-peripheralclock delay P Strong P Very Weak P Weak Port Pin Port Latch N Input Figure 9–1. Quasi Bi-direction I/O Structure The default configuration of P0 is open-drain structure. To serve as an I/O port the external pull-up resistor is always necessary. N78E059A/N78E055A also provide an internal P0 pull-up resistors for each pins. Via setting - 31 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet P0UP (P0OR.0) P0 will switch on its weak pull-up internally and behave the same as the quasi bi-directional I/O pins. P0 and P2 also serve as address/data bus when external memory is running or is accessed by MOVC or MOVX instruction. In these cases, it has strong pull-up and pull-down. In this application, there is no need of any external pull-up resistor. While external mode execution, P0 and P2 cannot be used as general purpose I/O anymore. In standard 8051 instruction set, one kind of instructions, read-modify-write instructions, should be specially taken care of. Instead of the normal instructions, the read-modify-write instructions read the internal port latch (Px in SFRs) rather than the external port pin state. This kind of instructions read the port SFR value, modify it and write back to the port SFR. Read-modify-write instructions are listed as follows. Instruction Description ANL Logical AND. (ANL Px,A and ANL Px,direct) ORL Logical OR. (ORL Px,A and ORL Px,direct) XRL Logical exclusive OR. (XRL Px,A and XRL Px,direct) JBC Jump if bit = 1 and clear it. (JBC Px.y,LABEL) CPL Complement bit. (CPL Px.y) INC Increment. (INC Px) DEC Decrement. (DEC Px) DJNZ Decrement and jump if not zero. (DJNZ Px,LABEL) MOV Px.y,C Move carry bit to Px.y. CLR Px.y Clear bit Px.y. SETB Px.y Set bit Px.y. The last three seems not obviously read-modify-write instructions but actually they are. They read the entire port latch value, modify the changed bit, then write the new value back to the port latch. - 32 - Publication Release Date: March 11, 2010 Revision: V2.0 P0 – Port 0 (bit-addressable) 7 6 5 P0.7 P0.6 P0.5 r/w r/w r/w Address: 80H Bit Name 7:0 P0[7:0] Name 7:1 - 0 P0UP Name 7:0 P1[7:0] 2 P0.2 r/w 1 0 P0.1 P0.0 r/w r/w reset value: 1111 1111b Port 0. Port 0 is an 8-bit open-drain port by default. Via setting P0UP (P0OR.0) P0 will switch as weakly pulled up internally. P0 has an alternative function as AD[7:0] while external memory accessing. During external Program Memory execution, SFR P0 cannot be accessed. 5 - 4 - 3 - 2 - 1 0 P0UP r/w reset value: 0000 0000b Description Reserved. Port 0 pull-up enable. 0 = Disable internal pull-up resistors of all 8-bits of Port 0. 1 = Enable internal pull-up resistors of all 8-bits of Port 0. P1 – Port 1 (bit-addressable) 7 6 5 P1.7 P1.6 P1.5 r/w r/w r/w Address: 90H Bit 3 P0.3 r/w Description P0OR – P0 Option Register 7 6 Address: 86H Bit 4 P0.4 r/w 4 P1.4 r/w 3 P1.3 r/w 2 P1.2 r/w 1 0 P1.1 P1.0 r/w r/w reset value: 1111 1111b 2 P2.2 r/w 1 0 P2.1 P2.0 r/w r/w reset value: 1111 1111b Description Port 1. Port 1 is an 8-bit quasi bi-directional I/O port. P2 – Port 2 (bit-addressable) 7 6 5 P2.7 P2.6 P2.5 r/w r/w r/w Address: A0H 4 P2.4 r/w 3 P2.3 r/w Bit Name Description 7:0 P2[7:0] Port 2. Port 2 is an 8-bit quasi bi-directional I/O port. It has an alternative function as A[15:8] while external memory accessing. During external Program Memory execution, SFR P2 cannot be accessed. - 33 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet P3 – Port 3 (bit-addressable) 7 6 5 P3.7 P3.6 P3.5 r/w r/w r/w Address: B0H Bit Name 7:0 P3[7:0] 4 P3.4 r/w 3 P3.3 r/w 2 P3.2 r/w 1 0 P3.1 P3.0 r/w r/w reset value: 1111 1111b 2 P4.2 r/w 1 0 P4.1 P4.0 r/w r/w reset value: 1111 1111b Description Port 3. Port 3 is an 8-bit quasi bi-directional I/O port. P4 – Port 4 (bit-addressable) 7 6 5 P4.7 P4.6 P4.5 r/w r/w r/w Address: D8H 4 P4.4 r/w 3 P4.3 r/w Bit Name Description 7:0 P4[7:0] Port 4. Port 4 is an 8-bit quasi bi-directional I/O port. It also possesses bit-addressable feature as P0~P3. Note that a full 8-bit P4 is just on LQPF-48 package. PLCC-44 and PQFP-44 just have low nibble 4 bits of P4. DIP-40 does not have this additional P4. - 34 - Publication Release Date: March 11, 2010 Revision: V2.0 10. TIMERS/COUNTERS N78E059A/N78E055A has three 16-bit programmable timers/counters. 10.1 Timer/Counters 0 and 1 Timer/Counter 0 and 1 on N78E059A/N78E055A are two 16-bit Timer/Counters. Each of them has two 8 bit registers which form the 16 bit counting register. For Timer/Counter 0 they are TH0, the upper 8 bits register, and TL0, the lower 8 bit register. Similarly Timer/Counter 1 has two 8 bit registers, TH1 and TL1. TCON and TMOD can configure modes of Timer/Counter 0 and 1. The Timer or Counter function is selected by the C/ T bit in TMOD. Each Timer/Counter has its own selection bit. TMOD.2 selects the function for Timer/Counter 0 and TMOD.6 selects the function for Timer/Counter 1 When configured as a “Timer”, the timer counts clock cycles. The timer clock is 1/6 of the peripheral clock (FPERIPH). In the “Counter” mode, the register increases on the falling edge of the external input pins T0 for Timer 0 and T1 for Timer 1. If the sampled value is high in one machine-cycle and low in the next, a valid 1 to 0 transition on the pin is recognized and the count register increases. In addition, each Timer/Counter can be set to operate in any one of four possible modes. Bits M0 and M1 in TMOD do the mode selection. TMOD – Timer 0 and 1 Mode 7 6 GATE C/ T r/w Address: 89H r/w 5 M1 4 M0 3 GATE 2 C/ T r/w r/w r/w r/w 1 M1 0 M0 r/w r/w reset value: 0000 0000b Bit Name Description 7 GATE 6 C/T Timer 1 Counter/Timer select. 0 = Timer 1 is incremented by internal peripheral clocks. 1 = Timer 1 is incremented by the falling edge of the external pin T1. 5 M1 4 M0 Timer 1 mode select. M1 M0 Timer 1 Mode 0 0 Mode 0: 8-bit Timer/Counter with 5-bit pre-scalar (TL1[4:0]) 0 1 Mode 1: 16-bit Timer/Counter 1 0 Mode 2: 8-bit Timer/Counter with auto-reload from TH1 1 1 Mode 3: Timer 1 halted Timer 1 gate control. 0 = Timer 1 will clock when TR1 = 1 regardless of INT1 logic level. 1 = Timer 1 will clock only when TR1 = 1 and INT1 is logic 1. - 35 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Bit Name 3 GATE Description Timer 0 gate control. 0 = Timer 0 will clock when TR0 = 1 regardless of INT0 logic level. 1 = Timer 0 will clock only when TR0 = 0 and INT0 is logic 1. 2 C/T Timer 0 Counter/Timer select. 0 = Timer 0 is incremented by internal peripheral clocks. 1 = Timer 0 is incremented by the falling edge of the external pin T0. 1 M1 0 M0 Timer 0 mode select. M1 M0 Timer 0 Mode 0 0 Mode 0: 8-bit Timer/Counter with 5-bit pre-scalar (TL0[4:0]) 0 1 Mode 1: 16-bit Timer/Counter 1 0 Mode 2: 8-bit Timer/Counter with auto-reload from TH0 1 1 Mode 3: TL0 as a 8-bit Timer/Counter and TH0 as a 8-bit Timer TCON – Timer 0 and 1 Control (bit-addressable) 7 6 5 4 TF1 TR1 TF0 TR0 r/w r/w r/w r/w Address: 88H 3 IE1 r/w 2 IT1 r/w 1 0 IE0 IT0 r/w r/w reset value: 0000 0000b Bit Name 7 TF1 Timer 1 overflow flag. This bit is set when Timer 1 overflows. It is automatically cleared by hardware when the program executes the Timer 1 interrupt service routine. Software can also set or clear this bit. 6 TR1 Timer 1 run control. 0 = Timer 1 is halted. Clearing this bit will halt Timer 1 and the current count will be preserved in TH1 and TL1. 1 = Timer 1 is enabled. 5 TF0 Timer 0 overflow flag. This bit is set when Timer 0 overflows. It is automatically cleared via hardware when the program executes the Timer 0 interrupt service routine. Software can also set or clear this bit. 4 TR0 Timer 0 run control. 0 = Timer 0 is halted. Clearing this bit will halt Timer 0 and the current count will be preserved in TH0 and TL0. 1 = Timer 0 is enabled. TL0 – Timer 0 Low Byte 7 6 Description 5 4 3 2 1 0 TL0[7:0] r/w Address: 8AH reset value: 0000 0000b Bit Name 7:0 TL0[7:0] Description Timer 0 low byte. The TL0 register is the low byte of the 16-bit Timer 0. - 36 - Publication Release Date: March 11, 2010 Revision: V2.0 TH0 – Timer 0 High Byte 7 6 5 4 3 2 1 0 TH0[7:0] r/w Address: 8CH reset value: 0000 0000b Bit Name 7:0 TH0[7:0] TL1 – Timer 1 Low Byte 7 6 Description Timer 0 high byte. The TH0 register is the high byte of the 16-bit Timer 0. 5 4 3 2 1 0 TL1[7:0] r/w Address: 8BH reset value: 0000 0000b Bit Name 7:0 TL1[7:0] TH1 – Timer 1 High Byte 7 6 Description Timer 1 low byte. The TL1 register is the low byte of the 16-bit Timer 1. 5 4 3 2 1 0 TH1[7:0] r/w Address: 8DH reset value: 0000 0000b Bit Name 7:0 TH1[7:0] Description Timer 1 high byte. The TH1 register is the high byte of the 16-bit Timer 1. 10.1.1 Mode 0 (13-bit Timer) In Mode 0, the Timer/Counter is a 13-bit counter. The 13-bit counter consists of THx and the five lower bits of TLx. The upper three bits of TLx are ignored. The Timer/Counter is enabled when TRx is set and either GATE is 0 or INTx is 1. Gate = 1 allows the Timer to calculate the pulse width on external input pin INTx . When the 13-bit value moves from 1FFFH to 0000H, the Timer overflow flag TFx is set and an interrupt occurs if enabled. Note that the peripheral clock is FOSC/2 in 12T mode and is FOSC in 6T mode. See Section 20. “CLOCK SYSTEM” on page 102. - 37 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet FPERIPH 1/6 C/T 0 1 T0 = P3.4 (T1 = P3.5) 0 TL0 (TL1) 4 7 TR0 (TR1) 0 GATE 7 TH0 (TH1) INT0 = P3.2 (INT1 = P3.3) TF0 (TF1) Timer Interrupt Figure 10–1. Timer/Counters 0 and 1 in Mode 0 10.1.2 Mode 1 (16-bit Timer) Mode 1 is similar to Mode 0 except that the counting registers are fully used as a 16-bit counter. Roll-over occurs when a count moves FFFFH to 0000H. The Timer overflow flag TFx of the relevant Timer/Counter is set and an interrupt will occurs if enabled. FPERIPH T0 = P3.4 (T1 = P3.5) 1/6 C/T TL0 (TL1) 0 1 0 7 0 7 TR0 (TR1) GATE TH0 (TH1) INT0 = P3.2 (INT1 = P3.3) TF0 (TF1) Timer Interrupt Figure 10–2. Timer/Counters 0 and 1 in Mode 1 10.1.3 Mode 2 (8-bit Auto-reload Timer) In Mode 2, the Timer/Counter is in auto-reload mode. In this mode, TLx acts as an 8-bit count register whereas THx holds the reload value. When the TLx register overflows from FFH to 00H, the TFx bit in TCON is set, TLx is reloaded with the contents of THx, and the counting process continues from here. The reload operation leaves the contents of the THx register unchanged. This feature is best suitable for UART baud rate generator for it runs without continuous software intervention. Note that only Timer1 can be the baud rate source for UART. Counting is enabled by the TRx bit and proper setting of GATE and INTx pins. The functions of GATE and INTx pins are just the same as Mode 0 and 1. - 38 - Publication Release Date: March 11, 2010 Revision: V2.0 FPERIPH 1/6 C/T TL0 (TL1) 0 0 1 T0 = P3.4 (T1 = P3.5) 7 TF0 (TF1) Timer Interrupt TR0 (TR1) GATE 0 INT0 = P3.2 (INT1 = P3.3) 7 TH0 (TH1) Figure 10–3. Timer/Counter 0 and 1 in Mode 2 10.1.4 Mode 3 (Two Separate 8-bit Timers) Mode 3 has different operating methods for the two Timer/Counters. For Timer/Counter 1, Mode 3 simply freezes the counter. Timer/Counter 0, however, configures TL0 and TH0 as two separate 8 bit count registers in this mode. TL0 uses the Timer/Counter 0 control bits C/ T , GATE, TR0, INT0 , and TF0. The TL0 also can be used as a 1-to-0 transition counter on pin T0 as determined by C/ T (TMOD.2). TH0 is forced as a clock cycle counter and takes over the usage of TR1 and TF1 from Timer/Counter 1. Mode 3 is used in case which an extra 8 bit timer is needed. If Timer/Counter 0 is configured in Mode 3, Timer/Counter 1 can be turned on or off by switching it out of or into its own Mode 3. It can still be used in Modes 0, 1 and 2 although its flexibility is restricted. It no longer has control over its overflow flag TF1 and the enable bit TR1. However Timer 1 can still be used as a Timer/Counter and retains the use of GATE and INT1 pin. It can be used as a baud rate generator for the serial port or other application not requiring an interrupt. FPERIPH T0 = P3.4 1/6 C/T TL0 0 1 0 7 TF0 Timer 0 Interrupt 7 TF1 Timer 1 Interrupt TR0 GATE INT0 = P3.2 TH0 TR1 0 Figure 10–4. Timer/Counter 0 in Mode 3 - 39 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet 10.2 Timer/Counter 2 Timer/Counter 2 is a 16-bit up counter, which is configured by the T2MOD and T2CON registers. The count stores in two 8-bit cascade registers TH2 and TL2. Timer/Counter 2 is additionally equipped with a capture or reload capability. It also can be configured as the baud rate generator for UART or a square wave generator. The features listed above could be achieved because of the addition Timer/Counter 2 capture registers RCAP2H and RCAP2L. As with the Timer 0 and Timer 1 counters, there exists considerable flexibility in selecting and controlling the clock and in defining the operating mode. The clock source for Timer/Counter 2 may be selected from either the external T2 pin ( C/ T2 (T2CON.1) = 1) or the crystal oscillator ( C/ T2 = 0). The clock is then enabled when TR2 (T2CON.2) is a 1, and disabled when TR2 is a 0. The following registers are related to Timer/Counters 2 function. T2CON – Timer 2 Control (bit-addressable) 7 6 5 4 TF2 EXF2 RCLK TCLK r/w r/w r/w r/w Address: C8H 3 EXEN2 r/w 2 TR2 r/w 1 C/ T2 CP/RL2 r/w r/w reset value: 0000 0000b Bit Name Description 7 TF2 Timer 2 overflow flag. This bit is set when Timer 2 overflows. If the Timer 2 interrupt and the global interrupt are enable, setting this bit will make CPU execute Timer 2 interrupt service routine. This bit is not automatically cleared via hardware and must be cleared via software. TF2 will not be set while Timer 2 is configured in the baud rate generator or clockout mode. 6 EXF2 Timer 2 external flag. This bit is set via hardware when a 1-to-0 transition on the T2EX input pin occurs and EXEN2 is logic 1. When the Timer 2 interrupt is enabled, setting this bit causes the CPU to execute the Timer 2 Interrupt service routine. This bit is not automatically cleared via hardware and must be cleared via software. 5 RCLK Receive clock flag. This bit selects which Timer is used for the UART‟s receive clock in serial Mode 1 or 3. 0 = Timer 1 overflows is used for UART receive baud rate clock. 1 = Timer 2 overflows is used for UART receive baud rate clock. 4 TCLK Transmit clock flag. This bit selects which Timer is used for the UART‟s transmit clock in serial Mode 1 or 3. 0 = Timer 1 overflows is used for UART transmit baud rate clock. 1 = Timer 2 overflows is used for UART transmit baud rate clock. - 40 - 0 Publication Release Date: March 11, 2010 Revision: V2.0 Bit Name Description 3 EXEN2 Timer 2 external enable. This bit enables 1-to-0 transitions on T2EX trigger. 0 = 1-to-0 transitions on T2EX is ignored. 1 = 1-to-0 transitions on T2EX will set EXF2 logic 1. If Timer 2 is configured in capture or auto-reload mode, the 1-to-0 transitions on T2EX will cause capture or reload event. 2 TR2 Timer 2 run control. 0 = Timer 2 is halted. Clearing this bit will halt Timer 2 and the current count will be preserved in TH2 and TL2. 1 = Timer 2 is enabled. 1 C/T2 Timer 2 Counter/Timer select. 0 = Timer 2 is incremented by internal peripheral clocks. 1 = Timer 2 is incremented by the falling edge of the external pin T2. If Timer 2 would like to be set in clock-out mode, C/T2 must be 0. 0 CP/RL2 Timer 2 Capture or Reload select. This bit selects whether Timer 2 functions in capture or auto-reload mode. EXEN2 must be logic 1 for 1-to-0 transitions on T2EX to be recognized and used to trigger captures or reloads. If RCLK or TCLK is set, this bit is ignored and Timer 2 will function in auto-reload mode. 0 = Auto-reload on Timer 2 overflow or 1-to-0 transition on T2EX pin. 1 = Capture on 1-to-0 transition at T2EX pin. T2MOD – Timer 2 Mode 7 6 Address: C9H Bit Name 7:2 - 1 T2OE 0 - 5 - 4 - 3 - 2 - 1 0 T2OE r/w reset value: 0000 0000b Description Reserved. Timer 2 clock-out enable. 0 = Disable Timer 2 clock-out function. T2 pin functions either as a standard port pin or as a counter input for Timer 2. 1 = Enable Timer 2 clock-out function. Timer 2 will drive T2 pin with a clock output if C/T2 is 0. Reserved. RCAP2L – Timer 2 Reload/Capture Low Byte 7 6 5 4 3 RCAP2L[7:0] r/w Address: CAH 2 1 reset value: 0000 0000b Bit Name Description 7:0 RCAP2L[7:0] Timer 2 reload/capture low byte. This register captures and stores the low byte of Timer 2 when Timer 2 is configured in capture mode. When Timer 2 is in auto-reload mode, baud rate generator mode, or clock-out mode, it holds the low byte of the reload value. - 41 - 0 Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet RCAP2H – Timer 2 Reload/Capture High Byte 7 6 5 4 3 RCAP2H[7:0] r/w Address: CBH 2 1 reset value: 0000 0000b Bit Name Description 7:0 RCAP2H[7:0] Timer 2 reload/capture high byte. This register captures and stores the high byte of Timer 2 when Timer 2 is configured in capture mode. When Timer 2 is in auto-reload mode, baud rate generator mode, or clock-out mode, it holds the high byte of the reload value. TL2 – Timer 2 Low Byte 7 6 5 4 0 3 2 1 0 TL2[7:0] r/w Address: CCH reset value: 0000 0000b Bit Name 7:0 TL2[7:0] TH2 – Timer 2 High Byte 7 6 Description Timer 2 low byte. The TL2 register is the low byte of the 16-bit Timer 2. 5 4 3 2 1 0 TH2[7:0] r/w Address: CDH reset value: 0000 0000b Bit Name 7:0 TH2[7:0] Description Timer 2 high byte. The TH2 register is the high byte of the 16-bit Timer 2. Timer/Counter 2 provides four operating mode which can be selected by control bits in T2CON and T2MOD as shown in table below. Note that the TH2 and TL2 are accessed separately. It is strongly recommended that the user stop Timer 2 temporally for a reading from or writing to TH2 and TL2. The free-running reading or writing may cause unpredictable situation. - 42 - Publication Release Date: March 11, 2010 Revision: V2.0 Table 10–1. Timer 2 Operating Modes RCLK (T2CON.5) or TCLK (T2CON.4) CP/RL2 (T2CON.0) T2OE (T2MOD.1) 16-bit capture 0 1 X 16-bit auto-reload 0 0 0 Baud rate generator 1 X 0 [2] X 0 1 Timer 2 Mode [1] Clock-out [1] The capture is valid while EXEN2 (T2CON.3) is a 1. Or Timer/Counter 2 behaves just like a 16-bit timer/counter. [2] C/T2 (T2CON.1) must be 0. 10.2.1 Capture Mode The capture mode is enabled by setting the CP/RL2 bit in the T2CON register to 1. In the capture mode, Timer/Counter 2 serves as a 16 bit up counter. When the counter rolls over from FFFFH to 0000H, the TF2 bit is set, which will generate an Timer 2 interrupt request. If the EXEN2 bit is set, then a negative transition of T2EX pin (alternative function of P1.1) will cause the value in the TL2 and TH2 register to be captured by the RCAP2L and RCAP2H registers. The TH2 and TL2 keeps on counting while this capture event occurs. This capture action also causes the EXF2 (T2CON.6) bit set, which will also generate an Timer 2 interrupt. If Timer 2 interrupt enabled, both TF2 and EXF2 flags will generate interrupt vectoring to the same location. The user should check which one triggers the Timer 2 interrupt in the interrupt service routine. FPERIPH T2 = P1.0 1/6 C/T2 TL2 0 1 TH2 0 7 0 7 0 7 0 7 TF2 TR2 Timer 2 Interrupt T2EX = P1.1 RCAP2L RCAP2H EXF2 EXEN2 Figure 10–5. Timer/Counter 2 in Capture Mode 10.2.2 Auto-reload Mode The auto-reload mode is enabled by clearing the CP/RL2 bit in the T2CON register. In this mode, Timer/Counter 2 is a 16 bit up counter. When the counter rolls over from FFFFH, TF2 (T2CON.7) is set as 1 and a reload is generated that causes the contents of the RCAP2L and RCAP2H registers to be reloaded into the TL2 and TH2 registers respectively. If the EXEN2 bit is set, then a negative transition on T2EX pin will also cause a reload. This action also sets the EXF2 bit in T2CON. - 43 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet FPERIPH T2 = P1.0 1/6 C/T2 TL2 0 1 TH2 0 7 0 7 0 7 0 7 TF2 TR2 RCAP2L T2EX = P1.1 Timer 2 Interrupt RCAP2H EXF2 EXEN2 Figure 10–6. Timer/Counter 2 in Auto-reload Mode 10.2.3 Baud Rate Generator Mode The Timer 2 can generate the baud rate for UART in its Mode 1 and 3. The baud rate generator mode is enabled by setting either the RCLK or TCLK bits in T2CON register. While in the baud rate generator mode, Timer/Counter 2 is a 16 bit counter with auto-reload when the count rolls over from FFFFH. However, rolling over is used to generate the shift clock for UART data rather than to set the TF2 bit. If EXEN2 bit is set, then a negative transition of the T2EX pin will set EXF2 bit in the T2CON register and cause an interrupt request. It simply provides a external interrupt. Note that TCLK and RCLK are selected individually, the serial port transmit rate can be different from the receive rate. For example the transmit clock can be generated from Timer 2 by setting TCLK and the receive clock from Timer 1 by clearing RCLK. Timer 1 Overflow 1/2 FPERIPH T2 = P1.0 C/T2 TL2 0 1 Timer 2 Overflow TH2 7 0 0 7 TR2 0 RCLK 1 0 1 SMOD (PCON.7) 1/16 Rx clock 1/16 Tx clock TCLK 0 7 0 RCAP2L 7 1 0 RCAP2H T2EX = P1.1 EXEN2 EXF2 Timer 2 Interrupt Figure 10–7. Timer/Counter 2 in Baud Rate Generator Mode - 44 - Publication Release Date: March 11, 2010 Revision: V2.0 10.2.4 Clock-out Mode Timer 2 is equipped with a clock-out feature, which outputs a 50% duty cycle clock on P1.0. It can be invoked as a programmable clock generator. To configure Timer 2 with clock-out mode, software must initiate it by setting bit T2OE (TMOD.1) = 1, C/ T2 = 0 and CP/RL2 = 0. Setting bit TR2 will start the clock output. This mode is similar to the baud rate generator mode which does not generate an interrupt while Timer 2 overflow. Similar with the baud rate generator mode, T2EX can also be configured as a simple external interrupt. The clock-out frequency follows the equation FOSC 22 EN6T  65536  RCAP2H,RCAP2L  . In this formula, EN6T is bit 6 of CONFIG3. While EN6T = 0, the clock system runs under 6T mode and the clock-out frequency will be double of that in 12T mode. (RCAP2H,RCAP2L) in the formula means 256  RCAP2H  RCAP2L . FPERIPH TL2 TH2 7 0 0 7 1/2 T2 = P1.0 TR2 0 7 0 RCAP2L 7 RCAP2H T2EX = P1.1 EXEN2 EXF2 Timer 2 Interrupt Figure 10–8. Timer/Counter 2 in Clock-out Mode - 45 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet 11. WATCHDOG TIMER 11.1 Function Description of Watchdog Timer N78E059A/N78E055A provides one Watchdog Timer to serve as a system monitor, which improve the reliability of the system. Watchdog Timer is useful for systems that are susceptible to noise, power glitches, or electrostatic discharge. The Watchdog Timer is basic a setting of dividers that divide the peripheral clock. The divider output is selectable and determines the time-out interval. When the time-out interval is fulfilled, a direct system reset will occur. 10kHz Internal RC Clock Divider WDT counter (6-bit) overflow WDTRF Watchdog Timer Reset clear IDL (PCON.0) PD (PCON.1) WIDPD FLOSC WPS[2:0] WDCLR WDTEN Figure 11–1. Watchdog Timer Block Diagram The Watchdog Timer should first be reset 00H by using WDCLR(WDCON.6) to ensure that the timer starts from a known state. The WDCLR bit is used to reset the Watchdog Timer. This bit is self-cleared thus the user doesn‟t need to clear it. After writing a 1 to WDCLR, the hardware will automatically clear it. After WDTEN set as 1, the Watchdog Timer starts counting. The time-out interval is selected by the three bits WPS2, WPS1, and WPS0 (WDCON[2:0]). When the selected time-out occurs, the Watchdog Timer will reset the system directly. Once a reset due to Watchdog Timer occurs, the Watchdog Timer reset flag WDTRF (WDCON.3) will be set. This bit keeps unchanged after any reset other than a power-on reset. The user may clear WDTRF via software. In general, software should restart the counter to put it into a known state by setting WDCLR. The Watchdog Timer also provides an WIDPD bit (WDCON.4) to allow the Watchdog Timer continuing running after the system enters into Idle or Power Down operating mode. WDT counter should be specially taken care. The hardware automatically clears WDT counter after entering into or being woken-up from Idle or Power Down mode. It prevents unconscious system reset. - 46 - Publication Release Date: March 11, 2010 Revision: V2.0 CONFIG3 7 CWDTEN r/w 6 EN6T r/w Bit Name 7 CWDTEN 5 ROG r/w 4 CKF r/w 3 INTOSCFS r/w 2 1 0 FOSC r/w unprogrammed value: 1111 1111b Description CONFIG Watchdog Timer enable. 1 = Disable Watchdog Timer after all resets. 0 = Enable Watchdog Timer after all resets. WDCON – Watchdog Timer Control (TA protected) 7 6 5 4 3 2 1 0 WDTEN[1] WDCLR WIDPD[2] WDTRF[3] WPS2[2] WPS1[2] WPS0[2] r/w w r/w r/w r/w r/w r/w Address: AAH reset value: see Table 6–2. N78E059A/N78E055A SFR Descriptions and Reset Values Bit Name Description 7 WDTEN Watchdog Timer enable. 0 = Disable Watchdog Timer. 1 = Enable Watchdog Timer. The WDT counter starts running. 6 WDCLR Watchdog Timer clear. Setting this bit will reset the Watchdog Timer count to 00H. It puts the counter in a known state and prohibit the system from reset. Note that this bit is written-only and has no need to be cleared via software. 5 - 4 WIDPD Watchdog Timer running in Idle and Power Down mode. This bit decides whether Watchdog Timer runs in Idle or Power Down mode. 0 = WDT counter is halted while CPU is in Idle or Power Down mode. 1 = WDT keeps running while CPU is in Idle or Power Down mode. 3 WDTRF Watchdog Timer reset flag. When the CPU is reset by Watchdog Timer time-out event, this bit will be set via hardware. This flag is recommended to be cleared via software. 2 WPS2 1 WPS1 Watchdog Timer clock pre-scalar select. These bits determine the scale of the clock divider for WDT counter. The scale is from 1/1 through 1/256. See Table 11–1. Reserved. 0 WPS0 [1] WDTEN is initialized by the inversed value of CWDTEN (CONFIG3.7) after all resets. [2] WIDPD and WPS[2:0] are cleared after power-on reset, and keep unchanged after any other resets. [3] WDTRF will be cleared after power-on reset, be set after Watchdog Timer reset, and remains unchanged after any other resets. The Watchdog time-out interval is determined by the formula 1  64 . Where FILRC is FLOSC  clock dividerscalar the frequency of internal 10kHz RC. The following table shows an example of the Watchdog time-out interval under different FWCK and pre-scalars. - 47 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Table 11–1. Watchdog Timer-Out Interval under different pre-scalars WPS2 WPS1 WPS0 Clock Divider Scale Typical Watchdog Time-out Interval (FILRC ~= 10kHz) 0 0 0 1/1 6.40ms 0 0 1 1/2 12.80ms 0 1 0 1/8 51.20ms 0 1 1 1/16 102.40ms 1 0 0 1/32 204.80ms 1 0 1 1/64 409.60ms 1 1 0 1/128 819.20ms 1 1 1 1/256 1.638s 11.2 Applications of Watchdog Timer The main application of the Watchdog Timer is for the system monitor. This is important in real-time control applications. In case of some power glitches or electro-magnetic interference, the processor may begin to execute erroneous codes and operate in an unpredictable state. If this is left unchecked the entire system may crash. Using the Watchdog Timer during software development will require the user to select ideal watchdog reset locations for inserting instructions to reset the Watchdog Timer. By inserting the instruction setting WDCLR, it will allow the code to run without any Watchdog Timer reset. However If any erroneous code executes by any power of other interference, the instructions to clear the Watchdog Timer counter will not be executed at the required instants. Thus the Watchdog Timer reset will occur to reset the system start from an erroneously executing condition. The user should remember that WDCON requires a timed access writing. - 48 - Publication Release Date: March 11, 2010 Revision: V2.0 12. POWER DOWN WAKING-UP TIMER 12.1 Function Description of Power Down Waking-up Timer N78E059A/N78E055A provides another free-running Timer, Power Down waking-up timer which serves as a event timer or a durational system supervisor in a monitoring system which generally operates in Idle or Power Down modes. It is basic a setting of dividers that divide the peripheral clock. The divider output is selectable and determines the time-out interval. When the time-out interval is fulfilled, it will wake the system up from Idle or Power Down mode and an interrupt event will occur. 10kHz Internal RC FLOSC Clock Divider PDT counter (6-bit) overflow clear PDTEN PPS[2:0] Power Down wakingup timer interrupt PDTF EPDT PCLR Figure 12–1. Power Down Waking-up Timer Block Diagram The Power Down waking-up timer should first be reset 00H by using PDCLR(PDCON.6) to ensure that the timer starts from a known state. The PDCLR bit is used to restart the Power Down waking-up timer. This bit is self-cleared thus the user doesn‟t need to clear it. After writing a 1 to PDCLR, the hardware will automatically clear it. After PDTEN set as 1, the Power Down waking-up timer will start counting clock cycles. The time-out interval is selected by the three bits PPS2, PPS1, and PPS0 (PDCON[2:0]). When the selected time-out occurs, the Power Down waking-up timer will set the interrupt flag PDTF (PDCON.5). The Power Down wakingup timer interrupt enable bit locates at bit 1 in EIE. In general, software should restart the counter to put it into a known state by setting WDCLR. PDCON – Power Down Waking-up Timer Control 7 6 5 4 PDTEN PDCLR PDTF r/w w r/w Address: ABH 3 - 2 PPS2 r/w 1 0 PPS1 PPS0 r/w r/w reset value: 0000 0000b Bit Name Description 7 PDTEN Power Down waking-up timer enable. 0 = Disable Power Down waking-up timer. 1 = Enable Power Down waking-up timer. The PDT counter starts running. 6 PDCLR Power Down waking-up timer clear. Setting this bit will reset the Power Down waking-up timer count to 00H. It put the counter in a known state. This bit is written-only and has no need to be cleared via software. - 49 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Bit Name 5 PDTF 4:3 - 2 PPS2 1 PPS1 0 PPS0 Description Power Down waking-up timer Interrupt Flag. This bit will be set via hardware when PDT counter overflows. This bit must be cleared via software. Reserved. Power Down waking-up timer clock pre-scalar select. These bits determine the scale of the clock divider for PDT counter. The scale is from 1/1 through 1/1024. See Table 12–1. The Power Down waking-up time-out interval is determined by the formula 1  64 FLOSC  clock dividerscalar where FILRC is the frequency of internal 10kHz RC. The following table shows an example of the Power Down waking-up time-out interval under different pre-scalars. Table 12–1. Power Down Waking-up Timer-Out Interval under different pre-scalars Clock Divider Scale Typical Power Down Waking-up Time-out Interval (FILRC ~= 10kHz) PPS2 PPS1 PPS0 0 0 0 1/1 6.40ms 0 0 1 1/4 25.60ms 0 1 0 1/8 51.20ms 0 1 1 1/32 204.80ms 1 0 0 1/64 409.60ms 1 0 1 1/256 1.638s 1 1 0 1/512 3.277s 1 1 1 1/1024 6.554s 12.2 Applications of Power Down Waking-up Timer The main application of the Power Down waking-up timer is a simple timer. The PDTF flag will be set while the Power Down waking-up timer completes the selected time interval. The software polls the PDTF flag to detect a time-out and the PDCLR allows software to restart the timer. The Power Down waking-up timer can also be used as a very long timer. Every time the time-out occurs, an interrupt will occur if the individual interrupt EPDT (EIE.1) and global interrupt enable EA is set. In some application of low power consumption, the CPU usually stays in Idle mode when nothing needs to be served to save power consumption. After a while the CPU will be woken up to check if anything needs to be served at an interval of programmed period implemented by Timer 0, 1 or 2. However, the current consumption - 50 - Publication Release Date: March 11, 2010 Revision: V2.0 of Idle mode still keeps at a “mA” level. To further reducing the current consumption to “μA” level, the CPU should stay in Power Down mode when nothing needs to be served, and has the ability of waking up at a programmable interval. N78E059A/N78E055A is equipped with this useful function. It provides a very low power internal RC 10kHz. Along with the low power consumption application, the Power Down Waking-up timer needs to count under Idle and Power Down mode and wake CPU up from Idle or Power Down mode. The demo code to accomplish this feature is shown below. The demo code of Power Down waking-up timer waking up CPU from Power Down. ORG LJMP 0000H START ORG LJMP 004BH PDT_ISR ORG PDT_ISR: ORL ANL RETI 0100H PDCON,#01000000B PDCON,#11011111B ;Clear Power Down Waking-up timer counter ;Clear Power Down Waking-up timer interrupt flag PDCON,#00000111B EIE,#00000010B EA PDCON,#10000000B ;Choose interval length ;Enable Power Down Waking-up timer interrupt START: ORL ORL SETB ORL ;Enable Power Down Waking-up timer to run ;******************************************************************** ;Enter into Power Down mode ;******************************************************************** LOOP: ORL PCON,#02H LJMP LOOP - 51 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet 13. SERIAL PORT N78E059A/N78E055A includes one enhanced full duplex serial port. The serial port supports three modes of full duplex UART (Universal Asynchronous Receiver and Transmitter) in Mode 1, 2, and 3. This means it can transmit and receive simultaneously. The serial port is also receive-buffered, meaning it can commence reception of a second byte before a previously received byte has been read from the register. The serial port receive and transmit registers are both accessed at SBUF. Writing to SBUF loads the transmit register, and reading SBUF accesses a physically separate receive register. There are four operation modes in serial port. In all four modes, transmission initiates by any instruction that uses SBUF as a destination register. Note that before serial port function works, the port latch bits of P3.0 and P3.1 (for RXT and TXD pins) have to be set to 1. SCON – Serial Port Control (bit-addressable) 7 6 5 4 SM0 SM1 SM2 REN r/w r/w r/w r/w Address: 98H Bit Name 7 SM0 6 SM1 5 SM2 3 TB8 r/w 2 RB8 r/w 1 0 TI RI r/w r/w reset value: 0000 0000b Description Serial port mode select. See Table 13–1. Serial Port Mode Description for details. Multiprocessor communication mode enable. The function of this bit is dependent on the serial port mode. Mode 0: This bit has no effect. Mode 1: This bit checks valid stop bit. 0 = Reception is always valid no matter the logic level of stop bit. 1 = Reception is ignored if the received stop bit is not logic 1. Mode 2 or 3: For multiprocessor communication. th 0 = Reception is always valid no matter the logic level of the 9 bit. th 1 = Reception is ignored if the received 9 bit is not logic 1. 4 REN Receive enable. 0 = Disable serial port reception. 1 = Enable serial port reception in Mode 1,2, and 3. In Mode 0, clearing and then setting REN initiates one-byte reception. After reception is complete, this bit will not be cleared via hardware. The user should clear and set REN again via software to triggering the next byte reception. 3 TB8 9 transmit bit. th This bit defines the state of the 9 transmission bit in serial port Mode 2 and 3. It is not used in Mode0 and 1. th - 52 - Publication Release Date: March 11, 2010 Revision: V2.0 Bit Name Description th 2 RB8 9 receive bit. th The bit identifies the logic level of the 9 received bit in Modes 2 and 3. In Mode 1, if SM2 0, RB8 is the logic level of the received stop bit. RB8 is not used in Mode 0. 1 TI Transmission interrupt flag. This flag is set via hardware when a byte of data has been transmitted by the th UART after the 8 bit in Mode 0 or the last bit of data in other modes. When the UART interrupt is enabled, setting this bit causes the CPU to execute the UART interrupt service routine. This bit must be cleared manually via software. 0 RI Receiving interrupt flag. This flag is set via hardware when a 8-bit or 9-bit data has been received by the th UART after the 8 bit in Mode 0, after sampling the stop bit in Mode 1, or after th sampling the 9 bit in Mode 2 and 3. SM2 bit has restriction for exception. When the UART interrupt is enabled, setting this bit causes the CPU to execute to the UART interrupt service routine. This bit must be cleared manually via software. Table 13–1. Serial Port Mode Description Mode SM0 SM1 Description Data Bits Baud Rate 0 0 0 Synchronous 8 FOSC divided by 12 for 12T mode, by 6 for 6T mode 1 0 1 Asynchronous 10 Timer 1 overflow rate divided by 16 or divided by 32 , or Timer 2 overflow rate divided by 16 2 1 0 Asynchronous 11 FOSC divided by 32 or 64 [1] [1] for 12T mode, by 16 or 32 [1] for 6T mode [1] 3 1 1 Asynchronous 11 Timer 1 overflow rate divided by 16 or divided by 32 , or Timer 2 overflow rate divided by 16 [1] While SMOD (PCON.7) is logic 0. PCON – Power Control 7 6 5 4 3 2 1 0 SMOD POF GF1 GF0 PD IDL r/w r/w r/w r/w r/w r/w Address: 87H reset value: see Table 6–2. N78E059A/N78E055A SFR Descriptions and Reset Values Bit Name Description 7 SMOD Serial port double baud rate enable. Setting this bit doubles the serial port baud rate in UART mode 2 and mode 1 or 3 only if Timer 1 overflow is used as the baud rate source. See Table 13–1. Serial Port Mode Description in details. - 53 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet SBUF – Serial Data Buffer 7 6 5 4 3 2 1 0 SBUF[7:0] r/w Address: 99H reset value: 0000 0000b Bit Name Description 7:0 SBUF[7:0] Serial data buffer. This byte actually consists two separate registers. One is the receive resister, and the other is the transmit buffer. When data is moved to SBUF, it goes to the transmit buffer and is shifted for serial transmission. When data is moved from SBUF, it comes from the receive buffer. The transmission is initiated through moving a byte to SBUF. 13.1 Mode 0 Mode 0 provides synchronous communication with external devices. Serial data enters and exits through RXD pin. TXD outputs the shift clock. 8 bits are transmitted or received. Mode 0 therefore provides half-duplex communication because the transmitting or receiving data is via the same data line RXD. The baud rate is fixed at 1/12 the oscillator frequency in 12T Mode or 1/6 the oscillator frequency in 6T Mode. Note that whenever transmitting or receiving, the serial clock is always generated by the microcontroller. Thus any device on the serial port in Mode 0 must accept the microcontroller as the Master. Figure 13–1 shows a simplified functional diagram of the serial port in Mode 0 and associated timing. Note that the peripheral clock is FOSC/2 in 12T mode and is FOSC in 6T mode. See Section 20. “CLOCK SYSTEM” on page 102. - 54 - Publication Release Date: March 11, 2010 Revision: V2.0 Figure 13–1. Serial Port Mode 0 Function Block and Timing Diagram - 55 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet As shown there is one bi-direction data line (RXD) and one shift clock line (TXD). The shift clock is used to shift data in or out of the serial port controller bit by bit for a serial communication. Data bits enter or exit LSB first. The band rate is equal to the shift clock frequency. Transmission is initiated by any instruction writes to SBUF. The control block will then shift out the clock and begin to transfer data until all 8 bits are complete. Then the transmitted flag TI (SCON.1) will be set 1 to indicate one byte transmitting complete. Reception is initiated by the condition REN (SCON.4) = 1 and RI (SCON.0) = 0. This condition tells the serial port controller that there is data to be shifted in. This process will continue until 8 bits have been received. Then the received flag RI will be set as 1. The user can clear RI to trigger the next byte reception. 13.2 Mode 1 Mode 1 supports asynchronous, full duplex serial communication. The asynchronous mode is commonly used for communication with PCs, modems or other similar interfaces. In Mode 1, 10 bits are transmitted (through TXD) or received (through RXD) including a start bit (logic 0), 8 data bits (LSB first) and a stop bit (logic 1). The baud rate is determined by the Timer 1 or Timer 2 overflow rate according to RCLK and TCLK bits in T2CON. SMOD (PCON.7) setting 1 makes the baud rate double while Timer 1 is selected as the clock source. Figure 13–2 shows a simplified functional diagram of the serial port in Mode 1 and associated timings for transmit and receive. - 56 - Publication Release Date: March 11, 2010 Revision: V2.0 Figure 13–2. Serial Port Mode 1 Function Block and Timing Diagram - 57 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Transmission is initiated by any writing instructions to SBUF. Transmission takes place on TXD pin. First the start bit comes out, the 8-bit data follows to be shifted out and then ends with a stop bit. After the stop bit appears, TI (SCON.1) will be set to indicate one byte transmission complete. All bits are shifted out depending on the rate determined by the baud rate generator. Once the baud rate generator is activated and REN (SCON.4) is 1, the reception can begin at any time. Reception is initiated by a detected 1-to-0 transition at RXD. Data will be sampled and shifted in at the selected baud rate. In the midst of the stop bit, certain conditions must be met to load SBUF with the received data: 1. RI (SCON.0) = 0, and 2. Either SM2 (SCON.5) = 0, or the received stop bit = 1 while SM2 = 1. If these conditions are met, then the SBUF will be loaded with the received data, the RB8 (SCON.2) with stop bit, and RI will be set. If these conditions fail, there will be no data loaded and RI will remain 0. After above receiving progress, the serial control will look forward another 1-0 transition on RXD pin in order to start next data reception. 13.3 Mode 2 Mode 2 supports asynchronous, full duplex serial communication. Different from Mode1, there are 11 bits to be th transmitted or received. They are a start bit (logic 0), 8 data bits (LSB first), a programmable 9 bit TB8 or RB8 th bit and a stop bit (logic 1). The most common use of 9 bit is to put the parity bit in it. The baud rate is fixed as 1/32 or 1/64 the oscillator frequency depending on SMOD bit. (This is under 12T mode. Under 6T mode, the baud rate will be 1/16 or 1/32 the oscillator frequency.) Figure 13–3 shows a simplified functional diagram of the serial port in Mode 2 and associated timings for transmit and receive. - 58 - Publication Release Date: March 11, 2010 Revision: V2.0 Figure 13–3. Serial Port Mode 2 Function Block and Timing Diagram - 59 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Transmission is initiated by any writing instructions to SBUF. Transmission takes place on TXD pin. First the start bit comes out, the 8-bit data and bit TB8 (SCON.3) follows to be shifted out and then ends with a stop bit. After the stop bit appears, TI will be set to indicate the transmission complete. While REN is set, the reception is allowed at any time. A falling edge of a start bit on RXD will initiate the reth ception progress. Data will be sampled and shifted in at the selected baud rate. In the midst of the 9 bit, certain conditions must be met to load SBUF with the received data: 1. RI (SCON.0) = 0, and th 2. Either SM2(SCON.5) = 0, or the received 9 bit = 1 while SM2 = 1. If these conditions are met, then the SBUF will be loaded with the received data, the RB8(SCON.2) with TB8 bit and RI will be set. If these conditions fail, there will be no data loaded and RI will remain 0. After above receiving progress, the serial control will look forward another 1-0 transition on RXD pin in order to start next data reception. 13.4 Mode 3 Mode 3 has the same operation as Mode 2, except its baud rate clock source. As shown is Figure 13–4, Mode 3 uses Timer 1 or Timer 2 overflow as its baud rate clock. - 60 - Publication Release Date: March 11, 2010 Revision: V2.0 Figure 13–4. Serial Port Mode 3 Function Block and Timing Diagram - 61 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet 13.5 Baud Rate Table 13–2. UART Baud Rate Formulas UART mode EN6T (CONFIG3.6) value Baud rate clock source 1 (12T mode) 0 (6T mode) 0 Oscillator FOSC / 12 FOSC / 6 2 Oscillator 2SMOD  FOSC 64 2SMOD  FOSC 32 2SMOD FOSC  32 12  256  TH1 2SMOD FOSC  16 12  256  TH1 FOSC [3] 32  65536  RCAP2H,RCAP2L  FOSC 16  65536  RCAP2H,RCAP2L  [1] Timer/Counter 1 overflow 1 or 3 [2] Timer/Counter 2 overflow [1] Timer 1 is configured as a timer in auto-reload mode (Mode 2). [2] Timer 2 is configured as a timer in baud rate generator mode. [3] (RCAP2H,RCAP2L) in the formula means 256  RCAP2H  RCAP2L . Note that in using Timer 1 as the baud rate generator, the interrupt should be disabled. In using Timer 2, the interrupt is automatically switched off. The Timer itself can be configured for either “Timer” or “Counter” operation. And Timer 1 can be in any of its 3 running modes. In the most typical applications, it is configured for “Timer” operation, in the auto-reload mode (Mode2). If Timer 1 is used as the baud rate generator, the reloaded value is stored in TH1. Therefore the baud rate is determined by TH1 value. If Timer 2 is used, the user should configure it in baud rate generator mode (RCLK or TCLK in T2CON is logic 1) and give 16-bit reloaded value in RCAP2H and RCAP2L. Table 13–3 lists various commonly used baud rates and how they can be obtained from Timer 1. In this mode, Timer 1 as an auto-reload Timer operates in 12T mode and SMOD (PCON.7) is 0. Table 13–4 is for Timer 2 as the baud rate generator. Timer 2 operates in baud rate generator mode in 12T mode. In 6T mode, the baud rate generated from both Timer 1 and Timer 2 overflows will be doubled. Table 13–3. Timer 1 Generated Commonly Used Baud Rates Oscillator Frequency (MHz) TH1 reload value 11.0592 14.7456 18.432 22.1184 36.864 Baud Rate 57600 FFh 38400 FFh 19200 FEh FDh - 62 - FBh Publication Release Date: March 11, 2010 Revision: V2.0 Oscillator Frequency (MHz) TH1 reload value 11.0592 14.7456 18.432 22.1184 36.864 Baud Rate 9600 FDh FCh FBh FAh F6h 4800 FAh F8h F6h F4h ECh 2400 F4h F0h ECh E8h D8h 1200 E8h E0h D8h D0h B0h 300 A0h 80h 60h 40h Table 13–4. Timer 2 Generated Commonly Used Baud Rates RCAP2H, RCAP2L reload value Oscillator Frequency (MHz) 11.0592 14.7456 18.432 22.1184 36.864 Baud Rate 115200 FFh, FDh FFh, FCh FFh, FBh FFh, FAh FFh, F6h 57600 FFh, FAh FFh, F8h FFh, F6h FFh, F4h FFh, ECh 38400 FFh, F7h FFh, F4h FFh, F1h FFh, EEh FFh, E2h 19200 FFh, EEh FFh, E8h FFh, E2h FFh, DCh FFh, C4h 9600 FFh, DCh FFh, D0h FFh, C4h FFh, B8h FFh, 88h 4800 FFh, B8h FFh, A0h FFh, 88h FFh, 70h FFh, 10h 2400 FFh, 70h FFh, 40h FFh, 10h FEh, E0h FEh, 20h 1200 FEh, E0h FEh, 80h FEh, 20h FDh, C0h FCh, 40h 300 FBh, 80h FAh, 00h F8h, 80h F7h, 00h F1h, 00h 13.6 Multiprocessor Communication N78E059A/N78E055A multiprocessor communication feature of UART lets a Master device send a multiple frame serial message to a Slave device in a multi-slave configuration. It does this without interrupting other slave devices that may be on the same serial line. This feature can be used only in UART mode 2 or 3 mode. th After 9 data bits are received. The 9 bit value is written to RB8 (SCON.2). The user can enable this function by setting SM2 (SCON.5) as a logic 1 so that when the stop bit is received, the serial interrupt will be generatth ed only if RB8 is 1. When the SM2 bit is 1, serial data frames that are received with the 9 bit as 0 do not genth erate an interrupt. In this case, the 9 bit simply separates the address from the serial data. When the Master device wants to transmit a block of data to one of several slaves on a serial line, it first sends out an address byte to identify the target slave. Note that in this case, an address byte differs from a data byte: th In an address byte, the 9 bit is 1 and in a data byte, it is 0. The address byte interrupts all slaves so that each slave can examine the received byte and see if it is being addressed. The addressed slave then clears its SM2 - 63 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet bit and prepares to receive incoming data bytes. The SM2 bits of slaves that were not addressed remain set, and they continue operating normally while ignoring the incoming data bytes. Follow these steps to configure multiprocessor communications: 1. Set all devices (Masters and Slaves) to UART mode 2 or 3. 2. Write the SM2 bit of all the Slave devices to 1. 3. The Master device‟s transmission protocol is: th – First byte: the address, identifying the target slave device, (9 bit = 1). th – Next bytes: data, (9 bit = 0). th 4. When the target Slave receives the first byte, all of the Slaves are interrupted because the 9 data bit is 1. The targeted Slave compares the address byte to its own address and then clears its SM2 bit in order to receive incoming data. The other slaves continue operating normally. 5. After all data bytes have been received, set SM2 back to 1 to wait for next address. SM2 has no effect in Mode 0, and in Mode 1 can be used to check the validity of the stop bit. For mode 1 reception, if SM2 is 1, the receive interrupt will not be issue unless a valid stop bit is received. - 64 - Publication Release Date: March 11, 2010 Revision: V2.0 14. SERIAL PERIPHERAL INTERFACE (SPI) 14.1 Features N78E059A/N78E055A exists a Serial Peripheral Interface (SPI) block to support high speed serial communication. SPI is a full-duplex, high speed, synchronous communication bus between MCUs or other peripheral devices such as serial EEPROM, LCD driver, or D/A converter. It provides either Master or Slave mode, high speed rate up to FPERIPH/16 for Master mode and FPERIPH/4 for Slave mode, transfer complete and write collision flag. For a multi-master system, SPI supports Master Mode Fault to protect a multi-master conflict. 14.2 Function Description FPERIPH S M MSB Select M S CLOCK SPR0 SPR1 LSB 8-bit Shift Register Read Data Buffer MISO MOSI Pin Contorl Logic Divider /16, /32, /64, /128 Clock Logic SPCLK SSOE DISMODF SPIEN MSTR SS MSTR SPI Status Register SPI Interrupt Request SPR1 SPR0 CPHA CPOL LSBFE MSTR SSOE SPIEN DISMODF MODF SPIOVF WCOL SPIF SPI Status Control Logic SPIEN SPI Control Register Internal Data Bus Figure 14–1. SPI Block Diagram - 65 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Figure 14–1 shows SPI block diagram. It provides an overview of SPI architecture in this device. The main blocks of SPI are the SPI control register logic, SPI status logic, clock rate control logic, and pin control logic. For a serial data transfer or receiving, The SPI block exists a shift register and a read data buffer. It is single buffered in the transmit direction and double buffered in the receiving direction. Transmit data cannot be written to the shifter until the previous transfer is complete. Receiving logic consists of parallel read data buffer so the shift register is free to accept a second data, as the first received data will be transferred to the read data buffer. The four pins of SPI interface are Master-In/Slave-Out (MISO), Master-Out/Slave-In (MOSI), Shift Clock (SPCLK), and Slave Select ( SS ). The MOSI pin is used to transfer a 8-bit data in series from the Master to the Slave. Therefore, MOSI is an output pin for Master device and a input for Slave. Respectively, the MISO is used to receive a serial data from the Slave to the Master. The SPCLK pin is the clock output in Master mode, but is the clock input in Slave mode. The shift clock is used to synchronize the data movement both in and out of the devices through their MOSI and MISO pins. The shift clock is driven by the Master mode device for eight clock cycles which exchanges one byte data on the serial lines. For the shift clock is always produced out of the Master device, the system should never exist more than one device in Master mode for avoiding device conflict. Each Slave peripheral is selected by one Slave Select pin ( SS ). The signal must stay low for any Slave access. When SS is driven high, the Slave device will be inactivated. If the system is multi-slave, there should be only one Slave device selected at the same time. In the Master mode MCU, the SS pin does not function and it can be configured as a general purpose I/O. However, SS can be used as Master Mode Fault detection (see Section 14.7 “Mode Fault Detection” on page 74) via software setting if multi-master environment exists. N78E059A/N78E055A also provides auto-activating function to toggle SS between each byte-transfer. - 66 - Publication Release Date: March 11, 2010 Revision: V2.0 Master/Slave MCU1 Master/Slave MCU2 MISO MISO MOSI MOSI SPCLK Slave device 1 Slave device 2 I/O PORT SO SI SCK SS SO SI SCK SS 0 1 2 3 SO 0 1 2 3 SI SS SCK SS SS I/O PORT SPCLK Slave device 3 Figure 14–2. SPI Multi-master, Multi-slave Interconnection Figure 14–2 shows a typical interconnection of SPI devices. The bus generally connects devices together through three signal wires, MOSI to MOSI, MISO to MISO, and SPCLK to SPCLK. The Master devices select the individual Slave devices by using four pins of a parallel port to control the four SS pins. MCU1 and MCU2 play either Master or Slave mode. The SS should be configured as Master Mode Fault detection to avoid multi-master conflict. MOSI MOSI MISO MISO SPI shift register 7 6 5 4 3 2 1 0 SPI shift register 7 6 5 4 3 2 1 0 SPCLK SPCLK SPI clock generator SS Master MCU SS * VSS Slave MCU * SS configuration follows DISMODF and SSOE bits. Figure 14–3. SPI Single-master, Single-slave Interconnection Figure 14–3 shows the simplest SPI system interconnection, single-master and signal-slave. During a transfer, the Master shifts data out to the Slave via MOSI line. While simultaneously, the Master shifts data in from the Slave via MISO line. The two shift registers in the Master MCU and the Slave MCU can be considered as one 16-bit circular shift register. Therefore, while a transfer data pushed from Master into Slave, the data in Slave will also be pulled in Master device respectively. The transfer effectively exchanges the data which was in the SPI shift registers of the two MCUs. - 67 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet By default, SPI data is transferred MSB first. If the LSBFE (SPCR.5) is set, SPI data shifts LSB first. This bit does not affect the position of the MSB and LSB in the data register. Note that all following descriptions and figures are under the condition of LSBFE logic 0. MSB is transmitted and received first. 14.3 Control Registers of SPI There are three SPI registers to support its operations, they are SPI control register (SPCR), SPI status register (SPSR), and SPI data register (SPDR). These registers provide control, status, data storage functions, and clock rate selection. The following registers relate to SPI function. SPCR – Serial Peripheral Control Register 7 6 5 4 SSOE SPIEN LSBFE MSTR r/w r/w r/w r/w Address: F3H 3 CPOL r/w 2 CPHA r/w 1 0 SPR1 SPR0 r/w r/w reset value: 0000 0000b Bit Name Description 7 SSOE Slave select output enable. This bit is used in combination with the DISMODF (SPSR.3) bit to determine the feature of SS pin as shown in Table 14–1. Slave Select Pin Configurations. This bit takes effect only under MSTR = 1 and DISMODF = 1 condition. 0 = SS functions as a general purpose I/O pin. 1 = SS automatically goes low for each transmission when selecting external Slave device and goes high during each idle state to de-select the Slave device. 6 SPIEN SPI enable. 0 = Disable SPI function. 1 = Enable SPI function. 5 LSBFE LSB first enable. 0 = The SPI data is transferred MSB first. 1 = The SPI data is transferred LSB first. 4 MSTR Master mode enable. This bit switches the SPI operating between Master and Slave modes. 0 = The SPI is configured as Slave mode. 1 = The SPI is configured as Master mode. 3 CPOL SPI clock polarity select. CPOL bit determines the idle state level of the SPI clock. See Figure 14–4. SPI Clock Formats. 0 = The SPI clock is low in idle state. 1 = The SPI clock is high in idle state. 2 CPHA SPI clock phase select. CPHA bit determines the data sampling edge of the SPI clock. See Figure 14–4. SPI Clock Formats. 0 = The data is sampled on the first edge of the SPI clock. 1 = The data is sampled on the second edge of the SPI clock. - 68 - Publication Release Date: March 11, 2010 Revision: V2.0 Bit Name 1 SPR1 0 SPR0 Description SPI clock rate select. These two bits select four grades of SPI clock divider. SPR1 SPR0 Divider SPI clock rate 0 0 16 1.25M bit/s 0 1 32 625k bit/s 1 0 64 312k bit/s 1 1 128 156k bit/s The clock rates above are illustrated under F PERIPH = 20MHz condition. Table 14–1. Slave Select Pin Configurations DISMODF SSOE Master Mode (MSTR = 1) 0 x SS input for Mode Fault 1 0 General purpose I/O 1 1 Automatic SS output Slave Mode (MSTR = 0) SS Input for Slave select SPSR – Serial Peripheral Status Register 7 6 5 4 SPIF WCOL SPIOVF MODF r/w r/w r/w r/w Address: F4H 3 DISMODF r/w 2 - 1 0 reset value: 0000 0000b Bit Name Description 7 SPIF SPI complete flag. This bit is set to logic 1 via hardware while an SPI data transfer is complete or an receiving data has been moved into the SPI read buffer. If ESPI (EIE .0) and EA are enabled, an SPI interrupt will be required. This bit must be cleared via software. Attempting to write to SPDR is inhibited if SPIF is set. 6 WCOL Write collision error flag. This bit indicates a write collision event. Once a write collision event occurs, this bit will be set. It must be cleared via software. 5 SPIOVF SPI overrun error flag. This bit indicates an overrun event. Once an overrun event occurs, this bit will be set. If ESPI and EA are enabled, an SPI interrupt will be required. This bit must be cleared via software. 4 MODF Mode Fault error flag. This bit indicates a Mode Fault error event. If SS pin is configured as Mode Fault input (MSTR = 1 and DISMODF = 0) and SS is pulled low by external devices, a Mode Fault error occurs. Instantly MODF will be set as logic 1. If ESPI and EA are enabled, an SPI interrupt will be required. This bit must be cleared via software. - 69 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Bit Name Description 3 DISMODF Disable Mode Fault error detection. This bit is used in combination with the SSOE (SPCR.7) bit to determine the feature of SS pin as shown in Table 14–1. Slave Select Pin Configurations. DISMODF affects only in Master mode (MSTR = 1). 0 = Mode Fault detection is not disabled. SS serves as input pin for Mode Fault detection disregard of SSOE. 1 = Mode Fault detection is disabled. The feature of SS follows SSOE bit. 2:0 - Reserved. SPDR – Serial Peripheral Data Register 7 6 5 4 3 2 1 0 SPDR[7:0] r/w Address: F5H reset value: 0000 0000b Bit Name Description 7:0 SPDR[7:0] Serial peripheral data. This byte is used of transmitting or receiving data on SPI bus. A write of this byte is a write to the shift register. A read of this byte is actually a read of the read data buffer. In Master mode, a write to this register initiates transmission and reception of a byte simultaneously. 14.4 Operating Modes 14.4.1 Master mode The SPI can operate in Master mode while MSTR (SPCR.4) is set as 1. Only one Master SPI device can initiate transmissions. A transmission always begins by Master through writing to SPDR. The byte written to SPDR begins shifting out on MOSI pin under the control of SPCLK. Simultaneously, another byte shifts in from the Slave on the MISO pin. After 8-bit data transfer complete, SPIF (SPSR.7) will automatically set via hardware to indicate one byte data transfer complete. At the same time, the data received from the Slave is also transferred in SPDR. The user can clear SPIF and read data out of SPDR. 14.4.2 Slave Mode When MSTR is 0, the SPI operates in Slave mode. The SPCLK pin becomes input and it will be clocked by another Master SPI device. The SS pin also becomes input. The Master device cannot exchange data with the Slave device until the SS pin of the Slave device is externally pulled low. Before data transmissions occurs, the SS of the Slave device must be pulled and remain low until the transmission is complete. If SS goes - 70 - Publication Release Date: March 11, 2010 Revision: V2.0 high, the SPI is forced into idle state. If the SS is force to high at the middle of transmission, the transmission will be aborted and the rest bits of the receiving shifter buffer will be high and goes into idle state. In Slave mode, data flows from the Master to the Slave on MOSI pin and flows from the Slave to the Master on MISO pin. The data enters the shift register under the control of the SPCLK from the Master device. After one byte is received in the shift register, it is immediately moved into the read data buffer and the SPIF bit is set. A read of the SPDR is actually a read of the read data buffer. To prevent an overrun and the loss of the byte that caused by the overrun, the Slave must read SPDR out and the first SPIF must be cleared before a second transfer of data from the Master device comes in the read data buffer. 14.5 Clock Formats and Data Transfer To accommodate a wide variety of synchronous serial peripherals, the SPI has a clock polarity bit CPOL (SPCR.3) and a clock phase bit CPHA (SPCR.2). Figure 14–4. SPI Clock Formats shows that CPOL and CPHA compose four different clock formats. The CPOL bit denotes the SPCLK line level in SPI idle state. The CPHA bit defines the edge on which the MOSI and MISO lines are sampled. The CPOL and CPHA should be identical for the Master and Slave devices on the same system. To Communicate in different data formats with one another will result undetermined result. Clock Phase (CPHA) CPOL = 0 CPHA = 1 sample sample sample sample CPOL = 1 Clock Polarity (CPOH) CPHA = 0 Figure 14–4. SPI Clock Formats In SPI, a Master device always initiates the transfer. If SPI is selected as Master mode (MSTR = 1) and enabled (SPIEN = 1), writing to the SPI data register (SPDR) by the Master device starts the SPI clock and data transfer. After shifting one byte out and receiving one byte in, the SPI clock stops and SPIF (SPSR.7) in both Master and Slave are set. If SPI interrupt enable bit ESPI (EIE.0) is set 1 and global interrupt is enabled (EA = 1), the interrupt service routine (ISR) of SPI will be executed. - 71 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Concerning the Slave mode, the SS signal needs to be taken care. As shown in Figure 14–4. SPI Clock Formats, when CPHA = 0, the first SPCLK edge is the sampling strobe of MSB (for an example of LSBFE = 0, MSB first). Therefore, the Slave must shift its MSB data before the first SPCLK edge. The falling edge of SS is used for preparing the MSB on MISO line. The SS pin therefore must toggle high and then low between each successive serial byte. Furthermore, if the slave writes data to the SPI data register (SPDR) while SS is low, a write collision error occurs. When CPHA = 1, the sampling edge thus locates on the second edge of SPCLK clock. The Slave uses the first SPCLK clock to shift MSB out rather than the SS falling edge. Therefore, the SS line can remain low between successive transfers. This format may be preferred in systems having single fixed Master and single fixed Slave. The SS line of the unique Slave device can be tied to VSS as long as only CPHA = 1 clock mode is used. Note: The SPI should be configured before it is enabled (SPIEN = 1), or a change of LSBFE, MSTR, CPOL, CPHA and SPR[1:0] will abort a transmission in progress and force the SPI system into idle state. Prior to any configuration bit changed, SPIEN must be disabled first. SPCLK Cycles 1 SPCLK Cycles 2 3 4 5 6 7 8 SPCLK (CPOL=0) SPCLK (CPOL=1) Transfer Progress[1] (internal signal) MOSI MISO MSB MSB 6 5 4 3 2 1 6 5 4 3 2 1 LSB LSB Input to Slave SS SS output of Master[2] SPIF (Master) SPIF (Slave) [1] Transfer progress starts by a writing SPDR of Master MCU. [2] SS automatic output affects when MSTR = DISMODF = SSOE = 1. Figure 14–5. SPI Clock and Data Format with CPHA = 0 - 72 - Publication Release Date: March 11, 2010 Revision: V2.0 SPCLK Cycles SPCLK Cycles 1 2 3 4 5 6 7 8 MSB 6 5 4 3 2 1 LSB 6 5 4 3 2 1 SPCLK (CPOL=0) SPCLK (CPOL=1) Transfer Progress[1] (internal signal) MOSI MSB MISO LSB [3] [4] Input to Slave SS SS output of Master[2] SPIF (Master) SPIF (Slave) [1] Transfer progress starts by a writing SPDR of Master MCU. [2] SS automatic output affects when DISMODF = SSOE = MSTR = 1. [3] If SS of Slave is low, the MISO will be the LSB of previous data. Otherwise, MISO will be high. [4] While SS stays low, the LSB will last its state. Once SS is released to high, MISO will switch to high level. Figure 14–6. SPI Clock and Data Format with CPHA = 1 14.6 Slave Select Pin Configuration N78E059A/N78E055A SPI gives a flexible SS pin feature for different system requirements. When the SPI operates as a Slave, SS pin always rules as Slave select input. When the Master mode is enabled, SS has three different functions according to DISMODF (SPSR.3) and SSOE (SPCR.7). By default, DISMODF is 0. It means that the Mode Fault detection activates. SS is configured as a input pin to check if the Mode Fault appears. On the contrary, if DISMODF is 1, Mode Fault is inactivated and the SSOE bit takes over to control the function of the SS pin. While SSOE is 1, it means the Slave select signal will generate automatically to select a Slave device. The SS as output pin of the Master usually connects with the SS input pin of the Slave device. The SS output automatically goes low for each transmission when selecting external Slave device and goes high during each idle state to de-select the Slave device. While SSOE is 0 and DISMODF is 1, SS is no more used by the SPI and reverts to be a general purpose I/O pin. - 73 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet 14.7 Mode Fault Detection The Mode Fault detection is useful in a system where more than one SPI devices might become Masters at the same time. It may induce data contention. When the SPI device is configured as a Master and the SS input line is configured for Mode Fault input depending on Table 14–1. Slave Select Pin Configurations, a Mode Fault error occurs once the SS is pulled low by others. It indicates that some other SPI device is trying to address this Master as if it is a Slave. Instantly the MSTR and SPIEN control bits in the SPCR are cleared via hardware to disable SPI, Mode Fault flag MODF (SPSR.4) is set and an interrupt is generated if ESPI (EIE .0) and EA are enabled. 14.8 Write Collision Error The SPI is signal buffered in the transfer direction and double buffered in the receiving direction. New data for transmission cannot be written to the shift register until the previous transaction is complete. Write collision occurs while an attempt was made to write data to the SPDR while a transfer was in progress. SPDR is not double buffered in the transmit direction. Any writing to SPDR cause data to be written directly into the SPI shift register. Once a write collision error is generated, WCOL (SPSR.6) will be set as a 1 via hardware to indicate a write collision. In this case, the current transferring data continues its transmission. However the new data that caused the collision will be lost. Although the SPI logic can detect write collisions in both Master and Slave modes, a write collision is normally a Slave error because a Slave has no indicator when a Master initiates a transfer. During the receive of Slave, a write to SPDR causes a write collision under Slave mode. WCOL flag needs to be cleared via software. 14.9 Overrun Error For receiving data, the SPI is double buffered in the receiving direction. The received data is transferred into a parallel read data buffer so the shifter is free to accept a second serial byte. However, the received data must be read from SPDR before the next data has been completely shifted in. As long as the first byte is read out of the read data buffer and SPIF is cleared before the next byte is ready to be transferred, no overrun error condition occurs. Otherwise the overrun error occurs. In this condition, the second byte data will not be successfully received into the read data register and the previous data will remains. If overrun occur, SPIOVF (SPSR.5) will be set via hardware. This will also require an interrupt if enabled. Figure 14–7. SPI Overrun Waveform shows the relationship between the data receiving and the overrun error. - 74 - Publication Release Date: March 11, 2010 Revision: V2.0 Data[n] Receiving Begins Shift Register Data[n+1] Receiving Begins Shifting Data[n] in SPIF Data[n+2] Receiveing Begins Shifting Data[n+1] in Shifting Data[n+2] in [1] [3] Read Data Buffer Data[n] SPIOVF [4] Data[n] [2] Data[n+2] [3] [1] When Data[n] is received, the SPIF will be set. [2] If SPIF is not clear before Data[n+1] progress done, the SPIOVF will be set. Data[n] will be kept in read data buffer but Data [n+1] will be lost. [3] SPIF and SPIOVF must be cleared by software. [4] When Data[n+2] is received, the SPIF will be set again. Figure 14–7. SPI Overrun Waveform 14.10 SPI Interrupts Three SPI status flags, SPIF, MODF, and SPIOVF, can generate an SPI event interrupt requests. All of them locate in SPSR. SPIF will be set after completion of data transfer with external device or a new data have been received and copied to SPDR. MODF becomes set to indicate a low level on SS causing the Mode Fault state. SPIOVF denotes a receiving overrun error. If SPI interrupt mask is enabled via setting ESPI (EIE.0) and EA is 1, CPU will executes the SPI interrupt service routine once any of these three flags is set. The user needs to check flags to determine what event caused the interrupt. These three flags are software cleared. SPIF SPIOVF SS MSTR DISMODF Mode MODF Fault Detection SPI Interrupt Request ESPI (EIE.0) EA Figure 14–8. SPI Interrupt Request - 75 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet 15. PULSE WIDTH MODULATOR (PWM) N78E059A/N78E055A provides five pulse width modulated (PWM) output channels to generate pulses of programmable length and interval. Five PWM channels, PWM0~4, shares the same pins with P1.3~P1.7. The PWM period is defined by an 8-bit pre-scalar PWMP, which supplies the clock of the PWM counter. The prescalar is common for all PWM channels. The duty of each PWM channel is determined by the value of five registers, PWM0, PWM1, PWM2, PWM3, and PWM4. If the contents of these registers are equal to or less than the 8-bit counter value, the output will be 0. Else the output will be 1 if these registers value are larger than the counter. Set PWMxEN (in PWMCON0[0,1,4,5] and PWMCON1.0) will enable to run or disable to stop each PWM channel respectively. In addition, the PWMxOM (in PWMCON0[2,3,6,7] and PWMCON1.2) must set 1 to output the internal PWM signal to port pins. Without setting PWMxOM, the pins which share with alternative PWM function will be normal general purpose I/O of P1.3~P1.7 even though PWM is enabled. The following registers relate to PWM function. PWMCON0 – PWM Control 0 7 6 5 PWM3OE PWM2OE PWM3EN r/w r/w r/w Address: DCH 4 PWM2EN r/w 3 PWM1OE r/w 2 PWM0OE r/w Bit Name 7 PWM3OE PWM3 output enable. 0 = P1.6 serves as general purpose I/O. 1 = P1.6 serves as output pin of PWM3 signal. 6 PWM2OE PWM2 output enable. 0 = P1.5 serves as general purpose I/O. 1 = P1.5 serves as output pin of PWM2 signal. 5 PWM3EN PWM3 enable. 0 = PWM3 is disabled and stops. 1 = PWM3 is enabled and runs. 4 PWM2EN PWM2 enable. 0 = PWM2 is disabled and stops. 1 = PWM2 is enabled and runs. 3 PWM1OE PWM1 output enable. 0 = P1.4 serves as general purpose I/O. 1 = P1.4 serves as output pin of PWM1 signal. 2 PWM0OE PWM0 output enable. 0 = P1.3 serves as general purpose I/O. 1 = P1.3 serves as output pin of PWM0 signal. 1 PWM1EN PWM1 enable. 0 = PWM1 is disabled and stops. 1 = PWM1 is enabled and runs. 1 0 PWM1EN PWM0EN r/w r/w reset value: 0000 0000b Description - 76 - Publication Release Date: March 11, 2010 Revision: V2.0 Bit Name 0 PWM0EN Description PWM0 enable. 0 = PWM0 is disabled and stops. 1 = PWM0 is enabled and runs. PWMCON1 – PWM Control 1 7 6 Address: CEH Bit Name 7:3 - 2 PWM4OE 1 - 0 PWM4EN PWMP – PWM Period 7 6 5 - 4 - 3 - 2 PWM4OE r/w 1 0 PWM4EN r/w reset value: 0000 0000b Description Reserved. PWM4 output enable. 0 = P1.7 serves as general purpose I/O. 1 = P1.7 serves as output pin of PWM4 signal. Reserved. PWM0 enable. 0 = PWM4 is disabled and stops. 1 = PWM4 is enabled and runs. 5 4 3 2 1 0 PWMP[7:0] r/w Address: D9H reset value: 0000 0000b Bit Name 7:0 PWMP[7:0] PWM0 – PWM0 Duty 7 6 Description PWM period. This byte controls the period of the PWM output of PWM0~PWM4 channels. 5 4 3 2 1 0 PWM0[7:0] r/w Address: DAH reset value: 0000 0000b Bit Name 7:0 PWM0[7:0] Description PWM0 duty. This byte controls the duty of the PWM0 output. - 77 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet PWM1 – PWM1 Duty 7 6 5 4 3 2 1 0 PWM1[7:0] r/w Address: DBH reset value: 0000 0000b Bit Name 7:0 PWM1[7:0] PWM2 – PWM2 Duty 7 6 Description PWM1 duty. This byte controls the duty of the PWM1 output. 5 4 3 2 1 0 PWM2[7:0] r/w Address: DDH reset value: 0000 0000b Bit Name 7:0 PWM2[7:0] PWM3 – PWM3 Duty 7 6 Description PWM2 duty. This byte controls the duty of the PWM2 output. 5 4 3 2 1 0 PWM3[7:0] r/w Address: DEH reset value: 0000 0000b Bit Name 7:0 PWM3[7:0] PWM4 – PWM4 Duty 7 6 Description PWM3 duty. This byte controls the duty of the PWM3 output. 5 4 3 2 1 0 PWM4[7:0] r/w Address: CFH reset value: 0000 0000b Bit Name 7:0 PWM4[7:0] Description PWM4 duty. This byte controls the duty of the PWM4 output. The repetition frequency of PWM, FPWM is given by, FPWM  FPERIPH , pre-scalar division factor = PWM + 1. (PWMP  1)  255 PWM high duty of PWMx = PWMx . 255 - 78 - Publication Release Date: March 11, 2010 Revision: V2.0 This gives a repetition frequency range of 122Hz to 31.25kHz (FPERIPH = 16MHz). By loading the PWMx registers with either 00H or FFH, the PWM channels will generate a constant low or high level output, respectively. When a compare register PWMx is loaded with a new value, the associated output updated immediately. It does not have to wait until the end of the current counter period. FPERIPH Pre-scalar PWMP 8-bit Up-counter PWM0 PWM0EN + - PWM0OE PWM0 (P1.3) PWM1EN PWM1 + - PWM1OE PWM1 (P1.4) PWM2EN PWM2 + - PWM2OE PWM2 (P1.5) PWM3EN PWM3 + - PWM3OE PWM3 (P1.6) PWM4EN PWM4 + - PWM4OE PWM4 (P1.7) Figure 15–1. PWM Function Block PWM demo code, MOV MOV MOV MOV MOV MOV ORL ORL ORL ORL PWMP,#128 PWM0,#0H PWM1,#40H PWM2,#80H PWM3,#0C0H PWM4,#0FFH PWMCON0,#00110011b PWMCON1,#00000001b PWMCON0,#11001100b PWMCON1,#00000100b ;determine PWM period ;duty = 0% ;duty = 25% ;duty = 50% ;duty = 75% ;duty = 100% ;enable PWM0~3 ;enable PWM4 ;output enable PWM0~3 ;output enable PWM4 - 79 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet 16. TIMED ACCESS PROTECTION (TA) N78E059A/N78E055A has several features like the Watchdog Timer, the ISP function, Boot select control, etc. are crucial to proper operation of the system. If leaving these control registers unprotected, errant code may write undetermined value into them, it results in incorrect operation and loss of control. In order to prevent this risk, the N78E059A/N78E055A has a protection scheme which limits the write access to critical SFRs. This protection scheme is done using a timed access. The following registers are related to TA process. TA – Timed Access 7 6 5 4 3 2 1 0 TA[7:0] w Address: C7H reset value: 0000 0000b Bit Name Description 7:0 TA[7:0] Timed access. The timed access register controls the access to protected SFRs. To access protected bits, the user must first write AAH to the TA and immediately followed by a write of 55H to TA. After these two steps, a writing permission window is opened for three machine-cycles during which the user may write to protected SFRs. In timed access method, the bits, which are protected, have a timed write enable window. A write is successful only if this window is active, otherwise the write will be discarded. When the software writes AAH to TA, a counter is started. This counter waits for three machine-cycles looking for a write of 55H to TA. If the second write of 55H occurs within three machine-cycles of the first write of AAH, then the timed access window is opened. It remains open for three machine-cycles during which the user may write to the protected bits. After three machine-cycles, this window automatically closes. Once the window closes, the procedure must be repeated to access the other protected bits. Not that the TA protected SFRs are required timed access for writing. But the reading is not protected. The user may read TA protected SFR without giving AAH and 55H to TA. The suggestion code for opening the timed access window is shown below. (CLR EA) ;if any interrupt is enabled, disable temporally MOV TA,#0AAH MOV TA,#55H (Instruction that writes a TA protected register) (SETB EA) ;resume interrupts enabled The writings of AAH, 55H to TA register and the writing-protection register must occur within 3 machine-cycles of each other. Any enabled interrupt should be disabled during this procedure to avoid delay between these three writings. If there is no interrupt enabled, the CLR EA and SETB EA instructions can be left out. Once the timed access window closes, the procedure must be repeated to access the other protected bits. - 80 - Publication Release Date: March 11, 2010 Revision: V2.0 Examples of timed assessing are shown to illustrate correct or incorrect writing processes. Example 1, MOV MOV ORL TA,#0AAH TA,#55H CHPCON,#data ;2 machine-cycles. ;2 machine-cycles. ;2 machine-cycles. TA,#0AAH TA,#55H ;2 ;2 ;1 ;1 ;2 machine-cycles. machine-cycles. machine-cycle. machine-cycle. machine-cycles. ;2 ;1 ;2 ;2 ;2 machine-cycles. machine-cycle. machine-cycles. machine-cycles. machine-cycles. ;2 ;1 ;1 ;2 ;2 machine-cycles. machine-cycle. machine-cycle. machine-cycles. machine-cycles. Example 2, MOV MOV NOP NOP ANL ISPTRG,#data Example 3, MOV NOP MOV MOV ORL TA,#0AAH TA,#55H WDCON,#data1 PMC,#data2 Example 4, MOV NOP NOP MOV ANL TA,#0AAH TA,#55H WDCON,#data In the first examples, the writing to the protected bits is done before the three-machine-cycle window closes. In example 2, however, the writing to ISPTRG does not complete during the window opening, there will be no change of the value of ISPTRG. In example 3, the WDCON is successful written but the PMC access is out of the three-machine-cycle window. Therefore PMC value will not change either. In Example 4, the second write 55H to TA completes after three machine-cycles of the first write TA of AAH, therefore the timed access window in not opened at all, and the write to the protected bit fails. In N78E059A/N78E055A, the TA protected SFRs includes CHPCON (9FH), ISPTRG (A4H), PMC (ACH), and WDCON (AAH). - 81 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet 17. INTERRUPT SYSTEM The purpose of the interrupt is to make the software deal with unscheduled or asynchronous events. N78E059A/N78E055A has a four-priority-level interrupt structure with 11 interrupt sources. Each of the interrupt sources has an individual priority bit, flag, interrupt vector and enable bit. In addition, the interrupts can be globally enabled or disabled. When an interrupt occurs, the CPU is expected to service the interrupt. This service is specified as an Interrupt Service Routine (ISR). The ISR resides at a predetermined address as shown in Table 17–1. N78E059A/N78E055A Interrupt Vectors. When the interrupt occurs if enabled, the CPU will vector to the appropriate location. It will execute the code at this location, staying in an interrupt service state until done with the ISR. Once an ISR has begun, it can be interrupted only by a higher priority interrupt. The ISR is terminated by a return from interrupt instruction RETI. This instruction will force the CPU return to the instruction that would have been next when the interrupt occurred. Table 17–1. N78E059A/N78E055A Interrupt Vectors Vector Address Vector Number External Interrupt 0 0003H 0 External Interrupt 1 0013H Serial Port Interrupt External Interrupt 2 Source SPI Interrupt Brown-out Detection Interrupt Vector Address Vector Number Timer 0 Overflow 000BH 1 2 Timer 1 Overflow 001BH 3 0023H 4 Timer 2 Overflow/Capture/Reload 002BH 5 0033H 6 External Interrupt 3 003BH 7 0043H 8 Power Down Waking-up Timer Interrupt 004BH 9 0053H 10 Source The SFRs associated with these interrupts are listed below. IE – Interrupt Enable (bit-addressable) 7 6 5 EA ET2 r/w r/w Address: A8H 4 ES r/w 3 ET1 r/w 2 EX1 r/w 1 0 ET0 EX0 r/w r/w reset value: 0000 0000b Bit Name Description 7 EA Enable all interrupt. This bit globally enables/disables all interrupts. It overrides the individual interrupt mask settings. 0 = Disable all interrupt sources. 1 = Enable each interrupt depending on its individual mask setting. Individual interrupts will occur if enabled. 6 - Reserved. - 82 - Publication Release Date: March 11, 2010 Revision: V2.0 Bit Name Description 5 ET2 Enable Timer 2 interrupt. 0 = Disable all Timer 2 interrupts. 1 = Enable interrupt generated by TF2 (T2CON.7) or EXF2 (T2CON.6). 4 ES Enable serial port (UART) interrupt. 0 = Disable all UART interrupts. 1 = Enable interrupt generated by TI (SCON.1) or RI (SCON.0). 3 ET1 Enable Timer 1 interrupt. 0 = Disable Timer 1 interrupt 1 = Enable interrupt generated by TF1 (TCON.7). 2 EX1 Enable external interrupt 1. 0 = Disable external interrupt 1. 1 = Enable interrupt generated by INT1 pin (P3.3). 1 ET0 Enable Timer 0 interrupt. 0 = Disable Timer 0 interrupt 1 = Enable interrupt generated by TF0 (TCON.5). 0 EX0 Enable external interrupt 0. 0 = Disable external interrupt 0. 1 = Enable interrupt generated by INT0 pin (P3.2). EIE – Extensive Interrupt Enable 7 6 5 Address: BDH 4 - 3 - 2 EBOD r/w 1 0 EPDT ESPI r/w r/w reset value: 0000 0000b Bit Name Description 7:3 - 2 EBOD Enable Brown-out detection interrupt. 0 = Disable Brown-out detection interrupt. 1 = Enable interrupt generated by BOF (PMC.3). 1 EPDT Enable Power Down waking-up timer interrupt. 0 = Disable Power Down waking-up timer interrupt 1 = Enable interrupt generated by PDTF (PDCON.5). 0 ESPI Enable SPI interrupt. 0 = Disable SPI interrupt. 1 = Enable interrupt generated by SPIF (SPSR.7), SPIOVF (SPSR.5), or MODF (SPSR.4). Reserved. IP – Interrupt Priority (bit-addressable)[1] 7 6 5 PT2 r/w Address: B8H Bit Name 7:6 - 4 PS r/w 3 PT1 r/w 2 PX1 r/w 1 0 PT0 PX0 r/w r/w reset value: 0000 0000b Description Reserved. - 83 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Bit Name Description 5 PT2 Timer 2 interrupt priority low bit. 4 PS Serial port (UART) interrupt priority low bit. 3 PT1 Timer 1 interrupt priority low bit. 2 PX1 External interrupt 1 priority low bit. 1 PT0 Timer 0 interrupt priority low bit. External interrupt 0 priority low bit. 0 PX0 [1] IP is used in combination with the IPH to determine the priority of each interrupt source. See Table 17–2. Interrupt Priority Level Setting for correct interrupt priority configuration. IPH – Interrupt Priority High 7 6 5 PX3H[2] PX2H[2] PT2H[3] r/w r/w r/w Address: BAH 4 PSH[3] r/w 3 PT1H[3] r/w 2 PX1H[3] r/w Bit Name 7 PX3H External interrupt 3 priority high bit. 6 PX2H External interrupt 3 priority high bit. 5 PT2H Timer 2 interrupt priority high bit. 4 PSH Serial port (UART) interrupt priority high bit. 3 PT1H Timer 1 interrupt priority high bit. 2 PX1H External interrupt 1 priority high bit. 1 PT0H Timer 0 interrupt priority high bit. 1 0 PT0H[3] PX0H[3] r/w r/w reset value: 0000 0000b Description External interrupt 0 priority high bit. 0 PX0H [2] PX2H and PX3H are used in combination with the PX2 (XICON.3) and PX3 (XICON.7) respectively to determine the priority of external interrupt 2 and 3. See Table 17–2. Interrupt Priority Level Setting for correct interrupt priority configuration. [3] These bits is used in combination with the IP respectively to determine the priority of each interrupt source. See Table 17–2. Interrupt Priority Level Setting for correct interrupt priority configuration. EIP – Extensive Interrupt Priority[4] 7 6 5 Address: BCH 4 - 3 - 2 PBOD r/w Bit Name 7:3 - 2 PBOD Brown-out detection interrupt priority low bit. 1 PPDT Power Down waking-up timer interrupt priority low bit. 0 PSPI SPI interrupt priority low bit. 1 0 PPDT PSPI r/w r/w reset value: 0000 0000b Description Reserved. - 84 - Publication Release Date: March 11, 2010 Revision: V2.0 [4] EIP is used in combination with the EIPH to determine the priority of each interrupt source. See Table 17–2. Interrupt Priority Level Setting for correct interrupt priority configuration. EIPH – Extensive Interrupt Priority High[1] 7 6 5 Address: BBH 4 - 3 - 2 PBODH r/w Bit Name 7:3 - 2 PBODH Brown-out detection interrupt priority high bit. 1 PPDTH Power Down waking-up timer interrupt priority high bit. 1 0 PPDTH PSPIH r/w r/w reset value: 0000 0000b Description Reserved. SPI interrupt priority high bit. 0 PSPIH [1] EIPH is used in combination with the EIP to determine the priority of each interrupt source. See Table 17–2. Interrupt Priority Level Setting for correct interrupt priority configuration. TCON – Timer 0 and 1 Control (bit-addressable) 7 6 5 4 TF1 TR1 TF0 TR0 r/w r/w r/w r/w Address: 88H 3 IE1 r/w 2 IT1 r/w 1 0 IE0 IT0 r/w r/w reset value: 0000 0000b Bit Name Description 3 IE1 External interrupt 1 edge flag. This flag is set via hardware when an edge/level of type defined by IT1 is detected. If IT1 = 1, this bit will remain set until cleared via software or at the beginning of the External Interrupt 1 service routine. If IT1 = 0, this flag is the inverse of the INT1 input signal‟s logic level. 2 IT1 External interrupt 1 type select. This bit selects whether the INT1 pin will detect falling edge or low level triggered interrupts. 0 = INT1 is low level triggered. 1 = INT1 is falling edge triggered. 1 IE0 External interrupt 0 edge flag. This flag is set via hardware when an edge/level of type defined by IT0 is detected. If IT0 = 1, this bit will remain set until cleared via software or at the beginning of the External Interrupt 0 service routine. If IT0 = 0, this flag is the inverse of the INT0 input signal‟s logic level. 0 IT0 External interrupt 0 type select. This bit selects whether the INT0 pin will detect falling edge or low level triggered interrupts. 0 = INT0 is low level triggered. 1 = INT0 is falling edge triggered. - 85 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet XICON – External Interrupt Control (bit-addressable) 7 6 5 4 [1] PX3 EX3 IE3 IT3 r/w r/w r/w r/w Address: C0H 3 PX2[1] r/w 2 EX2 r/w 1 0 IE2 IT2 r/w r/w reset value: 0000 0000b Bit Name Description 7 PX3 External interrupt 3 priority low bit. 6 EX3 Enable external interrupt 3. 0 = Disable external interrupt 3. 1 = Enable interrupt generated by INT3 pin (P4.2). 5 IE3 External interrupt 3 edge flag. This flag is set via hardware when an edge/level of type defined by IT3 is detected. If IT3 = 1, this bit will remain set until cleared via software or at the beginning of the External Interrupt 3 service routine. If IT3 = 0, this flag is the inverse of the INT3 input signal‟s logic level. 4 IT3 External interrupt 3 type select. This bit selects whether the INT3 pin will detect falling edge or low level triggered interrupts. 0 = INT3 is low level triggered. 1 = INT3 is falling edge triggered. 3 PX2 External interrupt 2 priority low bit. 2 EX2 Enable external interrupt 2. 0 = Disable external interrupt 2. 1 = Enable interrupt generated by INT2 pin (P4.3). 1 IE2 External interrupt 2 edge flag. This flag is set via hardware when an edge/level of type defined by IT2 is detected. If IT2 = 1, this bit will remain set until cleared via software or at the beginning of the External Interrupt 2 service routine. If IT2 = 0, this flag is the inverse of the INT2 input signal‟s logic level. External interrupt 2 type select. This bit selects whether the INT2 pin will detect falling edge or low level triggered interrupts. 0 = INT2 is low level triggered. 1 = INT2 is falling edge triggered. [1] PX2 and PX3 are used in combination with the PX2H (IPH.6) and PX3H (IPH.7) respectively to determine the priority of external interrupt 2 and 3. See Table 17–2. Interrupt Priority Level Setting for correct interrupt priority configuration. 0 IT2 The External Interrupts INT0 and INT1 can be either edge or level triggered depending on bits IT0 (TCON.0) and IT1 (TCON.2). The bits IE0 (TCON.1) and IE1 (TCON.3) are the flags which are checked to generate the interrupt. In the edge triggered mode, the INT0 or INT1 inputs are sampled in every machine-cycle. If the sample is high in one cycle and low in the next, then a high to low transition is detected and the interrupts request flag IE0 or IE1 will be set. Since the external interrupts are sampled every machine-cycle, they have to be held high or low for at least one complete machine-cycle. The IE0 and IE1 are automatically cleared when the interrupt service routine is called. If the level triggered mode is selected, then the requesting source has to - 86 - Publication Release Date: March 11, 2010 Revision: V2.0 hold the pin low till the interrupt is serviced. The IE0 and IE1 will not be cleared by the hardware on entering the service routine. In the level triggered mode, IE0 and IE1 follows the inverse value of INT0 and INT1 pins. If interrupt pins continue to be held low even after the service routine is completed, the processor will acknowledge another interrupt request from the same source. N78E059A/N78E055A (on PLCC-44, PQFP-44, and LQFP-48 packages) possessed other two external interrupts INT2 and INT3 . Their setting and operation are just the same as interrupt 0 and 1. All configuring bits locate in XICON. The individual interrupt flag corresponding to external interrupt 2 to 3 will also be automatically cleared via hardware once its own interrupt service routine is executed. The Timer 0 and 1 Interrupts are generated by the TF0 and TF1 flags. These flags are set by the overflow in the Timer 0 and Timer 1 and automatically cleared by the hardware when the timer interrupt is serviced. TF2 or EXF2 flag generates the Timer 2 interrupt. These flags are set by overflow, capture, or reload events in the Timer 2 operation. The hardware will not clear these flags when a Timer 2 interrupt service routine executes. Software has to resolve the cause of the interrupt between TF2 and EXF2 and clear the appropriate flag. The serial port can generate interrupts on reception or transmission. There are two interrupt sources from the serial port block, which are obtained by the RI and TI bits in the SCON. These bits are not automatically cleared by the hardware. The user has to clear these bits via software. The Power Down waking-up timer can be used as a simple timer. The Power Down waking-up timer interrupt flag PDTF (PDCON.5) is set once an overflow occurs. If the interrupt is enabled by the enable bit EPDT (EIE.1), then an interrupt will occur. Brown-out detection, if enabled, can cause Brown-out flag BOF (PMC.3) to be asserted if power voltage drop below Brown-out voltage level. The interrupt will occur if BORST (PMC.4) is 0 and EBOD (EIE.2) is 1. SPI asserts interrupt flag SPIF (SPSR.7) on completion of data transfer with an external device. If SPI interrupt enable bit ESPI (EIE.0), a serial peripheral interrupt generates. SPIF flag is software clear. MODF (SPSR.4) and SPIOVF (SPSR.5) will also generate SPI interrupt. They share the same vector address with SPIF. When interrupt is generated, the user should tell which flag requires the interrupt. All the bits that generate interrupts can be set or reset via hardware, and thereby software initiated interrupts can be generated. Each of the individual interrupts can be enabled or disabled by setting or clearing its controlling bit in the IE or EIE. IE also has a global enable bit EA (IE.7) which can be cleared to disable all the interrupts at once. It is set to enable all individually enabled interrupt. Note that every interrupts, if enabled, is generated by a setting as a logic 1 of its interrupt flag no matter by hardware or software. The user should take care of each interrupt flag in its own interrupt service routine (ISR). - 87 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Most of interrupt flags must be cleared by writing it as a logic 0 via software. Without clearing the flag, the ISR of corresponding interrupt source will execute again and again non-stopped. 17.1 Priority Level Structure There are four priority levels for the interrupts, highest, high, low, and lowest. The interrupt sources can be individually set to one of four priority levels by setting their own priority bits. Table 17–2 lists four priority setting. Naturally, a low priority interrupt can itself be interrupted by a high priority interrupt, but not by another same level interrupt or lower level. A highest priority can‟t be interrupted by any other interrupt source. In addition, there exists a pre-defined hierarchy among the interrupts themselves. This hierarchy comes into play when the interrupt controller has to resolve simultaneous requests having the same priority level. This hierarchy is defined as shown on Table 17–3. It also summarizes the interrupt sources, flag bits, vector addresses, enable bits, priority bits, natural priority and the permission to wake up the CPU from Power Down mode. For details of waking CPU up from Power Down mode, please see Section 19.2 “Power Down Mode” on page 100. Table 17–2. Interrupt Priority Level Setting Interrupt Priority Control Bits Interrupt Priority Level IPH / EIPH IP / EIP / XICON[7,3] 0 0 Level 0 (lowest) 0 1 Level 1 1 0 Level 2 1 1 Level 3 (highest) Table 17–3. Characteristics of Each Interrupt Source Source Vector Address Flag [1] External interrupt 0 0003H IE0 Timer 0 overflow 000BH TF0 [2] [1] External interrupt 1 0013H IE1 Timer 1 overflow 001BH TF1 Serial port (UART) 0023H RI + TI [2] [2] Enable Bit Natural Power Down Priority Control Bits Priority Waking up EX0 1 PX0, PX0H Yes ET0 2 PT0, PT0H No EX1 3 PX1, PX1H Yes ET1 4 PT1, PT1H No ES 5 PS, PSH No ET2 6 PT2, PT2H No Timer 2 overflow / capture / reload 002BH TF2 External interrupt 2 0033H IE2 [1] EX2 7 PX2, PX2H Yes External interrupt 3 003BH IE3 [1] EX3 8 PX3, PX3H Yes + EXF2 - 88 - Publication Release Date: March 11, 2010 Revision: V2.0 Source SPI interrupt Vector Address 0043H Flag Enable Bit Natural Power Down Priority Control Bits Priority Waking up SPIF (SPSR.7) + MODF (SPSR.4) + SPIOVF (SPSR.5) ESPI (EIE.0) 9 PSPI (EIP.0), PSPIH (EIPH.0) No Power Down waking-up 004BH timer interrupt PDTF (PDCON.5) EPDT (EIE.1) 10 PPDT (EIP.1), PPDTH (EIPH.1) Yes Brown-out interrupt BOF (PMC.3) EBOD (EIE.2) 11 PBOD (EIP.2), PBODH (EIPH.2) Yes 0053H [1] While the external interrupt pin is set as edge triggered (ITx = 1), its own flag IEx will be automatically cleared if the interrupt service routine (ISR) is executed. While as level triggered (ITx = 0), IEx follows the inverse of respective pin state. It is not controlled via software. [2] TF0 and TF1 will be automatically cleared if the interrupt service routine (ISR) is executed. But be aware that TF2 will not. The interrupt flags are sampled every machine-cycle. In the same machine-cycle, the sampled interrupts are polled and their priority is resolved. If certain conditions are met then the hardware will execute an internally generated LCALL instruction which will vector the process to the appropriate interrupt vector address. The conditions for generating the LCALL are, 1. An interrupt of equal or higher priority is not currently being serviced. 2. The current polling cycle is the last machine-cycle of the instruction currently being executed. 3. The current instruction does not involve a write to any enable or priority setting bits and is not a RETI. If any of these conditions are not met, then the LCALL will not be generated. The polling cycle is repeated every machine-cycle. If an interrupt flag is active in one cycle but not responded to for the above conditions are not met, if the flag is not still active when the blocking condition is removed, the denied interrupt will not be serviced. This means that the interrupt flag was once active but not serviced is not remembered. Every polling cycle is new. The processor responds to a valid interrupt by executing an LCALL instruction to the appropriate service routine. This may or may not clear the flag, which caused the interrupt according to different interrupt source. The hardware LCALL behaves exactly like the software LCALL instruction. This instruction saves the Program Counter contents onto the Stack RAM but does not save the Program Status Word (PSW). The PC is reloaded with the vector address of that interrupt which caused the LCALL. Execution continues from the vectored address till an RETI instruction is executed. On execution of the RETI instruction the processor pops the Stack and loads the PC with the contents at the top of the stack. The user must take care that the status of the stack is restored to what it was after the hardware LCALL. If the execution is to return to the interrupted program, the processor does not notice anything if the stack contents are modified and will proceed with execution from the address put back into PC. Note that a simple RET instruction would perform exactly the same process as a - 89 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet RETI instruction, but it would not inform the Interrupt controller that the interrupt service routine is completed. RET would leave the controller still thinking that the service routine is underway, making future interrupts impossible. 17.2 Interrupt Latency The response time for each interrupt source depends on several factors, such as the nature of the interrupt and the instruction underway. In the case of external interrupts INT0 and INT1 , they are sampled at every machine-cycle and then their corresponding interrupt flags IE0 or IE1 will be set or reset. The value are not actually polled by the circuit until the next machine-cycle. If a request is active and all three previous conditions are met, then the hardware generated LCALL is executed. This LCALL itself takes 2 machine-cycles to be completed. Thus there is a minimum time of 3 machine-cycles between the interrupt flag being set and the interrupt service routine being executed. A longer response time should be anticipated if any of the three conditions are not met. If a higher or equal priority is being serviced, then the interrupt latency time obviously depends on the nature of the service routine currently being executed. If the polling cycle is not the last machine-cycle of the instruction being executed, then an additional delay is introduced. The maximum response time (if no other interrupt is in service) occurs if the device is performing a write to IE, IP and then executes a MUL or DIV instruction. From the time an interrupt source is activated, the longest reaction time is 9 machine-cycles. This includes 1 machine-cycle to detect the interrupt, 2 machine-cycles to complete the IE, EIE, IP, IPH, EIP, or EIPH access, 4 machine-cycles to complete the MUL or DIV instruction and 2 machine-cycles to complete the hardware LCALL to the interrupt vector location. Thus in a single-interrupt system the interrupt response time will always be more than 3 machine-cycles and not more than 9 machine-cycles. - 90 - Publication Release Date: March 11, 2010 Revision: V2.0 18. IN SYSTEM PROGRAMMING (ISP) The internal Program Memory and on-chip Data Flash support both hardware programming and in system programming (ISP). Hardware programming mode uses gang-writers to reduce programming costs and time to market while the products enter into the mass production state. However, if the product is just under development or the end product needs firmware updating in the hand of an end user, the hardware programming mode will make repeated programming difficult and inconvenient. ISP method makes it easy and possible. N78E059A/N78E055A supports ISP mode allowing a device to be reprogrammed under software control. Furthermore, the capability to update the application firmware makes wide range of applications possible. ISP is performed without removing the microcontroller from the system. The most common method to perform ISP is via UART along with the firmware in LDROM. General speaking, PC transfers the new APROM code through serial port. Then LDROM firmware receives it and re-programs into APROM through ISP commands. Nuvoton provides ISP firmware, USB ISP writer and PC application program for N78E059A/N78E055A. It makes users quite easy perform ISP through Nuvoton standard ISP tool. Please explore Nuvoton 8-bit Microcontroller website: Nuvoton 80C51 Microcontroller Development Tool. 18.1 ISP Procedure Unlike RAM‟s real-time operation, to update flash data often takes long time. Furthermore, it is a quite complex timing procedure to erase, program, or read flash data. Fortunately, N78E059A/N78E055A carried out the flash operation with convenient mechanism to help the user update the flash content. After ISP enabled by setting ISPEN (CHPCON.0 with TA protected), the user can easily fill the 16-bit target address in ISPAH and ISPAL, data in ISPFD and command in ISPCN. Then the ISP is ready to begin by setting a triggering bit ISPGO (ISPTRG.0). Note that ISPTRG is also TA protected. At this moment, the CPU holds the Program Counter and the built-in ISP automation takes over to control the internal charge-pump for high voltage and the detail signal timing. After ISP action completed, the Program Counter continues to run the following instructions. The ISPGO bit will be automatically cleared. The user may repeat steps above for next ISP action if necessary. Through this progress, the user can easily erase, program, and verify the embedded flash by just taking care of the pure software. The following registers relate to ISP processing. - 91 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet CHPCON – Chip Control (TA protected) 7 6 5 4 3 2 1 0 SWRST ISPF LDUEN XRAMEN BS ISPEN w r/w r/w r/w r/w r/w Address: 9FH reset value: see Table 6–2. N78E059A/N78E055A SFR Descriptions and Reset Values Bit Name Description 6 ISPF ISP fault flag. The hardware will set this bit when any of the following condition is met: 1. The accessing area is illegal, such as, (a) Erasing or programming APROM itself when APROM code runs. (b) Erasing or programming LDROM when APROM code runs but LDUEN is 0. (c) Erasing, programming, or reading CONFIG bytes when APROM code runs. (d) Erasing or programming LDROM itself when LDROM code runs. (e) Accessing oversize. 2. The ISP operating runs from internal Program Memory into external one. This bit should be cleared via software. 5 LDUEN Updating LDROM enable. 0 = The LDROM is inhibited to be erased or programmed when APROM code runs. LDROM remains read-only. 1 = The LDROM is allowed to be fully accessed when APROM code runs. 0 ISPEN ISP enable. 0 = Enable ISP function. 1 = Disable ISP function. To enable ISP function will start the internal 22.1184MHz RC oscillator for timing control. To clear ISPEN should always be the last instruction after ISP operation in order to stop internal RC for reducing power consumption. ISPCN – ISP Control 7 6 ISPA.17 ISPA.16 r/w r/w Address: AFH Bit Name 7:6 ISPA[17:16] 5 FOEN 4 FCEN 3:0 FCTRL[3:0] 5 FOEN r/w 4 FCEN r/w 3 FCTRL.3 r/w 2 FCTRL.2 r/w 1 0 FCTRL.1 FCTRL.0 r/w r/w reset value: 0000 0000b Description ISP control. This byte is for ISP controlling command to decide ISP destinations and actions. For details, see Table 18–1. ISP Modes and Command Codes. - 92 - Publication Release Date: March 11, 2010 Revision: V2.0 ISPAH – ISP Address High Byte 7 6 5 4 3 2 1 0 ISPA[15:8] r/w Address: A7H reset value: 0000 0000b Bit Name 7:0 ISPA[15:8] Description ISP address high byte. ISPAH contains address ISPA[15:8] for ISP operations. ISPAL – ISP Address Low Byte 7 6 5 4 3 2 1 0 ISPA[7:0] r/w Address: A6H reset value: 0000 0000b Bit Name 7:0 ISPA[7:0] ISPFD – ISP Flash Data 7 6 Description ISP address low byte. ISPAL contains address ISPA[7:0] for ISP operations. 5 4 3 2 1 0 ISPFD[7:0] r/w Address: AEH reset value: 0000 0000b Bit Name 7:0 ISPFD[7:0] Description ISP flash data. This byte contains flash data which is read from or is going to be written to the flash memory. The user should write data into ISPFD for program mode before triggering ISP processing and read data from ISPFD for read/verify mode after ISP processing is finished. ISPTRG – ISP Trigger (TA protected) 7 6 5 Address: A4H 4 - 3 - 2 - 1 0 ISPGO w reset value: 0000 0000b Bit Name Description 0 ISPGO ISP go. ISP begins by setting this bit as a logic 1. After this instruction, the CPU holds the Program Counter (PC) and the ISP hardware automation takes over to control the progress. After ISP action completed, the Program Counter continues to run the following instructions. The ISPGO bit will be automatically cleared and always read as logic 0. - 93 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet 18.2 ISP Commands N78E059A/N78E055A provides a wide application to perform ISP to APROM, LDROM or on-chip Data Flash. The ISP action mode and the destination of the flash block are defined by ISP control register ISPCN. Table 18–1. ISP Modes and Command Codes ISPCN FCTRL[3:0] ISPAH, ISPAL ISPA[15:0] ISPFD[7:0] FCEN 1 X X X ISP Mode ISPA.17, ISPA.16 FOEN Standby [1] X, X 1 APROM and Data Flash Page Erase 0, 0 1 0 0010 Address in [2] LDROM Page Erase 0, 1 1 0 0010 Address in [2] APROM and Data Flash Program 0, 0 1 0 0001 Address in Data in LDROM Program 0, 1 1 0 0001 Address in Data in APROM and Data Flash Read 0, 0 0 0 0000 Address in Data out LDROM Read 0, 1 0 0 0000 Address in Data out All CONFIG bytes Erase 1, 1 1 0 0010 00XXH X CONFIG Program 1, 1 1 0 0001 CONFIG0: 0000H CONFIG2: 0002H CONFIG3: 0003H Data in CONFIG Read 1, 1 0 0 0000 CONFIG0: 0000H CONFIG2: 0002H CONFIG3: 0003H Data out X X [1] “x” means “don‟t care”. [2] Each page is 256-byte size. Therefore, the address for Page Erase should be 0000H, 0100H, 0200H, 0300H, etc., which is incremented by one of high byte address. 18.3 User Guide of ISP ISP facilitates the updating flash contents in a convenient way; however, the user should follow some restricted laws in order that the ISP operates correctly. Without noticing warnings will possible cause undetermined results even serious damages of devices. Be attention of these notices. Furthermore, this paragraph will also support useful suggestions during ISP procedures. (1) If no more ISP operation needs, the user must clear ISPEN (CHPCON.0) to zero. It will make the system void to trigger ISP unaware. Furthermore, ISP requires internal 22.1184MHZ RC oscillator running. If the external clock source is chosen, disabling ISP will stop internal 22.1184MHz RC for saving power consumption. Note that a write to ISPEN is TA protected. - 94 - Publication Release Date: March 11, 2010 Revision: V2.0 (2) If the loader code, which controls the ISP procedure, locates in the external Program Memory or runs from the internal into the external, the ISP will not work anymore and set error indicator ISPF for data security. (3) CONFIG bytes can be ISP fully accessed only when loader code executing in LDROM. New CONFIG bytes other than CBS bit activate after all resets. New CBS bit activates after resets other than software reset. (4) When the LOCK bit (CONFIG0.1) is activated, ISP reading, writing, or erasing can still be valid. (5) ISP erasing or programming works from VDD 3.0V through 5.5V. (6) APROM and LDROM can read itself through ISP method. During ISP progress, interrupts (if enabled) should be disabled temporally by clearing EA bit for implement limitation. Note that If the user would like to develop your own ISP program, remember always erase and program CONFIG bytes at the last step for data security. 18.4 ISP Demo Code ;****************************************************************************** ; This code illustrates how to do APROM and CONFIG ISP from LDROM. ; APROM are re-programmed by the code to output P1 as 55h and P2 as aah. ; The CONFIG3 is also updated to 6T mode. ; The user should put this code in LDROM and boot from LDROM. ;****************************************************************************** PAGE_ERASE_AP EQU 00100010b BYTE_PROGRAM_AP EQU 00100001b BYTE_READ_AP EQU 00000000b BYTE_READ_CONFIG EQU 11000000b BYTE_PROGRAM_CONFIG EQU 11100001b ALL_ERASE_CONFIG EQU 11100010b ORG 0000h CALL CLR CALL CALL CALL CALL CALL CALL CALL CALL CALL MOV MOV ANL MOV MOV Enable_ISP EA Erase_AP Erase_AP_Verify Program_AP Program_AP_Verify Read_Config Erase_Config Program_Config Program_Config_Verify Disable_ISP TA,#0Aah TA,#55h CHPCON,#0FDh TA,#0Aah TA,#55h ;disable all interrupts ;erase AP data ;verify Erase AP data ;programming AP data ;verify Programmed AP data ;read back CONFIG3 ;erase CONFIG bytes ;programming CONFIG3 with new data ;verify Programmed CONFIG3 ;TA protection ; ;BS = 0, reset to APROM - 95 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet ORL CHPCON,#80h ;software reset and reboot from APROM SJMP $ ;******************************************************************** ; ISP Function ;******************************************************************** Enable_ISP: MOV TA,#0Aah ;CHPCON is TA protected MOV TA,#55h ORL CHPCON,#00000001b ;ISPEN = 1, enable ISP mode RET Disable_ISP: MOV TA,#0Aah ;CHPCON is TA protected MOV TA,#55h ANL CHPCON,#11111110b ;ISPEN = 0, disable ISP mode RET Trigger_ISP: MOV TA,#0Aah MOV TA,#55h ORL ISPTRG,#00000001b ;write „1‟ to ISPGO to trigger ISP process RET ;******************************************************************** ; ISP AP Function ;******************************************************************** Erase_AP: MOV ISPCN,#PAGE_ERASE_AP MOV ISPAL,#00h MOV R0,#00h Erase_AP_Loop: MOV ISPAH,R0 CALL Trigger_ISP INC R0 CJNE R0,#0,Erase_AP_Loop RET Erase_AP_Verify: MOV ISPCN,#BYTE_READ_AP MOV ISPAH,#00h MOV ISPAL,#00h Erase_AP_Verify_Loop: MOV ISPFD,#00h ;clear ISPFD Data CALL Trigger_ISP MOV A,ISPFD CJNE A,#0FFh,Erase_AP_Verify_Error INC ISPAL MOV A,ISPAL CJNE A,#0,Erase_AP_Verify_Loop INC ISPAH MOV A,ISPAH CJNE A,#0,Erase_AP_Verify_Loop RET Erase_AP_Verify_Error: CALL Disable_ISP mov P0,#00h SJMP $ Program_AP: MOV ISPCN,#BYTE_PROGRAM_AP MOV ISPAH,#00h MOV ISPAL,#00h MOV DPTR,#AP_code Program_AP_Loop: - 96 - Publication Release Date: March 11, 2010 Revision: V2.0 MOV A,#0 MOVC A,@A+DPTR MOV ISPFD,A CALL Trigger_ISP INC DPTR INC ISPAL MOV A,ISPAL CJNE A,#8,Program_AP_Loop RET Program_AP_Verify: MOV ISPCN,#BYTE_READ_AP MOV ISPAH,#00h MOV ISPAL,#00h MOV DPTR,#AP_code Program_AP_Verify_Loop: MOV ISPFD,#00h ;clear ISPFD Data CALL Trigger_ISP MOV A,#0 MOVC A,@A+DPTR MOV B,A MOV A,ISPFD CJNE A,B,Program_AP_Verify_Error INC DPTR INC ISPAL MOV A,ISPAL CJNE A,#8,Program_AP_Verify_Loop RET Program_AP_Verify_Error: CALL Disable_ISP mov P0,#00h SJMP $ ;******************************************************************** ; ISP Config Function ;******************************************************************** Erase_Config: MOV ISPCN,#ALL_ERASE_CONFIG MOV ISPAH,#00h CALL Trigger_ISP RET Read_Config: MOV ISPCN,#BYTE_READ_CONFIG MOV ISPAH,#00h MOV ISPAL,#03h CALL Trigger_ISP MOV A,ISPFD RET Program_Config: MOV ISPCN,#BYTE_PROGRAM_CONFIG MOV ISPAH,#00h MOV ISPAL,#03h ANL A,#10111111b MOV ISPFD,A ;switch to 6T mode MOV R0,A ;temp data CALL Trigger_ISP RET Program_Config_Verify: MOV ISPCN,#BYTE_READ_CONFIG MOV ISPAH,#00h MOV ISPAL,#03h MOV ISPFD,#00h ;clear ISPFD Data - 97 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet CALL Trigger_ISP MOV B,R0 MOV A,ISPFD CJNE A,B,Program_CONFIG_Verify_Error RET Program_CONFIG_Verify_Error: CALL Disable_ISP mov P0,#00h SJMP $ ;******************************************************************** ; APROM code ;******************************************************************** AP_code : DB 75h, 90h, 55h ;OPCODEs of “mov P1,#55h” DB 75h,0A0h,0Aah ;OPCODEs of “mov P2,#0aah” DB 80h,0Feh ;OPCODEs of “sjmp $” END - 98 - Publication Release Date: March 11, 2010 Revision: V2.0 19. POWER SAVING MODES N78E059A/N78E055A has several features that help the user to control the power consumption of the device. The power saved features have the Power Down mode and the Idle mode of operation. For a stable current consumption, states of P0 pins should be taken care of. P0 should be set as 0 if floating or external pull-downs exist. Or P0 should be set as 1 if external pull-ups exist or internal pull-ups are enabled by P0UP (P0OR.0). In system power saving modes, the Watchdog Timer should be specially taken care. The hardware will clear WDT counter automatically after entering into or being woken-up from Idle or Power Down mode. It prevents unconscious system reset. PCON – Power Control 7 6 5 4 3 2 1 0 SMOD POF GF1 GF0 PD IDL r/w r/w r/w r/w r/w r/w Address: 87H reset value: see Table 6–2. N78E059A/N78E055A SFR Descriptions and Reset Values Bit Name Description 1 PD Power Down mode. Setting this bit puts MCU into Power Down mode. Under this mode, both CPU and peripheral clocks stop and Program Counter (PC) suspends. It provides the lowest power consumption. After CPU is woken up from Power Down, this bit will be automatically cleared via hardware and the program continue executing the interrupt service routine (ISR) of the very interrupt source that woke the system up before. After return from the ISR, the device continues execution at the instruction which follows the instruction that put the system into Power Down mode. Note that If IDL bit and PD bit are set simultaneously, the MCU will enter into Power Down mode. Then it does not go to Idle mode after exiting Power Down. 0 IDL Idle mode. Setting this bit puts MCU into Idle mode. Under this mode, the CPU clock stops and Program Counter (PC) suspends. After CPU is woken up from Idle, this bit will be automatically cleared via hardware and the program continue executing the ISR of the very interrupt source that woke the system up before. After return from the ISR, the device continues execution at the instruction which follows the instruction that put the system into Idle mode. 19.1 Idle Mode Idle mode suspends CPU processing by holding the Program Counter. No program code are fetched and run in Idle mode. This forces the CPU state to be frozen. The Program Counter (PC), the Stack Pointer (SP), the Program Status Word (PSW), the Accumulator (ACC), and the other registers hold their contents during Idle mode. The port pins hold the logical states they had at the time Idle was activated. Generally, it saves considerable power of typical half of the full operating power. - 99 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Since the clock provided for peripheral function logic circuit like timer or serial port still remain in Idle mode, the CPU can be released from the Idle mode using any of the interrupt sources if enabled. The user can put the device into Idle mode by writing 1 to the bit IDL (PCON.0). The instruction that sets the IDL bit is the last instruction that will be executed before the device goes into Idle mode. The Idle mode can be terminated in two ways. First, any interrupt if enabled will cause an exit. This will automatically clear the IDL bit, terminate the Idle mode, and the interrupt service routine (ISR) will be executed. After using the RETI instruction to jump out of the ISR, execution of the program will be the one following the instruction which put the CPU into Idle mode. The second way to terminate the Idle mode is with any reset other than software reset. Remember that if Watchdog reset is used to exit Idle mode, the WIDPD (WDCON.4) needs to be set 1 to let Watchdog Timer keep running in Idle mode. 19.2 Power Down Mode Power Down mode is the lowest power state that N78E059A/N78E055A can enter. It remain the power consumption as a ”μA” level. This is achieved by stopping the system clock no matter internal RC clock or external crystal. Both of CPU and peripheral functions like Timers or UART are frozen. Flash memory stops. All activity is completely stopped and the power consumption is reduced to the lowest possible value. The device can be put into Power Down mode by writing 1 to bit PD (PCON.1). The instruction that does this action will be the last instruction to be executed before the device goes into Power Down mode. In the Power Down mode, RAM maintains its content. The port pins output the values held by their respective. There are two ways to exit N78E059A/N78E055A from the Power Down mode. First is with all resets except software reset. Brown-out reset will also wake up CPU from Power Down mode. Be sure that Brown-out detection is enabled before the system enters into Power Down. But for a principle of least power consumption, it is uncommon to enable Brown-out detection in Power Down mode. It is not a recommended application. Of course the RST pin reset and power-on reset will remove the Power Down status. After RST pin reset or power-on reset. The CPU is initialized and start executing program code from the beginning. N78E059A/N78E055A can be woken up from the Power Down mode by forcing an external interrupt pin activated, providing the corresponding interrupt enabled and the global enable EA bit (IE.7) is set. If these conditions are met, then the trigger on the external pin will asynchronously restart the system clock. Then device executes the interrupt service routine (ISR) for the corresponding external interrupt. After the ISR is completed, the program execution returns to the instruction after the one which put the device into Power Down mode and continues. The Power Down waking-up timer interrupt is also allowed to wake up Power Down. It is usually applied as a long period timer to monitoring a static behavior. For detail application, please see Section 12.2 “Applications - 100 - Publication Release Date: March 11, 2010 Revision: V2.0 of Power Down Waking-up Timer” on page 50. Brown-out interrupt is another source to wake up CPU from Power Down. As mentioned before the user will endure the large current of Brown-out detection circuit. It is not a typical application. - 101 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet 20. CLOCK SYSTEM N78E059A/N78E055A provides three options of the system clock source. It is configured by FOSC (CONFIG3.1). It switches the system clock from crystal/resonator, on-chip RC oscillator, or external clock from XTAL1 pin. N78E059A/N78E055A embeds an on-chip RC oscillator of 22.1184MHz/11.0592MHz selected by CONFIG setting, factory trimmed to ± 1% at room temperature. If the external clock source is from the crystal, the frequency supports from 4MHz to 40MHz. Flash XTAL1 Oscillating Circuit External Crystal 1 FIHRC XTAL2 Internal RC Oscillator (22.1184MHz) 1 1/2 1: turn on 0: turn off FOSC 0 0 1/2 0 INOSCFS (CONFIG3.3) 1: 12T mode 0: 6T mode FPRIPH EN6T (CONFIG3.6) CFOSC (CONFIG3.1) ISPEN (CHPCON.0) ISP Internal RC Oscillator (~10kHz) FCPU 1 80C51 CPU Timers Serial Port (UART) SPI PWM FILRC Watchdog Timer LPBOD (PMC.2) Power Down Waking-up Timer Brown-out Detection Figure 20–1. Clock System Block Diagram 20.1 12T/6T mode The clock for the entire circuit and peripherals is normally divided by 2 before being used by the CPU core and peripherals. In 6T mode, this divider is bypassed. This facility provides the same performance when operating with a 24MHz oscillator in 12T mode as with a 12MHz oscillator in 6T mode, for example. The user may choose a divided-by-2 frequency oscillator in 6T mode to reach the same performance as in the original 12T mode. Therefore, it reduces EMI and power consumption if 6T mode is used. - 102 - Publication Release Date: March 11, 2010 Revision: V2.0 CONFIG3 7 CWDTEN r/w 6 EN6T r/w 5 ROG r/w 4 CKF r/w 3 INTOSCFS r/w 2 1 0 FOSC r/w unprogrammed value: 1111 1111b Bit Name Description 6 EN6T Enable 6T mode. This bit switches MCU between 12T and 6T mode. See Figure 20–1. Clock System Block Diagram for definitions in details. 1 = MCU runs at 12T mode. Each machine-cycle is equal to 12 clocks of system oscillator. The operating mode is the same as a standard 8051 MCU. (FCPU and FPERIPH is a half of FOSC.) 0 = MCU runs at 6T mode. Each machine-cycle is equal to 6 clocks of system oscillator. This mode doubles the whole chip operation compared with the standard 8051. (FCPU and FPERIPH is equal to FOSC.) 5 ROG Reducing oscillator gain. 1 = Use normal gain for crystal oscillating. The crystal frequency can be up to 40MHz. 0 = Use reduced gain for crystal oscillating. The crystal frequency should be lower than 24MHz. In reduced gain mode, it will also help to decrease EMI. 4 CKF Clock filter enable. 1 = Enable clock filter. It increases noise immunity and EMC capacity. 0 = Disable clock filter. 3 INTOSCFS 2 - 1 FOSC 0 - Internal RC oscillator frequency select. 1 = Select 22.1184MHz as the system clock if internal RC oscillator mode is used. It bypasses the divided-by-2 path of internal oscillator to select 22.1184MHz output as the system clock source. 0 = Select 11.0592MHz as the system clock if internal RC oscillator mode is used. The internal RC divided-by-2 path is selected. The internal oscillator is equivalent to 11.0592MHz output used as the system clock. Reserved. Oscillator selection bit. This bit selects the source of the system clock. 1 = Crystal, resonator, or external clock input. 0 = Internal RC oscillator. Reserved. - 103 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet CHPCON – Chip Control (TA protected) 7 6 5 4 3 2 1 0 SWRST ISPF LDUEN XRAMEN BS ISPEN w r/w r/w r/w r/w r/w Address: 9FH reset value: see Table 6–2. N78E059A/N78E055A SFR Descriptions and Reset Values Bit Name 0 ISPEN Description ISP enable. 0 = Enable ISP function. 1 = Disable ISP function. To enable ISP function will start the internal 22.1184MHz RC oscillator for timing control. To clear ISPEN should always be the last instruction after ISP operation in order to stop internal RC for reducing power consumption. PMC – Power Monitoring Control (TA protected) 7 6 5 4 3 2 1 0 BODEN BORST BOF LPBOD BOS r/w r/w r/w r/w r Address: ACH reset value: see Table 6–2. N78E059A/N78E055A SFR Descriptions and Reset Values Bit Name Description 3 LPBOD Low power Brown-out detection enable. This bit switches the Brown-out detection into a power saving mode. This bit is only effective while BODEN = 1. 0 = Disable Brown-out power saving mode. Brown-out detection operates in normal mode if enabled. The detection is always on. 1 = Enable Brown-out power saving mode. Brown-out detection operates in power saving mode if enabled. Enable this bit will switch on internal 10kHz RC to be a timer for about 12.8ms interval of detection. The discrete detection will save much power but the hysteresis feature disappears. 20.2 External Clock Source The system clock source can be from external XTAL1 pin. When XTAL1 pin is driven by an external clock source, XTAL2 should be left floating. XTAL1 and XTAL2 are the input and output, respectively, of an internal inverting amplifier. A crystal or resonator can be used by connecting between XTAL1 and XTAL2 pins. The crystal or resonator frequency from 4MHz up to 40MHz is allowed. While an external crystal or resonator is used, ROG (CONFIG3.5) is for half gain selection of the inverting amplifier. When the system clock is lower than 24MHz and ROG is configured as a 0, the system EMI can be reduced. CKF (CONFIG3.4) is the control bit of clock filter circuit of XTAL1 input pin. 20.3 On-chip RC Oscillator The on-chip RC oscillator is enabled while FOSC (CONFIG3.1) is 0. Setting INTOSCFS (CONFIG3.3) logic 0 will switch to a divided-by-2 path. Note that a 0.1μF capacitor is recommended to be added on XTAL1 pin to gain the more precise frequency of the internal RC oscillator frequency if it is selected as the system clock source. - 104 - Publication Release Date: March 11, 2010 Revision: V2.0 21. POWER MONITORING In order to prevent incorrect execution during power up and power drop, N78E059A/N78E055A provides three power monitor functions, power-on detection, Brown-out detection, and low power detection. 21.1 Power-on Detection The power-on detection function is designed for detecting power up after power voltage reaches to a level about 2.0V where the system can work. After power-on detected, the POF (PCON.4) will be set 1 to indicate a cold reset, a power-on reset complete. The POF flag can be cleared via software. 21.2 Brown-out Detection The other power monitoring function, Brown-out detection circuit is for monitoring the VDD level during execution. There are four programmable Brown-out trigger levels available for wide voltage applications. The four nominal levels are 2.2V, 2.7V, 3.8V, and 4.5V selected via setting CBOV[1:0] in CONFIG2. When VDD drops to the selected Brown-out trigger level (VBOD), the Brown-out detection logic will either reset the CPU or request a Brown-out interrupt. The user may determine Brown-out reset or interrupt enable according to different application systems. The Brown-out detection will request the interrupt while VDD drops below VBOD while BORST (PMC.4) is 0. In this case, BOF (PMC.3) will set as a 1. After the user cleared this flag whereas VDD remains below VBOD, BOF will not set again. BOF just acknowledge the user a power drop occurs. The BOF will set 1 after V DD goes higher than VBOD to indicate a power resuming. The Brown-out circuit provides an useful status indicator BOS (PMC.0), which is helpful to tell a Brown-out event or power resuming event occurrence. If BORST bit is set, this will enable Brown-out reset function. After a Brown-out reset, BORF (RSR.2) will set 1 via hardware. It will not be altered by reset other than power-on. Software can clear this bit. VBOD has a hysteresis of 20~200mV. The Brown-out detection circuit also provides a low power Brown-out detection mode for power saving. When LPBOD is set 1, the Brown-out detection repeatedly senses the power voltage about every 12.8ms. For the interval counting, the internal 10kHz RC oscillator will turn on in Brown-out low power mode. Note that the hysteresis feature will disappear in low power Brown-out detection mode. - 105 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet VDD Brownout Detection BOF or - BOS + 4 VBOD Threshold Voltage Select BORF 1: ON 0: OFF Chip Reset BORST 0 1 CBOV1 CBOV0 Brownout Interrupt Always On LPBOD On/Off Interval Counter Internal 10KHz RC BODEN Figure 21–1. Brown-out Detection Block Diagram Power VDD VBODn VPOR Power-on Power fail event Brown-out event VSS [1] POF BOS[2] BOF[2] Reset status [1] 1 = reset state 0 = free running TBOR [3] TBOR ------ brownout reset disabled —— brownout reset enabled [1] POF and BOF are both cleared by software. [2] Brown-out reset is disabled. While the whole brown-out detection circuit disabled, BOS and BOF will keep 0. [3] TBOR ~= 8ms Figure 21–2. Power Monitoring Timing Diagram - 106 - Publication Release Date: March 11, 2010 Revision: V2.0 CONFIG2 7 CBODEN r/w 6 CBOV1 r/w Bit Name 7 CBODEN 6 CBOV1 5 CBOV0 4 CBORST 5 CBOV0 r/w 4 CBORST r/w 3 - 2 1 0 unprogrammed value: 1111 1111b Description CONFIG Brown-out detect enable. 1 = Enable Brown-out detection. 0 = Disable Brown-out detection. CONFIG Brown-out voltage select. These two bits select one of four Brown-out voltage level. CBOV1 CBOV0 Brown-out Voltage 1 1 2.2V 1 0 2.7V 0 1 3.8V 0 0 4.5V CONFIG Brown-out reset enable. This bit decides if a Brown-out reset is caused after a Brown-out event. 1 = Enable Brown-out reset when VDD drops below VBOD. 0 = Disable Brown-out reset when VDD drops below VBOD. PMC – Power Monitoring Control (TA protected) 7 6 5 4 3 2 1 0 BODEN[1] BORST[1] BOF LPBOD BOS r/w r/w r/w r/w r Address: ACH reset value: see Table 6–2. N78E059A/N78E055A SFR Descriptions and Reset Values Bit Name Description 7 BODEN 6:5 - 4 BORST 3 BOF Brown-out flag. This flag will be set as a logic 1 via hardware after a VDD dropping below or rising above VBOD event occurs. If both EBOD (EIE.2) and EA (IE.7) are set, a Brownout interrupt requirement will be generated. This bit must be cleared via software. 3 LPBOD Low power Brown-out detection enable. This bit switches the Brown-out detection into a power saving mode. This bit is only effective while BODEN = 1. 0 = Disable Brown-out power saving mode. Brown-out detection operates in normal mode if enabled. The detection is always on. 1 = Enable Brown-out power saving mode. Brown-out detection operates in power saving mode if enabled. Enable this bit will switch on internal 10kHz RC to be a timer for about 12.8ms interval of detection. The discrete detection will save much power but the hysteresis feature disappears. Brown-out detect enable. 0 = Disable Brown-out detection. 1 = Enable Brown-out detection. Reserved. Brown-out reset enable. This bit decides if a Brown-out reset is caused after a Brown-out event. 0 = Disable Brown-out reset when VDD drops below VBOD. 1 = Enable Brown-out reset when VDD drops below VBOD. - 107 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Bit Name 1 - Description Reserved. Brown-out status. This bit indicates the VDD voltage level comparing with VBOD while Brown-out circuit is enabled. It is helpful to tell a Brown-out event or power resuming event occurrence. This bit is read-only and keeps 0 if Brown-out detection is not enabled. 0 = VDD voltage level is higher than VBOD. 1 = VDD voltage level is lower than VBOD. [1] BODEN and BORST will be directly loaded from CONFIG2 bit 7 and bit 4 after all resets. 0 BOS Table 21–1. BOF Reset Value Reset source CBODEN (CONFIG2.7) CBORST (CONFIG2.4) VDD stable level BOF Brown-out reset 1 1 > VBOD always 1 1 1 > VBOD always 1 1 0 > VBOD 1 1 0 < VBOD 0 0 X X 0 Other resets Note that if BOF is 1 after chip reset, it is strongly recommended to initialize the user’s program by clearing BOF. PCON – Power Control 7 6 5 4 3 2 1 0 SMOD POF GF1 GF0 PD IDL r/w r/w r/w r/w r/w r/w Address: 87H reset value: see Table 6–2. N78E059A/N78E055A SFR Descriptions and Reset Values Bit Name 4 POF Description Power-on reset flag. This bit will be set as 1 after a power-on reset. It indicates a cold reset, a poweron reset complete. This bit remains its value after any other resets. This flag is recommended to be cleared via software. - 108 - Publication Release Date: March 11, 2010 Revision: V2.0 22. RESET CONDITIONS N78E059A/N78E055A has several options to place device in reset condition. It also offers the software flags to indicate the source, which causes a reset. In general, most SFRs go to their reset value irrespective of the reset condition, but there are several reset source indicating flags whose state depends on the source of reset. The user can read back these flags to determine the cause of reset using software. There are 5 ways of putting the device into reset state. They are power-on reset, RST pin reset, software reset, Watchdog Timer reset, and Brown-out reset. RSR – Reset Status Register 7 6 5 4 3 2 1 0 BORF SWRF r/w r/w Address: 96H reset value: see Table 6–2. N78E059A/N78E055A SFR Descriptions and Reset Values Bit Name 7:3 - 2 BORF 1 - 0 SWRF Description Reserved. Brown-out reset flag. When the MCU is reset by Brown-out reset, this bit will be set via hardware. This flag is recommended to be cleared via software. Reserved. Software reset flag. When the MCU is reset via software reset, this bit will be set via hardware. This flag is recommended to be cleared via software. PCON – Power Control 7 6 5 4 3 2 1 0 SMOD POF GF1 GF0 PD IDL r/w r/w r/w r/w r/w r/w Address: 87H reset value: see Table 6–2. N78E059A/N78E055A SFR Descriptions and Reset Values Bit Name 4 POF Description Power-on reset flag. This bit will be set as 1 after a power-on reset. It indicates a cold reset, a poweron reset complete. This bit remains its value after any other resets. This flag is recommended to be cleared via software. - 109 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet WDCON – Watchdog Timer Control (TA protected) 7 6 5 4 3 2 1 0 WDTEN WDCLR WIDPD WDTRF WPS2 WPS1 WPS0 r/w w r/w r/w r/w r/w r/w Address: AAH reset value: see Table 6–2. N78E059A/N78E055A SFR Descriptions and Reset Values Bit Name 3 WDTRF Description Watchdog Timer reset flag. When the CPU is reset by Watchdog Timer time-out event, this bit will be set via hardware. This flag is recommended to be cleared via software. 22.1 Power-on Reset N78E059A/N78E055A incorporate an internal voltage reference. During a power-on process of rising power supply voltage VDD, this voltage reference will hold the CPU in power-on reset mode when VDD is lower than the voltage reference threshold. This design makes CPU not access program flash while the VDD is not adequate performing the flash reading. If a undetermined operating code is read from the program flash and executed, this will put CPU and even the whole system in to a erroneous state. After a while, VDD rises above the reference threshold where the system can work, the selected oscillator will start and then program code will be executed from 0000H. At the same time, a power-on flag POF (PCON.4) will be set 1 to indicate a cold reset, a power-on reset complete. Note that the contents of internal RAM will be undetermined after a power-on. The user is recommended to give initial values for the RAM block. The POF is recommended to be cleared to 0 via software in order to check if a cold reset or warm reset performed after the next reset occurs. If a cold reset caused by power off and on, POF will be set 1 again. If the reset is a warm reset caused by other reset sources, POF will remain 0. The user may take a different course to check other reset flags and deal with the warm reset event. 22.2 Brown-out Reset Brown-out detection circuit is for monitoring the VDD level during execution. When VDD drops to the selected Brown-out trigger level (VBOD), the Brown-out detection logic will reset the CPU if BORST (PMC.4) setting 1. After a Brown-out reset, BORF (RSR.2) will set 1 via hardware. It will not be altered by any reset other than a power-on reset. Software can clear this bit. 22.3 RST Pin Reset The hardware reset input is RST pin which is the input with a Schmitt trigger. A hardware reset is accomplished by holding the RST pin high for at least two machine-cycles to ensure detection of a valid hardware reset sig- - 110 - Publication Release Date: March 11, 2010 Revision: V2.0 nal. The reset circuitry then synchronously applies the internal reset signal. Thus the reset is a synchronous operation and requires the clock to be running to cause an external reset. Once the device is in reset condition, it will remain so as long as RST pin is 1. After the RST high is removed, the CPU will exit the reset state with in two machine-cycles and begin code executing from address 0000H. There is no flag associated with the RST pin reset condition. However since the other reset sources have flags, the external reset can be considered as the default reset if those reset flags are cleared. If a RST pin reset applies while CPU is in Power Down mode, the way to trigger a hardware reset is slightly different. Since the Power Down mode stops system clock, the reset signal will asynchronously cause the system clock resuming. After the system clock is stable, CPU will enter into the reset state. 22.4 Watchdog Timer Reset The Watchdog Timer is a free running timer with programmable time-out intervals. The user can clear the Watchdog Timer at any time, causing it to restart the count. When the selected time-out occurs, the Watchdog Timer will reset the system directly. The reset condition is maintained via hardware for two machine-cycles. After the reset is removed, the device will begin execution from 0000H. Once a reset due to Watchdog Timer occurs the Watchdog Timer reset flag WDTRF (WDCON.3) will be set. This bit keeps unchanged after any reset other than a power-on reset. The user may clear WDTRF via software. 22.5 Software Reset N78E059A/N78E055A is enhanced with a software reset. This allows the program code to reset the whole system in software approach. It is quite useful in the end of an ISP progress. For example, if an LDROM updating APROM ISP finishes and the code in APROM is correctly updated, a software reset can be asserted to reboot CPU from the APROM in order to check the result of the updated APROM program code immediately. Writing 1 to SWRST (CHPCON.7) will trigger a software reset. Note that this bit is timed access protection. See demo code below. After a software reset the SWRF (RSR.0) will be automatically set via hardware. This bit will be preserved its value after all resets except power-on reset. SWRF can also be cleared via software. - 111 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet CHPCON – Chip Control (TA protected) 7 6 5 4 3 2 1 0 SWRST ISPF LDUEN XRAMEN BS ISPEN w r/w r/w r/w r/w r/w Address: 9FH reset value: see Table 6–2. N78E059A/N78E055A SFR Descriptions and Reset Values Bit Name 7 SWRST Description Software reset. To set this bit as a logic 1 will cause a software reset. It will automatically be cleared via hardware after reset in finished. The software demo code are listed below. MOV MOV ANL MOV MOV ORL TA,#0Aah TA,#55h CHPCON,#0FDh TA,#0Aah TA,#55h CHPCON,#80h ;TA protection. ; ;BS = 0, reset to APROM. ;Software reset 22.6 Boot Select CONFIG0.7 CHPCON.1 CBS BS Load Power-on reset Watchgod Timer reset Reset and boot from APROM BS = 0 Software reset BS = 1 Reset and boot from LDROM Brownout reset RST-pin reset Figure 22–1. Boot Selecting Diagram N78E059A/N78E055A provides users a flexible boot selection for variant application. The SFR bit BS in CHPCON.1 determines CPU booting from APROM or LDROM after any source of reset. If reset occurs and BS is 0, CPU will reboot from APPROM. Else, the CPU will reboot from LDROM. - 112 - Publication Release Date: March 11, 2010 Revision: V2.0 CONFIG0 7 CBS r/w 6 - 5 - 4 - 3 - 2 1 0 MOVCL LOCK r/w r/w unprogrammed value: 1111 1111b Bit Name Description 7 CBS CONFIG boot select. This bit defines from which block MCU boots after all resets except software reset. 1 = MCU will boot from APROM after all resets except software reset. 0 = MCU will boot from LDROM after all resets except software reset. CHPCON – Chip Control (TA protected) 7 6 5 4 3 2 1 0 SWRST ISPF LDUEN XRAMEN BS[1] ISPEN w r/w r/w r/w r/w r/w Address: 9FH reset value: see Table 6–2. N78E059A/N78E055A SFR Descriptions and Reset Values Bit Name 1 BS Description Boot select. There are different meanings of writing to or reading from this bit. Writing: It defines from which block MCU boots after all resets. 0 = The next rebooting will be from APROM. 1 = The next rebooting will be from LDROM. Reading: It indicates from which block MCU booted after previous reset. 0 = The previous rebooting is from APROM. 1 = The previous rebooting is from LDROM. [1] Note that this bit is initialized by being loaded from the inverted value of CBS bit in CONFIG0.7 at all resets except software reset. It keeps unchanged after software reset. Note that after the CPU is released from all reset state, the hardware will always check the BS bit instead of the CBS bit to determine from APROM or LDROM that the device reboots. 22.7 Reset State The reset state does not affect the on-chip RAM. The data in the RAM will be preserved during the reset. Note that the RAM contents may be lost if the VDD falls below approximately 1.2V. This is the minimum voltage level required for RAM data retention. Therefore, after the power-on reset the RAM contents will be indeterminate. During a power fail condition. If the power falls below the data retention minimum voltage, the RAM contents will also lose. After a reset, most of SFRs go to their initial values except bits which are affected by different reset events. See the notes of Table 6–2. N78E059A/N78E055A SFR Descriptions and Reset Values. The Program Counter - 113 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet is forced to 0000H and held as long as the reset condition is applied. Note that the Stack Pointer is also reset to 07H, therefore the stack contents may be effectively lost during the reset event even though the RAM contents are not altered. After a reset, interrupts and Timers are disabled. The I/O port SFRs have FFH written into them which puts the port pins in a high state. - 114 - Publication Release Date: March 11, 2010 Revision: V2.0 23. AUXILIARY FEATURES ALE is used to enable the address latch that separates the address from the data on Port 0. ALE runs at 1/6 of the Fosc in 12T mode. An ALE pulse is omitted always. The user can turn ALE signal off via setting ALEOFF to reduce EMI. ALEOFF enable will just make ALE activating during external memory access through a MOVC or MOVX instruction. ALE will stay high in other conditions. AUXR – Auxiliary Register 7 6 Address: 8EH Bit Name 7:1 - 0 ALEOFF 5 - 4 - 3 - 2 - 1 0 ALEOFF r/w reset value: 0000 0000b Description Reserved. ALE output off. 0 = ALE is emitted always. 1 = ALE is off normally and active only during external memory access through a MOVX or MOVC instruction. - 115 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet 24. CONFIG BYTES N78E059A/N78E055A has several hardware configuration bytes, called CONFIG bytes, those are used to configure the hardware options such as the security bits, system clock source, and so on. These hardware options can be re-configured through the Programmer/Writer or ISP modes. N78E059A/N78E055A has three CONFIG bytes those are CONFIG0, 2, and 3. Several functions which are defined by certain CONFIG bits are also available to be re-configured by certain SFR bits. Therefore, there is a need to load such CONFIG bits into respective SFR bits. Such loading will occurs after resets. (Software reset will reload all CONFIG bytes except CBS bit in CONFIG0.) These SFR bits can be continuously controlled via user‟s software. Note that CONFIG bits marked as “-“ should always keep unprogrammed. CONFIG0 7 CBS r/w 6 - 5 - 4 - 3 - 2 1 0 MOVCL LOCK r/w r/w unprogrammed value: 1111 1111b Bit Name Description 7 CBS CONFIG boot select. This bit defines from which block MCU boots after all resets except software reset. 1 = MCU will boot from APROM after all resets except software reset. 0 = MCU will boot from LDROM after all resets except software reset. 6:3 - 2 MOVCL 1 LOCK 0 - Reserved. MOVC lock enable. This bit determines MOVC instruction is inhibited or not when reading internal Program Memory by executing on the external Program Memory. This mechanism is for data security. 1 = MOVC has no restriction. 0 = MOVC is restricted. The external Program Memory code is inhibited to read internal APROM or LDROM contents through MOVC instruction. Chip lock enable. 1 = Chip is unlocked. All of APROM, LDROM, and Data Flash are not locked. Their contents can be read out through a parallel Programmer/Writer. 0 = Chip is locked. APROM, LDROM, and Data Flash are locked. Their contents read through parallel Programmer/Writer will become FFH. Note that CONFIG bytes are always unlocked and can be read. Hence, once the chip is locked, the CONFIG bytes cannot be erased or programmed individually. The only way to disable chip lock is to use the whole chip erase mode. However, all data within APROM, LDROM, Data Flash, and other CONFIG bits will be erased when this procedure is executed. If the chip is locked, it does not alter the ISP function. Reserved. - 116 - Publication Release Date: March 11, 2010 Revision: V2.0 CONFIG0 7 6 5 4 3 2 1 0 CBS - - - - MOVCL LOCK - 7 6 5 4 3 2 1 0 SWRST ISPF LDUE AUXRAM - - BS ISPEN CHPCON Figure 24–1. CONFIG0 Reset Reloading Except Software Reset CONFIG2 7 CBODEN r/w 6 CBOV1 r/w 5 CBOV0 r/w Bit Name 7 CBODEN 6 CBOV1 5 CBOV0 4 CBORST 3:0 CONFIG2 PMC 4 CBORST r/w 3 - 2 1 0 unprogrammed value: 1111 1111b Description CONFIG Brown-out detect enable. 1 = Enable Brown-out detection. 0 = Disable Brown-out detection. CONFIG Brown-out voltage select. These two bits select one of four Brown-out voltage level. CBOV1 CBOV0 Brown-out Voltage 1 1 2.2V 1 0 2.7V 0 1 3.8V 0 0 4.5V CONFIG Brown-out reset enable. This bit decides if a Brown-out reset is caused after a Brown-out event. 1 = Enable Brown-out reset when VDD drops below VBOD. 0 = Disable Brown-out reset when VDD drops below VBOD. Reserved. 7 6 5 4 3 2 1 0 CBODEN CBOV1 CBOV0 CBORST - - - - 7 6 5 4 3 2 1 0 BODEN - - BORST BOF LPBOD - BOS Figure 24–2. CONFIG2 Reset Reloading - 117 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet CONFIG3 7 CWDTEN r/w 6 EN6T r/w 5 ROG r/w 4 CKF r/w 3 INTOSCFS r/w 2 1 0 FOSC r/w unprogrammed value: 1111 1111b Bit Name 7 CWDTEN 6 EN6T Enable 6T mode. This bit switches MCU between 12T and 6T mode. See Figure 20–1. Clock System Block Diagram for definitions in details. 1 = MCU runs at 12T mode. Each machine-cycle is equal to 12 clocks of system oscillator. The operating mode is the same as a standard 8051 MCU. (FCPU and FPERIPH is a half of FOSC.) 0 = MCU runs at 6T mode. Each machine-cycle is equal to 6 clocks of system oscillator. This mode doubles the whole chip operation compared with the standard 8051. (FCPU and FPERIPH is equal to FOSC.) 5 ROG Reducing oscillator gain. 1 = Use normal gain for crystal oscillating. The frequency can be up to 40MHz. 0 = Use reduced gain for crystal oscillating. The frequency should be lower than 24MHz. In reduced gain mode, it will also help to decrease EMI. 4 CKF Clock filter enable. 1 = Enable clock filter. It increases noise immunity and EMC capacity. 0 = Disable clock filter. Note that the clock filter should be always disabled if the crystal frequency is above 24MHz. 3 INTOSCFS Internal RC oscillator frequency select. 1 = Select 22.1184MHz as the system clock if internal RC oscillator mode is used. It bypasses the divided-by-2 path of internal oscillator to select 22.1184MHz output as the system clock source. 0 = Select 11.0592MHz as the system clock if internal RC oscillator mode is used. The internal RC divided-by-2 path is selected. The internal oscillator is equivalent to 11.0592MHz output used as the system clock. 2 - 1 FOSC 0 CONFIG3 WDCON Description CONFIG Watchdog Timer enable. 1 = Disable Watchdog Timer after all resets. 0 = Enable Watchdog Timer after all resets. Reserved. Oscillator selection bit. This bit selects the source of the system clock. 1 = Crystal, resonator, or external clock input. 0 = Internal RC oscillator. Reserved. 7 6 5 4 3 2 1 0 CWDTEN EN6T ROG CKF INTOSCFS - FOSC - 7 6 5 4 3 2 1 0 WDTEN WDCLR - WIDPD WDTRF WPS2 WPS1 WPS0 Figure 24–3. CONFIG3 Reset Reloading - 118 - Publication Release Date: March 11, 2010 Revision: V2.0 25. INSTRUCTION SET N78E059A/N78E055A executes all the instructions of the standard 8051 family. All instructions are coded within an 8-bit field called an OPCODE. This single byte must be fetched from Program Memory. The OPCODE is decoded by the CPU. It determines what action the microcontroller will take and whether more operation data is needed from memory. If no other data is needed, then only one byte was required. Thus the instruction is called a one byte instruction. In some cases, more data is needed. These will be two or three byte instructions. Table 25–1 lists all instructions in details. Note of the instruction set and addressing modes are shown below. Rn (n = 0~7) Register R0~R7 of the currently selected Register Bank. direct 8-bit internal data location‟s address. This could be an internal data RAM location (0~ 127) or a SFR (e.g., I/O port, control register, status register, etc. (128~255)). @Ri (i = 0, 1) 8-bit internal data RAM location (0~255) addressed indirectly through register R0 or R1. #data 8-bit constant included in the instruction. #data16 16-bit constant included in the instruction. addr16 16-bit destination address. Used by LCALL and LJMP. A branch can be anywhere within the 64k-byte Program Memory address space. addr11 11-bit destination address. Used by ACALL and AJMP. The branch will be within the same 2k-byte page of Program Memory as the first byte of the following instruction. rel Signed (2‟s complement) 8-bit offset byte. Used by SJMP and all conditional branches. Range is -128 to +127 bytes relative to first byte of the following instruction. bit Direct addressed bit in internal data RAM or SFR. Table 25–1. Instruction Set for N78E059A/N78E055A Bytes Clock Cycles in 12T Mode Clock Cycles in 6T Mode 00 1 12 6 Instruction NOP OPCODE ADD A, Rn 28~2F 1 12 6 ADD A, @Ri 26, 27 1 12 6 ADD A, direct 25 2 12 6 ADD A, #data 24 2 12 6 ADDC A, Rn 38~3F 1 12 6 ADDC A, @Ri 36, 37 1 12 6 ADDC A, direct 35 2 12 6 ADDC A, #data 34 2 12 6 SUBB A, Rn 98~9F 1 12 6 SUBB A, @Ri 96, 97 1 12 6 SUBB A, direct 95 2 12 6 SUBB A, #data 94 2 12 6 - 119 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Table 25–1. Instruction Set for N78E059A/N78E055A Instruction OPCODE Bytes Clock Cycles in 12T Mode Clock Cycles in 6T Mode INC A 04 1 12 6 INC Rn 08~0F 1 12 6 INC @Ri 06, 07 1 12 6 INC direct 05 2 12 6 INC DPTR A3 1 24 12 DEC A 14 1 12 6 DEC Rn 18~1F 1 12 6 DEC @Ri 16, 17 1 12 6 DEC direct 15 2 12 6 MUL AB A4 1 48 24 DIV AB 84 1 48 24 DA A D4 1 12 6 ANL A, Rn 58~5F 1 12 6 ANL A, @Ri 56, 57 1 12 6 ANL A, direct 55 2 12 6 ANL A, #data 54 2 12 6 ANL direct, A 52 2 12 6 ANL direct, #data 53 3 24 12 ORL A, Rn 48~4F 1 12 6 ORL A, @Ri 46, 47 1 12 6 ORL A, direct 45 2 12 6 ORL A, #data 44 2 12 6 ORL direct, A 42 2 12 6 ORL direct, #data 43 3 24 12 XRL A, Rn 68~6F 1 12 6 XRL A, @Ri 66, 67 1 12 6 XRL A, direct 65 2 12 6 XRL A, #data 64 2 12 6 XRL direct, A 62 2 12 6 XRL direct, #data 63 3 24 12 CLR A E4 1 12 6 CPL A F4 1 12 6 RL A 23 1 12 6 RLC A 33 1 12 6 RR A 03 1 12 6 RRC A 13 1 12 6 SWAP A C4 1 12 6 MOV A, Rn E8~EF 1 12 6 MOV A, @Ri E6, E7 1 12 6 MOV A, direct E5 2 12 6 - 120 - Publication Release Date: March 11, 2010 Revision: V2.0 Table 25–1. Instruction Set for N78E059A/N78E055A Instruction OPCODE Bytes Clock Cycles in 12T Mode Clock Cycles in 6T Mode 6 MOV A, #data 74 2 12 MOV Rn, A F8~FF 1 12 6 MOV Rn, direct A8~AF 2 24 12 MOV Rn, #data 78~7F 2 12 6 MOV @Ri, A F6, F7 1 12 6 MOV @Ri, direct A6, A7 2 24 12 MOV @Ri, #data 76, 77 2 12 6 MOV direct, A F5 2 12 6 MOV direct, Rn 88~8F 2 24 12 MOV direct, @Ri 86, 87 2 24 12 MOV direct, direct 85 3 24 12 MOV direct, #data 75 3 24 12 MOV DPTR, #data16 90 3 24 12 MOVC A, @A+DPTR 93 1 24 12 MOVC A, @A+PC 83 1 24 12 MOVX A, @Ri E2, E3 1 24 12 MOVX A, @DPTR E0 1 24 12 MOVX @Ri, A F2, F3 1 24 12 MOVX @DPTR, A F0 1 24 12 PUSH direct C0 2 24 12 POP direct D0 2 24 12 XCH A, Rn C8~CF 1 12 6 XCH A, @Ri C6, C7 1 12 6 XCH A, direct C5 2 12 6 XCHD A, @Ri D6, D7 1 12 6 CLR C C3 1 12 6 CLR bit C2 2 12 6 SETB C D3 1 12 6 SETB bit D2 2 12 6 CPL C B3 1 12 6 CPL bit B2 2 12 6 ANL C, bit 82 2 24 12 ANL C, /bit B0 2 24 12 ORL C, bit 72 2 24 12 ORL C, /bit A0 2 24 12 MOV C, bit A2 2 12 6 MOV bit, C 92 2 24 12 ACALL addr11 11, 31, 51, 71, 91, [1] B1, D1, F1 2 24 12 LCALL addr16 12 3 24 12 - 121 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Table 25–1. Instruction Set for N78E059A/N78E055A Bytes Clock Cycles in 12T Mode Clock Cycles in 6T Mode 22 1 24 12 Instruction RET RETI OPCODE 32 1 24 12 AJMP addr11 01, 21, 41, 61, 81, [2] A1, C1, E1 2 24 12 LJMP addr16 02 3 24 12 JMP @A+DPTR 73 1 24 12 SJMP rel 80 2 24 12 JZ rel 60 2 24 12 JNZ rel 70 2 24 12 JC rel 40 2 24 12 JNC rel 50 2 24 12 JB bit, rel 20 3 24 12 JNB bit, rel 30 3 24 12 JBC bit, rel 10 3 24 12 CJNE A, direct, rel B5 3 24 12 CJNE A, #data, rel B4 3 24 12 CJNE @Ri, #data, rel B6, B7 3 24 12 CJNE Rn, #data, rel B8~BF 3 24 12 DJNZ Rn, rel D8~DF 2 24 12 DJNZ direct, rel D5 3 24 12 [1] The most three significant bits in the 11-bit address [A10:A8] decide the ACALL hex code. The code will be [A10,A9,A8,1,0,0,0,1]. [2] The most three significant bits in the 11-bit address [A10:A8] decide the AJMP hex code. The code will be [A10,A9,A8,0,0,0,0,1]. - 122 - Publication Release Date: March 11, 2010 Revision: V2.0 26. ELECTRICAL CHARACTERISTICS 26.1 Absolute Maximum Ratings Parameter Rating Unit Operating temperature under bias -40 to +85 C Storage temperature range -55 to +150 C Voltage on VDD pin to VSS -0.3 to +6.5 V -0.3 to (VDD+0.3) V Voltage on any other pin to VSS Stresses at or above those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions may affect device reliability. 26.2 DC Electrical Characteristics Temperature = -40℃~85℃; VSS = 0V; VDD = 4.5V to 5.5V @ F = 0 to 40MHz (12T mode), F = 0 to 33MHz (6T mode) VDD = 2.4V to 5.5V @ F = 0 to 27MHz (12T mode), F = 0 to 20MHz (6T mode) VDD = 3.0V to 5.5V for ISP erasing or programming. Table 26–1. DC Characteristics Symbol Parameter VIL Input low voltage VIH Input high voltage Condition Input high voltage (RST, XTAL1) VOL Output low voltage VOH VOH1 Typ. Max. Unit 0.2VDD – 0.1 V (Ports 0 ~ 4, EA ) VIH1 Min. [1] Output high voltage (Ports 1 ~ 4 and Port 0 with internal pull-up enabled) 0.2VDD + 0.9 V 0.7VDD V VDD = 4.5V, IOL = 8.2mA VDD = 3.0V, IOL = 5.8mA VDD = 2.4V, IOL = 4.4mA 0.4 V VDD = 4.5V, IOH = -300μA VDD = 3.0V, IOH = -75μA VDD = 2.4V, IOH = -35μA 2.4 2.4 2.0 V Output high voltage VDD = 4.5V, IOH = -9mA (Ports 0 and 2 in external bus VDD = 3.0V, IOH = -2.4mA VDD = 2.4V, IOH = -1.3mA mode, ALE, PSEN ) 2.4 2.4 2.0 V - 123 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Symbol IIL ITL Parameter Condition Logical 0 input current (Ports 1 ~ 4 and Port 0 with internal pull-up enabled) VDD = 5.5V, VIN = 0.4V VDD = 3.6V, VIN = 0.4V Logical 1-to-0 transition cur[2] rent (Ports 1~4 and Port 0 with internal pull-up enabled) VDD = 5.5V VDD = 3.6V ILI Input leakage current (Port 0) 0 < VIN < VDD IDD Supply current IID [3] Idle mode current Min. Typ. -570 -240 Max. Unit -50 -20 μA -650 -290 μA ±10 μA VDD = 5.0V, external clock, 12T 0.21F + 3.5 mA VDD = 3.3V, external clock, 12T 0.15F + 2.9 mA VDD = 5.0V, external clock, 6T 0.35F + 3.3 mA VDD = 3.3V, external clock, 6T 0.32F + 2.3 mA VDD = 5.0V, internal 22.1184MHz, 12T 4.8 mA VDD = 3.3V, internal 11.0592MHz, 12T 3.4 mA VDD = 5.0V, internal 22.1184MHz, 6T 7.0 mA VDD = 3.3V, internal 11.0592MHz, 6T 4.5 mA VDD = 5.0V, external clock, 12T 0.11F + 2.0 mA VDD = 3.3V, external clock, 12T 0.09F + 0.9 mA VDD = 5.0V, external clock, 6T 0.15F + 1.7 mA VDD = 3.3V, external clock, 6T 0.14F + 0.7 mA VDD = 5.0V, internal 22.1184MHz, 12T 1.5 mA VDD = 3.3V, internal 11.0592MHz, 12T 1.2 mA VDD = 5.0V, internal 22.1184MHz, 6T 2.0 mA VDD = 3.3V, internal 11.0592MHz, 6T 1.4 mA 35 μA 800 kΩ IPD Power Down mode current 2 RRST RST pin internal pull-down resistor VBOD0 Brown-out threshold 2.2V 2.05 2.2 2.3 V VBOD1 Brown-out threshold 2.7V 2.6 2.7 2.85 V VBOD2 Brown-out threshold 3.8V 3.65 3.8 4.0 V VBOD3 Brown-out threshold 4.5V 4.35 4.5 4.75 V 200 mV 2.4 < VDD < 5.5V 45 VBODHYS Brown-out hysteresis VPOR 20 Power-on reset threshold 2.0 V [1] Under steady state (non-transient) conditions, IOL must be externally limited as follows, Maximum IOL per port pin: 20mA Maximum IOL per 8-bit port: 40mA Maximum total IOL for all outputs: 100mA [2] Pins of ports 1~4 and port 0 with internal pull-up enabled will source a transition current when they are being externally driven from 1 to 0. The transition current reaches its maximum value when VIN is approximately 1.5V ~ 2.5V. [3] It is measured while MCU keeps in running SJMP $ loop continuously. P0 is externally or internally pulled-up. - 124 - Publication Release Date: March 11, 2010 Revision: V2.0 Figures below shows supply and Idle mode current under 12T/6T with internal program memory mode. Figure 26–1. Supply Current Under 12T Mode, External Clock (1) Figure 26–2. Supply Current Under 12T Mode, External Clock (2) - 125 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Figure 26–3. Supply Current Under 6T Mode, External Clock (1) Figure 26–4. Supply Current Under 6T Mode, External Clock (2) - 126 - Publication Release Date: March 11, 2010 Revision: V2.0 Figure 26–5. Idle Mode Current Under 12T Mode, External Clock (1) Figure 26–6. Idle Mode Current Under 12T Mode, External Clock (2) - 127 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Figure 26–7. Idle Mode Current Under 6T Mode, External Clock (1) Figure 26–8. Idle Mode Current Under 6T Mode, External Clock (2) - 128 - Publication Release Date: March 11, 2010 Revision: V2.0 26.3 AC Electrical Characteristics Table 26–2. AC Characteristics 12T mode Symbol 6T mode Parameter Unit Min. Max. Min. Max. External clock input frequency 0 40 0 33 Crystal/resonator frequency 4 40 4 33 tCHCX High time 12 15 ns tCLCX Low time 12 15 ns tCLCH Rise time 8 5 ns tCHCL Fall time 8 5 ns External Clock 1/ tCLCL MHz Program Memory tLHLL ALE pulse width 2 tCLCL -15 tCLCL -15 ns tAVLL Address valid to ALE low tCLCL -15 0.5 tCLCL -15 ns tLLAX Address hold after ALE low tCLCL -15 0.5 tCLCL -15 ns tLLIV ALE low to valid instruction in tLLPL ALE low to PSEN low tPLPH PSEN pulse width tPLIV PSEN low to valid instruction in tPXIX Input instruction hold after PSEN tPXIZ Input instruction float after PSEN tAVIV Address to valid instruction in tPLAZ PSEN low to address float 4 tCLCL -45 2 tCLCL -45 ns tCLCL -15 0.5 tCLCL -15 ns 3 tCLCL -15 1.5 tCLCL -15 ns 3 tCLCL -50 0 1.5 tCLCL -50 0 ns ns tCLCL -15 0.5 tCLCL -15 ns 5 tCLCL -60 2.5 tCLCL -60 ns 10 10 ns Data Memory tRLRH RD pulse width 6 tCLCL -30 3 tCLCL -30 ns tWLWH WR pulse width 6 tCLCL -30 3 tCLCL -30 ns tRLDV RD low to valid data in tRHDX Data hold after RD tRHDZ Data float after RD 2 tCLCL -12 tCLCL -12 ns tLLDV ALE low to valid data in 8 tCLCL -50 4 tCLCL -50 ns tAVDV Address to valid data in 9 tCLCL -75 4.5 tCLCL -75 ns tLLWL ALE low to RD or WR low 1.5 tCLCL +15 ns 5 tCLCL -50 0 2.5 tCLCL -50 0 3 tCLCL -15 - 129 - 3 tCLCL +15 1.5 tCLCL -15 ns ns Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet 12T mode Symbol 6T mode Parameter Unit Min. tAVWL Address valid to WR low or RD low tQVWX Max. Min. Max. 4 tCLCL -30 2 tCLCL -30 ns Data valid to WR transition tCLCL -20 0.5 tCLCL -20 ns tWHQX Data hold after WR tCLCL -15 0.5 tCLCL -15 ns tRLAZ RD low to address float tWHLH RD or WR high to ALE high 0 tCLCL -15 tCLCL +15 0.5 tCLCL -15 0 ns 0.5 tCLCL +15 ns Figure 26–9. External Clock Input Timing Figure 26–10. External Program Memory Read Cycle - 130 - Publication Release Date: March 11, 2010 Revision: V2.0 Figure 26–11. External Data Memory Read Cycle Figure 26–12. External Data Memory Write Cycle - 131 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Table 26–3. Characteristics of On-chip RC Oscillators Symbol FIHRC FILRC Parameter [1][2] System 22.1184MHz RC oscillator frequency Condition Frequency Deviation 25℃ 1% 21.8972 22.1184 22.3396 MHz -40℃~85℃ 3% 21.4548 22.1184 22.7820 MHz WDT and PDT 10kHz RC oscillator frequency 30% Min. Typ. 7 10 Max. 13 Unit kHz [1] Internal 11.0592MHz is not listed for the same frequency deviation due to directly divided by 2 from 22.1184MHz source. [2] A 0.1μF capacitor is recommended to be added on XTAL1 pin to gain the more precise frequency of the internal RC oscillator frequency if it is selected as the system clock source. Table 26–4. Characteristics of Brown-out Detection Symbol TBOD Parameter Brown-out detect pulse width TBODRD Brown-out release delay period Condition Min. Typ. Max. Unit VDD < VBOD 600 - - μs VDD > VBOD 5.6 8 10.4 ms - 132 - Publication Release Date: March 11, 2010 Revision: V2.0 27. PACKAGES D 40 21 1 20 1 E E S c 2 1 AA A Base Plane Seating Plane L B e1 α B1 Symbol A A1 A2 B B1 c D E E1 e1 L α eA S Dimension in inch eA Dimension in mm Min Nom Max Min Nom Max 5.33 0.210 0.010 0.25 0.150 0.155 0.160 3.81 3.94 4.06 0.016 0.018 0.022 0.41 0.46 0.56 0.048 0.050 0.054 1.22 1.27 1.37 0.008 0.010 0.014 0.20 0.25 0.36 2.055 2.070 52.20 52.58 0.590 0.600 0.610 14.99 15.24 15.49 0.540 0.545 0.550 13.72 13.84 13.97 0.090 0.100 0.110 2.29 2.54 2.79 0.120 0.130 0.140 3.05 3.30 3.56 0 15 0 15 0.630 0.650 0.670 16.00 16.51 17.02 0.090 2.29 Figure 27–1. DIP-40 Package Dimention - 133 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet HD D 6 1 44 40 7 39 E E E H 17 G 29 18 28 c L 2 A e 1 b b1 Seating Plane A A y GD Symbol A A1 A2 b1 b c D E e GD GE HD HE L y Dimension in inch Min Nom Dimension in mm Max Min Nom 0.185 Max 4.70 0.020 0.51 0.145 0.150 0.155 3.68 3.81 3.94 0.026 0.028 0.032 0.66 0.71 0.81 0.016 0.018 0.022 0.41 0.46 0.56 0.008 0.010 0.014 0.20 0.25 0.36 0.648 0.653 0.658 16.46 16.59 16.71 0.648 0.653 0.658 16.46 16.59 16.71 0.050 1.27 BSC BSC 0.590 0.610 0.630 14.99 15.49 16.00 0.590 0.610 0.630 14.99 15.49 16.00 0.680 0.690 0.700 17.27 17.53 17.78 0.680 0.690 0.700 17.27 17.53 17.78 0.090 0.100 0.110 2.29 2.54 2.79 0.004 0.10 Figure 27–2. PLCC-44 Package Dimention - 134 - Publication Release Date: March 11, 2010 Revision: V2.0 HD D 34 44 33 1 E E H 11 12 e b 22 c 2 A A Seating Plane 1 See Detail F L A y L1 Symbol A A1 A2 b c D E e HD HE L L1 y 0 Dimension in inch Dimension in mm Min Nom Max Min Nom Max - 0.002 0.01 0.02 0.05 0.25 0.5 0.075 0.081 0.087 1.90 2.05 2.20 0.01 0.014 0.018 0.25 0.35 0.45 0.004 0.006 0.010 0.10 0.15 0.390 0.394 0.398 9.9 10.00 10.1 0.390 0.394 0.398 9.9 10.00 10.1 0.510 0.520 0.530 12.95 13.20 13.45 0.510 0.520 0.530 12.95 13.20 13.45 0.025 0.031 0.037 0.65 .0315 0.25 0.80 0.8 0.95 1.60 0.063 0.10 0.004 0 Detail F 10 0 10 Figure 27–3. PQFP-44 Package Dimention - 135 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet Figure 27–4. LQFP-48 Package Dimention - 136 - Publication Release Date: March 11, 2010 Revision: V2.0 28. DOCUMENT REVISION HISTORY Version Date V1.0 2010/8/13 V1.1 2010/9/20 V1.2 2010/12/1 V2.0 2011/3/11 Page Description Initial release. 124 Increase the maximum value of Power Down mode current. 80 95 86 1. 2. 3. 4. Combine N78E059A and N78E055A into one data sheet. Add restriction of disabling interrupts during TA protected writing. Add restriction of disabling interrupts during ISP. Add more descriptions of software clearing interrupt flags. 29 Change XRAM default state “enabled” after all resets to fit general applications. Technical Supporting Web 80C51 8-bit MCU Series http://www.nuvoton.com/80C51 - 137 - Publication Release Date: March 11, 2010 Revision: V2.0 N78E059A/N78E055A Data Sheet More product details and update information, please visit our website: www.nuvoton.com Headquarter-Taiwan Nuvoton Technology Corp. No. 4, Creation Rd. Ill, Hsinchu Science Park, 300 Taiwan TEL: 886-3-5770066 Worldwide Sales Offices Taipei Sales Office Nuvoton Technology Corp. America 8F, No. 480, Rueiguang Rd., Neihu Chiu, Taipei, 114 Taiwan TEL: 886-2-26588066 2727 N. First Street, San Jose, CA 95134, U.S.A. TEL: 1-408-544-1718 Nuvoton Electronics Tech. (Shenzhen) Limited Nuvoton Electronics Tech. (H.K.) Limited Unit 1501, New World Center, 6009 Yitian Road, Futian, Shenzhen, P.R.China 518026 TEL: 86-755-83515350 Unit 9-11, 22F, Millennium City 2, 378 Kwun Tong Road, Kowloon, Hong Kong TEL: 852-27513100 Important Notice Nuvoton Products are neither intended nor warranted for usage in systems or equipment, any malfunction or failure of which may cause loss of human life, bodily injury or severe property damage. Such applications are deemed, “Insecure Usage”. Insecure usage includes, but is not limited to: equipment for surgical implementation, atomic energy control instruments, airplane or spaceship instruments, the control or operation of dynamic, brake or safety systems designed for vehicular use, traffic signal instruments, all types of safety devices, and other applications intended to support or sustain life. All Insecure Usage shall be made at customer’s risk, and in the event that third parties lay claims to Nuvoton as a result of customer’s Insecure Usage, customer shall indemnify the damages and liabilities thus incurred by Nuvoton. - 138 - Publication Release Date: March 11, 2010 Revision: V2.0
N78E055APG 价格&库存
很抱歉,暂时无法提供与“N78E055APG”相匹配的价格&库存,您可以联系我们找货
