Compliance
References
Edge Connectors,
One-Sided Boards
EuroMag Series
Terminal Blocks:
Single Row
Edge Connectors - 1 Sided Boards/Vertical Mount
Series 1384X
Edge Connectors –
SPECIFICATIONS
13848-08G02B
Rating: 10A, 250V
3
Center Spacing: 0.375” or ⁄8” (9.52mm)
Wire Range: #14-22 AWG Cu; entry to PC board at 90° angle.
Number of Poles: 4- to 16-poles
PC Board: Edge contact accepts standard 1⁄16” (0.0625) PCB.
Contacts: Cantilever design 0.02” thick phosphorus bronze
with mating surface tin-plated (0.0002) over copper (0.00005).
Terminals: Pressure plate terminals.
Material: Black, UL Rated 94V0 Thermoplastic (125°C)
Operating Temperature: -55°C to 105°C (212°F)
Agency Information: File E62622; CSA File 47235
13847-08TO2B
Dimensions - in (mm)
Poles
A
B
C
D
04
05
06
08
10
12
14
16
18
2.25
2.62
3.00
3.75
4.50
5.25
6.00
6.75
7.50
1.87
2.25
2.62
3.37
4.12
4.87
5.62
6.37
7.12
1.12
1.50
1.87
2.62
3.37
4.12
4.87
5.62
6.37
1.53
1.90
2.28
3.03
3.78
4.53
5.28
6.03
6.40
13847 Series
A
B
C
0.89
(22.6)
0.15
(3.9)
D
* Dimensions in inches. To convert to millimeters, multiply by 25.4.
Optional polarizing key (Part No. C5971) consult with factory.
1.03
(26.2)
13848 Series
A
B
C
0.15
(3.9)
1
1.03
(26.2)
2
3
4
5
Ø.06
(Ø1.5)
6
11
12
13
14
15
D
Ø.09
(Ø 2.3)
Part Numbering System
1n
3n
8n
4
n
Series
n
Block Style
nn
Poles
7 - Flat mtg. ears
04 to 18
w/ 2 slots
8 - Mtg. ears w/2 standoffs
with hole for mounting strip
Terminal Plating
Screw Style
n
0n
2
n
B
n
T - Tin over copper
02 - #6-32 pan head.
w/ SEMS wire
clamp
B - Black
Block Color
n
Special Options
M - Marking strip
* Consult Factory
For additional product information, visit www.eaton.com/connectors
108
很抱歉,暂时无法提供与“13847-10T02B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 250+245.55228250+30.72827
