GBFTX-19
GBFTX-19
    CURTISINDUSTRIES
    GBFTX-19
GBFTX-19 数据手册
Series GFT/GB 7/16" (11.11mm) Center-to-Center Spacing Single Row Features: Series GFT/GB Variations .718 (18,24) BARRIER STYLE ‡ Superior Construction – All terminals are molded in place with precision screw machined brass inserts which will not twist Yirtually eliminating broNen solder Moints while proYiding a full mechanical thread system. ‡ Ideal for Sub-Chassis or Thru-Panel Application – No costly insulation or mounting set-up since feed-thru insulators are an integral part of the moldings. Feature provides a full 1/4" terminal to ground clearance even thru 1/16" chassis. ‡ Durable Base Material – Made of black thermo-set phenolic, or high-impact, break-resistant thermoplastic ‡ Electrical Rating – 20A up to 600V ‡ Compact Barrier-Type Design – Especially suited for electronic and control applications ‡ Feed-Thru, Printed Circuit or Surface Connection – One thru 26 terminals on 7/16" center-to-center spacing ‡ Broad Wire Range – UL recognized for No. 22AWG to No. 12AWG, depending on type of external contact designated, with CSA requiring use of lugs on wire larger than No. 16AWG. ‡ Terminal Flexibility – External terminals available in two screw sizes with various internal terminal types ‡ Recognition and Listing – UL recognized and CSA certified .078 (18,24) GFTX turrettype solder pin .312 (7,92) .312 (7,92) Recognized under the Components Program of Underwriters Laboratories, Inc. Standard 1059, Guide No. XCFR2, File No. E62557. GFTPX .062" dia. printed circuit pin Guide No. 22.2 No. 158, Report No. LR39186-1. .203 (5,16) .203 (5,16) INTERNAL TERMINAL DESIGNATIONS .310 to .314 Dia. GFTP GFTSX No. 6-32 machine screw .031 (,79) GFTQLX .250 x .031 QC terminal GFT GFTS GBS GBP GBSX closed-back design .718 (18,24) .513 (13,49) .078 (18,24) .312 (7,92) GBPX .062" dia. printed circuit pin .203 (5,16) GBFTX turret-type solder pin .266 (6,76) 24 www.curtisind.com GBFT GFTQX Printed circuit board design with .062” dia. tin-plated brass turret-type solder pin Tin-plated brass turret-type solder pin Unplated brass insert. No. 6-32 plated steel screw. Unplated brass insert. Closed-back design which can be mounted on metal surface with no additional insulation required. Printed circuit board design with .062” dia. tin plated brass pin. Tin-plated brass turret-type solder pin. .250 x .031 tin-plated brass quick connect tab terminal. EXTERNAL TERMINAL DESIGNATIONS GBFT, GBP, GBS, GFT, GFTP Screw terminal with No. 6-32 plated steel* Screw accepting up to No. 12AWG wire GBFTA, GBPA, Screw terminal with No. 8-32 GBSA, GFTA, plated steel* screw accepting up to GFTSA, GFTPA No. 12AWG wire * Other materials available – contact factory or your local representative for additional information. Curtis Industries A Division of Powers Holdings, Inc. 6SHci¿cDtionssuEMHcttocKDnJH. Dimensions are shown for reference purposes only. SSeFi¿Fations: GB/GFT Series terminal blocks are ordered by listing a composite number made up of the model designatin followed by the number of poles required for the applicaiton. Example: Type GBP 10-pole block becomes stock number GBP-10. Suffixes are used as follows: A denotes model with No. 8-32 external screw terminal C denotes model less mounting positions X denotes model with thermoplastic molding To specify quick-connect terminals, simply add the style number required. May be purchased factory-assembled or as customer-installed accessory. The GBP-10 described above – made from thermo-set phenolic – less mounting positions thus converts to sock number GBPC-10. PC BOARD DRILLING DIMENSIONS .437 Typ. Dimensions Number of Terminals B ± .031 Mounting Dimensions (M.D.) Metric (mm) Inches Metric (mm) Inches C ± .031 Less Mounting Positions Inches Metric (mm) 1 .875 22.22 1.250 31.75 .562 14.28 2 1.312 33.33 1.687 42.86 1.000 25.40 3 1.750 44.45 2.125 53.97 1.437 36.51 4 2.187 55.56 2.562 65.08 1.875 47.62 5 2.625 66.67 3.000 76.20 2.312 58.73 6 3.062 77.78 3.437 87.31 2.750 69.85 7 3.500 88.90 3.875 98.42 3.187 80.96 8 3.937 100.01 4.312 109.53 3.625 92.07 9 4.375 111.12 4.750 120.65 4.062 103.18 10 4.812 122.23 5.187 131.76 4.500 114.30 11 5.250 133.35 5.625 142.87 4.937 125.41 12 5.687 144.46 6.062 153.98 5.375 136.52 13 6.125 155.57 6.500 165.10 5.812 147.63 14 6.562 166.68 6.937 176.21 6.250 158.75 15 7.000 177.80 7.375 187.32 6.687 169.86 16 7.437 188.91 7.812 198.43 7.125 180.97 17 7.875 200.02 8.250 209.55 7.562 192.08 18 8.312 211.13 8.687 220.66 8.000 203.20 19 8.750 222.25 9.125 231.77 8.437 214.31 20 9.187 233.36 9.562 242.88 8.875 225.42 21 9.625 244.47 10.000 254.00 9.312 236.53 22 10.062 255.58 10.437 23 10.500 266.70 10.875 276.22 10.187 258.76 24 10.937 277.81 11.312 287.33 10.625 269.87 25 11.375 288.92 11.750 298.45 11.062 280.98 265.11 9.750 247.65 26 11.812 300.03 12.187 309.56 11.500 292.10 Dimensions shown are ± 0.030" Series GFT/GB with Mounting Ends .187 (4,75) .437 (11,10) O.D. M.D. .718 (18,23) .562 (14,3) 2-11 Terminals Ø.079 (No. 47 Drill) 12 T Terminals and Over Ø.093 (No. 42 Drill) Dimensions are in inches and millimeters unless otherwise speci¿ed. Values in parentheses are metric equivalents. A ± .031 Overall Dimensions (O.D.) BARRIER STYLE How to Order Without Mounting Ends Series GFT/GB With Mounting Ends Single Row Center-to-Center Spacing: 7/16" (11.11mm) Wire Range: No. 22AWG to No. 12AWG (CSA requires use of lugs on wire larger than No. 16AWG.) No. of Terminals: 1 thru 26 Voltage Rating: CSA – 300 volts UL – *150 volts – General Industrial **250 volts – Commercial Applications 300 volts – Limited Energy Applications 600 volts – Limited Energy Applications * GFT, GFTP, GFTS, GFTAL rated for 300 volts. ** GFTQALX rated for 125 volts. Tightening Torque: Wire Binding Screw 9 in.-lb. Wire Clamp 9 in.-lb. Current Rating: 20 amps, UL and CSA Housing: Standard “X” Grade Material Phenolic Polyphenylene Oxide Continuous Use Temp. (UL Index) 150°C (302°F) 110°C (230°F) Flammability Rating 94V-0 94V-0 Water Absorption (24 hrs. % wt. gain) .04% .06% Breakdown Voltage: GFT GB Terminal - Terminal 3,600V Typ. 5,000V Typ. Terminal - Ground 5,800V Typ. 7,900V Typ. Note: Speci¿cations contained herein are subMect to change without notice. .350 (8,89) .190 Dia. Mtfg. Holes (2) (4,82) Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 25 Series GB/GFT Series GFT/GB Accessories QUICK-CONNECT TERMINALS Single Row GFT-GFT – Available with .250" x .032" quick-connect tabs of tin-plated brass, held in place by terminal screws. Six styles . . . one to six terminations per pole. Factory-assembled or customer installed. Last digit of part number corresponds to previous style numbers. .070 (1,78) Dia. Holes (2) .125 (3,175) 1.50 (38,1) .186 (4,72) .035 (,889) .250 .750 (19,05) .175 (6,35) (4,45) .201 (5,11) Dia. Hole .350 (8,89) Part No. TB21 TB21 .500 (12,70) .839 (21,31) 45° 90° TB26 TB22 BARRIER STYLE 1.25 (31,75) 45° TB23 .986 (25,04) .231 (5,87) TB24 .480 (12,19) 90° TB25 26 www.curtisind.com Curtis Industries A Division of Powers Holdings, Inc. Speci¿cations subMect to change. Dimensions are shown for reference purposes only. TINNERMAN NUT GFT – for speed mounting of terminal blocks less mounting position. Part No. TN-437. TERMINAL BLOCK JUMPERS MARKING STRIPS Single Row GB/GFT – Plated in two styles. Types 267A28 is designed to Mump two adMacent terminals as it is channeled to cross over the barrier top. “Rooster comb” design of Type 267A42 permits connections of two to 18 poles. To order, specify: Part No. 267A42 (plus no. of poles) Example: 267A42-18 GB/GFT – Pre-punched black ¿ber . . . mounts under block. May be imprinted to customer speci¿cations. To order, specify: Part No. 267A19-1 thru 26 (with mounting hole); Part No. 267A218-1 thru 26 (less mounting hole). BARRIER STYLE COVERS GB/GFT – Rigid .030" thick self-extinguishing vinyl. Black matte-¿nished on both sides. May double as marking strip when imprinted with white ink. Complete with spring clips for attaching to mounting positions. Part No. 267B86-1 thru 26 terminals Dimensions are in inches and millimeters unless otherwise speci¿ed. Values in parentheses are metric equivalents. Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 27
GBFTX-19
1. 物料型号:文档中提到了多种型号,如GFTX、GFTPX、GFTQLX、GBFTX、GBSX、GBPX等,这些型号具有不同的设计特点,例如闭背式设计或用于印刷电路板的针脚。
2. 器件简介:这些接线端子设计用于电子和控制应用,具有优越的构造,使用精密螺丝机加工的黄铜插入件,提供完整的机械螺纹系统。
3. 引脚分配:文档描述了不同型号的接线端子,包括它们的中心到中心间距、直径、和用于电线的螺丝规格。
4. 参数特性:包括电气额定值(20A至600V)、紧凑的屏障型设计、广泛的电线范围(从22AWG到12AWG)、UL认可和CSA认证。
5. 功能详解:文档强调了接线端子的耐用性、易于安装、无需额外绝缘或安装设置的特点,以及它们如何适用于子底盘或面板穿透应用。
6. 应用信息:适用于多种接线方式,包括穿透式、印刷电路或表面连接,适用于1至26个端子的配置。
7. 封装信息:提供了详细的安装尺寸和钻孔尺寸,以及不同材料的外壳特性,如标准酚醛和X级聚苯醚氧化物。
8. 订购信息:提供了如何根据需要的极数和特定型号来订购产品的信息。
9. 配件:文档还列出了可用于GB/GFT系列的配件,如快速连接端子、标记条、盖子和跨接跳线。
GBFTX-19 价格&库存
很抱歉,暂时无法提供与“GBFTX-19”相匹配的价格&库存,您可以联系我们找货
