KU10-BPWCMT
KU10-BPWCMT
    EATON(伊顿)
    接线端子 间距P=10.00mm
KU10-BPWCMT 数据手册
Connect with Magnum Product Catalog Make Wire Connections Simple and Fast MAGNUM ® Connect with Magnum Proven Products for Demanding Applications For over 50 years, the Magnum name has stood for proven products, custom solutions, quality commitment and superior service – core strengths that help build long-term relationships with our customers. Electronic: Our electronic products, including PCB mountable North American and Euro-Mag® terminal blocks, are found in a variety of demanding applications: • Industrial and • Telecom • Process logic control (PLC) environmental controls • Instrumentation • Test and measurement • Security and alarm systems • Power supplies • Traffic signals and controls • Elevators and conveyors Magnum quality products support a broad range of electronic and electrical OEM applications. Our product line offers the most comprehensive selection of barrier-style terminal blocks in the industry – as well as: • North American-style terminal blocks — single row, double row and tri-barrier • European-style terminal blocks — PCB mount (spring, cage, tiered, high current), screwless, and pluggable • Power distribution blocks — barrier and dead front, splicer, stud type, multi-line, and power blocks • Rail and base mount terminal blocks • DIN rail sectional blocks • Junction blocks — stud type and feed through • Edge connectors — vertical and right angle mount European-Style PCB Terminal Blocks: Magnum Euro-Mag® blocks come come in a variety of terminal options to make connections easy and in different wire-entry orientations to solve wire routing issues. These high highcurrent terminal blocks handle up to 115 amps right on the circuit board and are available in mold-to-length designs to provide the exact number of poles for a specific application. Table of Contents Single Row Series A5000 and CB5000 A1000 and CB1000 A2000, LP2000 and CB2000 A3000, LP3000 and CB3000 A38/B38 A4000 and B4000 All Series Accessories F38 Double Row Series TB100 TB200 and TB200HB TB300 and TB345 TB400 Top and Bottom Marking Strips TSXX01, TSXX02 Flat Base Series TSXX03, TSXX04 Raised Base Series Page 0.437” 24 Centers Page 0.375” 0.437” 0.562” 0.687” 25-26 27-28 29-30 31-32 33 Centers Page 8.00-13.50mm 34 Centers Page 8.00 and 10.00mm 35 Centers Page 8.00 and 10.00mm 36 EuroMag Series PCB Mount Terminal Blocks 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 Page 2.54mm 3.50mm, 45° 2.54mm, 30° 5.00mm, 45° 5.08mm 5.08mm 7.62mm 10.16mm 7.62mm, 60° 74 75 76 77 78 79 80 81 82 EuroMag Series PCB Mount Pluggable Terminal Blocks Series Centers/Type Page EM3533 EM2221 EM2413 EM2201 EM3553 EM3543 EM3583 EM3593 EM2423 EM2443 EM2211 EM2525 EM2485 EM3105 EM2535 EM2565 EM2488 EM3108 EM2575 EM2115 EM3115 EM2215 EM2118 EM3118 EM2218 EM3516 EM3526 EM2416 EM2426 EM5015 EM5025 EM5035 EM5045 3.50mm, Plug 3.50mm, Header 3.50mm, Plug 3.50mm, Header 3.81mm, Plug 3.81mm, Plug 3.81mm, IDC Plug 3.81mm, Header 3.81mm, Plug 3.81mm, Plug 3.81mm, Header 5.00mm, Plug 5.00mm, Plug 5.00mm, Plug 5.00mm, Header 5.08mm, Plug 5.08mm, Plug 5.08mm, Plug 5.08mm, Header 5.00mm, Plug 5.00mm, Plug 5.08mm, Plug 5.00mm, Header 5.08mm, Plug 5.08mm, Header 7.62mm, Plug 7.62mm, Header 7.62mm, Plug 7.62mm, Header 5.00mm, Plug 5.00mm, Header 5.00mm, Plug 5.00mm, Header 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 This catalog is intended to present product data and provide technical information that will help the end user with design application. Cooper Bussmann reserves the right, without notice, to change design or construction or any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice, any technical information contained in this catalog. Once a product has been selected, it should be tested by the user in all possible applications. Further, Cooper Bussmann takes no responsibility for errors or omissions contained in this catalog, or for mis-application of any Cooper Bussmann product. ©2009 Cooper Bussmann For additional product information, visit www.cooperbussmann.com/magnum Compliance References Page 3.50mm 5.00mm 5.00mm 5.00mm 5.00mm 7.50mm 10.00mm 10.00mm 10.00mm 3.50mm 3.81mm 5.00mm 5.00mm, 35° 5.00mm, 45° 5.08mm 5.08mm, 35° 7.50mm 7.50mm, 35° 7.62mm 7.62mm, 35° 9.52mm 9.52mm, 35° 5.00mm 5.08mm 6.35mm 7.50mm 7.62mm 10.16mm 15.00mm 3.81mm, Two-Tier Centers/Type EM2742 EM2783 EM2802 EM2785 EM2778 EM2795 EM2796 EM2791 EM2816 Edge Connectors, One-Sided Boards Centers/Type EM3123 EM2665 EM3660 EM3665 EM3675 EM3127 EM2661 EM3661 EM3671 EM3923 EM3503 EM2585 EM3225 EM2205 EM2505 EM3228 EM2507 EM3227 EM2506 EM3226 EM2403 EM2803 EM2445 EM2448 EM2855 EM2905 EM2908 EM9126 EM9127 EM9128 Series Wire Management Products Series EuroMag Series PCB Mount Screwless Terminal Blocks Power Distribution Blocks TSXX05, TSXX06 Centers 68 69 70 71 72 73 Terminal Blocks: Base & Rail Mount Standard Base Series Page 1-2 3-5 6-11 12-17 18-19 20-22 23 3.81mm, Three-Tier 5.00mm, Two-Tier 5.08mm, Two-Tier 5.00mm, Three-Tier 5.00mm, Two-Tier 5.08mm, Three-Tier EuroMag Series Filtered Series Centers 0.250” 0.325” 0.375” 0.437” 0.437” 0.562” EM2909 EM2919 EM2929 EM2939 EM3905 EM3908 Terminal Blocks: Single & Double Row Terminal Blocks EuroMag Series Terminal Blocks: Single & Double Row Table of Contents - continued Rail Mount Terminal Blocks and Accessories 116 Centers Page Series Page NDN63 NDN1 NDN11 NDNV4 NDN3 N512 NFT2 NFT3 NC3 NSE3 NSS3 0.375” 0.635” 0.635” 0.250” 0.300” 0.197” 0.281” 0.390” 1.06” 1.06” 0.385” 117 117 117 118 118 119 119 119 120 120 120 160, 162, 163 and 165 130 Terminal Blocks: Base & Rail Mount Power Distribution Blocks Power Distribution Blocks Series Page Finger-Safe 160, 162, 163 and 16 131 132 Connector/Stud Power Distribution Blocks Series Page 162, 163 and 165 133 Power Blocks Deplugable Rail Mount Terninal Blocks Series Centers Page PLU3 PLU1 PSU1 0.390” 0.625” 0.625” 121 121 121 Rail Mount Fuse Holding Terminal Blocks Series Page NDNF1 NDND1 (Non Fused) NDFD1 (Fuse) NDNFLFD1 (Fused with Visual Indicator) 122 122 122 122 Series Centers Page EN 1.78” 134 Wire Management Products Series Photo Control Receptacle Stud Type Junction Blocks Series/Type C4559 and C6083 C5237 and JB1032 Page 135 Centers Page 0.75” 0.625” 136 136-137 Power Feed Thru Terminal Blocks Series Centers Quick Connect Terminal Blocks Series Centers Page NTQ23 BNQ21 BQQ41 0.390” 0.437” 0.437” 123 123 123 C7021 C7024 Base Mount Terminal Blocks Series Centers Page KT3 KT4 PLK3 0.390” 0.250” 0.390” 124 124 124 Centers Page 15188 15288 0.375” 0.54” 125 126 0.375” Vertical Mount Series Series Centers Page KU 0.625” 127 Edge Connectors, One-Sided Boards Compliance References Centers Page 11675 11725 0.56” 0.68” 128 128 Page 14002 129 Right Angle Mount Series 15104 141 Centers Page 0.375” 142 Dead Front Terminal Blocks Series Centers Page 14004 0.50” 129 140 Page Barrier Terminal Blocks Series Page 0.375” Quick-Connect Power Distribution Blocks Series 138 139 Centers Compliance References Base Mount Double Row Terminal Blocks Page Edge Connectors - One-Sided Boards 1384X Series 0.69” 0.750” Depluggable PCB Mount Terminal Blocks Series Centers 15133 Disconnect Terminal Blocks Wire Management Products Splicer Terminal Blocks Series This catalog is intended to present product data and provide technical information that will help the end user with design application. Cooper Bussmann reserves the right, without notice, to change design or construction or any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice, any technical information contained in this catalog. Once a product has been selected, it should be tested by the user in all possible applications. Further, Cooper Bussmann takes no responsibility for errors or omissions contained in this catalog, or for mis-application of any Cooper Bussmann product. ©2009 Cooper Bussmann For additional product information, visit www.cooperbussmann.com/magnum 143 Terminal Blocks - Single Row Terminal Blocks: Single & Double Row Series A5000 & Series CB5000 Single Row Terminal Blocks A50110507 CB50220807 Dimensions - in (mm) Terminal Blocks: Base & Rail Mount * Max. rating shown; some options may be rated lower – consult factory. EuroMag Series SPECIFICATIONS Rating: 10A, 300V* Center Spacing: 0.250” (6.35mm) Wire Range: #18-30 AWG CU Screw Size: #3-48 zinc-plated philslot SEMS screws, wireready standard Torque Rating: 4 lb-in. Distance Between Barriers: 0.20” (5.08mm) Recommended PCB Hole Diameter: 0.062” (1.57mm) Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Molded Material: Black, UL Rated 94V0 Thermoplastic Breakdown Voltage: 1600V rms Agency Information: UL File E62622; CE Certified A5000 Series Poles 0.25 0.50 0.75 1.00 1.25 1.50 1.75 2.00 2.25 2.50 2.75 3.00 3.25 3.50 3.75 4.00 4.25 4.50 4.75 5.00 5.25 5.50 5.75 6.00 6.25 6.50 6.75 7.00 7.25 0.56 0.81 1.06 1.31 1.56 1.81 2.06 2.31 2.56 2.81 3.06 3.31 3.56 3.81 4.06 4.31 4.56 4.81 5.06 5.31 5.56 5.81 6.06 6.31 6.56 6.81 7.06 7.31 7.56 0.250 (6.35) 0.12 (3.0) Ø 0.43 (10.9) B Mount End Barrier End 0.50 (12.7) 0.25 (6.35) 0.025 (0.64) A Mount End Barrier End CB5000 Series #3-48 screw 0.250 (6.35) 0.12 (3.0) Ø Edge Connectors, One-Sided Boards 1.06 1.31 1.56 1.81 2.06 2.31 2.56 2.81 3.06 3.31 3.56 3.81 4.06 4.31 4.56 4.81 5.06 5.31 5.56 5.81 6.06 6.31 6.56 6.81 7.06 7.31 7.56 – – #3-48 screw Wire Management Products 0.75 1.00 1.25 1.50 1.75 2.00 2.25 2.50 2.75 3.00 3.25 3.50 3.75 4.00 4.25 4.50 4.75 5.00 5.25 5.50 5.75 6.00 6.25 6.50 6.75 7.00 7.25 – – BARRIER ENDS A B Pole Overall Centers Length Power Distribution Blocks 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 MOUNTING ENDS A B Mount Overall Centers Length 0.50 (12.7) * Dimensions in inches. To convert to millimeters, multiply by 25.4. B Mount End Barrier End 0.50 (12.7) Compliance References 0.025 (0.64) Mount End A Barrier End For additional product information, visit www.cooperbussmann.com/magnum 1 EuroMag Series Terminal Blocks: Single & Double Row Terminal Blocks - Single Row Part Numbering System Series Terminal Style Base/End Poles Screw Options Options A 5  C B 5       01 02 03 04 1 - mount end 2 - barrier end 02 to 30 02 to 28 on mount end base 07 - steel SEMS std. wire ready C1 to C8 - 0.110˝ QC L1 to L6 marking options (pg 22) LT1 to LT6 marking options (CB5 only-pg 22) MP - mounting plate 0.120˝ dia *OJ - over barrier jumper S1 - single solder lug/flat S2 - double solder lug/flat (A5 only) *Contact factory for configuration A5 - standard barrier CB5 - closed back - handwired - printed circuit - non feed-thru - wire wrap tail Terminal Blocks: Base & Rail Mount Terminal Styles Inches (Millimeters) 0.16 (4.1) 0.40 (10.2) 0.10 (2.54) 0.055 (1.40) 0.025 (.64) 0.14 (3.6) 0.12 (3.0) 01 Handwired Power Distribution Blocks 0.50 (12.7) 0.032 (0.81) 02 Circuit Board 0.045 (1.14) 03 Non Feed-Thru CB5 Terminal Exit Options 0.025 (0.64) 0.12 (3.0) 04 Wire Wrap Tail Inches (Millimeters) 0.12 (3.0) Wire Management Products Screw Options Edge Connectors, One-Sided Boards Exit Rear (std.) Hardware Options Wire ready screws standard on all terminal styles 07 Steel SEMS Zinc-Plated (B001-7035-J) Jumpers (Bulk ordering part numbers are in parentheses.) 07 Standard Wire Ready (Bulk ordering part numbers are in parentheses.) Inches (Millimeters) Quick Connects Blade Width 0.110” (For other orientations, contact factory.) Solder Lugs 0.56 (14.3) Compliance References (OJ12-J) (5C1-J)* (5C2-J)* (5C4-J)* S1 (5S1-J) 1.12 (28.4) C7 (5C7-J) C8 (5C8-J) * N/A on CB5 Series. 2 For additional product information, visit www.cooperbussmann.com/magnum S2 (5S2-J) Terminal Blocks - Single Row A1000 Series 0.325 (8.26) C Mount End Barrier End 0.50 (12.7) 0.25 (6.4) A Mount Centers B Pole Centers Mount End Barrier End CB1000 Series 0.325 (8.26) 0.15 (3.8) Ø 0.25 (6.4) 0.60 (15.2) C Mount End Barrier End 0.52 (13.2) 0.27 (6.9) 0.025 (0.64) A Mount Centers B Pole Centers Mount End Compliance References 0.72 1.04 1.37 1.69 2.02 2.34 2.67 2.99 3.32 3.64 3.97 4.29 4.62 4.94 5.27 5.59 5.92 6.24 6.57 6.89 7.22 7.54 7.87 8.19 8.52 8.84 9.17 9.49 9.82 10.14 10.47 10.79 11.12 11.44 11.77 0.50 (12.7) Edge Connectors, One-Sided Boards 0.33 0.65 0.98 1.30 1.63 1.95 2.28 2.60 2.93 3.25 3.58 3.90 4.23 4.55 4.88 5.20 5.53 5.85 6.18 6.50 6.83 7.15 7.48 7.80 8.13 8.45 8.78 9.10 9.43 9.75 10.08 10.40 10.73 11.05 11.38 BARRIER ENDS ONLY C Length Wire Management Products 1.37 1.69 2.02 2.34 2.67 2.99 3.32 3.64 3.97 4.29 4.62 4.94 5.27 5.59 5.92 6.24 6.57 6.89 7.22 7.54 7.87 8.19 8.52 8.84 9.17 9.49 9.82 10.14 10.47 10.79 11.12 11.44 11.77 – – BARRIER & MOUNTING ENDS B Pole Ctrs. Power Distribution Blocks MOUNTING ENDS ONLY A C Mount Ctrs. Length 0.98 1.30 1.63 1.95 2.28 2.60 2.93 3.25 3.58 3.90 4.23 4.55 4.88 5.20 5.53 5.85 6.18 6.50 6.83 7.15 7.48 7.80 8.13 8.45 8.78 9.10 9.43 9.75 10.08 10.40 10.73 11.05 11.38 – – Dimensions - in (mm) Terminal Blocks: Base & Rail Mount 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 A102206 0.15 (3.8) Ø *General industrial applications Poles CB10210707 EuroMag Series SPECIFICATIONS Rating: 20A, 250V* Center Spacing: 0.325” (8.26mm) Wire Range: #14-22 AWG CU Screw Size: #6-32 zinc-plated philslot wire-ready screws with a #2 driving recess. Torque Rating: 9 lb-in. Base: Standoffs are standard on CB1000 Series for easy flux washing. Distance Between Barriers: 0.26” (6.6mm) Recommended PCB Hole Diameter: 0.070” (1.78mm) Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Molded Material: Black, UL Rated 94V0 Thermoplastic Breakdown Voltage: 1600V Agency Information: UL/CSA; IEC Compliance; CE Certified; UL File: E62622, CSA File: 15364 Terminal Blocks: Single & Double Row Series A1000 & Series CB1000 Single Row Terminal Blocks Barrier End * Dimensions in inches. To convert to millimeters, multiply by 25.4. For additional product information, visit www.cooperbussmann.com/magnum 3 Terminal Blocks - Single Row MAGNUM ® Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Part Numbering System Series A 1  C B 1  A1 - standard barrier CB1 - closed back Terminal Style Base/End Poles Screw Options Options      02 03 04 07 - printed circuit - non feed-thru - wire wrap tail - extended pin 1 - mount end 2 - barrier end 02 to 36 02 to 34 on mount end base Covers - (pg 23) Blank - std. screws 03 - stainless steel 04 - nickel brass 07 - steel SEMS & washer (not available with hardware options) 09 - brass/nickel-plated SEMS CA - standard captive screw Terminal Styles Inches (Millimeters) 0.35 (8.9) 0.16 (4.1) 0.055 (1.40) 0.14 (3.6) 03 Non Feed-Thru Power Distribution Blocks Screw Options Standard Zinc-Plated Steel 0.54 (13.7) 0.032 (0.81) 0.055 (1.40) 0.032 (0.81 02 Printed Circuit 0.14 (3.6) 0.055 (1.40) 0.14 (3.6) 04 Wire Wrap Tail 0.032 (0.81) 07 Extended Pin Wire ready screws standard on all terminal styles 04 Brass Nickel-Plated 03 Stainless Steel 09 Nickel-plated Brass Screws 07 Steel SEMS Zinc-Plated CB1 Terminal Exit Options Wire Management Products AB & DR - angle mts. (A1 only-pg 5) B1 to B9 - 0.187” QC (all positions) EB - exit back terminals on CB1 w/07 screw option only †JA, JB & JC - barrier jumpers L1 to L6 marking options (pg 22) LT1 to LT6 marking options (CB1 only-pg 22) MP & MT - mounting plates 0.150 dia (pg 5) R26 & R45 - right angle bends (A1 only-pg 5) Inches (Millimeters) 0.275 (6.98) 0.12 (3.0) EB Exit Back Exit Rear (std.) Hardware Options Edge Connectors, One-Sided Boards Jumpers Inches (Millimeters) (Bulk ordering part numbers are in parentheses.) Quick Connects Blade Width B = 0.187”. (For other orientations, contact factory.) 0.33 (8.4) 3JA (JA1-XX) B1 (1B1-J) * B2 (1B2-J) * B3 (1B3-J) * B4 (1B4-J) * B5 (1B5-J) * B6 (1B6-J) * B7 (1B7-J) B8 (1B8-J) 0.33 (8.4) Compliance References †JB (JB1-XX) 0.33 (8.4) * N/A on CB1 Series. †Contact factory for pole configuration.. †JC (JC1-XX) 4 . B9 (1B9-J) For additional product information, visit www.cooperbussmann.com/magnum Terminal Blocks - Single Row Mounting Options Terminal Blocks: Single & Double Row Series A1000 & CB1000 Single Row Terminal Blocks Continued Inches (Millimeters) Right Angle Bends (A1 only) EuroMag Series Right angle terminals are offered on the A1000 Series. Configurations are defined in these dimensions: X = pin extension beyond the block base; Z = length from block base to centerline of the terminal tip. Standard bends consist of the X and Z dimensions shown in the chart. Specify by adding the selected Bend Option Code to the terminal part number. Z Terminal Blocks: Base & Rail Mount X Bend Option Code R26 (04 terminal only) R45 (07 terminal only) X (minimum) Z 0.14 (3.5) 0.33 (8.4) 0.09 (2.3) 0.09 (2.3) Drilled Right Angle (A1 only) Angle Brackets (A1 only) 5 0.32 0.12 Wire Management Products 0 0.25 0.04 0.450 0.144 HOLE w/0.312 C' BORE 0.320 0.150 Power Distribution Blocks Dimensions in inches. To convert to millimeters, multiply by 25.4. Option AB Angle brackets enable block to be fastened at right angles to normal mount position. Bulk part number 1AB-J. Option DR Counterbored holes across mount ends of block enable fastening with two screws at right angles to normal mount position. Edge Connectors, One-Sided Boards Mounting Plates MOUNTING PLATE MP MT For additional product information, visit www.cooperbussmann.com/magnum Compliance References Options MP & MT MP Metal inserts with 0.150” (3.8) dia. hole accept #6 screw. MT Metal inserts with tapped hole accept #6-32 screw. Bulk part numbers 1MP-J & 1MT-J. 5 Series A2000, LP2000 & CB2000 Single Row Terminal Blocks A20510807WR SPECIFICATIONS Rating: A2: 30A, 300V* LP2: 30A, 150V* CB2: 30A, 300V* Center Spacing: 0.375” or 3/8” (9.52mm) Wire Range: #12-22 AWG CU Screw Size: #6-32 zinc-plated philslot LP202110 Torque Rating: 9 lb-in. Base: Standoffs standard for easy flux washing Distance Between Barriers: 0.32” (8.1mm) Recommended PCB Hole Diameter: 0.076” (1.93mm) Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Molded Material: Black, UL Rated 94V0 Thermoplastic Breakdown Voltage: 3400V (A2 & LP2); 4100V (CB2). Agency Information: UL File E62622, CSA File 47235; IEC Compliance; CE Certified *30A Rating achieved with a #10 copper wire crimped to a ring terminal.; 20A Rating without ring terminal. CB20210507 Dimensions - in (mm) A2000 & LP2000 Series Poles Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Terminal Blocks - Single Row Edge Connectors, One-Sided Boards Wire Management Products 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 MOUNTING ENDS ONLY A C Mount Ctrs. Length 1.13 1.50 1.88 2.25 2.63 3.00 3.38 3.75 4.13 4.50 4.88 5.25 5.63 6.00 6.38 6.75 7.13 7.50 7.88 8.25 8.63 9.00 9.38 9.75 10.13 10.50 10.88 11.25 11.63 – – 1.56 1.93 2.30 2.68 3.06 3.43 3.81 4.18 4.56 4.93 5.31 5.69 6.06 6.43 6.81 7.18 7.56 7.93 8.31 8.68 9.06 9.43 9.81 10.18 10.56 10.93 11.31 11.68 12.05 – – BARRIER & MOUNTING ENDS B Pole Ctrs. BARRIER ENDS ONLY C Length 0.38 0.75 1.13 1.50 1.88 2.25 2.63 3.00 3.38 3.75 4.13 4.50 4.88 5.25 5.63 6.00 6.38 6.75 7.13 7.50 7.88 8.25 8.63 9.00 9.38 9.75 10.13 10.50 10.88 11.25 11.63 0.81 1.18 1.56 1.93 2.31 2.68 3.06 3.43 3.81 4.18 4.56 4.93 5.31 5.68 6.06 6.43 6.81 7.18 7.56 7.93 8.31 8.68 9.06 9.43 9.81 10.18 10.55 10.93 11.31 11.68 12.05 0.375 (9.53) 0.15 (3.8) Ø 0.65 (16.5) C Mount End Barrier End 0.76 (19.3) 0.565 (14.35) on LP2000 0.40 (10.2) 0.02 (0.5) A Mount Centers B Pole Centers Mount End Barrier End CB2000 Series 0.375 (9.53) 0.19 (4.8) Ø 0.70 (17.8) 0.32 (8.1) C Mount End Barrier End * Dimensions in inches. To convert to millimeters, multiply by 25.4. Compliance References 0.60 (15.2) 0.02 (0.5) A Mount Centers B Pole Centers Mount End 6 For additional product information, visit www.cooperbussmann.com/magnum Barrier End Terminal Blocks - Single Row Terminal Blocks: Single & Double Row Series A2000 & LP2000 Single Row Terminal Blocks Part Numbering System Series Base/End Poles Screw Options Options      Blank - std. screw 00 - screws shipped bulk 03 - stainless steel 04 - brass nickel-plated 07 - steel SEMS (not available with hardware options) 09 - brass SEMS nickel-plated (not available with hardware options) CA - captive screw WR - wire ready (not available on LP2 series) AB - angle mnt. options (pg 9) A1 to A9 - 0.250˝ QC B1 to B9 - 0.187˝ QC DR - drilled right angle (pg 9) †JA, JB & JC - barrier jumpers L1 to L6 marking options (pg 22) MP, MP8 & MT mounting plates (pg 9) †OJ2 & OJ4 - over barrier jumpers (not available w/covers) RC - retaining clips (pg 9) R30 to R77 - right angle bends (pg 9) SO - stand off insulators (pg 9) S1 - solder lug/flat A2 - standard barrier 01 - handwired LP2 - low profile 02 - printed circuit barrier 03 - non feed-thru 04 - wire wrap tail 05 - extended handwired 06 - handwired 07 - extended pin 08 - printed circuit 09 - 0.250˝ QC short 10 - 0.187˝ QC 14 - printed circuit 19 - 0.250˝ QC long 0 - flat base/molded 02 to 32 mount end 02 to 30 on mount 1 - flat base/mnt. end end base 2 - flat base/barrier end 3 - insulator base/mnt. end 4 - insulator base/ barrier end 5 - closed base/ mount end 6 - closed base/ molded mount end 9 - insulator base/ molded mount end Covers - (pg 23) Power Distribution Blocks Base/End Note: 0, 6, 9 styles not available with covers. 5 & 6 Styles only available with 03 terminals. †Contact factory for configuration... Terminal Styles Inches (Millimeters) 0.031 (.79) 0.110 (2.79) 0.031 (0.79) 01 Handwired 0.062 (1.57) 03 Non Feed-Thru 04 Wire Wrap Tail 0.54 (13.7) 0.031 (0.79) 05 Extended Handwired 0.11 (2.79) 0.055 (1.40) 0.14 (3.6) 0.17 (4.3) 0.032 (0.81) 0.031 (0.79) 0.062 (1.57) 08 Printed Circuit 07 Extended Pin 06 Handwired 0.33 (8.4) 09 0.250˝ QC short 0.031 (0.79) 0.31 (7.9) 0.187 (4.75) 10 0.187˝ QC 0.41 (10.4) Compliance References 0.250 (6.35) 0.031 (0.79) 0.72 (18.3) 0.42 (10.7) 0.40 (10.2) Edge Connectors, One-Sided Boards 0.30 (7.6) 0.110 (2.79) 0.062 (1.57) 0.031 (0.79) 02 Printed Circuit 0.66 (16.8) 0.031 (0.79) 0.55 (14.0) 0.20 (5.1) Wire Management Products 0.55 (14.0) 0.031 (0.79) 0.125 (3.2) 0.062 (1.57) 14 Printed Circuit For additional product information, visit www.cooperbussmann.com/magnum 0.031 (0.79) Terminal Blocks: Base & Rail Mount Terminal Style EuroMag Series A 2  L P  2  0.250 (6.35) 19 30.250˝ QC long 7 Series A2000 & LP2000 Single Row Terminal Blocks Continued Screw Options EuroMag Series Terminal Blocks: Single & Double Row Terminal Blocks - Single Row Standard zinc-plated Steel Hardware Options Terminal Blocks: Base & Rail Mount 04 Brass Nickel-Plated 03 Stainless Steel WR Wire Ready 09 Brass SEMS Nickel-Plated Inches (Millimeters) (Bulk ordering part numbers are in parentheses.) Jumpers Solder Lugs 07 Steel SEMS Quick Connects Blade Width A = 0.250” Blade Width B = 0.187” 0.68 (17.3) 0.33 (8.4) 0.84 (21.2) †JA (JA2-XX-J) Power Distribution Blocks S1 (2S1-J) †OJ2 (OJ2-J) A1 & B1 (2A1-J & 2B1-J) A2 & B2 (2A2-J & 2B2-J) A3 & B3 (2A3-J & 2B3-J) †OJ4 (OJ4-J) A4 & B4 (2A4-J & 2B4-J) A5 & B5 (2A5-J & 2B5-J) A6 & B6 (2A6-J & 2B6-J) A7 & B7 (2A7-J & 2B7-J) A8 & B8 (2A8-J & 2B8-J) A9 & B9 (2A9-J & 2B9-J) 0.33 (8.4) †JB (JB2-XX-J) Wire Management Products 0.33 (8.4) †Contact factory for configuration. †JC (JC2-XX-J) Base/End Options Inches (Millimeters) B Edge Connectors, One-Sided Boards B B B 0.180 (4.57) 0.150 Ø (3.8) mounting holes (2) 0.218 (5.54) 0.40 (10.2) 0.40 (10.2) 0.095 (2.4) Compliance References SECTION A–A 0, 6 & 9 Molded Mount End 8 SECTION B–B 1, 3 & 5 Mount End For additional product information, visit www.cooperbussmann.com/magnum Terminal Blocks - Single Row Terminal Blocks: Single & Double Row Series A2000 & LP2000 Single Row Terminal Blocks Continued Mounting Options Right Angle Bends (A2, LP2 only) 07 Terminal Bend Configurations EuroMag Series Right angle terminals are offered on the A2000 & LP2000 Series. Configurations are defined in these dimensions: X = pin extension beyond the block base; Z = length from block base to centerline of the terminal tip. Standard bends consist of the X and Z dimensions shown in the chart. Specify by adding the selected Bend Option Code to the terminal part number. Z 04 Terminal Bend Configurations 0.82 X Z Bend Option Code Bend Option Code X Available w/insulator base R30 R35 R36 R39 R42 R46 R48 R50 0.04 0.01 0.02 0.05 0.08 0.12 0.14 0.16 0.28 0.23 0.22 0.19 0.16 0.12 0.10 0.08 No No No No No No No No R30 R35 R36 R42 R46 R50 R53 R66 R69 R75 R77 0.04 0.01 0.02 0.08 0.12 0.16 0.19 0.32 0.35 0.41 0.43 Z Available w/insulator base 0.55 0.50 0.49 0.43 0.39 0.35 0.32 0.19 0.16 0.10 0.08 Yes Yes Yes Yes Yes No No No No No No Power Distribution Blocks Z X (minimum) X (minimum) Terminal Blocks: Base & Rail Mount 0.55 Dimensions in inches. To convert to millimeters, multiply by 25.4. Drilled Right Angle (A2, LP2 only) Angle Brackets (A2, LP2 only) Wire Management Products 0.12 5 0.32 0.25 0.04 0.45 0.144 HOLE w/0.312 C' BORE 0.32 0.15 Standoffs Mounting Plates MOUNTING PLATE Option DR Counterbored holes across mount ends of block enable fastening with two screws at right angles to normal mount position. Edge Connectors, One-Sided Boards Option AB Angle brackets enable block to be fastened at right angles to normal mount position. Bulk part number 2AB-J. Retaining Clip MP MP8 0.300 MT RETAINING CLIP Options MP, MP8 & MT MP Metal inserts with 0.150” dia. hole accept #6 screw. MP8 Metal inserts with 0.187” dia. hole accept #8-32 screw. MT Metal inserts with tapped hole accept #6-32 screw. Option SO Standoff mounts are tubes molded to the mounting positions. Available with insulator bases only. Option RC Use on standoff tubes. Fit panels up to 0.125” thick. Two clips for every five positions. Supplied unassembled. Bulk part number H541-J. For additional product information, visit www.cooperbussmann.com/magnum 9 Compliance References STANDOFF Series CB2000 Single Row Terminal Blocks Part Numbering System Series Terminal Style Base/End Poles Screws Options B 2 C       CB2 - closed back 01 02 03 07 14 22 1 - mount end 2 - barrier end 02 to 32 02 to 30 on mount end base 03 - stainless steel 04 - brass nickel-plated 07 - steel SEMS standard 09 - brass SEMS nickel-plated CA - captive screw 07CA - SEMS captive *AB - angle mounting brackets (pg 11) A7 to A9 - 0.250” QC B7 to B9 - 0.187” QC EB - exit back terminals EF - exit front terminals †JA, JB & JC - barrier jumpers L1 to L6 marking options (pg 22) LT1 to LT6 marking options (pg 22) †OJ2 & OJ4 - over barrier jumpers MP, MP8, MT & MT8 mtg. plates (pg 11) S1 - solder lug/flat - handwired - printed circuit - non feed-thru - extended pin - printed circuit - dual tail printed circuit *Only available on 3-poles and up. †Contact factory for configuration.. Terminal Styles Inches (Millimeters) 0.19 (4.9) 0.40 (10.2) 0.18 (4.6) 0.045 (1.14) 01 Handwired 0.031 (0.79) 02 Printed Circuit Screw Options 03 Stainless Steel (F507-J) 0.18 (4.6) 0.062 (1.57) 03 Non Feed-Thru Available on Mount End (1) only. 0.18 (4.6) 0.81 (4.6) 0.125 (3.18) 0.70 (17.8) 0.19 (4.8 ) 0.031 (0.79) 0.120 (3.05) 0.031 (0.79) 0.045 (1.14) 0.18 (4.6) 0.031 (0.79) 14 Printed Circuit 07 Extended Pin 0.045 (1.14) 0.03 (0.79) 0.40 (10.2) 0.43 (10.9) 22 Dual Tail Printred Circuit (Bulk ordering part numbers are in parentheses.) 04 Brass nickel-plated (F506-J) 07 Steel SEMS zinc-plated (BOO1-7084-J) 09 Brass SEMS nickel-plated (F524-J) * NOTE: Wire ready screws standard on all terminal styles. CB2 Terminal Exit Options Inches (Millimeters) 0.255 (6.48) Compliance References Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Terminal Blocks - Single Row 0.18 (4.6) Exit Rear (std.) 10 0.18 (4.6) EF Exit Front X EB Exit Back For additional product information, visit www.cooperbussmann.com/magnum Terminal Blocks - Single Row Hardware Options Solder Lugs Inches (Millimeters) (Bulk ordering part numbers are in parentheses.) Jumpers Terminal Blocks: Single & Double Row Series CB2000 Single Row Terminal Blocks Quick Connects Blade Width A = 0.250”. Blade Width B = 0.187”. 0.68 (17.3) 0.84 (21.2) S1 (2S1-J) †OJ2 (OJ2-J) †JA (JA2-XX-J) A7 & B7 (2A7-J & 2B7-J) A8 & B8 (2A8-J & 2B8-J) A9 & B9 (2A9-J & 2B9-J) EuroMag Series 0.33 (8.4) 0.33 (8.4) Terminal Blocks: Base & Rail Mount †JB (JB2-XX-J) †OJ4 (OJ4-J) 0.33 (8.4) †JC (JC2-XX-J) †Contact factory for configuration.. Power Distribution Blocks Mounting Options Inches (Millimeters) Right Angle Mounting Bracket End Positions usable 0.71 (18.0) Snap-in Angle Bracket Chassis or PCB A 0.79 (20.1) 1.02 (25.8) Exit Back (EB) Terminals 0.24 (6.1) Wire Management Products #6 or #8 mounting screw & nut (Customer supplied.) 0.45 (11.4) A 0.42 (10.7) Angle Bracket Option AB Edge Connectors, One-Sided Boards Mounts blocks on PC boards at a right angle. • Protects solder joints. • Recommended for all EB (Exit Back) PCB terminal blocks. • Bracket snaps securely on block (no hardware required). • Minimum strip length (end positions are usable). • Mount with #6-32 or #8-32 screws (not supplied). Mounting Plates MOUNTING PLATE Options MP, MP8, MT & MT8 MP Metal inserts with 0.150” dia. hole accept #6 screw. MP8 Metal inserts with 0.187” dia. hole accept #8-32 screw. MT Metal inserts with tapped hole accept #6-32 screw. MT8 Metal inserts with tapped hole accept #8-32 screw. Compliance References MP MP8 MT MT8 For additional product information, visit www.cooperbussmann.com/magnum 11 Series A3000, LP3000 & CB3000 Single Row Terminal Blocks A31940707WR SPECIFICATIONS Rating: A3: 30A, 600V* #12-22 AWG LP3: 30A, 150V #12-22 AWG CB3: 30A, 600V #12-22 AWG Wire Range: #12-22 AWG CU Center Spacing: 0.437” or 7/16” (11.10mm) Screw Size: #6-32 zinc-plated philslot screws. Torque Rating: 9 lb-in. Base: Standoffs standard for easy flux washing. Distance Between Barriers: 0.32” (8.1mm) Recommended PCB Hole Diameter: 0.076” (1.93mm) Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Molded Material: Black, UL Rated 94V0 Thermoplastic Breakdown Voltage: 3500V (A3 & LP3); 8200V (CB3) Agency Information: UL File E62622, CSA 47235; IEC Compliance, CE Certified *30A Rating achieved with a #10 copper wire crimped to a ring terminal; 20 Rating without ring terminal. Poles MOUNTING ENDS ONLY A C Mount Ctrs. Length BARRIER & MOUNTING ENDS B Pole Ctrs. BARRIER ENDS ONLY C Length LP301105 CB31420807 Dimesions - in (mm) A3000 & LP3000 Series 0.437 (11.10) 0.15 (3.8) Ø 0.65 (16.5) C Mount End 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Terminal Blocks - Single Row 1.31 1.75 2.18 2.62 3.06 3.50 3.93 4.37 4.81 5.25 5.68 6.12 6.56 7.00 7.43 7.87 8.31 8.75 9.18 9.62 10.06 10.50 10.93 11.37 11.81 – – 1.73 2.17 2.61 3.05 3.48 3.92 4.36 4.80 5.23 5.67 6.11 6.55 6.98 7.42 7.86 8.30 8.73 9.17 9.60 10.05 10.48 10.92 11.36 11.80 12.23 – – 0.43 0.87 1.31 1.75 2.18 2.62 3.06 3.50 3.93 4.37 4.81 5.25 5.68 6.12 6.56 7.00 7.43 7.87 8.31 8.50 9.18 9.62 10.06 10.50 10.93 11.37 11.81 0.98 1.43 1.87 2.31 2.75 3.18 3.62 4.06 4.50 4.93 5.37 5.81 6.25 6.68 7.12 7.56 8.00 8.43 8.87 9.31 9.75 10.18 10.62 11.06 11.50 11.93 12.37 Barrier End 0.565 (19.3) 0.76 (14.35) 0.40 (10.2) 0.02 (0.5) A Mount Centers B Pole Centers Mount End Barrier End CB3000 Series 0.437 (11.10) 0.19 (4.8) Ø 0.70 (17.8) 0.32 (8.1) C Mount End Barrier End Dimensions in inches. To convert to millimeters, multiply by 25.4. Compliance References 0.61 (15.5) 0.02 (0.5) A Mount Centers B Pole Centers Mount End 12 For additional product information, visit www.cooperbussmann.com/magnum Barrier End Terminal Blocks - Single Row Terminal Blocks: Single & Double Row Series A3000 & LP3000 Single Row Terminal Blocks Part Numbering System Series Terminal Style A3 - standard barrier LP3 - low profile barrier Poles Screw Options Options (Views pg. 15)   01 - handwired 02 - printed circuit 03 - non feed-thru 04 - wire wrap tail 05 - extended handwired 06 - handwired 07 - extended pin 08 - printed circuit 09 - 0.250 QC short 10 - 0.187 QC 14 - printed circuit 19 - 0.250 QC long 1 - flat base/mnt. end 02 to 28 2 - flat base/barrier end 02 to 26 on mount 3 - insulator base/ end base mnt. end 4 - insulator base/ barrier end *5 - closed base/ mount end *Base/End Note: 5 Style only available with 03 terminals.   Blank - std. screw 00 - screws shipped bulk 03 - stainless steel 04 - brass nickel-plated 07 - steel SEMS zinc-plated (not available with hardware options) 09 - brass SEMS nickel-plated (not available with hardware options) 07WR - steel SEMS wire ready (A3 only) CA - captive screw AB - angle mnt. options (pg 15) A1 to A9 - 0.250” QC B1 to B9 - 0.187” QC DR - drilled right angle (pg 15) †J201 - flat slip-on jumper L1 to L6 marking options (pg 22) MP, MP8 & MT mounting plates (pg 15) †OJ3, OJ5 & OJ7 - over barrier jumpers RC - retaining clips (pg 15) R30 to R77 - right angle bends (pg 15) SO - stand off insulators (pg 15) S1 - solder lug/flat †Contact factory for configuration. ready (A3 only) Inches (Millimeters) 0.20 (5.1) 0.55 (14.0) 0.031 (0.79) 0.66 (16.8) 0.55 (14.0) 0.062 (1.57) 0.062 (1.57) 0.031 (0.79) 01 Handwired 02 Printed Circuit 03 Non Feed-Thru 04 Wire Wrap Tail 0.30 (7.6) 0.110 (2.79) 0.031 (0.79) 0.031 (0.79) 05 Extended Handwired 0.11 (2.79) 06 Handwired 0.33 (8.4) 0.17 (4.3) 0.062 (1.57 ) 07 Extended Pin 0.031 (0.79) 0.40 (10.2) 0.062 (1.57) 08 Printed Circuit 0.250 (6.35) 0.031 (0.79) 09 0.250˝ QC Short 0.031 (0.79) 0.031 (0.79) 0.125 (3.2) 0.062 (1.57) 0.31 (7.9) 0.187 (4.75) 10 0.187˝ QC 0.41 (10.4) 0.031 (0.79) 0.250 (6.35) 19 0.250˝ QC Long 14 Printed Circuit Screw Options 03 Stainless Steel 04 Brass Nickel-Plated 07 Steel SEMS Zinc-Plated (F523-J) 09 Brass SEMS Nickel-Plated Compliance References Standard Zinc-Plated Steel 07WR Wire Ready (A3 only) For additional product information, visit www.cooperbussmann.com/magnum Edge Connectors, One-Sided Boards 0.82 (20.8) 0.72 (18.3) 0.42 (10.7) Wire Management Products 0.110 (2.79) 0.031 (0.79) Power Distribution Blocks Terminal Styles 0.031 (.79) Terminal Blocks: Base & Rail Mount  EuroMag Series 3 A  P 3 L  Base/End 13 Terminal Blocks: Single & Double Row Terminal Blocks - Single Row Series A3000 & LP3000 Single Row Terminal Blocks Continued Hardware Options (Bulk ordering part numbers are in parentheses.) Jumpers Solder Lugs Inches (Millimeters) Quick Connects Blade Width A = 0.250” Blade Width B = 0.187” EuroMag Series 0.68 (17.3) 0.84 (21.2) S1 (2S1-J) †J201 A1 & B1 (2A1-J & 2B1-J) A2 & B2 (2A2-J & 2B2-J) A3 & B3 (2A3-J & 2B3-J) †OJ7 LP3 Only (OJ7-J) A4 & B4 (2A4-J & 2B4-J) A5 & B5 (2A5-J & 2B5-J) A6 & B6 (2A6-J & 2B6-J) †OJ5 (OJ5-J) A7 & B7 (2A7-J & 2B7-J) A8 & B8 (2A8-J & 2B8-J) A9 & B9 (2A9-J & 2B9-J) Terminal Blocks: Base & Rail Mount Flat slip-on (J201-J) †Contact factory for pole configuration. Power Distribution Blocks †OJ3 (OJ3-J) Base/End Options B Inches (Millimeters) B Wire Management Products 0.150 Ø (3.8) mounting holes (2) 0.40 (10.2) 0.095 (2.4) SECTION B–B Compliance References Edge Connectors, One-Sided Boards 1, 3 & 5 Mount End 14 For additional product information, visit www.cooperbussmann.com/magnum Terminal Blocks - Single Row Terminal Blocks: Single & Double Row Series A3000 & LP3000 Single Row Terminal Blocks Continued Mounting Options Inches (Millimeters) Right Angle Bends (A3, LP3 only) EuroMag Series Right angle terminals are offered on the A3000 & LP3000 Series. Configurations are defined in these dimensions: X = pin extension beyond the block base; Z = length from block base to centerline of the terminal tip. Standard bends consist of the X and Z dimensions shown in the chart. Specify by adding the selected Bend Option Code to the terminal part number. 07 Terminal Bend Configurations 04 Terminal Bend Configurations Z Z 0.82 Bend Option Code 0.04 0.01 0.02 0.05 0.08 0.12 0.14 0.16 0.28 0.23 0.22 0.19 0.16 0.12 0.10 0.08 No No No No No No No No Bend Option Code R30 R35 R36 R50 R53 R66 R69 R75 R77 X (minimum) 0.04 0.01 0.02 0.16 0.19 0.32 0.35 0.41 0.43 Z Available w/insulator base 0.55 0.50 0.49 0.35 0.32 0.19 0.16 0.10 0.08 Yes Yes Yes No No No No No No Power Distribution Blocks Z Available w/insulator base X (minimum) R30 R35 R36 R39 R42 R46 R48 R50 X X Dimensions in inches. To convert to millimeters, multiply by 25.4. Drilled Right Angle (A3, LP3 only) Angle Brackets (A3, LP3 only) Wire Management Products 0.24 7 0.43 0.25 0.04 0.45 0.144 HOLE w/0.312 C' BORE 0.32 0.15 Option DR Counterbored holes across mount ends of block enable fastening with two screws at right angles to normal mount position. Mounting Plates Standoffs MOUNTING PLATE Edge Connectors, One-Sided Boards Option AB Angle brackets enable block to be fastened at right angles to normal mount position. Bulk part number 2AB-J. Terminal Blocks: Base & Rail Mount 0.55 Retaining Clip MP MP8 0.300 MT Options MP, MP8 & MT MP Metal inserts with 0.150” dia. hole accept #6 screw. MP8 Metal inserts with 0.187” dia. hole accept #8-32 screw. MT Metal inserts with tapped hole accept #6-32 screw. Option SO Standoff mounts are tubes molded to the mounting positions. Available with insulator bases only. Option RC Use on standoff tubes. Fit panels up to 0.125” thick. Two clips for every five positions. Supplied unassembled. Bulk part number H541-J. For additional product information, visit www.cooperbussmann.com/magnum 15 Compliance References RETAINING CLIP STANDOFF Series CB3000 Single Row Terminal Blocks Part Numbering System Series Terminal Style Base/End Poles Screws Options C B3        CB3 - closed back 01 - handwired #6-32 screw 02 - printed circuit #6-32 screw 03 - non feed-thru #6-32 screw 07 - extended pin #6-32 screw 14 - printed circuit #6-32 screw 51 - handwired #8-32* 52 - printed circuit #8-32* 53 - non feed-thru #8-32* 57 - extended pin #8-32* 64 - printed circuit #8-32* *Note: #8-32 screw is a special with #6-32 head. 1 - mount end 2 - barrier end 5 - closed base/ mount end 02 to 28 02 to 26 on mount end base 07 - steel SEMS (standard) 09 - brass SEMS nickel-plated CA - SEMS captive AB - angle mounting brackets (pg 17) A7 to A9 - 0.250” QC B7 to B9 - 0.187” QC EB - exit back terminals L1 to L6 marking options (pg 22) LT1 to LT6 marking options (pg 22) †OJ3 & OJ7 - over barrier jumpers MP, MP8, MT & MT8 mtg. plates (pg 17) S1 - solder lug/flat Covers - (pg 23) Base/End Note: 5 Style only available with 03 terminals. †Contact factory for configuration. Terminal Styles Inches (Millimeters) 0.40 (10.2) 0.045 (1.14) 0.18 (4.6) 01 Handwired #6-32 screw 51 #8-32 screw 0.125 (3.18) 0.70 (17.8) 0.19 (4.8 ) 0.031 (0.79) 0.120 (3.05) 0.18 (4.6) 0.031 (0.79) 0.062 (1.57) 02 Printed Circuit #6-32 screw 52 #8-32 screw 03 Non Feed-Thru #6-32 screw 53 #8-32 screw Available on Mount End (5) only. 0.18 (4.6) 0.031 (0.79) 07 Extended Pin #6-32 screw 57 #8-32 screw 0.045 (1.14) 0.18 (4.6) 09 07 Brass SEMS Steel SEMS Nickel-Plated Zinc-Plated (standard) * NOTE: Wire ready screws standard on all terminal styles. CB3 Terminal Exit Options Inches (Millimeters) 0.255 (6.48) 0.18 (4.6) Exit Rear (std.) 16 EB Exit Back For additional product information, visit www.cooperbussmann.com/magnum 0.031 (0.79) 14 Printed Circuit #6-32 screw 64 #8-32 screw Screw Options Compliance References Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Terminal Blocks - Single Row Terminal Blocks - Single Row Hardware Options Solder Lugs Inches (Millimeters) (Bulk ordering part numbers are in parentheses.) Jumpers Terminal Blocks: Single & Double Row Series CB3000 Single Row Terminal Blocks Continued Quick Connects Blade Width A = 0.250”. Blade Width B = 0.187”. 0.68 (17.3) S1 (2S1-J) †J201 Flat slip-on (J201-J) †OJ3 (OJ3-J) A7 & B7 (2A7-J & 2B7-J) A8 & B8 (2A8-J & 2B8-J) A9 & B9 (2A9-J & 2B9-J) EuroMag Series 0.84 (21.2) Terminal Blocks: Base & Rail Mount †OJ7 (OJ7-J) †Contact factory for pole configuration. Power Distribution Blocks Mounting Options Inches (Millimeters) Right Angle Mounting Bracket End Positions usable 0.71 (18.0) Snap-in Angle Bracket Chassis or PCB A 0.79 (20.1) 1.02 (25.8) 0.45 (11.4) Exit Back (EB) Terminals 0.24 (6.1) Angle Bracket A 0.42 (10.7) Option AB Edge Connectors, One-Sided Boards Mounts blocks on PC boards at a right angle. • Protects solder joints. • Recommended for all EB (Exit Back) PCB terminal blocks. • Bracket snaps securely on block (no hardware required). • Minimum strip length (end positions are usable). • Mount with #6-32 or #8-32 screws (not supplied). Wire Management Products #6 or #8 mounting screw & nut (Customer supplied.) Mounting Plates MP MP8 MT MT8 For additional product information, visit www.cooperbussmann.com/magnum Compliance References MOUNTING PLATE Options MP, MP8, MT & MT8 MP Metal inserts with 0.150” dia. hole accept #6 screw. MP8 Metal inserts with 0.187” dia. hole accept #8-32 screw. MT Metal inserts with tapped hole accept #6-32 screw. MT8 Metal inserts with tapped hole accept #8-32 screw. 17 Series A38 / B38 Single Row Terminal Blocks SPECIFICATIONS Rating: A38: 30A, 600V B38: 50A, 300V Center Spacing: 0.437” (11.10mm) Wire Range: A38: #10-22 AWG CU; B38: #8-16 AWG Screw Size: #8-32 zinc-plated steel Torque Rating: A38: 9 lb-in; B38: 15 lb-in for #8, 9 lb-in for #6 Base: A38 Only: Standoffs standard for easy flux washing Distance Between Barriers: 0.378” (9.60mm) Recommended PCB Hole Diameter (A38): 0.076” (1.93mm) Operating Temperature: 221°F (105°C) B384904 Molded Material: Black, UL Rated 94V0 Thermoplastic Breakdown Voltage: 5000V Agency Information: UL File E62622, CSA File 47235; CE Certified Dimensions - in (mm) TABLE A MOUNTING ENDS ONLY Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Terminal Blocks - Single Row Poles B Mount Ctrs. “A” Dim. Length BARRIER ENDS ONLY “A” Dim. Length 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 1.31 1.75 2.19 2.62 3.06 3.50 3.93 4.37 4.81 5.24 5.68 6.12 6.56 6.99 7.43 1.67 2.10 2.54 2.98 3.41 3.85 4.29 4.72 5.16 5.60 6.04 6.47 6.91 7.35 7.78 0.93 1.37 1.81 2.25 2.68 3.12 3.56 3.99 4.43 4.87 5.30 5.74 6.18 6.61 7.05 * Dimensions in inches. To convert to millimeters, multiply by 25.4. A382208 Series A38 A Dim. Length B Mount Centers 9.0 [0.3] HOLE SIZE Ø5.0 [Ø0.20] 11.10 [0.437] 21.5 [0.85] 7.0 [0.28] 20.4 [0.80] 6.3 [0.25] Ø8.0 [0.31] 19.7 [0.78] A Dim. Length Series B38 Edge Connectors, One-Sided Boards B Mount Centers 13.0 [0.51] HOLE SIZE Ø5.0 [Ø0.20] 16.5 [0.65] 11.10 [0.437] 7.0 [0.28] Compliance References 16.5 [0.65] Ø8.0 [0.31] 15.0 [0.59] 18 For additional product information, visit www.cooperbussmann.com/magnum 6.8 [0.27] Terminal Blocks - Single Row Part Numbering System Terminal Style A 38    0 1 2 7 9 - 0.187˝ QC - hand wired - printed circuit - extended wire wrap - 0.250" QC Screw Options Options     1 - flat base, mount end 2 - flat base, barrier end 3 - insulator base* mount end 4 - insulator base* barrier end 02 to 16 Blank - standard screw L1 to L6 marking options (pg 22) (steel zinc-plated, RC - retaining clips (pg 15) philslot BHMS) Covers - (pg 23) 04 - brass, nickel-plated, philslot BHMS 07 - steel, SEMS zinc-plated philslot screw 92 - steel, zinc-plated slotted BHMS 94 - brass, nickel-plated slotted BHMS (Binding Hard Machine Screw)    02 to 16 Blank - standard screw steel zinc-plated philslot BHMS) 04 - brass, nickel-plated, philslot BHMS #8-32 *34 - #6-32 nickel-plated brass philslot BHMS L1 to L6 marking options (pg 23) RC - retaining clips (pg 16) *N/A on 2 terminal style. B 3 8    1 - long turret 0 - flat base, 2 - short turret mount ends 3 - screw terminal 4 - insulator base, #6-32 screw top barrier ends & bottom) 9 - insulator base 4 - stud (#8-32 screw mount ends top, #6-32 stud bottom) †5 - double stud (#6-32 stud top & bottom) †C360 Copper alloy (bright tin plate) *Note: 34 screws only *available with 3 terminal style. Wire ready screws standard 0.031 (0.79) 0.062 (1.58) 0.110 (2.80) 0.20 (5.1) 0.031 (0.79) 1 Handwired 2 Printed Circuit 0.062 (1.58) 0.67 (17.0) 0.031 (0.79) 7 Extended Pin 0.250 (6.35) Wire Management Products 0.031 (0.79) Inches (Millimeters) 0.59 (15.1) 0.55 (14.0) Power Distribution Blocks A38 Terminal Styles Terminal Blocks: Base & Rail Mount # of Poles EuroMag Series Base/End Terminal Blocks: Single & Double Row Series 9 0.250” QC B38 Terminal Styles #6 - 32 SCREW #6 - 32 NUT 7.6 (0.30) 4.6 (0.18) 6.4 (0.25) 1 Long Turret 4.6 (0.18) 0.58 (4.8) 6.8 (0.27) 2 Short Turret #6 - 32 SCREW 0.58 (4.8) #6 - 32 NUT #6 - 32 NUT 3 Screw Terminal 4 Stud 5 Double Stud Edge Connectors, One-Sided Boards 0.21 (5.3) 11.6 (0.46) Screw Options 04 Brass Nickel-Plated 07 Steel SEMS Zinc-Plated 34 Nickel-Plated Brass Philslot BHMS 92 Slotted, Zinc-Plated Steel Compliance References Standard Zinc-Plated Steel 94 Slotted, Nickel-Plated Brass For additional product information, visit www.cooperbussmann.com/magnum 19 Terminal Blocks - Single Row SPECIFICATIONS Rating: See table. Center Spacing: 0.562” or 9/16” (14.28mm) Wire Range: See rating table. Screw Size: #8-32 or #10-32 zinc-plated slotted screws Torque Rating: #8 screw size 16 lb-in.; #10 screw size 20 lb-in. Distance Between Barriers: 0.47” (11.9mm) Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Molded Material: Black, UL Rated 94V0 Thermoplastic Hardware: Bottom studs supplied with nuts assembled. Cup washers are optional on bottom studs but are not recommended with ring terminals. Extended Hex Nuts: Optional extended, slotted hex nuts enable easier installation and removal with hex wrench or screwdriver. Available in bulk for the #10-32 studs on Series A4953 blocks. Specify part number F582 and quantity. Breakdown Voltage: 6100V Agency Information: UL File E62622, CSA File 47235; CE Certified B484304 A40110407 A4000 Series Dimensions - in (mm) 0.31 (7.9) 0.562 (14.27) 0.87 (22.1) A B Part Number A4003XX A4011XX A4013XX A4021XX A4035XX A4041XX A4043XX A4051XX A4803XX A4813XX A4843XX A4953XX B4843XX Terminal Top # 8 Screw # 8 Screw # 8 Screw # 8 Screw # 8 Screw #10 Screw #10 Screw #10 Screw #10 Screw #10 Screw #10 Screw #10 Stud #10 Screw Terminal Bottom #8 Stud Solder Solder 0.250 QC Closed Solder Solder 0.250 QC #8 Stud SolderTurret #8 Screw #10 Stud #8 Screw Wire* Range CU 8-16 AWG 10-16 AWG 10-16 AWG 10-16 AWG 8-16 AWG 10-16 AWG 10-16 AWG 10-16 AWG 8-16 AWG 10-16 AWG 8-16 AWG 8-16 AWG 8-16 AWG Ratings* Volts/Amps 150V/50A 600V/35A 600V/35A 600V/35A 600V/50A 600V/35A 600V/35A 600V/35A 150V/50A 600V/35A 150V/50A 150V/50A 600V/50A * All models 30A Max. with 10 AWG; 35-50A ratings with 8 AWG using ring or fork type terminals. Note: 50A rating achieved with #8 copper wire crimped to ring terminal. Poles A (in.) Mount Centers B (in.) Length 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 1.69 2.25 2.81 3.37 3.93 4.50 5.06 5.62 6.18 6.74 7.31 7.87 8.43 8.99 9.55 10.12 10.68 2.12 2.68 3.24 3.80 4.36 4.93 5.34 6.05 6.61 7.17 7.74 8.30 8.86 9.44 9.98 10.55 11.11 0.31 (7.9) 1.05 (26.7) 0.57 (14.5) 0.36 dia. (9.1) Note: Above unit supplied with nuts assembled. Cup washers are optional. Optional Cup Washers Assembled Available on A4003, A4803, A4843, A4953 & B4843. CUP WASHERS Reference Panel Cutout for 6 Position Block 0.20 DIA. (5.1) 0.75 (19.1) 3.31 (84.1) 3.93 (99.8) * Dimensions in inches. To convert to millimeters, multiply by 25.4. 20 0.21 (5.3) #8-32 or #10-32 THD’S RATING TABLE Compliance References Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row A481307 Series A4000 & Series B4000 Single Row Terminal Blocks For additional product information, visit www.cooperbussmann.com/magnum Terminal Blocks - Single Row Part Numbering System A 4  B 4  Base/End Poles Screw Options Options 00 01 02 03 04 05 80 *1 - flat base/ mount end 3 - insulator base(not available in 03 terminal style) /mount end 5 - closed base/ mount end (available in 03 terminal only) 02 to 18 Blank - std. screw 00 - screws shipped bulk 04 - brass nickel-plated 07 - steel SEMS zinc plated (not available with hardware options; not available on A4003, A4803, A4813, A4843, B4843) A1 to A9 - 0.250” QC †CW - cup washer (pg 20) J301 - flat slip-on jumper (2 position only) L1 to L6 marking options (pg 22) S1 & S2 - solder lugs/flat  A4 - standard B4 - barrier (only available in 84 terminal style) - screw top; stud bottom - screw top; solder bottom - #8 screw top; 0.250˝ QC bottom - screw top only - #10 screw top; solder term. b. - #10 screw top; 0.250˝ QC bottom - screw top; stud bottom #10-32 top, #8-32 bottom insulated base 81 - screw top; solder turret bottom #10-32 84 - screw top; screw bottom #10-32 95 - stud top; stud bottom #10-32     † Available only on A4003, A4803, A4843, A4953 & B4843. *Available in 01, 02, 04 & 05 terminal style only. Terminal Styles Inches (Millimeters) Terminal Blocks: Base & Rail Mount #8-32 SCREW #8-32 or #10-32 SCREW #8-32 or #10-32 SCREW 0.94 (23.9) 1.41 (35.8) 1.41 (35.8) 1.99 (50.6) #8-32 HEX NUT 0.43 (10.9) 0.04 (1.0) 0.41 (10.4) A4003XX 0.17 (4.3) 0.04 (1.0) 0.43 (10.9) 0.36 (9.1) A4013XX (#8-32) A4043XX (#10-32) #10-32 SCREW #10-32 SCREW #8-32 SCREW (TYP) 0.80 (20.3) 0.94 (23.9) 1.56 (39.6) 1.85 (47.0) 1.99 (50.6) 0.59 (15.0) 0.250 (6.35) #8-32 HEX NUT A4035XX 0.41 (10.4) A4813XX #10-32 STUD #10-32 SCREW #10-32 SCREW 1.05 (26.7) 1.55 (39.4) 0.49 (12.5) #10-32 HEX NUT #8-32 SCREW A4843XX 0.41 (10.4) 1.99 (50.6) 0.79 (20.1) 0.30 (7.6) 0.94 (23.9) 1.84 (46.7) 0.09 (2.4) A4953XX Jumpers #8-32 SCREW 0.41 (10.4) B4843XX Edge Connectors, One-Sided Boards Hardware Options 0.36 (9.1) TURRET A4803XX Wire Management Products A4021XX (#8-32) A4051XX (#10-32) Solder Lugs Power Distribution Blocks A4011XX (#8-32) A4041XX (#10-32) #8-32 or #10-32 SCREW 0.03 (0.8) Inches (Millimeters) (Bulk ordering part numbers are in parentheses.) Quick Connects Blade Width A = 0.250”. (For other orientations, contact factory.) 1.12 (28.4) *S1 (2S1-J) J301 (J301-J) A1 (4A1-J) A2 (4A2-J) A3 (4A3-J) A6 (4A6-J) A7 (4A7-J) A8 (4A8-J) A4 (4A4-J) A5 (4A5-J) *Not available for A4843 Compliance References 0.56 (14.3) *S2 (2S2-J) EuroMag Series Terminal Style Terminal Blocks: Single & Double Row Series A9 (4A9-J) For additional product information, visit www.cooperbussmann.com/magnum 21 Terminal Blocks: Single & Double Row Terminal Blocks - Single Row All Series Marking Options Single Row Terminal Blocks Marking Options & Accessories 1 2 3 L3 Left Lying Numerals Left to Right L5 Upside-Down Numerals Right to Left L4 Right Lying Numerals Right to Left L6 Upside-Down Numerals Left to Right Special Marking Special markings are available for Series 1000, 2000, 3000, 4000 & 5000 at an additional charge for preparation. Production charges for setup, handling and marking are the same as for standard marking and the same quantity discounts apply. Consult factory for price and delivery. Z A ☎ RE BL D BL K U ❹ ✙ Terminal Blocks: Base & Rail Mount Power Distribution Blocks Wire Management Products 3 Edge Connectors, One-Sided Boards 2 1 1 1 L2 Upright Numerals Right to Left L1 Upright Numerals Left to Right 2 2 1 3 3 3 2 2 Standard marking this side 1 % Ω Options LT1 - LT6 Top Marking For high visibility in tight packages. Closed Barrier Terminal Block Marking Options # 8 7 6 5 L1 & LT1 = Upright numerals, numbered from left to right L2 & LT2 = Upright numerals, numbered from right to left L3 = Left lying numerals, numbered from left to right L4 = Right lying numerals, numbered from right to left L5 & LT5 = Upside down numerals, numbered from right to left L6 & LT6 = Upside down numerals, numbered from left to right 4 3 2 8 1 7 6 5 4 3 2 1 Options L1 - L6 Regular Marking Marker Strips Black marker strips with white numerals mount beneath the terminal blocks to clearly identify terminal and wire positions. Available with forward or reverse markings, top or bottom of strip. If special markings are required, submit a drawing. 1 2 3 4 1 2 3 4 4 3 2 1 4 3 2 1 1 2 3 4 1 2 3 4 4 3 2 1 4 3 2 1 Top Forward - TF Bottom Forward - BF Compliance References Blocks to be marked on both sides require a different code for each side. Example: “L1” on one side of the block requires “L2” on the other side to ensure common terminal marking. Specify by adding suffix to part number. Markings are applied directly to the sides of Series 1000, 2000, 3000, and 4000. Standard characters are white and 1/8” high. Factory may substitute 3/32” high characters. 3 EuroMag Series Standard Marking Top Reverse - TR Bottom Reverse - BR Series Base Poles Marking M S      MS1 - 1000 Series MS2 - 2000 Series MS3 - 3000 Series 1 2 3 4 5 02 to 36 BF - bottom forward TF - top forward BR - bottom reverse TR - top reverse 22 - mount end, feed thru - barrier end, feed thru - mount end, insulator tubes - barrier end, insulator tubes - mount end, non feed-thru For additional product information, visit www.cooperbussmann.com/magnum Terminal Blocks - Single Row Terminal Blocks: Single & Double Row All Series Accessories Single Row Terminal Blocks Continued Cover Options - Single Row Terminal Block Covers Standard Cover Markings Top Forward - TF 1 2 3 4 1 2 3 4 EuroMag Series Available for Series A1000, A2000, A3000, A4000, CB2000, CB3000, LP2000, & LP3000. Three styles of UL 94V0 thermoplastic covers are offered in black. Covers are ordered separately and supplied with two clips each, unless ordered without clips. Optional markings may be specified (black on yellow; white on black). Bottom Forward - BF Skirted Access Side Notes: Covers can not be used with: • mounting plate options MP & MT. • certain quick connect terminals. • 0, 6, & 9 base/end styles on A2 or A3 4 3 2 1 Bulk Cover Clips: Series 1000 = CC1-J; Series 2000 & 3000 = CC2-J; Series 4000 = CC4-J. 4 3 2 1 Top Reverse - TR Terminal Blocks: Base & Rail Mount Bottom Reverse - BR Skirted Access Side Cover Options BC & TC Open access on both sides. Cover Options BO & CO Skirted access on one side only. Series Poles Markings Options      BB - skirted access, both sides, black BO - skirted access, one side, black BC - open access, both sides, black* 1 2 3 4 02 to 36 BF - bottom forward TF - top forward BR - bottom reverse TR - top reverse 00 - without clips * Not available in 4000 Series - 1000 - 2000 - 3000 - 4000 Wire Management Products Cover Power Distribution Blocks Cover Options BB & CB Skirted access on both sides. Snap-On Covers for A38/B38/F38 Series & CB2/CB3 Series - CB2/CB3 Series Poles    A38 Series B38 Series T O 2  O 3 T  - Poles   Compliance References T A 8  T B 8  B8 F   Edge Connectors, One-Sided Boards A38/B38 Series CB2 Series CB3 Series F38 Series For additional product information, visit www.cooperbussmann.com/magnum 23 Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Terminal Blocks - Filtered F38 Series Filtered Terminal Blocks SPECIFICATIONS Ratings: 35A, 240Vac, 300Vdc. Center Spacing: 0.437" or 7/16" (11.10mm) Wire Size: # 10-22 AWG CU Screw Size: # 8-32 (# 6-32 available, consult factory) Torque Rating: 15 lb-in. Operating Temperature: –55°C to +105°C. Housing Material: 94V0 thermoplastic. Molded Material: Black, UL rated 94V0 thermoplastic. Terminal Material: Brass, tin-plated Capacitance: 1000 pF to 5000 pF in either C or Pi Schematic Dielectric Withstanding Voltage: 1000 Vac; 1700Vdc DC Resistance: 0.01 ohms max. Agency Information: UL File E62622, CE Certified # of Poles A A Front Mount Rear Mount 2 3 4 5 6 7 8 1.67 2.10 2.54 2.98 3.41 3.85 4.29 1.88 2.32 2.76 3.19 3.63 4.07 4.51 B C D 1.31 1.75 2.19 2.63 3.06 3.50 3.94 0.93 1.37 1.81 2.25 2.68 3.12 3.56 0.44 0.88 1.31 1.75 2.19 2.62 3.06 FEATURES • Rugged integrated construction of filtering elements around a solid brass pin provides excellent EMI/RFI filtering • Filter element provides high insertion loss for EMI/RFI filtering of AC and DC power and control lines • 2 to 8 terminals standard – up to 16 poles available • Cost-effective EMI solution for industrial interconnection filtering • Termination options are straight lead, male or female quick connect • Custom and special options available including: – Different capacitance values on each position – Wire assemblies added to pins Insertion Loss for 2,500 pF Pi Schematic Typical Insertion Loss (dB) in 50 Ohm Circuit 30MHz . . . . . . . . . . . .42 dB 50 MHz . . . . . . . . . . .45 dB 100 MHz . . . . . . . . . .50 dB 300 MHz . . . . . . . . . .68 dB 1000 MHz . . . . . . . . .70 dB * Note: For other capacitance insertion loss, consult factory. Dimensions - mm (in) I - Rear Panel Mount O - Front Panel Mount Part Numbering System Series F 3 8  Terminal Style Inches (Millimeters) Mounting # of Poles Screw Options Filter Options Capacitance      . Blank - #8-32, steel, zinc-plated philslot BHMS (stnadard) 04 - #8-32, brass, nickel-plated philslot BHMS 92 - #8-32, steel, zinc-plated slotted BHMS 94 - #8-32, brass, nickel-plated slotted BHMS C - C Filter P - Pi Filter 1.0 - 1000 pF + 100%-0% 2.5 - 2500 pF + 100%-0% 5.0 - 5000 pF + 100%-0% 0 - straight lead 0 - front panel mount 02 to 08* 1 - 0.187" quick with mount ends 1 - rear panel mount connect (male) 2 - 0.187" quick with #4-40 threaded inserts connect (male) 3 - 0.250" quick connect (male) 4 - 0.250" quick connect (female) Compliance References Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks * Note: In inches. Available up to 16 poles. Consult factory. * Note: Standard is 02-08 poles. Available up to 16 poles. Consult factory for availability. Special electrical/mechanical configurations are available upon request from factory. 24 For additional product information, visit www.cooperbussmann.com/magnum Terminal Blocks - Double Row Terminal Blocks: Single & Double Row Series TB100 Double Row Terminal Blocks EuroMag Series SPECIFICATIONS Rating: 30A, 300V* Center Spacing: 0.375” or 3/8” (9.52mm) Wire Range: #14 - 22 AWG CU TB100-08 Screw Size: #6-32 philslot screws Torque Rating: 9 lb-in. Distance Between Barriers: 0.30” (7.62mm) Mounting: #6 screws Operating Temperature: 130°C (266°F) max., -40°C (-40°F) min. Materials: Molded base: Black, UL rated 94V0 thermoplastic Terminal plating: Tin over brass; Screws: Zinc-plated steel Breakdown Voltage: 3600V Agency Information: UL File E62622/CSA File 47235; IEC TB100-04SP Compliance; CE Certified Dimensions - in (mm) A B Poles A 02 03 04 05 06 07 08 09 10 11 12 13 1.40 1.78 2.16 2.53 2.90 3.28 3.66 4.03 4.40 4.78 5.16 5.53 1.12 1.50 1.88 2.25 2.62 3.00 3.38 3.75 4.12 4.50 4.88 5.25 14 15 16 17 18 19 20 21 22 23 24 25 5.90 6.28 6.66 7.03 7.40 7.78 8.16 8.53 8.90 9.28 9.66 10.03 B Poles A B 26 27 28 29 30 31 32 33 34 35 36 10.40 10.78 11.16 11.53 11.90 12.28 12.66 13.03 13.40 13.78 14.16 10.12 10.50 10.88 11.25 11.62 12.00 12.38 12.75 13.12 13.50 13.88 TB100 Inches (mm) A 5.62 6.00 6.38 6.75 7.12 7.50 7.88 8.25 8.62 9.00 9.38 9.75 * Dimensions in inches. To convert to millimeters, multiply by 25.4. 0.14 (3.5) 0.14 (3.5) B 0.88 (22.3) 0.31 (7.9) 0.17 dia. (4.3) 0.375 (9.5) Power Distribution Blocks Poles 0.30 (7.6) 0.41 (10.4) 0.25 (6.3) Wire Management Products Part Numbering System Series T B 1 0 0  - Poles Marking    02 to 36 Blank - steel philslot, zinc-plated L1 to L6 - (pg 32) 00 - screws shipped bulk Marker strips (pg 33) B - brass philslot, nickel-plated Covers (pg 32) BS - brass Sems philslot, nickel-plated SP - steel Sems philslot, zinc-plated P - steel Sems (P-style) ST - stainless steel, philslot STR - stainless steel, phillips (recess) Hardware Options  QC1 to QC20 - quick connects †J101 - flat slip-on jumper (2 position only) †0J2 - over barrier jumpers †0J4 - over barrier jumpers Edge Connectors, One-Sided Boards Screw Options Terminal Blocks: Base & Rail Mount * Max. rating shown; some options may be rated lower - consult factory. Compliance References † Contact factory for pole configuration. For additional product information, visit www.cooperbussmann.com/magnum 25 EuroMag Series Terminal Blocks: Single & Double Row Terminal Blocks - Double Row Screw Options B Brass Philslot Nickel-Plated BS Brass SEMS Philslot Nickel-Plated Hardware Options ST Stainless Steel Philslot SP Steel SEMS Philslot Zinc-Plated P Steel SEMS (P-Style) STR Stainless Steel Phillips (recess) (Bulk ordering part numbers are in parentheses.) QC1 QC2 QC3 QC4 QC5 QC6 QC8 QC9 QC10 QC11 QC12 QC13 QC14 QC15 QC16 QC17 QC18 QC107 QC 45° – QC 45° QC108 QC 45° – QC 90° QC19 Quick Connects – Bulk Min. order per part no. – 100 pieces. Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount Quick Connects – Assembled Terminal 0.187” x 0.020”. Max. current rating 13 Amps. For other orientations, contact factory. QC101 Flat – none QC102 QC 45° – none QC103 QC 90° – none QC104 Flat – Flat QC105 Flat – QC 45° QC106 Flat – QC 90° Compliance References Jumpers – Bulk QC109 QC 90° – QC 90° Min. order per part no. – 100 pieces. Contact factory for jumper assembly. †J101 Flat slip-on (J101-J) †OJ2 Slip-on over barrier †OJ4 Closed over barrier (0J2-J) (0J4-J) † Contact factory for pole configuration. 26 For additional product information, visit www.cooperbussmann.com/magnum QC7 QC20 Terminal Blocks - Double Row Terminal Blocks: Single & Double Row Series TB200 & TB200HB Double Row Terminal Blocks SPECIFICATIONS Rating: TB200 - 30A, 300V* TB200HB - 30A, 600V* Center Spacing: 0.437” or 7/16” (11.10mm) Wire Range: #12 - 22 AWG CU Screw Size: #6-32 philslot screws Torque Rating: 9 lb-in. Distance Between Barriers: 0.353” (8.97mm) Mounting: #6 screws Operating Temperature: 130°C (266°F) max., -40°C (-40°F) min. TB200HB-06 Materials: Molded base: Black, UL rated 94V0 thermoplastic Terminal plating: Tin over brass; Screws: zinc-plated steel Breakdown Voltage: 4800V Agency Information: UL File E62622, CSA File 47235 & 15364; Dimensions - in (mm) IEC Compliance; CE Certified TB200 * Max. rating shown; some options may be rated lower - consult factory. TB200-10SP EuroMag Series A B Poles A B Poles A B 02 03 04 05 06 07 08 09 10 11 1.63 2.07 2.51 2.94 3.38 3.82 4.25 4.69 5.13 5.57 1.31 1.75 2.18 2.62 3.06 3.50 3.93 4.37 4.81 5.25 12 13 14 15 16 17 18 19 20 21 6.00 6.44 6.87 7.31 7.75 8.19 8.62 9.06 9.50 9.94 5.68 6.12 6.56 7.00 7.43 7.87 8.31 8.75 9.18 9.62 22 23 24 25 26 27 28 29 30 10.37 10.81 11.25 11.68 12.12 12.56 13.00 13.44 13.87 10.06 10.50 10.93 11.37 11.81 12.25 12.68 13.12 13.56 * Dimensions in inches. To convert to millimeters, multiply by 25.4. 0.16 (4.0) 0.16 (4.0) B 1.12 (28.4) 0.44 (11.2) 0.437 (11.1) 0.17 dia. (4.3) 0.353 (8.9) Power Distribution Blocks Poles 0.56 (14.2) 0.31 (7.8) Terminal Blocks: Base & Rail Mount Inches (mm) A TB200HB A 0.16 (4.0) B 0.90 1.37 (22.8) (34.8) 0.44 (11.2) 0.17 dia. (4.3) 0.437 (11.1) 0.353 (8.9) 0.17 x 0.22 slots (4.3 x 5.6) 0.75 (19.0) 0.33 (8.4) Edge Connectors, One-Sided Boards Part Numbering System Series - Poles B 2 0 0   T  200 - Standard 200HB - High barrier 02 to 30 Wire Management Products 0.16 (4.0) Screw Options Marking Hardware Options    For additional product information, visit www.cooperbussmann.com/magnum 27 Compliance References Blank - steel philslot, zinc-plated L1 to L6 - (pg 32) QC1 to QC20 - quick connects †J201 - flat slip-on jumper 00 - screws shipped bulk Marker strips (pg 32) B - brass philslot, nickel-plated Covers (pg 32) (2 position only) †0J3 - over barrier jumpers BS - brass Sems philslot, nickel-plated †0J5 - over barrier jumpers SP - steel Sems philslot, zinc-plated †0J7 - over barrier jumpers P - steel Sems (P-style) ST - stainless steel, philslot SS - stainless steel Sems, philslot STR - stainless steel, phillips (recess) † Contact factory for pole configuration EuroMag Series Terminal Blocks: Single & Double Row Terminal Blocks - Double Row Screw Options B Brass Philslot Nickel-Plated BS Brass SEMS Philslot Nickel-Plated Hardware Options SP Steel SEMS Philslot Zinc-Plated ST Stainless Steel Philslot P Steel SEMS (P-Style) SS Stainless Steel SEMS Philslot STR Stainless Steel Phillips (recess) (Bulk ordering part numbers are in parentheses.) QC1 QC2 QC3 QC4 QC5 QC6 QC8 QC9 QC10 QC11 QC12 QC13 QC14 QC15 QC16 QC17 QC18 QC207 QC 45° – QC 45° QC208 QC 45° – QC 90° QC19 Quick Connects – Bulk Min. order per part no. – 100 pieces. Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount Quick Connects – Assembled Terminal 0.250” x 0.031”. Max. current rating 20 Amps. For other orientations, contact facto- QC201 Flat – none QC202 QC 45° – none QC203 QC 90° – none QC204 Flat – Flat QC205 Flat – QC 45° QC206 Flat – QC 90° Compliance References Jumpers – Bulk QC209 QC 90° – QC 90° Min. order per part no. – 100 pieces. Contact factory for jumper assembly. †J201 Flat slip-on (not available on TB200HB) (J201-J) †OJ3 Slip-on over barrier for TB200HB (0J3-J) †OJ5 Closed over barrier for TB200HB (0J5-J) †OJ7 Closed over barrier for TB200 (0J7-J) † Contact factory for pole configuration. 28 For additional product information, visit www.cooperbussmann.com/magnum QC7 QC20 Terminal Blocks - Double Row Terminal Blocks: Single & Double Row Series TB300 & TB345 Double Row Terminal Blocks Poles 02 03 04 05 06 07 08 09 2.13 2.69 3.25 3.81 4.37 4.94 5.50 6.06 1.69 2.25 2.81 3.37 3.94 4.50 5.06 5.62 10 11 12 13 14 15 16 17 A B 6.62 6.19 7.18 6.75 7.75 7.31 8.31 7.87 8.87 8.44 9.43 9.00 9.99 9.56 10.56 10.12 Poles A B 18 19 20 21 22 23 24 11.12 11.68 12.24 12.80 13.37 13.93 14.49 10.68 11.25 11.81 12.37 12.93 13.50 14.06 * Dimensions in inches. To convert to millimeters, multiply by 25.4. TB300 & TB345 8-32 binding head screw - TB 300 10-32 binding head screw - TB 345 A 0.22 (5.6) B 0.90 1.33 (22.8) (33.8) 0.50 (12.7) 0.56 (14.2) 0.21dia. (5.3) 0.56 (14.2) 0.412 (10.4) 0.21 x 0.25 slots (5.3 x 6.3) Wire Management Products 0.81 (20.5) 0.33 (8.4) T B 3   300 - 8-32 screw 345 - 10-32 screw - Poles Screw Options Marking Hardware Options    02 to 24 Blank - steel philslot, zinc-plated 00 - screws shipped bulk B - brass philslot, nickel-plated BS - brass Sems philslot, nickel-plated (TB300 only) SP - steel Sems philslot, zinc-plated P - steel Sems (P-style) (TB300 Series only) ST - stainless steel, philslot STR - stainless steel, phillips (recess) L1 to L6 - (pg 32) Marker strips (pg 33) Covers (pg 32) QC1 to QC20 - quick connects (TB300 only) †J301 - flat slip-on jumper †0J6 - over barrier jumper †0J11 - over barrier jumper Compliance References  Edge Connectors, One-Sided Boards Part Numbering System Series Power Distribution Blocks B TB345-06SP Terminal Blocks: Base & Rail Mount A TB300-08 Dimensions - in (mm) * Max. rating shown; some options may be rated lower - consult factory. Poles EuroMag Series SPECIFICATIONS Rating: TB300 – 30A, 600V* TB345 – 45A, 600V* Center Spacing: 0.562” or 9/16” (14.28mm) Wire Range: #8 - 22 AWG CU Screw Size: TB300 – #8-32 philslot screws TB345 – #10-32 philslot screws Torque Rating: #8 screws - 16 lb-in.; #10 screws - 20 lb-in. Distance Between Barriers: 0.41” (10.5mm) Mounting: TB300 – #8 screws; TB345 – #10 screws Operating Temperature: 130°C (266°F) max., -40°C (-40°F) min. Material: Molded base: Black, UL rated 94V0 thermoplastic Terminal plating: Tin over brass; Screws: zinc-plated steel Breakdown Voltage: 7500V Agency Information: UL File E62622, CSA File 47235; IEC Compliance; CE Certified †Contact factory for pole configuration. For additional product information, visit www.cooperbussmann.com/magnum 29 EuroMag Series Terminal Blocks: Single & Double Row Terminal Blocks - Double Row Screw Options B Brass Philslot Nickel-Plated BS Brass SEMS Philslot Nickel-Plated SP Steel SEMS Philslot Zinc-Plated ST Stainless Steel Philslot P Steel SEMS (P-Style) STR Stainless Steel Phillips (recess) Hardware Options QC1 QC2 QC3 QC4 QC5 QC6 QC8 QC9 QC10 QC11 QC12 QC13 QC14 QC15 QC16 QC18 QC17 QC19 Quick Connects – Bulk *TB300 only. Min. order per part no. – 100 pieces. Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount Quick Connects – Assembled TB300 only. Terminals 0.250” x 0.031”. Max. current rating 20 Amps. For other orientations, contact factory. QC201 Flat – none QC202 QC 45° – none QC203 QC 90° – none QC204 Flat – Flat QC205 Flat – QC 45° QC206 Flat – QC 90° Compliance References Jumpers – Bulk QC207 QC 45° – QC 45° QC208 QC 45° – QC 90° QC209 QC 90° – QC 90° Min. order per part no. – 100 pieces. Contact factory for jumper assembly. †J301 Flat slip-on (TB300 only) (J301-J) †OJ6 Closed over barrier (OJ6-J) †OJ11 Slip-on over barrier (OJ11-J) †Contact factory for pole configuration. 30 For additional product information, visit www.cooperbussmann.com/magnum QC7 QC20 Terminal Blocks - Double Row Terminal Blocks: Single & Double Row Series TB400 Double Row Terminal Blocks SPECIFICATIONS Rating: 75A, 600V Center Spacing: 0.687” or 11/16” (17.45mm) Wire Range: #6-14 AWG CU Screw Size: #10-32 philslot screws Torque Rating: 20 lb-in. Distance Between Barriers: 0.56” (14.3mm) Mounting: #10 screws Operating Temperature: 130°C (266°F) max., -40°C (-40°F) min. Material: Molded base: Black, UL rated 94V0 thermoplastic Terminal plating: Tin over brass; Screws: zinc-plated steel Breakdown Voltage: 7500V Agency Information: UL File E62622, CSA File 47235; IEC Compliance; CE Certified TB400-05 EuroMag Series Terminal Blocks: Base & Rail Mount Dimensions - in (mm) TB400 A Poles A B Poles A 02 03 04 05 2.51 3.20 3.89 4.58 2.06 2.75 3.44 4.13 06 07 08 09 5.26 5.95 6.64 7.33 B 4.81 5.50 6.19 6.88 Poles A B 10 11 12 8.01 8.70 9.39 7.56 8.25 8.94 B 0.22 (5.6) 0.15 dia. (3.8) 0.625 (15.9) Power Distribution Blocks * Dimensions in inches. To convert to millimeters, multiply by 25.4. 1.12 (28.4) 0.22 dia. (5.6) 0.687 (17.4) 0.687 (17.4) 0.562 (14.3) 1.81 (46.0) 0.76 (19.3) 0.46 (11.7) 1.34 (34.0) ST Stainless Steel Philslot STR Stainless Steel Phillips (recess) OJ14 Closed over barrier Part Numbering System Series –  02 to 12 Screw Options Marking Hardware Options Not available †0J14  Blank - steel philslot, zinc-plated 00 - screws shipped bulk B - brass philslot, nickel-plated ST - stainless steel, philslot STR - stainless steel, phillips (recess) Compliance References T B 4 0 0  Poles - Jumper over barrier †Contact factory for pole configuration. For additional product information, visit www.cooperbussmann.com/magnum Edge Connectors, One-Sided Boards B Brass Philslot Nickel-Plated Hardware Options Wire Management Products Screw Options 31 Terminal Blocks: Single & Double Row Terminal Blocks - Double Row All Series Marking Options & Accessories Double Row Terminal Blocks Marking Options 1 2 3 L2 L3 L4 L5 L6 134 G RED BLK BLU 3 4 OUT PUT 3AC 134 MAS TER 20A K GND M 300V MAX A Special markings are available at an additional charge for preparation. Production charges for setup, handling and marking are the same as for standard marking. Drawing(s) must be submitted to ensure accuracy of part required. Consult factory for price and delivery. INPUT Special Marking 5 Terminal Blocks: Base & Rail Mount L1 MB Power Distribution Blocks 3 2 1 1 2 3 Note: Blocks marked on both sides require a different code for each side. Example Style L1 on one side of the block requires Style L2 on the other side to ensure common terminal marking. To order, add appropriate suffix (L1, L2, L3, L4, L5 and/or L6) to block part number in the proper sequence. 1 2 3 1 2 3 Wire Management Products Standard markings are applied directly to the side(s) of a block. Standard color is white. Standard height is 0.125”. 3 2 1 EuroMag Series Standard Marking Note: Marking is not available on TB400 Series Covers Covers prevent personnel, screws and foreign items from contacting live terminals. Available in white or clear plastic. Two cover clips supplied with each cover. Cover width is 1.31 inches. All covers must be ordered separately. Consult factory for special legends. Compliance References Edge Connectors, One-Sided Boards Example: 10 position cover, white, TB100 Series, no legends . . . Part number is X12010. Part Numbering System Series Cover Strip Poles High Barrier Option Only X     120 119 220 219 320 319 02 to 36 (TB100) 02 to 30 (TB200/TB200HB) 02 to 24 (TB300/TB345) HB = High Barrier - TB100/white TB100/clear TB200/TB200HB - white TB200/TB200HB - clear TB300 & TB345 - white TB300 & TB345 - clear Example: 10 position cover, white, TB100 Series, no legends . . . Part number is X12010. Note: Covers are not available on TB400 Series. 32 For additional product information, visit www.cooperbussmann.com/magnum Cover Clips – Bulk Part Number DD1-J – TB100 Series DD2-J – TB200 Series DD2HB-J–TB200HB Series DD3-J – TB300 Series Terminal Blocks - Double Row Terminal Blocks: Single & Double Row Top & Bottom Marking Strips Double Row Terminal Blocks Top Marker Strips Top mounting marker strips are available in white (opaque) plastic. Two cover clips are supplied with each marker strip. All top marker strips must be ordered separately. Consult factory for special legends. EuroMag Series Example: 12 position cover, TB200, 0.032” x 0.312”, with no legends . . . Part No. is X20312. Example: 12 position cover, TB200HB, 0.060” x 0.500”, with no legends . . . Part No. is X23312HB. Part Numbering System X  Top Marker Strip Poles    133 103 233 203 333 303 02 to 36 (TB100) 02 to 30 (TB200/TB200HB) 02 to 24 (TB300/TB345) HB = High Barrier TB100 (0.060 thk x 0.500w) TB100 (0.032 thk x 0.312w) TB200/TB200HB (0.060 thk x 0.500w) TB200/TB200HB (0.032 thk x 0.312w) TB300 & TB345 (0.060 thk x 0.500w) TB300 & TB345 (0.032 thk x 0.380w) High Barrier Option Only Example: 12 position cover, TB200HB, 0.060” x 0.500”, with no legends . . . Part No. is X23312HB. Note: Marking Strips are not available on TB400 Series. Space for marking two sides Space for marking one side Bottom Marker Strips Power Distribution Blocks - Terminal Blocks: Base & Rail Mount Series Bottom mounting marker strips are made of black PVC, 0.030” thick. Space is available to handle most marking situations. All marker strips must be ordered separately. Wire Management Products To order, specify part number, required legends and (BF) bottom forward, (BR) bottom reverse, (TF) top forward, or (TR) top reverse. Consult factory for specials. Example: 13 position strip, TB100 with no legends, space for marking one side . . . Part number is X10513. Dim. A Dim. B TB100 TB200 TB200HB TB300 TB345 TB400 1.13” 1.38” 1.37” 1.62” 1.62” 1.81” 1.58” 1.81” 1.58” 1.81” N/A N/A Edge Connectors, One-Sided Boards Position for legends (one side, two sides) can be specified standard. Standard legend height is 0.125”. Standard legends are 0-99 and A-Z. Special legends are available on special order. Drawing(s) must be submitted to ensure accuracy of part required. Part Numbering System Bottom Marker Strip Poles X      105 101 205 201 295 291 305 301 02 to 36 (TB100) 02 to 30 (TB200/TB200HB) 02 to 24 (TB300/TB345) HB = High Barrier BF – bottom forward BR – bottom reverse TF – top forward TR – top reverse - TB100 – marking one side TB100 – marking both sides TB200 – marking one side TB200 – marking both sides TB200HB – marking one side TB200HB – marking both sides TB300 & TB345 – marking one side TB300 & TB345 – marking both sides High Barrier Option Only Orientation Note: Marking Strips are not available on TB400 Series. For additional product information, visit www.cooperbussmann.com/magnum 33 Compliance References Series Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Terminal Blocks - Standard Base Series TS - Standard Base Terminal Blocks; 8.00, 10.00, 12.00, 13.50mm Centers SPECIFICATIONS Rating: TS08 – 20A, 600V TS10 – 30A, 600V TS12 – 35A, 600V TS14 – 50A, 600V Wire Range: See Table Housing Material: Polyamide Type 6/6, 94V2 (white) Contact Material: Nickel-Plated Brass Wire Protector: Stainless Steel Screw Size: See Table Operating Temperature: 105°C (221°F) max., -30°C (-22°F) min. Torque Rating: See Table Construction: Mold-to-Length Agency Information: UL File E62622; CE Certified Dimensions E C A Dimensions TS08 # of Poles mm 2 3 4 5 6 7 8 9 10 11 12 15.80 23.80 31.80 39.80 47.80 55.80 63.80 71.80 79.80 87.80 95.80 TS10 in mm TS12 in 0.622 17.50 0.689 0.937 27.50 1.083 1.252 37.50 1.476 1.567 47.50 1.870 1.882 57.50 2.264 2.232 67.50 2.657 2.512 77.50 3.051 2.827 87.50 3.445 3.142 97.50 3.839 3.457 107.50 4.232 3.772 117.50 4.626 TS14 mm in mm in 20.70 32.70 44.70 56.70 68.70 80.70 92.70 104.70 116.70 128.70 140.70 0.815 1.287 1.760 2.232 2.705 3.177 3.650 4.122 4.594 5.067 5.539 23.00 36.50 50.00 63.50 77.00 90.50 104.00 117.50 131.00 144.50 158.00 0.906 1.437 1.969 2.500 3.031 3.563 4.094 4.626 5.157 5.689 6.220 Position Torque lb-in Clamping Area TS0801 3.5 4.0mm2 TS0802 3.5 1.5mm2 TS1001 4.4 6.0mm2 TS1002 4.4 2.5mm2 TS1201 7.0 10.0mm2 TS1202 7.0 6.0mm TS1401 12.0 16.0mm2 TS1402 12.0 10.0mm2 2 Wire Range AWG (Cu) 22-12 Sol./Str. 22-12 Sol./Str 22-10 Sol. 14-10 Str. 22-12 Sol./Str. 10 Sol. 22-10 Sol./Str. 22-10 Sol./Str. 20-8 Sol./Str. 20-8 Sol./Str. B D A D D 1.2mm STANDOFF F F WIRE PROTECTOR Dimensions mm (in) Screw M2.6x5 M2.6x5 M3.0x6 M3.0x6 M3.5x7 M3.5x7 M4.0x9 M4.0x9 B C D E F 17.00 (0.67) 17.00 (0.67) 20.20 (0.80) 20.20 (0.80) 23.80 (0.94) 23.80 (0.94) 25.60 (1.01) 25.60 (1.01) 14.50 (0.57) 14.50 (0.57) 17.00 (0.67) 17.00 (0.67) 19.00 (0.75) 19.00 (0.75) 25.20 (0.99) 25.20 (0.99) 8.00 (0.32) 8.00 (0.32) 10.00 (0.39) 10.00 (0.39) 12.00 (0.47) 12.00 (0.47) 13.50 (0.53) 13.50 (0.53) 2.90 (0.11) 2.90 (0.11) 3.60 (0.14) 3.60 (0.14) 3.90 (0.14) 3.90 (0.15) 4.40 (0.17) 4.40 (0.17) 2.8±0.1 (0.11) 2.8±0.1 (0.11) 3.4±0.1 (0.13) 3.4±0.1 (0.13) 4.2±0.1 (0.15) 4.2±0.1 (0.15) 5.0±0.1 (0.19) 5.0±0.1 (0.19) Compliance References Part Numbering System Spacing T S   08 10 12 14 34 - Base Positions   01 - std 02 - std w/ wire protector 02 to 12 For additional product information, visit www.cooperbussmann.com/magnum Terminal Blocks - Flat Base Dimensions EuroMag Series SPECIFICATIONS Rating: TS08 – 20A, 600V TS10 – 30A, 600V Wire Range: See Table Housing Material: Polyamide Type 6/6, 94V2 (white) Contact Material: Nickel-Plated Brass Wire Protector: Stainless Steel Screw Size: See Table Operating Temperature: 105°C (221°F) max., -30°C (-22°F) min. Torque Rating: See Table Construction: Mold-to-Length Agency Information: UL File E62622; CE Certified Terminal Blocks: Single & Double Row Series TS - Flat Base Terminal Blocks; 8.00, 10.00mm Centers E C Terminal Blocks: Base & Rail Mount A Dimensions TS08 B TS10 mm in mm in 2 3 4 5 6 7 8 9 10 11 12 15.80 23.80 31.80 39.80 47.80 55.80 63.80 71.80 79.80 87.80 95.80 0.622 0.937 1.252 1.567 1.882 2.232 2.512 2.827 3.142 3.457 3.772 17.50 27.50 37.50 47.50 57.50 67.50 77.50 87.50 97.50 107.50 117.50 0.689 1.083 1.476 1.870 2.264 2.657 3.051 3.445 3.839 4.232 4.626 Torque lb-in Clamping Area Wire Range AWG (Cu) TS0803 3.5 4.0mm2 TS0804 3.5 1.5mm2 TS1003 4.4 6.0mm2 TS1004 4.4 2.5mm 22-12 Sol./Str. 22-12 Sol./Str 22-10 Sol. 14-10 Str. 22-12 Sol./Str. 10 Sol. 2 D D F F WIRE PROTECTOR Dimensions mm (in) Screw B C D E F M2.6x5 16.30 (0.64) 16.30 (0.64) 20.20 (0.80) 20.20 (0.80) 13.30 (0.53) 13.30 (0.52) 15.80 (0.62) 15.80 (0.62) 8.00 (0.32) 8.00 (0.32) 10.00 (0.39) 10.00 (0.39) 2.90 (0.11) 2.90 (0.11) 3.60 (0.14) 3.60 (0.14) 2.8±0.1 (0.11) 2.8±0.1 (0.11) 3.2±0.1 (0.13) 3.2±0.1 (0.13) M2.6x5 M3.0x6 M3.0x6 Edge Connectors, One-Sided Boards Part Numbering System Spacing T S   08 10 - Base Positions   03 - flat 04 - flat w/ wire protector 02 to 12 Wire Management Products Position D A Power Distribution Blocks # of Poles Compliance References For additional product information, visit www.cooperbussmann.com/magnum 35 EuroMag Series Terminal Blocks: Single & Double Row Terminal Blocks - Raised Base Series TS - Raised Base Terminal Blocks; 8.00, 10.00mm Centers SPECIFICATIONS Rating: TS08 – 20A, 600V TS10 – 30A, 600V Wire Range: See Table Housing Material: Polyamide Type 6/6, 94V2 (white) Contact Material: nickel-plated Brass Wire Protector: Stainless Steel Screw Size: See Table Operating Temperature: 105°C (221°F) max., -30°C (-22°F) min. Torque Rating: See Table Construction: Mold to Length Agency Information: UL File E62622; CE Certified Note: TS Series standard base pictured above Dimensions E Terminal Blocks: Base & Rail Mount C Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks A Dimensions TS08 TS10 # of Poles mm in mm in 2 3 4 5 6 7 8 9 10 11 12 15.80 23.80 31.80 39.80 47.80 55.80 63.80 71.80 79.80 87.80 95.80 0.622 0.937 1.252 1.567 1.882 2.232 2.512 2.827 3.142 3.457 3.772 17.50 27.50 37.50 47.50 57.50 67.50 77.50 87.50 97.50 107.50 117.50 0.689 1.083 1.476 1.870 2.264 2.657 3.051 3.445 3.839 4.232 4.626 Position Torque lb-in Clamping Area TS0805 3.5 4.0mm2 TS0806 3.5 1.5mm2 TS1005 4.4 6.0mm2 TS1006 4.4 2.5mm2 Wire Range AWG (Cu) 22-12 Sol./Str. 22-12 Sol./Str 22-10 Sol. 14-10 Str. 22-12 Sol./Str. 10 Sol. B D A D D 4.3mm F F WIRE PROTECTOR Dimensions mm (in) Screw M2.6x5 M2.6x5 M3.0x6 M3.0x6 B C D E F 16.30 (0.64) 16.30 (0.64) 20.20 (0.80) 20.20 (0.80) 16.90 (0.67) 16.90 (0.67) 20.10 (0.79) 20.10 (0.79) 8.00 (0.32) 8.00 (0.32) 10.00 (0.39) 10.00 (0.39) 2.90 (0.11) 2.90 (0.11) 3.60 (0.14) 3.60 (0.14) 2.8±0.1 (0.11) 2.8±0.1 (0.11) 3.2±0.1 (0.13) 3.2±0.1 (0.13) Part Numbering System Spacing T S   Compliance References 08 10 36 - Base Positions   05 - stand offs 06 - stand offs w/ wire protector 02 to 12 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series Log onto our website at www.cooperbussmann.com/magnum to see all of MAGNUM’s product offerings. PCB Mount: • Spring Clamp Design p38-46 • Cage Clamp Design p47-57 • Two & Three Tier p58-62 • High Current (28A-115A) p63-73 Screwless p74-82 Pluggable p83-115 EuroMag Series Aside from the collection covered in the next section, MAGNUM also offers a variety of other standard European style PCB terminal blocks. Configurations include straight to board, plug and header, screwless, insulation displacement connectors (IDC), 2-tiered, 3-tiered, mold-tolength, modular (stackable) design, and terminal blocks with horizontal, vertical, 35 and 45 degree wire entry orientations. Available center spacings range from 2.54 mm to 15.00 mm. Terminal Blocks: Single & Double Row EUROMAG (EM) SERIES Terminal Blocks: Base & Rail Mount Power Distribution Blocks Wire Management Products Edge Connectors, One-Sided Boards Compliance References For additional product information, visit www.cooperbussmann.com/magnum 37 EM3123 Series Euro-Mag Terminal Blocks 3.50 Centers; Modular SPECIFICATIONS Rating: 6A, 300V Center Spacing: 0.138” (3.50mm) Wire Range: #16-26 AWG Housing Material: Black Polyamide Type 6/6, 94V0 Contact Material: Tin-Plated Brass Wire Protector: Stainless Steel Screw Size: M2.0 Chromate Steel Operating Temperature: 105°C (221°F) max., -33°C (-27°F) min. Torque Rating: 2.5 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Poles L (mm) Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 7.0 10.5 14.0 17.5 21.0 24.5 28.0 31.5 35.0 38.5 42.0 45.5 14 15 16 17 18 19 20 21 22 23 24 49.5 52.5 56.0 59.5 63.0 66.5 70.0 73.5 77.0 80.5 84.0 Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Terminal Blocks EM312305 Dimensions - mm (in) PCB Hole Layout To convert to inches, divide by 25.4 Part Numbering System Series # of Poles E M 3 1 2 3   Compliance References 02 to 24 38 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Terminal Blocks Terminal Blocks: Single & Double Row EM2665 Series Euro-Mag Terminal Blocks 5.00 Centers Position L (mm) 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 Power Distribution Blocks 02 03 04 05 06 07 08 09 10 11 12 13 L (mm) EM266512 Terminal Blocks: Base & Rail Mount Position EuroMag Series SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.197” (5.00mm) Consult factory for 0.394” (10.00mm) Wire Range: #14-22 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Screw Size: M3x5 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 7 lb-in. Recommended PCB Hole Diameters: 0.055” (1.40mm) Construction: Mold to Length Connector Style: Spring Clamp Agency Information: File E62622; CE Certified 0.15 (3.7) "L" To convert to inches, divide by 25.4 0.50 (12.8) 0.197 (5.00) Wire Management Products 0.16 (4.0) 0.13 (3.43) 0.33 (8.4) 0.31 (7.8) 0.16 (4.0) 0.028 (0.70) Edge Connectors, One-Sided Boards 0.047 (1.20) Also available in 10.00mm (EM2661XX). Part Numbering System Series # of Positions Compliance References E M 2 6 6 5   02 to 24 For additional product information, visit www.cooperbussmann.com/magnum 39 EuroMag Series PCB Mount Terminal Blocks MAGNUM EM3660 Series Euro-Mag Terminal Blocks 5.00 Centers; Modular Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 L+ _0.5 ø1+ _0.1 (ø0.039") 3.3+ _0.3 (0.130") PCB Hole Layout 2.5+ _0.3 (0.098") Part Numbering System Series # of Poles E M 3 6 6 0   Compliance References 02 to 24 40 5+ _0.1 (0.197") ø1.4 (ø0.055") 3.3+ _0.3 (0.130") Wire Management Products Edge Connectors, One-Sided Boards To convert to inches, divide by 25.4 7.5+ _0.3 (0.295") 4.2+ _0.3 (0.165") L (mm) Dimensions - mm (in) 7.5+ _0.3 (0.295") Poles EM366005 10+ _0.3 (0.394") SPECIFICATIONS Rating: 16A, 250V Center Spacing: 0.197” (5.00mm) Wire Range: #16-24 AWG Housing Material: Blue Polyamide Type 6/6, 94V0 Contact Material: Tin-Plated Brass Wire Protector: Stainless Steel Screw Size: M3 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -33°C (-27°F) min. Torque Rating: 4.0 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row ® For additional product information, visit www.cooperbussmann.com/magnum 5+ _0.1 (0.197") EuroMag Series PCB Mount Terminal Blocks Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 PCB Hole Layout Wire Management Products To convert to inches, divide by 25.4 Power Distribution Blocks L (mm) Dimensions - mm (in) Terminal Blocks: Base & Rail Mount Poles EM366512 EuroMag Series SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.197” (5.00mm) Wire Range: #16-22 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Screw Size: M2.5x5 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 2.5 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Connector Style: Spring Clamp Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM3665 Series Euro-Mag Terminal Blocks 5.00 Centers; Modular Series Edge Connectors, One-Sided Boards Part Numbering System # of Poles E M 3 6 6 5   02 to 24 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 41 EM3675 Series Euro-Mag Terminal Blocks 5.00 Centers SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.197” (5.00mm) Wire Range: #14-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Screw Size: M2x6, Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 4.0 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Mold to Length Connector Style: Spring Clamp Agency Information: File E62622; CE Certified Wire Management Products Edge Connectors, One-Sided Boards EM367512 Dimensions - mm (in) 0.32 (8.0) Poles 2 3 4 5 6 7 8 9 10 11 12 13 14 Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Terminal Blocks L (mm) 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 70.0 Poles 15 16 17 18 19 20 21 22 23 24 25 26 27 L L (mm) 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 125.0 130.0 135.0 0.39 (10.0) 0.039 (1.00) 0.15 (3.7) 0.10 (2.5) 0.19 (4.8) 0.197 (5.00) To convert to inches, divide by 25.4 Part Numbering System Series # of Poles E M 3 6 7 5   Compliance References 02 to 27 42 For additional product information, visit www.cooperbussmann.com/magnum 0.024 (0.60) EuroMag Series PCB Mount Terminal Blocks EM312705 Dimensions - mm (in) 15.0 22.5 33.0 37.5 45.0 52.5 60.0 67.5 75.0 82.5 90.0 97.5 14 15 16 17 18 19 20 21 22 23 24 105.0 112.5 120.0 127.5 133.0 142.5 150.0 157.5 165.0 172.5 180.0 4.2+ _0.3 (0.165") 7.5+ _0.1 (0.295") 3.8+ _0.3 (0.150") ø1.4 (ø0.055") 4.6+ _0.3 (0.181") PCB Hole Layout Wire Management Products To convert to inches, divide by 25.4 ø1+ _0.1 (ø0.039") 9.5+ _0.3 (0.374") 2 3 4 5 6 7 8 9 10 11 12 13 4.5+ _0.3 (0.177") L (mm) 13+ _0.3 (0.512") Poles L+ _0.5 Power Distribution Blocks L (mm) Terminal Blocks: Base & Rail Mount 9.5+ _0.3 (0.374") Poles EuroMag Series SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.295” (7.50mm) Wire Range: #14-22 AWG Housing Material: Black Polyamide Type 6/6, 94V0 Contact Material: Tin-Plated Brass Wire Protector: Stainless Steel Screw Size: M3.0 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -33°C (-27°F) min. Torque Rating: 3.5 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM3127 Series Euro-Mag Terminal Blocks 7.50 Centers; Modular 7.5+ _0.1 (0.295") Series Edge Connectors, One-Sided Boards Part Numbering System # of Poles E M 3 1 2 7   02 to 24 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 43 EM2661 Series Euro-Mag Terminal Blocks 10.00 Centers Edge Connectors, One-Sided Boards EM266106 Dimensions - mm (in) 8.0 (0.315") L Poles 2 3 4 5 6 7 L (mm) 15.0 25.0 35.0 45.0 55.0 65.0 Poles 8 9 10 11 12 13 3.8 (0.156") 10.0 (0.394") SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.394” (10.00mm) Wire Range: #14-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Wire Protector: Stainless Steel Screw Size: M2.6 Chromate Steel Operating Temperature: 105°C (221°F) max., -55°C (-40°F) min. Torque Rating: 4.0 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified L (mm) 75.0 85.0 95.0 105.0 115.0 125.0 0.6 (0.024") 0.9 (0.035") 4.8 (0.189") 2.5 (0.098") 10.0 (0.394") Ø 1.4 ( Ø 0.005"0 4.8 (0.189") PCB Hole Layout 8.0 (0.315") To convert to inches, divide by 25.4 Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Terminal Blocks Part Numbering System Series # of Poles E M 2 6 6 1   Compliance References 02 to 13 44 For additional product information, visit www.cooperbussmann.com/magnum 10.0 (0.394") EuroMag Series PCB Mount Terminal Blocks Poles L (mm) 8.0 (0.315") 9 10 11 12 13 14 50.0 55.0 60.0 65.0 70.0 75.0 10.0 (0.394") Ø 1.4 ( Ø 0.005"0 PCB Hole Layout 4.8 (0.189") To convert to inches, divide by 25.4 2.5 (0.098") Power Distribution Blocks 15.0 20.0 25.0 30.0 35.0 40.0 45.0 0.6 (0.024") 0.9 (0.035") 4.8 (0.189") 2 3 4 5 6 7 8 3.8 (0.156") 10.0 (0.394") L 8.0 (0.315") L (mm) Dimensions - mm (in) Terminal Blocks: Base & Rail Mount Poles EM366102 EuroMag Series SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.394” (10.00mm) Wire Range: #14-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Wire Protector: Stainless Steel Screw Size: M2.6 Chromate Steel Operating Temperature: 105°C (221°F) max., -55°C (-40°F) min. Torque Rating: 4.0 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM3661 Series Euro-Mag Terminal Blocks 10.00 Centers; Modular 10.0 (0.394") Wire Management Products Edge Connectors, One-Sided Boards Part Numbering System Series # of Poles E M 3 6 6 1   02 to 14 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 45 EM3671 Series Euro-Mag Terminal Blocks 10.00 Centers Poles L (mm) Poles L (mm) EM367106 Dimensions - mm (in) 8.0 (0.315") L 15.0 25.0 35.0 45.0 55.0 65.0 8 9 10 11 12 13 Edge Connectors, One-Sided Boards 75.0 85.0 95.0 105.0 115.0 125.0 3.8 (0.156") 2.5 (0.098") PCB Hole Layout Part Numbering System Series # of Poles E M 3 6 7 1   Compliance References 02 to 13 46 10.0 (0.394") Ø 1.4 ( Ø 0.005"0 4.8 (0.189") To convert to inches, divide by 25.4 Wire Management Products Power Distribution Blocks 4.8 (0.189") 2 3 4 5 6 7 0.6 (0.024") 0.9 (0.035") 8.0 (0.315") SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.394” (10.00mm) Wire Range: #14-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Wire Protector: Stainless Steel Screw Size: M2.6 Chromate Steel Operating Temperature: 105°C (221°F) max., -55°C (-40°F) min. Torque Rating: 4.0 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified 10.0 (0.394") Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Terminal Blocks For additional product information, visit www.cooperbussmann.com/magnum 10.0 (0.394") EuroMag Series PCB Mount Terminal Blocks EM392305 Dimensions - mm (in) L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 7.0 10.5 14.0 17.5 21.0 24.5 28.0 31.5 35.0 38.5 42.0 45.5 14 15 16 17 18 19 20 21 22 23 24 49.5 52.5 56.0 59.5 63.0 66.5 70.0 73.5 77.0 80.5 84.0 3.7+ _0.3 (0.146") 1.75+ _0.3 (0.069") 0.9+ _0.1 (0.035") 3.5+ _0.1 (0.137") ø1.3 (ø0.051") 3.7+ _0.3 (0.146") PCB Hole Layout 3.5+ _0.1 (0.137") Series Edge Connectors, One-Sided Boards Part Numbering System Wire Management Products To convert to inches, divide by 25.4 0.5+ _0.1 (0.020") 7.2+ _0.3 (0.283") Poles Power Distribution Blocks L (mm) L+ _0.5 3.5+ _0.3 (0.138") 8.5+ _0.3 (0.335") 7.2+ _0.3 (0.283") Terminal Blocks: Base & Rail Mount Poles EuroMag Series SPECIFICATIONS Rating: 8A, 300V Center Spacing: 0.138” (3.50mm) Wire Range: #16-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.0 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-67°F) min. Torque Rating: 2.5 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM3923 Series Euro-Mag Terminal Blocks 3.50 Centers; Modular # of Poles E M 3 9 2 3   02 to 24 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 47 EM3503 Series Euro-Mag Terminal Blocks 3.81 Centers; Modular SPECIFICATIONS Rating: 8A, 300V Center Spacing: 0.150” (3.81mm) Wire Size: #16-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Screw Size: M 2x3 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 4.5 lb-in. Recommended PCB Hole Diameters: 0.055” (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Poles L (mm) Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 7.62 11.43 15.24 19.05 22.86 26.67 30.48 34.29 38.10 41.91 45.72 49.53 14 15 16 17 18 19 20 21 22 23 24 53.34 57.15 60.96 64.77 68.58 72.39 76.20 80.01 83.82 87.63 91.44 Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Terminal Blocks To convert to inches, divide by 25.4 Dimensions - mm (in) L 0.29 (7.3) 0.150 (3.81) 0.33 (8.5) 0.14 (3.6) Wire Management Products Edge Connectors, One-Sided Boards Part Numbering System # of Positions E M 3 5 0 3   02 to 24 48 0.075 (1.90) 0.09 (2.3) 0.02 (.50) Series Compliance References EM350305 For additional product information, visit www.cooperbussmann.com/magnum 0.031 (0.79) EuroMag Series PCB Mount Terminal Blocks EM258505V Dimensions - mm (in) EuroMag Series HORIZONTAL 0.035 (0.90) 0.19 (4.9) 0.40 (10.2) 0.197 (5.00) 0.10 (2.50) L 0.12 (3.1) 0.10 (2.5) Position Position L (mm) 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 0.10 (2.6) 0.57 (14.5) 0.33 (8.5) 0.07 (1.8) Power Distribution Blocks 02 03 04 05 06 07 08 09 10 11 12 13 L (mm) Terminal Blocks: Base & Rail Mount SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.197” (5.00mm) Consult factory for 0.394” (10.00mm) Wire Range: #12-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Screw Size: M3x5 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 7 lb-in. Recommended PCB Hole Diameters: 0.055” (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Connector Style: Rising Cage Clamp Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM2585 Series Euro-Mag Terminal Blocks 5.00 Centers; Modular 0.03 (0.8) VERTICAL 0.197 (5.00) 0.40 (10.2) Wire Management Products To convert to inches, divide by 25.4 0.10 (2.5) L 0.12 (3.1) 0.10 (2.5) 0.10 (2.5) 0.57 (14.5) Edge Connectors, One-Sided Boards 0.34 (8.5) 0.18 (4.7) Part Numbering System Series # of Positions 02 to 24 0.031 (0.79) Orientation  Compliance References E M 2 5 8 5   0.035 (0.90) H - horizontal V - vertical For additional product information, visit www.cooperbussmann.com/magnum 49 EM3225 Series Euro-Mag Terminal Blocks 35° Angle; 5.00 Centers; Modular Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 L+ _0.5 0.9+ _0.1 (0.035") 0.8+ _0.1 (0.031") 2.5+ _0.3 (0.098") 7+ _0.3 (0.276") PCB Hole Layout To convert to inches, divide by 25.4 Part Numbering System Series # of Poles E M 3 2 2 5   Compliance References 02 to 24 50 5+ _0.1 (0.197") 5+ _0.1 (0.197") 7+ _0.3 (0.276") Wire Management Products Edge Connectors, One-Sided Boards 13.3+ _0.3 (0.524") 13.3+ _0.3 (0.524") L (mm) Dimensions - mm (in) 3.5+ _0.3 (0.138") Poles EM322505 15.3+ _0.3 (0.602") SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.197” (5.00mm) Consult factory for 0.393" (10.00mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.6 nickel-plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Terminal Blocks For additional product information, visit www.cooperbussmann.com/magnum ø1.4~1.5 (ø0.055"~0.059") EuroMag Series PCB Mount Terminal Blocks L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 PCB Hole Layout Wire Management Products Poles Dimensions - mm (in) Power Distribution Blocks L (mm) EM220505 Terminal Blocks: Base & Rail Mount Poles EuroMag Series SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.197” (5.00mm) Consult factory for 0.393" (10.00mm) Wire Range: #12-24 AWG Housing Material: Grey Polyamide Type 6/6, 94V0 Contact Material: Brass Tin-Plated Cage Clamp: Brass, Tin-Plated Screw Size: M2.6 Chromate Steel Operating Temperature: 105°C (221°F) max., -33°C (-27°F) min. Torque Rating: 3.5 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM2205 Series Euro-Mag Terminal Blocks 45° Angle, 5.00 Centers, Modular To convert to inches, divide by 25.4 Series Edge Connectors, One-Sided Boards Part Numbering System # of Poles E M 22 0 5    02 to 24 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 51 Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Terminal Blocks EM2505 Series Euro-Mag Terminal Blocks 5.08 Centers; Modular SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.20” (5.08mm) Consult factory for 0.40” (10.16mm) Wire Range: #12-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Screw Size: M3x5 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 7 lb-in. Recommended PCB Hole Diameters: 0.055” (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Connector Style: Rising Cage Clamp Agency Information: File E62622; CE Certified Position L (mm) Position EM250505V Dimensions - mm (in) 0.24 (6.1) 0.44 (11.2) 0.13 (3.3) L (mm) 0.10 (2.54) 0.20 (5.08) L 14 15 16 17 18 19 20 21 22 23 24 71.12 76.20 81.28 86.36 91.44 96.52 101.60 106.68 111.76 116.84 121.92 0.59 (15.0) 0.35 (9.0) 0.031 (0.8) 0.17 (4.2) 0.035 (0.9) Part Numbering System Series Compliance References 10.16 15.24 20.32 25.40 30.48 35.56 40.64 45.72 50.80 55.88 60.96 66.04 To convert to inches, divide by 25.4 Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks 02 03 04 05 06 07 08 09 10 11 12 13 # of Positions E M 2 5 0 5   02 to 24 52 Orientation  V - vertical For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Terminal Blocks EM322805 Dimensions - mm (in) 13.3±0.3 (0.524") 2 3 4 5 6 7 8 9 10 11 12 13 10.16 15.24 20.32 25.40 30.48 35.56 40.64 45.72 50.80 55.88 60.96 66.04 14 15 16 17 18 19 20 21 22 23 24 72.12 76.20 81.28 86.36 91.44 96.52 101.60 106.68 111.76 116.84 121.92 0.8±0.1 (0.031") 7±0.3 (0.276") 0.9±0.1 (0.035") 2.54±0.3 (0.100") 5.08±0.1 (0.200") ø1.4~1.5 (ø0.055"~0.059") 9.9±0.3 (0.390") L (mm) PCB Hole Layout To convert to inches, divide by 25.4 5.08±0.1 (0.200") Wire Management Products 5.+ _0.3 (0.213") Poles Power Distribution Blocks L (mm) L±0.5 3.5±0.3 (0.138") 15.3±0.3 (0.602") L±0.5 Terminal Blocks: Base & Rail Mount Poles EuroMag Series SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.20” (5.08mm) Consult factory for 0.40" (10.16mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.6 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM3228 Series Euro-Mag Terminal Blocks 35° Angle; 5.08 Centers; Modular Series Edge Connectors, One-Sided Boards Part Numbering System # of Poles E M 3 2 2 8   02 to 24 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 53 EM2507 Series Euro-Mag Terminal Blocks 7.50 Centers; Modular Dimensions - mm (in) 10.+ _0.3 (0.402") L+ _0.5 15.0 22.5 33.0 37.5 45.0 52.5 60.0 67.5 75.0 82.5 90.0 97.5 Poles 14 15 16 17 18 19 20 21 22 23 24 To convert to inches, divide by 25.4 L (mm) 105.0 112.5 120.0 127.5 133.0 142.5 150.0 157.5 165.0 172.5 180.0 0.8+ _0.1 (0.031") 1+ _0.1 (0.039") 5.4+ _0.3 (0.213") 7.5+ _0.1 (0.295") 2.5+ _0.3 (0.098") 7.5+ _0.1 (0.295") 10.2+ _0.3 (0.402") 2 3 4 5 6 7 8 9 10 11 12 13 L (mm) PCB Hole Layout 5.4+ _0.3 (0.213") Wire Management Products Power Distribution Blocks Poles Edge Connectors, One-Sided Boards EM250705 3.5+ _0.3 (0.138") SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.295” (7.50mm) Wire Range: #14-22 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.6 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5.0 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified 14+ _0.3 (0.551") Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Terminal Blocks Part Numbering System Series # of Poles E M2 5 0 7    Compliance References 02 to 24 54 For additional product information, visit www.cooperbussmann.com/magnum ø1.4~1.5 (ø0.055"~0.059") EuroMag Series PCB Mount Terminal Blocks EM322705 EuroMag Series Dimensions - mm (in) 10.+ _0.3 (0.402") 3.5+ _0.3 (0.138") L+ _0.5 14+ _0.3 (0.551") 15.0 22.5 33.0 37.5 45.0 52.5 60.0 67.5 75.0 82.5 90.0 97.5 Poles 14 15 16 17 18 19 20 21 22 23 24 0.8+ _0.1 (0.031") 5.4+ _0.3 (0.213") 7.5+ _0.1 (0.295") 2.5+ _0.3 (0.098") 7.5+ _0.1 (0.295") PCB Hole Layout 5.4+ _0.3 (0.213") 105.0 112.5 120.0 127.5 133.0 142.5 150.0 157.5 165.0 172.5 180.0 1+ _0.1 (0.039") Wire Management Products To convert to inches, divide by 25.4 L (mm) Power Distribution Blocks 2 3 4 5 6 7 8 9 10 11 12 13 L (mm) 10.2+ _0.3 (0.402") Poles Terminal Blocks: Base & Rail Mount SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.295” (7.50mm) Consult factory for 0.40" (10.16mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.6 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5.0 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM3227 Series Euro-Mag Terminal Blocks 35° Angle, 7.50 Centers; Modular ø1.4~1.5 (ø0.055"~0.059") Series Edge Connectors, One-Sided Boards Part Numbering System # of Poles E M 3 2 2 7   02 to 24 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 55 EM2506 Series Euro-Mag Terminal Blocks 7.62 Centers; Modular SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.30” (7.62mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.6 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5.0 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Poles L (mm) Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 15.24 22.86 30.48 38.10 45.72 53.34 60.96 68.58 76.20 83.82 91.44 99.07 14 15 16 17 18 19 20 21 22 23 24 106.69 114.31 121.93 129.55 137.17 144.79 152.41 160.03 167.65 175.27 182.89 Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Terminal Blocks EM250605 Dimensions - mm (in) Ø Ø PCB Hole Layout To convert to inches, divide by 25.4 Part Numbering System Series # of Poles E M 2 5 0 6   Compliance References 02 to 24 56 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Terminal Blocks 15.24 22.86 30.48 38.10 45.72 53.34 60.96 68.58 76.20 83.82 91.44 99.07 14 15 16 17 18 19 20 21 22 23 24 106.69 114.31 121.93 129.55 137.17 144.79 152.41 160.03 167.65 175.27 182.89 0.8+ _0.1 (0.031") 3.81+ _0.3 (0.150") 7+ _0.3 (0.276") 7.62+ _0.1 (0.300") 0.9+ _0.1 (0.035") 7.62+ _0.1 (0.300") 13.3+ _0.3 (0.524") 2* 3* 4 5 6 7 8 9 10 11 12 13 3.5+ _0.3 (0.138") L (mm) L+ _0.5 15.3+ _0.3 (0.602") Poles 13.3+ _0.3 (0.524") Power Distribution Blocks L (mm) Dimensions - mm (in) Terminal Blocks: Base & Rail Mount Poles EM322605 EuroMag Series SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.30” (7.62mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.6 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5.0 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM3226 Series Euro-Mag Terminal Blocks 35° Angle, 7.62 Centers; Modular PCB Hole Layout 7+ _0.3 (0.276") Wire Management Products * Mold To Length To convert to inches, divide by 25.4 ø1.4~1.5 (ø0.055"~0.059") Series Edge Connectors, One-Sided Boards Part Numbering System # of Poles E M 3 2 2 6   02 to 24 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 57 EM2403 Series Euro-Mag Terminal Blocks Two Tier; 3.81 Centers; Modular 2 3 4 5 6 7 9.53 13.34 17.15 20.96 24.77 28.58 8 9 10 11 12 32.39 36.20 40.00 43.80 47.60 To convert to inches, divide by 25.4 L+ _0.5 L+ _0.5 1.9+ _0.3 (0.075") 1.9+ _0.3 (0.075") 0.9+ _0.1 (0.035") 0.5+ _0.1 (0.197") 3.55+ _0.3 (0.140") 11.6+ _0.2 (0.457") 3.81+ _0.1 (0.150") PCB Hole Layout 11.6+ _0.3 (0.457") 1.91+ _0.3 (0.075") 3.81+ _0.2 (0.150") Edge Connectors, One-Sided Boards 16.2+ _0.3 (0.638") 16.2+ _0.3 (0.638") L (mm) 1.9+ _0.3 (0.075") Part Numbering System Series # of Poles E M 2 4 0 3   Compliance References 02 - 12 58 For additional product information, visit www.cooperbussmann.com/magnum 3.81+ _0.1 (0.150") ø1.3 (ø0.051") 16.2+ _0.3 (0.638") Poles Dimensions - mm (in) 3.55+ _0.3 (0.140") L (mm) EM240304 3.5+ _0.3 (0.138") Poles EM240308 8.5+ _0.3 (0.335") SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.150” (3.81mm) Wire Range: #16-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.0 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 2.5 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Terminal Blocks 3.81+ _0.1 (0.150") EuroMag Series PCB Mount Terminal Blocks 34.29 38.10 41.90 45.70 49.50 To convert to inches, divide by 25.4 1.91+ _0.3 (0.075") 23.9+ _0.5 (0.941") 8 9 10 11 12 3.55+ _0.3 0.90+ _0.1 (0.140") (0.035") 3.81+ _0.1 (0.150") 11.6+ _0.3 (0.457") 7.62+ _0.3 (0.300") 3.81+ _0.1 (0.150") 11.6+ _0.3 7.62+ _0.3 (0.457") (0.300") 25+ _0.3 (0.985") 3.81+ _0.3 (0.150") PCB Hole Layout 3.81+ _0.1 (0.150") 3.81+ _0.1 (0.150") Edge Connectors, One-Sided Boards 5.72+ _0.3 (0.225") Part Numbering System Series Wire Management Products 1.91+ _0.3 (0.075") 3.55+ _0.3 (0.140") 11.43 15.24 19.05 22.86 26.67 30.48 1.91+ _0.3 (0.075") 1.91+ _0.3 (0.075") 8.5+ _0.5 (0.335") 2 3 4 5 6 7 L+ _0.5 16.2+ _0.5 (0.638") L (mm) 3.5+ _0.3 (0.138") Poles Dimensions - mm (in) Power Distribution Blocks L (mm) EM280302 Terminal Blocks: Base & Rail Mount Poles EuroMag Series SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.150” (3.81mm) Wire Range: #16-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.0 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 2.5 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM2803 Series Euro-Mag Terminal Blocks Three Tier; 3.81 Centers; Modular # of Poles Compliance References E M 2 8 0 3   02 - 12 For additional product information, visit www.cooperbussmann.com/magnum 59 EM2445 Series Euro-Mag Terminal Blocks Two Tier; 5.00 Centers; Modular SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.197” (5.00mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin Plated Brass Screw Size: M2x6 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5.0 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Connector Style: Rising Cage Clamp Agency Information: File E62622; CE Certified Poles 2 3 4 5 6 7 8 9 10 11 12 Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Terminal Blocks L (mm) 12.5 17.5 22.5 27.5 32.5 37.5 42.5 47.5 52.5 57.5 62.5 Poles 13 14 15 16 17 18 19 20 21 22 23 24 EM244508 EM244504 Dimensions - mm (in) L (mm) 67.5 72.5 77.5 82.5 87.5 92.5 97.5 102.5 107.5 112.5 117.5 122.5 0.84 (21.40) L 0.10 (2.5) 0.15 (3.7) 0.54 (13.8) 0.031 (0.79) 0.10 (2.5) 0.598 (15.20) 0.18 (4.6) 0.10 (2.5) Part Numbering System # of Poles E M 2 4 4 5   Compliance References 02 to 24 60 0.10 (2.5) 0.99 (25.1) To convert to inches, divide by 25.4 Series L For additional product information, visit www.cooperbussmann.com/magnum 0.031 (0.79) 0.197 (5.00) EuroMag Series PCB Mount Terminal Blocks EM244808 EM244804 10.16 15.24 20.32 25.40 30.48 35.56 40.64 45.72 50.80 55.88 60.96 66.04 14 15 16 17 18 19 20 21 22 23 24 71.12 76.20 81.28 86.36 91.44 96.52 101.60 106.68 111.76 116.84 121.92 0.8+ _0.1 (0.031") 15.5+ _0.2 (0.610") 13.8+ _0.3 (0.543") 3.7+ _0.3 (0.146") 2 3 4 5 6 7 8 9 10 11 12 13 2.54+ _0.3 (0.100") 25.1+ _0.3 (0.988") L (mm) 0.8+ _0.1 (0.031") 5.08+ _0.1 (0.200") 0.8+ _0.1 (0.031") 2.54+ _0.2 (0.100") 2.54+ _0.3 (0.100") 4.6+ _0.3 (0.181") ø1.4~1.5 (ø0.055"~0.059") 5.08+ _0.1 (0.200") PCB Hole Layout 15.5+ _0.2 (0.610") 21.4+ _0.3 (0.843") To convert to inches, divide by 25.4 2.54+ _0.2 (0.100") Wire Management Products Poles L+ _0.5 Power Distribution Blocks L (mm) L+ _0.5 Terminal Blocks: Base & Rail Mount Dimensions - mm (in) 21.4+ _0.3 (0.843") Poles EuroMag Series SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.20” (5.08mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.6 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 4.5 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM2448 Series Euro-Mag Terminal Blocks Two Tier; 5.08 Centers; Modular 4.6+ _0.3 (0.181") 5.08+ _0.1 (0.200") Edge Connectors, One-Sided Boards Part Numbering System Series # of Poles E M 2 4 4 8   02 to 24 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 61 EM2855 Series Euro-Mag Terminal Blocks Three Tier; 5.00 Centers EM285510 Dimensions - mm (in) L±0.5 2 3 4 5 6 12.5 17.5 22.5 27.5 32.5 To convert to inches, divide by 25.4 4.1±0.3 (0.161") 5.08±0.1 (0.200") 10.1±0.3 (0.397") PCB Hole Layout 2.54±0.2 (0.100") Part Numbering System Series # of Poles E M 2 8 5 5   Compliance References 02 to 06 Note: Longer positions, please consult factory. 62 0.5±0.1 (0.019") 10.1±0.2 (0.397") 4.1±0.3 (0.161") 10.16±0.3 (0.400") Wire Management Products Edge Connectors, One-Sided Boards 19.1±0.3 (0.751") 0.9±0.1 (0.035") 2.54±0.3 (0.100") 28.1±0.3 (1.107") 28.2±0.5 (1.111") L (mm) 10±0.3 (0.393") Poles 2.54±0.3 (0.100") 3.5±0.3 (0.137") Power Distribution Blocks 2.54±0.3 (0.100") For additional product information, visit www.cooperbussmann.com/magnum 10.16±0.2 (0.400") 2.54±0.3 (0.100") 3 ) 1. 1" Ø .05 0 (Ø 28.1±0.3 (1.107") SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.197" (5.00mm) Wire Range: #14-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass Nickel-Plated Screw Size: M26 Steel Chromatized Operating Temperature: 105°C max., -55°C min. Torque Rating: 4.5 lb-in Recommended PCB Hole Diameters: 1.30mm (0.051") Construction: Mold-to-Length Agency Information: File E62622; CE Certified Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Terminal Blocks 5.08±}0.1 (0.200") EuroMag Series PCB Mount Terminal Blocks EM290508 EuroMag Series Dimensions - mm (in) 11.2+ _0.3 (0.441") 3.5+ _0.3 (0.138") 18+ _0.3 (0.709") L+ _0.5 2 3 4 5 6 7 8 9 10 11 12 13 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 1+ _0.1 (0.039") 0.8+ _0.1 (0.031") 5+ _0.1 (0.197") 5.6+ _0.3 (0.220") To convert to inches, divide by 25.4 ø1.5 (ø0.059") 11.2+ _0.3 (0.441") L (mm) 5.6+ _0.3 (0.220") Poles PCB Hole Layout 2.5+ _0.3 (0.098") Wire Management Products L (mm) Power Distribution Blocks Poles Terminal Blocks: Base & Rail Mount SPECIFICATIONS Rating: 28A, 250V Center Spacing: 0.197” (5.00mm) Wire Range: #12-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.6 nickel-plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 4.5 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM2905 Series Euro-Mag Terminal Blocks High Current; 5.00 Centers; Modular 5+ _0.1 (0.197") Series Edge Connectors, One-Sided Boards Part Numbering System # of Poles E M 2 9 0 5   02 to 24 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 63 EM2908 Series Euro-Mag Terminal Blocks High Current; 5.08 Centers; Modular Dimensions - mm (in) L+ _0.5 18+ _0.3 (0.709") L+ _0.5 11.2+ _0.3 (0.441") L (mm) Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 10.16 15.24 20.32 25.40 30.48 35.56 40.64 45.72 50.80 55.88 60.96 66.04 14 15 16 17 18 19 20 21 22 23 24 71.12 76.20 81.28 86.36 91.44 96.52 101.60 106.68 111.76 116.84 121.92 0.8+ _0.1 (0.031") _0.1 5.08+ _0.1 1.0+ (0.200") (0.039") 5.6+ _0.3 (0.220") Poles 5.6+ _0.3 (0.220") 5.08+ _0.1 (0.200") 11.2±0.3 (0.441") Wire Management Products Edge Connectors, One-Sided Boards EM290808 3.5+ _0.3 (0.138") SPECIFICATIONS Rating: 28A, 250V Center Spacing: 0.20” (5.08mm) Wire Range: #12-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.6 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 4.5 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Terminal Blocks PCB Hole Layout To convert to inches, divide by 25.4 2.54+ _0.3 (0.100") Part Numbering System Series # of Poles E M 2 9 0 8   Compliance References 02 to 24 64 For additional product information, visit www.cooperbussmann.com/magnum ø1.5 (0.059") EuroMag Series PCB Mount Terminal Blocks Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 12.70 19.05 25.40 31.75 38.10 44.45 50.80 57.15 63.50 69.85 76.20 82.55 14 15 16 17 18 19 20 21 22 23 24 88.90 95.25 101.60 107.95 114.30 120.65 127.00 133.35 139.70 146.05 152.40 Dimensions - mm (in) Power Distribution Blocks L (mm) EM912605 Terminal Blocks: Base & Rail Mount Poles EuroMag Series SPECIFICATIONS Rating: 30A, 300V Center Spacing: 0.250” (6.35mm) Wire Range: #10-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M3.0 Steel Nickel-Plated Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5.5 lb-in. Recommended PCB Hole Diameters: 0.071" (1.80mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM9126 Series Euro-Mag Terminal Blocks 6.35 Centers; Modular Ø Ø PCB Hole Layout Wire Management Products To convert to inches, divide by 25.4 Edge Connectors, One-Sided Boards Part Numbering System Series # of Poles E M 9 1 2 6   02 to 24 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 65 EM9127 Series Euro-Mag Terminal Blocks 7.50 Centers; Modular SPECIFICATIONS Rating: 30A, 300V Center Spacing: 0.29” (7.50mm) Wire Range: #10-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M3.5 Steel Nickel-Plated Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5.5 lb-in. Recommended PCB Hole Diameters: 0.071" (1.80mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Poles L (mm) Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 15.0 22.5 30.0 37.5 45.0 52.5 60.0 67.5 75.0 82.5 90.0 97.5 14 15 16 17 18 19 20 21 22 23 24 105.0 112.5 120.0 127.5 135.0 142.5 150.0 157.5 165.0 172.5 180.0 Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Terminal Blocks To convert to inches, divide by 25.4 EM912705 Dimensions - mm (in) Ø Ø PCB Hole Layout Part Numbering System Series # of Poles E M 9 1 2 7   Compliance References 02 to 24 66 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Terminal Blocks 14 15 16 17 18 19 20 21 22 23 24 106.68 114.30 121.92 129.54 137.16 144.78 152.40 160.02 167.64 175.26 182.88 3.8+ _0.2 (0.150") 1+ _0.1 (0.039") 7.9+ _0.2 (0.311") 1+ _0.1 (0.039") PCB Hole Layout ø1.8 (ø0.071") Wire Management Products To convert to inches, divide by 25.4 7.62+ _0.1 (0.300") 12.5+ _0.3 (0.492") 15.24 22.86 30.48 38.10 45.72 53.34 60.96 68.58 76.20 83.82 91.44 99.06 7.9+ _0.1 (0.311") 2 3 4 5 6 7 8 9 10 11 12 13 L+ _0.5 5+ _0.3 (0.197") L (mm) 21.7+ _0.3 (0.854") Poles 12.5+ _0.3 (0.492") 7.62+ _0.1 (0.300") Edge Connectors, One-Sided Boards Part Numbering System Series Power Distribution Blocks L (mm) Dimensions - mm (in) Terminal Blocks: Base & Rail Mount Poles EM912805 EuroMag Series SPECIFICATIONS Rating: 30A, 300V Center Spacing: 0.30˝ (7.62mm) Wire Range: #10-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M3.0 Steel Nickel-Plated Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5.5 lb-in. Recommended PCB Hole Diameters: 0.071" (1.80mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM9128 Series Euro-Mag Terminal Blocks 7.62 Centers; Modular # of Poles E M 9 1 2 7   02 to 24 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 67 EM2909 Series Euro-Mag Terminal Blocks 35° Angle; 9.52 Centers; Modular SPECIFICATIONS Rating: 30A, 600V Center Spacing: 0.375” (9.52mm) Wire Range: #10-20 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Steel, Nickel-Plated Screw Size: M3.0 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5.5 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Poles L (mm) Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 19.04 28.56 38.08 47.60 57.12 66.64 76.16 85.68 95.20 104.72 114.24 123.76 14 15 16 17 18 19 20 21 22 23 24 133.28 142.80 152.32 161.84 171.36 180.88 190.40 199.92 209.44 218.96 228.48 Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Terminal Blocks EM290905 Dimensions - mm (in) Ø Ø PCB Hole Layout To convert to inches, divide by 25.4 Part Numbering System Series # of Poles E M 2 9 09    Compliance References 02 to 24 68 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Terminal Blocks L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 19.04 28.56 38.08 47.60 57.12 66.64 76.16 85.68 95.20 104.72 114.24 123.76 14 15 16 17 18 19 20 21 22 23 24 133.28 142.80 152.32 161.84 171.36 180.88 190.40 199.92 209.44 218.96 228.48 ø ø PCB Hole Layout Wire Management Products Poles Dimensions - mm (in) Power Distribution Blocks L (mm) EM291905 Terminal Blocks: Base & Rail Mount Poles EuroMag Series SPECIFICATIONS Rating: 30A, 600V Center Spacing: 0.375” (9.52mm) Wire Range: #10-20 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Steel, Nickel-Plated Screw Size: M3.0 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5.5 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM2919 Series Euro-Mag Terminal Blocks 9.52 Centers; Modular To convert to inches, divide by 25.4 Series Edge Connectors, One-Sided Boards Part Numbering System # of Poles E M 2 9 1 9   02 to 24 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 69 EM2929 Series Euro-Mag Terminal Blocks Hi-Current; 10.16 Centers SPECIFICATIONS Rating: 65A, 600V Center Spacing: 0.40” (10.16mm) Wire Range: #6-20 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Copper Cage Clamp: Steel, Chromate Plated Screw Size: M4 Stainless Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 15 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Mold to length Agency Information: File E62622; CE Certified EM292908 Dimensions - mm (in) Poles L (mm) 2 3 4 5 6 7 8 20.34 30.50 40.66 50.82 60.98 71.14 81.30 Test Points 20.0 L To convert to inches, divide by 25.4 Edge Connectors, One-Sided Boards 0.50 1.3 10.16 0.8 10.16 4.5 Wire Management Products 29.5 Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Terminal Blocks 2.5 Part Numbering System Series # of Poles E M 2 9 2 9   Compliance References 02 to 08 70 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Terminal Blocks Terminal Blocks: Single & Double Row EM2939 Series Euro-Mag Terminal Blocks Hi-Current, 15.00 Centers EuroMag Series SPECIFICATIONS Rating: 115A, 600V with No Bottom Cover (NC) Option. Center Spacing: 0.591” (15.00mm) Wire Range: #2-20 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Copper Cage Clamp: Steel, Chromate-Plated Screw Size: M5 Stainless Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 15 lb-in. Recommended PCB Hole Diameters: 0.063" (1.60mm) Construction: Mold to length Agency Information: File E62622; CE Certified EM293908 Terminal Blocks: Base & Rail Mount Dimensions - mm (in) L (mm) 2 3 4 5 6 7 8 30.0 45.0 60.0 75.0 90.0 105.0 120.0 Test Points To convert to inches, divide by 25.4 L Power Distribution Blocks Poles 15.0 3.8 1.2 12.5 4.5 0.5 1.3 Wire Management Products 39.0 31.0 3.0 Series # of Poles E M 2 9 3 9   02 to 08 Edge Connectors, One-Sided Boards Part Numbering System Bottom Cover Option (  ) N C *NC = No Bottom Cover Compliance References For additional product information, visit www.cooperbussmann.com/magnum 71 EM3905 Series Euro-Mag Terminal Blocks High Current; Two Tier; 5.00 Centers; Modular SPECIFICATIONS Rating: 28A, 250V Center Spacing: 0.197” (5.00mm) Wire Range: #12-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Cage Clamp: Brass, Nickel-Plated Screw Size: M2.6 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 4.5 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 12.5 17.5 22.5 27.5 32.5 37.5 42.5 47.5 52.5 57.5 62.5 67.5 14 15 16 17 18 19 20 21 22 23 24 72.5 77.5 82.5 87.5 92.5 97.5 102.5 107.5 112.4 117.5 122.5 Wire Management Products To convert to inches, divide by 25.4 22.3+ _0.3 (0.878") 2.5+ _0.3 (0.098") 31.4+ _0.1 (1.237") 18+ _0.3 (0.709") Power Distribution Blocks L+ _0.5 1+ _0.1 (0.039") 2.5+ _0.3 (0.098") 0.8+ _0.1 (0.032") 2.5+ _0.3 (0.098") 5+ _0.1 (0.197") 5.6+ _0.3 (0.221") 15+ _0.3 (0.591") 2.5+ _0.2 (0.098") 5+ _0.1 (0.197") Edge Connectors, One-Sided Boards PCB Hole Layout ø1.5 (ø0.059") 5+ _0.1 (0.197") Part Numbering System Series Compliance References 3.6+ _0.3 (0.142") Poles Dimensions - mm (in) # of Poles E M 3 9 0 5   02 to 24 72 For additional product information, visit www.cooperbussmann.com/magnum 22.3+ _0.3 (0.878") L (mm) EM390504 5.6+ _0.3 (0.221") Poles EM390508 15+ _0.3 (0.591") Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Terminal Blocks 2.5+ _0.3 (0.098") EuroMag Series PCB Mount Terminal Blocks 71.12 76.20 81.28 86.36 91.44 96.52 101.60 106.68 111.76 116.84 121.92 To convert to inches, divide by 25.4 1±0.1 (0.039") 2.54±0.3 (0.100") 0.8±0.1 (0.032") 2.54±0.3 (0.100") 5.08±0.1 (0.200") 3.6±0.3 (0.142") 14 15 16 17 18 19 20 21 22 23 24 5.6±0.3 (0.221") 15±0.3 (0.591") 2.54±0.2 (0.100") PCB Hole Layout 15±0.3 (0.591") 5.08±0.1 (0.200") Ø1.5 (Ø0.059") Edge Connectors, One-Sided Boards 5.08±0.1 (0.200") 22.3±0.3 (0.878") 10.16 15.24 20.32 25.40 30.48 35.56 40.64 45.72 50.80 55.88 60.96 66.04 22.3±0.3 (0.878") 2.54±0.3 (0.100") 5.6±0.3 (0.221") 2 3 4 5 6 7 8 9 10 11 12 13 A±0.5 31.4±0.1 (1.237") 18±0.3 (0.709") L (mm) Wire Management Products Poles Dimensions - mm (in) Power Distribution Blocks L (mm) EM390804 Terminal Blocks: Base & Rail Mount Poles EM390808 EuroMag Series SPECIFICATIONS Rating: 28A, 250V Center Spacing: 0.20” (5.08mm) Wire Range: #12-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.6 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 4.5 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM3908 Series Euro-Mag Terminal Blocks High Current; Two-Tier; 5.08 Centers; Modular 2.54±0.3 (0.100") Part Numbering System Series # of Poles Compliance References E M 3 9 0 8   02 to 24 For additional product information, visit www.cooperbussmann.com/magnum 73 EM2742 Series Euro-Mag Terminal Blocks Screwless; 2.54 Centers 2.6 (0.102") L (mm) 2 3 4 5 6 7 8 9 8.08 10.62 13.16 15.70 18.24 33.48 30.94 28.40 10 11 12 13 14 15 16 30.94 33.48 36.02 38.56 41.10 43.64 46.18 0.8 (0.032") Ø1.5 (Ø0.059") 2.54 (0.100") 0.5 (0.020") 5.08 (0.200") 2.54 (0.100") 5.5 (0.217") Poles 10 (0.394") L (mm) 3.5 (0.138") Poles L 5.08 (0.200") Power Distribution Blocks 14 (0.551") SPECIFICATIONS Rating: 6A, 63V EM274210H Center Spacing: 0.10” (25.4mm) Wire Range: #20-26 AWG EM274206V Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Spring Material: Stainless Steel Dimensions - mm (in) Operating Temperature: 105°C (221°F) max., -40°C VERTICAL (-40°F) min. Recommended PCB Hole Diameters: 0.051" (1.30mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Screwless Terminal Blocks To convert to inches, divide by 25.4 PCB Hole Layout Ø1.2 (Ø0.04") Wire Management Products Ø1.5 (Ø0.06") 10 (0.394") 2.6 (0.102") # of Poles Compliance References E M 2 7 4 2   02 to 16 Orientation  H - horizontal V - vertical 5.8 (0.200") 0.8 (0.03") 2.54 (0.100") 2.54 (0.100") PCB Hole Layout 5.08 (0.200") Series 0.5 (0.020") 4.7 (0.85") Part Numbering System L 14 (0.55") 3.5 (0.138") Edge Connectors, One-Sided Boards 2.54 (0.100") HORIZONTAL Ø1.2 (Ø0.047") 74 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Screwless Terminal Blocks 2 4 6 8 10 12 14 16 18 20 22 24 8.5 15.5 22.5 29.5 36.5 43.5 50.5 57.5 64.5 71.5 78.5 92.5 Power Distribution Blocks L (mm) Dimensions - mm (in) Terminal Blocks: Base & Rail Mount Poles EM278305 EuroMag Series SPECIFICATIONS Rating: 2A, 300V Center Spacing: 0.136” (3.50mm) Wire Range: #16-20 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin Plated Phos Bronze Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.051" (1.30mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM2783 Series Euro-Mag Terminal Blocks 45° Entry; Screwless; 3.50 Centers Wire Management Products To convert to inches, divide by 25.4 PCB Hole Layout Ø1.3 (Ø0.051) Series Edge Connectors, One-Sided Boards Part Numbering System # of Poles E M 2 7 8 3   02 to 24 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 75 EM2802 Series Euro-Mag Terminal Blocks 30° Entry; Screwless; 2.54 Centers SPECIFICATIONS Rating: 4A, 125V Center Spacing: 0.10” (2.54mm) Wire Range: #20-24 AWG Housing Material: Gray Polyamide Type 6/6, 94V0 Contact Material: Tin-Plated Brass Spring Material: Stainless Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.051" (1.30mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified 2 3 4 5 6 7 8 9 10 11 12 7.08 9.62 12.16 14.70 17.24 19.78 22.32 24.86 27.40 29.94 32.48 To convert to inches, divide by 25.4 Edge Connectors, One-Sided Boards Dimensions - mm (in) L+ _0.5 12.1+ _0.3 (0.477") 11.6+ _0.3 (0.457") L (mm) EM280207 4+ _0.5 (0.158") Poles Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Screwless Terminal Blocks 2.6+ _0.3 (0.102") 0.5+ _0.1 (0.020") 2.7+ _0.3 (0.106") 5+ _0.2 (0.197") Part Numbering System Series # of Poles E M 2 8 0 2   Compliance References 02 to 12 76 For additional product information, visit www.cooperbussmann.com/magnum 0.8+ _0.1 (0.032") 2.54+ _0.1 (1.00") EuroMag Series PCB Mount Screwless Terminal Blocks Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 Power Distribution Blocks L (mm) Dimensions - mm (in) Terminal Blocks: Base & Rail Mount Poles EM278505 EuroMag Series SPECIFICATIONS Rating: 7A, 300V Center Spacing: 0.197” (5.00mm) Wire Range: #16-22 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Spring Material: Stainless Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.051" (1.30mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM2785 Series Euro-Mag Terminal Blocks 45° Entry; Screwless; Modular; 5.00 Centers PCB Hole Layout ø ø Wire Management Products To convert to inches, divide by 25.4 Edge Connectors, One-Sided Boards Part Numbering System Series # of Poles E M 2 7 8 5   02 to 24 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 77 EM2778 Series Euro-Mag Terminal Blocks Screwless, Modular, 5.08 Centers SPECIFICATIONS Rating: 10A, 250V Center Spacing: 0.20” (5.08mm) Wire Size: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.051" (1.30mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Poles L (mm) Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 10.16 15.24 20.32 25.40 30.48 35.56 40.64 45.72 50.80 55.88 60.96 66.04 14 15 16 17 18 19 20 21 22 23 24 71.12 76.20 81.28 86.36 91.44 96.52 101.16 106.68 111.76 116.84 121.92 Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Screwless Terminal Blocks EM277805 Dimensions - mm (in) PCB Hole Layout To convert to inches, divide by 25.4 Part Numbering System Series # of Poles E M 2 7 7 8   Compliance References 02 to 24 78 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Screwless Terminal Blocks SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.20” (5.08mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.051" (1.30mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM2795 Series Euro-Mag Terminal Blocks Screwless; 5.08 Centers EM279507H EuroMag Series EM279502V Dimensions - mm (in) VERTICAL 0.20 (5.08) Poles L (mm) 2 3 4 5 6 7 8 9 12.70 17.78 22.86 27.94 33.02 38.10 43.18 48.26 10 11 12 13 14 15 16 68.58 73.66 78.74 83.82 53.34 58.42 63.50 L 0.55 (14.0) 0.094 DIA. (2.4) 0.51 (13.0) 0.41 (10.3) 0.024 (0.6) To convert to inches, divide by 25.4 0.039 (1.0) 0.12 (3.0) 0.30 (7.62) 0.10 (2.5) 0.20 (5.08) 0.200 (5.08) 0.51 (13.00) L 0.094 DIA. (2.40) Edge Connectors, One-Sided Boards Part Numbering System 0.12 (3.0) Series # of Positions E M 2 7 9 5   02 to 16 0.55 (14.0) Orientation  H - horizontal V - vertical 0.02 (0.50) 1.00 (0.039) 0.30 (7.6) 0.20 (5.80) Wire Management Products HORIZONTAL Power Distribution Blocks L (mm) Terminal Blocks: Base & Rail Mount Poles 0.10 (2.54) Compliance References For additional product information, visit www.cooperbussmann.com/magnum 79 EM2796 Series Euro-Mag Terminal Blocks Screwless; 7.62 Centers SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.30” (7.62mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.051" (1.30mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified EM279606V EM279603H Dimensions - mm (in) 7.62+ _0.2 (0.300") Poles L (mm) 2 3 4 5 6 7 8 9 15.24 22.56 30.48 37,19 45.72 53.34 60.96 68.58 10 11 12 13 14 15 16 76.20 83.82 91.44 99.07 106.69 114.31 121.93 0.5+ _0.1 (0.020") 1+ _0.1 (0.039") 7.62+ _0.1 (0.300") 7.62+ _0.1 (0.300") 2.54+ _0.3 (0.100") ø1.3~1.4 (ø0.051"~0.055") To convert to inches, divide by 25.4 7.62+ _0.1 (0.300") 4.2+ _0.3 (0.165") PCB Hole Layout 13+ _0.5 (0.512") HORIZONTAL ø2.4 (ø0.094") 02 to 16 Orientation  H - horizontal V - vertical 0.6+ _0.1 (0.024") 2.54+ _0.3 (0.100") PCB Hole Layout 7.62+ _0.1 (0.300") ø1.3~1.4 (ø0.051"~0.055") 80 7.62+ _0.1 (0.300") 4.65+ _0.3 (0.183") E M 2 7 9 6   7.62+ _0.1 (0.300") 14+ _0.5 (0.551") # of Poles 1+ _0.1 (0.039") L+ _0.5 7.62+ _0.1 (0.300") Part Numbering System 3.3+ _0.5 (0.130") 10.3+ _0.5 (0.406") 14+ _0.5 (0.551") 13+ _0.5 (0.512") Edge Connectors, One-Sided Boards 7.62+ _0.2 (0.300") Series Compliance References 14+ _0.5 (0.551") L (mm) 13+ _0.5 (0.512") Poles 3.3+ _0.5 (0.130") L+ _0.5 Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount VERTICAL 7.62+ _0.1 (0.300") EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Screwless Terminal Blocks For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Screwless Terminal Blocks EM279104V EuroMag Series SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.40” (10.16mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.051" (1.30mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM2791 Series Euro-Mag Terminal Blocks Screwless; 10.16 Centers Dimensions - mm (in) 7.62+ _0.2 (0.300") VERTICAL 14+ _0.5 (0.551") 0.5+ _0.1 (0.020") 2 3 4 5 6 7 8 9 17.78 27.94 38.10 48.26 58.42 68.58 78.74 88.90 10 11 12 13 14 15 16 99.06 109.22 119.38 129.54 139.70 149.86 160.02 ø1.3~1.4 (ø0.051"~0.055") PCB Hole Layout 7.62+ _0.1 (0.300") 13+ _0.5 (0.512") HORIZONTAL To convert to inches, divide by 25.4 10.16+ _0.2 (0.400") L+ _0.5 13+ _0.5 (0.512") 3.3+ _0.5 (0.130") 10.3+ _0.5 (0.406") Wire Management Products ø2.4 (ø0.094") 14+ _0.5 (0.551") 1+ _0.1 (0.039") 7.62+ _0.1 (0.300") L (mm) 4.2+ _0.3 (0.165") Poles 2.54+ _0.3 (0.100") 7.62+ _0.1 (0.300") 13+ _0.5 (0.512") L (mm) 1+ _0.1 (0.039") 7.62+ _0.1 (0.300") Power Distribution Blocks Poles Terminal Blocks: Base & Rail Mount 3.3+ _0.5 (0.130") L+ _0.5 0.6+ _0.1 (0.024") 7.62+ _0.1 (0.300") 2.54+ _0.3 (0.100") 10.16+ _0.1 (0.400") 14+ _0.5 (0.551") Edge Connectors, One-Sided Boards 4.65+ _0.3 (0.183") 7.62+ _0.1 (0.300") PCB Hole Layout 10.16+ _0.1 (0.400") ø1.3~1.4 (ø0.051"~0.055") Part Numbering System # of Poles E M 2 7 9 1   02 to 16 Orientation Compliance References Series  H - horizontal V - vertical For additional product information, visit www.cooperbussmann.com/magnum 81 EM2816 Series Euro-Mag Terminal Blocks 60° Entry; Screwless; 7.62 Centers 15.24 22.86 30.48 38.10 45.72 53.34 60,96 68.58 76.20 83.82 91.44 0.8+ _0.3 (0.032") 0.5+ _0.1 (0.020") 10.2+ _0.2 (0.402") 7.62+ _0.1 (0.300") 18.7+ _0.3 (0.736") 18.7+ _0.3 (0.736") Ø1.3 (Ø0.051") PCB Hole Layout 6.8+ _0.3 (0.268") 7.62+ _0.1 (0.300") Edge Connectors, One-Sided Boards L+ _0.5 Part Numbering System Series # of Poles E M 2 8 1 6   Compliance References 02 to 12 82 5.1+ _0.3 (0.201") 1+ _0.1 (0.039") 2.4+ _0.3 (0.095") To convert to inches, divide by 25.4 25.9+ _0.5 (1.020") 3+ _0.3 (0.118") 2 3 4 5 6 7 8 9 10 11 12 Dimensions - mm (in) 10.2+ _0.1 (0.402") L (mm) Wire Management Products Power Distribution Blocks Poles EM281606 23.5+ _0.3 (0.926") SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.30” (7.62mm) Wire Range: #16-22 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Spring Material: Stainless Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.051" (1.30mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Screwless Terminal Blocks For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Pluggable Terminal Blocks SPECIFICATIONS Rating: 8A, 300V Center Spacing: 0.138” (3.50mm) Wire Range: #16-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.0 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 2.5 lb-in. Construction: Mold-to-Length Agency Information: File E62622; CE Certified 7.8 11.3 14.8 18.3 21.8 25.3 28.8 32.3 35.8 33.3 42.8 46.3 49.8 15.6+ _0.3 (0.614") 11.2+ _0.3 (0.441") L+ _0.5 Power Distribution Blocks 2 3 4 5 6 7 8 9 10 11 12 13 14 Dimensions - mm (in) Terminal Blocks: Base & Rail Mount L (mm) EM353308 EuroMag Series Poles Terminal Blocks: Single & Double Row EM3533 Series Euro-Mag Terminal Blocks Pluggable Block (Mates with EM2221 Series); 3.50 Centers 3.5+ _0.1 (0.138") 2.15+ _0.3 (0.084") To convert to inches, divide by 25.4 6.6+ _0.3 (0.260") Wire Management Products Edge Connectors, One-Sided Boards Part Numbering System Series # of Poles E M 3 5 3 3   02 to 14 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 83 EM2221 Series Euro-Mag Terminal Blocks Closed Header; (Mates with EM3553 Series); 3.50 Centers SPECIFICATIONS Rating: 8A, 300V Center Spacing: 0.138” (3.50mm) Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 14 7.6 11.1 14.6 18.1 21.6 25.1 28.6 32.1 35.6 39.1 42.6 42.1 49.6 EM222112H EM222108V Dimensions - mm (in) HORIZONTAL 3.5+ _0.3 (0.138") 9.2+ _0.3 (0.362") 6.9+ _0.3 (0.272") 0.8 (0.031") 2.06+ _0.3 (0.081") 1.2+ _0.3 (0.047") 3.5+ _0.1 (0.138") ø1.3 (ø0.051") 9.2+ _0.3 (0.362") To convert to inches, divide by 25.4 PCB Hole Layout 3.5+ _0.1 (0.138") Wire Management Products Edge Connectors, One-Sided Boards L+ _0.5 1.2+ _0.3 (0.047") Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Pluggable Terminal Blocks VERTICAL 3.5+ _0.1 (0.138") 2.06+ _0.3 (0.081") Part Numbering System Series # of Poles E M 2 2 2 1   02 to 14 Orientation  H - horizontal V - vertical 0.80+ _0.1 (0.031") 9.2+ _0.3 (0.362") L+ _0.5 2.9+ _0.3 (0.114") 6.9+ _0.3 (0.272") 3.4+ _0.3 (0.134") Compliance References ø1.3 (ø0.051") 6.9+ _0.3 (0.272") PCB Hole Layout 2.9+ _0.3 (0.114") 84 For additional product information, visit www.cooperbussmann.com/magnum 3.5+ _0.1 (0.138") EuroMag Series PCB Mount Pluggable Terminal Blocks 2 3 4 5 6 7 8 9 10 11 12 17.4 20.9 24.4 27.9 31.4 34.9 38.4 41.9 45.4 48.9 52.4 15.6 (0.614") L 11.2 (0.441") Power Distribution Blocks L (mm) Dimensions - mm (in) Terminal Blocks: Base & Rail Mount Poles EM241307 EuroMag Series SPECIFICATIONS Rating: 8A, 300V Center Spacing: 0.138” (3.50mm) Wire Range: #16-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.0 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 2.5 lb-in. Construction: Mold-to-Length Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM2413 Series Euro-Mag Terminal Blocks Pluggable Block with Flanges (Mates with EM2201 Series); 3.50 Centers 6.6 (0.60") 2.15 (0.084") 3.5–.1 (0.138") To convert to inches, divide by 25.4 Wire Management Products Series Edge Connectors, One-Sided Boards Part Numbering System # of Poles E M 2 4 1 3   02 to 12 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 85 EM2201 Series Euro-Mag Terminal Blocks Header with Flanges (Mates with EM2413 Series); 3.50 Centers EM220110H SPECIFICATIONS Rating: 8A, 300V Center Spacing: 0.138” (3.50mm) Housing Material: Green Polyamide Type 6/6, 94V0 Contact Material: Brass Tin-Plated Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Mold to Length Agency Information: File E62622; CE Certified Power Distribution Blocks Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 17.4 20.9 24.4 27.9 31.4 34.9 38.4 41.3 45.4 48.9 52.4 HORIZONTAL To convert to inches, divide by 25.4 Ø Ø PCB Hole Layout Wire Management Products Edge Connectors, One-Sided Boards EM220109V Dimensions - mm (in) Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Pluggable Terminal Blocks HORIZONTAL Part Numbering System Series # of Poles E M 2 2 0 1   Compliance References 02 to 12 Orientation  H - horizontal V - vertical Ø Ø PCB Hole Layout 86 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Pluggable Terminal Blocks L (mm) 15.6+ _0.3 (0.614") L+ _0.5 11.2+ _0.3 (0.441") 7.90 11.71 15.52 19.33 23.14 26.95 30.76 34.57 38.38 42.19 46.00 Power Distribution Blocks 02 03 04 05 06 07 08 09 10 11 12 Dimensions - mm (in) Terminal Blocks: Base & Rail Mount Position EM355308 EuroMag Series SPECIFICATIONS Rating: 8A, 300V Center Spacing: 0.15” (3.81mm) Consult factory for 0.30” (7.62mm) Wire Range: #18-20 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Screw Size: M2x3 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 3.0 lb-in. Construction: Mold-to-Length Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM3553 Series Euro-Mag Terminal Blocks (Mates with EM3593 Series); 3.81 Centers 3.5+ _0.1 (0.138") 2.15+ _0.3 (0.084") 6.6+ _0.3 (0.260") To convert to inches, divide by 25.4 Wire Management Products Edge Connectors, One-Sided Boards Part Numbering System Series # of Positions Mating Header: EM3593 pg. 90 Compliance References E M 3 5 5 3   02 to 12 For additional product information, visit www.cooperbussmann.com/magnum 87 EM3543 Series Euro-Mag Terminal Blocks Pluggable Block (Mates with EM3593 Series); 3.81 Centers SPECIFICATIONS Rating: 8A, 300V Center Spacing: 0.15” (3.81mm) Consult factory for 0.30" (7.62mm) Wire Range: #16-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.0 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 2.5 lb-in. Construction: Mold-to-Length Agency Information: File E62622; CE Certified Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 8.41 12.22 16.03 19.84 23.65 27.46 31.27 35.08 38.89 42.70 46.51 Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Pluggable Terminal Blocks EM354309 Dimensions - mm (in) Edge Connectors, One-Sided Boards Wire Management Products To convert to inches, divide by 25.4 Part Numbering System Series # of Poles E M 3 5 4 3   Mating Header: EM3593 pg. 90 Compliance References 02 to 12 88 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Pluggable Terminal Blocks Terminal Blocks: Single & Double Row Series EM3583 Euro-Mag Terminal Blocks IDC Pluggable Block (Mates with EM3593 Series); 3.81 Centers EuroMag Series SPECIFICATIONS Ratings: 6A, 160V Center Spacing: 0.15" (3.81mm) Wire Range: #22-20 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass, Tin-Plated Operating Temperature: 105°C (221°F) max., –49°C (–40°F) min. Construction: Mold-to-length. Agency Information: File E62622; CE Certified EM358307 Dimensions - mm (in) L1 (mm) L2 (mm) Poles L1 (mm) L2 (mm) 02 03 04 05 06 07 3.81 7.62 11.43 15.24 19.05 22.86 8.40 12.21 16.02 19.83 23.64 27.45 08 09 10 11 12 26.67 30.48 34.29 38.10 41.91 31.26 35.07 38.88 42.69 46.50 Terminal Blocks: Base & Rail Mount Poles 3.8 (0.15) REF. (IN OPEN POSITION) 12.9 (0.51) 3.8 (0.15) 4.0 (0.16) EM3583 6.6 (0.26) Wire Management Products 15.7 (0.62) L1 L2 Series E M 3 5 8 3  Edge Connectors, One-Sided Boards Part Numbering System Power Distribution Blocks 2.9 (0.11) Inches (Millimeters) # of Positions  Mating Header: EM3593 pg. 90 Compliance References 02 to 12 For additional product information, visit www.cooperbussmann.com/magnum 89 EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Pluggable Terminal Blocks Series EM3593 Euro-Mag Terminal Blocks Header (Mates with EM3553 Series); 3.81 Centers EM359312HC SPECIFICATIONS Ratings: 6A, 160V Center Spacing: 0.15" (3.81mm) Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass, Tin-Plated Operating Temperature: 105°C (221°F) max., –40°C (–40°F) min. Recommended PCB Hole Diameters: 0.51" (1.30mm) Construction: Mold-to-length. Agency Information: File E62622; CE Certified EM359308VC Dimensions - mm (in) Terminal Blocks: Base & Rail Mount Poles L (mm) Poles L (mm) Horizontal 02 03 04 05 06 07 8.23 12.04 15.85 19.66 23.47 27.28 08 09 10 11 12 31.09 34.90 38.71 42.52 46.33 L 9.20 (0.062) * Dimensions in inches. To convert to millimeters, multiply by 25.4. Power Distribution Blocks 6.90 (0.272) 3.00 (0.100) 1.21 (0.062) 2.21 (0.087) 3.81 (0.150) 3.81 (0.150) Wire Management Products 1.80 (0.031) Vertical 3.60 (0.198) Edge Connectors, One-Sided Boards 2.93 (0.110) 3.81 (0.150) 2.2 (0.087) Compliance References Part Numbering System EM 3 5 9 3   90 # of Positions Ø1.30 (Ø 0.051) 1.20 (0.047) 6.90 (0.272) Series 1.20 (0.047) L 9.20 (0.062) PCB Hole Layout 3.81 (0.150) Inches (Millimeters) Orientation Side Base   C  02 to 12 H - Horizontal V - Vertical C - Closed Mating Plugs: EM3553 pg. 87 EM3543 pg. 88 EM3583 pg. 89 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Pluggable Terminal Blocks 2 3 4 5 6 7 8 9 10 11 12 17.91 21.72 25.53 29.34 33.15 36.96 40.77 44.58 48.39 52.20 56.01 3 Power Distribution Blocks L (mm) Dimensions - mm (in) Terminal Blocks: Base & Rail Mount Poles EM242307 EuroMag Series SPECIFICATIONS Rating: 8A, 300V Center Spacing: 0.15” (3.81mm) Wire Range: #16-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.0 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 2.5 lb-in. Construction: Mold-to-Length Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM2423 Series Euro-Mag Terminal Blocks Pluggable Block with Flanges (Mates with EM2211 Series); 3.81 Centers To convert to inches, divide by 25.4 Wire Management Products Edge Connectors, One-Sided Boards Part Numbering System Series # of Poles E M 2 4 2 3   Mating Header: EM2211 pg. 93 02 to 12 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 91 EM2443 Series Euro-Mag Terminal Blocks Pluggable Block with Flanges (Mates with EM2211 Series); 3.81 Centers SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.15” (3.81mm) Consult factory for 0.30" (7.62mm) Wire Range: #16-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.0 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 2.5 lb-in. Construction: Mold-to-Length Agency Information: File E62622; CE Certified Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 7.90 11.71 15.52 19.33 23.14 26.95 30.76 34.57 38.38 42.19 46.00 Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Pluggable Terminal Blocks EM2443 Dimensions - mm (in) L Edge Connectors, One-Sided Boards Wire Management Products To convert to inches, divide by 25.4 Part Numbering System Series # of Poles E M 2 4 4 3   Mating Header: EM2211 pg. 93 Compliance References 02 to 12 92 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Pluggable Terminal Blocks Terminal Blocks: Single & Double Row EM2211 Series Euro-Mag Terminal Blocks Header with Flanges (Mates with EM2423, EM2443 Series); 3.81 Centers EM221106H EuroMag Series SPECIFICATIONS Rating: 8A, 300V Center Spacing: 0.15” (3.81mm) Consult factory for 0.30" (7.62mm) Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Mold to Length Agency Information: File E62622; CE Certified EM221109V Dimensions - mm (in) HORIZONTAL 2 3 4 5 6 7 8 9 10 11 12 14 18.02 21.83 25.64 29.45 33.26 37.07 40.88 44.69 48.50 52.31 56.12 63.74 L 9.20 [.362] 2.60 [.102] 2.60 [.102] 6.90 [.272] (2) M2.6 0.80 [.031] 7.10 [.280] 3.50 [.138] Power Distribution Blocks L (mm) Terminal Blocks: Base & Rail Mount Poles 3.81 [.150] 1.20 [.047] Ø1.30 [Ø.051] 1.20 [.047] To convert to inches, divide by 25.4 PCB Hole Layout 9.20 [.362] Wire Management Products 3.81 [.150] VERTICAL Edge Connectors, One-Sided Boards L Ø Ø Part Numbering System PCB Hole Layout # of Poles E M 2 2 1 1   02 to 14 Orientation Compliance References Series  H - horizontal V - vertical Mating Plugs: EM2423 pg. 91 EM2443 pg. 92 For additional product information, visit www.cooperbussmann.com/magnum 93 EM2525 Series Euro-Mag Terminal Blocks Pluggable Block (Mates with EM2535 Series); 5.00 Centers SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.197” (5.00mm) Consult factory for 0.394” (10.00mm) Wire Range: #12-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Screw Size: M3x5 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 7 lb-in. Construction: Mold-to-Length Connector Style: Rising Cage Clamp Agency Information: File E62622; CE Certified EM252503 Dimensions - mm (in) 0.197 (5.00) 0.197 (5.00) 0.10 (2.5) Poles L (mm) Poles L (mm) 0.72 (18.3) 02 03 04 05 06 07 08 09 10 11 12 13 Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Pluggable Terminal Blocks 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 14 15 16 17 18 19 20 21 22 23 24 0.39 (10.0) L 0.13 (3.3) 0.095 (2.4) 0.57 (14.5) Wire Management Products To convert to inches, divide by 25.4 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 Edge Connectors, One-Sided Boards 0.11 (2.8) Part Numbering System Compliance References Series # of Positions E M 2 5 2 5   Mating Header: EM2535 pg. 97 02 to 24 94 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Pluggable Terminal Blocks Terminal Blocks: Single & Double Row EM2485 Series Euro-Mag Terminal Blocks Pluggable Block with Cover (Mates with EM2535 Series); 5.00 Centers Dimensions - mm (in) L 13+ _0.3 (0.512") L (mm) To convert to inches, divide by 25.4 2.5+ _0.3 (0.098") 8.2+ _0.3 (0.323") 25.8+ _0.3 (1.016") 10.0 15.0 20.0 25.0 30.0 35.0 40.0 29.1+ _0.3 (1.146") 5+ _0.1 (0.197") Power Distribution Blocks 2 3 4 5 6 7 8 EM248506 Terminal Blocks: Base & Rail Mount Poles EuroMag Series SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.197” (5.00mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Phos Bronze Cage Clamp: Brass, Nickel-Plated Screw Size: M2.6 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 4.5 lb-in. Construction: Mold-to-Length Agency Information: File E62622; CE Certified Wire Management Products Edge Connectors, One-Sided Boards Part Numbering System Series # of Poles E M 2 4 8 5   Mating Header: EM2535 pg. 97 02 - 08 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 95 EM3105 Series Euro-Mag Terminal Blocks Pluggable Block; Top Entry (Mates with EM2535 Series); 5.00 Centers SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.197” (5.00mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Phos Bronze Cage Clamp: Brass, Nickel-Plated Screw Size: M2.6 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 4.5 lb-in. Construction: Mold-to-Length Agency Information: File E62622; CE Certified L (mm) Poles L (mm) 2 3 4 5 6 7 10.0 15.0 20.0 25.0 30.0 35.0 8 9 10 11 12 40.0 45.0 50.0 55.0 60.0 Edge Connectors, One-Sided Boards EM310508 Dimensions - mm (in) L+ _0.5 14.9+ _0.3 Poles 5+ _0.1 2.5+ _0.2 27.1+ _0.3 To convert to inches, divide by 25.4 8.2+ _0.3 Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Pluggable Terminal Blocks Part Numbering System Series # of Poles E M 3 1 0 5   Compliance References 02 to 12 Mating Plugs: EM2525 pg. 94 EM2485 pg. 95 EM3105 pg. 96 96 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Pluggable Terminal Blocks Terminal Blocks: Single & Double Row EM2535 Series Euro-Mag Terminal Blocks Header (Mates with EM2525, EM2485 & EM3105 Series); 5.00 Centers EM253505VC SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.197” (5.00mm) Consult factory for 0.394” (10.00mm) Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.055” (1.40mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified EM253508HO EuroMag Series Dimensions - mm (in) VERTICAL - CLOSED L 0.47 (12.0) 0.039 (1.00) Position Closed L (mm) 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 12.0 17.0 22.0 27.0 32.0 37.0 42.0 47.0 52.0 57.0 62.0 67.0 Position Open L (mm) Closed L (mm) 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 72.0 77.0 82.0 87.0 92.0 97.0 102.0 107.0 112.0 117.0 122.0 0.197 (5.00) 0.14 (3.5) 0.11 (2.7) 9.1 (0.36) 0.15 (3.8) HORIZONTAL - OPEN 0.039 (1.0) L Power Distribution Blocks 02 03 04 05 06 07 08 09 10 11 12 13 Open L (mm) 0.039 (1.00) Terminal Blocks: Base & Rail Mount 0.17 (4.2) To convert to inches, divide by 25.4 0.47 (12.0) Wire Management Products 0.197 (5.00) 0.10 (2.5) 0.08 (2.0) 0.17 (4.2) 0.039 (1.0) Edge Connectors, One-Sided Boards 0.36 (9.1) Part Numbering System Series # of Positions 02 to 24 Side Base   H - horizontal V - vertical O - open C - closed Mating Plugs: EM2525 pg. 94 EM2485 pg. 95 EM3105 pg. 96 For additional product information, visit www.cooperbussmann.com/magnum Compliance E M 2 5 3 5   Orientations 97 EM2565 Series Euro-Mag Terminal Blocks Pluggable Block (Mates with EM2575 Series); 5.08 Centers SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.20” (5.08mm) Consult factory for 0.40” (10.16mm) Wire Range: #12-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Screw Size: M3x5 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 7 lb-in. Construction: Mold-to-Length Agency Information: File E62622; CE Certified EM25603VR Dimensions - mm (in) HORIZONTAL 0.197 (5.00) 0.200 (5.08) 0.10 (2.54) 0.72 (18.3) 0.39 (10.0) Position 02 03 04 05 06 07 08 09 10 11 12 13 Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Pluggable Terminal Blocks L (mm) Position L (mm) 10.16 15.24 20.32 25.40 30.48 35.56 40.64 45.72 50.80 55.88 60.96 66.04 14 15 16 17 18 19 20 21 22 23 24 71.12 76.20 81.28 86.36 91.44 96.52 101.60 106.68 111.76 116.84 121.92 0.39 (10.0) 0.13 (3.3) L 0.57 (14.5) 0.11 (2.8) 0.08 (2.1) VERTICAL To convert to inches, divide by 25.4 L Wire Management Products 0.47 (12.0) 0.47 (12.0) WIRE WIRE ENTRY ENTRY 0.11 (2.8) 0.13 (3.3) 0.13 (3.3) 1.02 (26.0) 0.09 (2.4) Edge Connectors, One-Sided Boards 0.33 (8.3) RIGHT LEFT 1.0 (2.54) 0.200 (5.08) 0.200 (5.08) Compliance References Part Numbering System Series # of Positions E M 2 5 6 5   02 to 24 98 Orientation Wire Entry (Vertical Orientation Only)   H - horizontal V - vertical L - left R - right Mating Header: EM2575 pg. 101 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Pluggable Terminal Blocks Terminal Blocks: Single & Double Row EM2488 Series Euro-Mag Terminal Blocks Pluggable Block (Mates with EM2575 Series); 5.08 Centers with Cover EuroMag Series SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.20” (5.08mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.6 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 4.5 lb-in. Construction: Mold-to-Length Agency Information: File E62622; CE Certified EM248806 Dimensions - mm (in) 13+ _0.3 (0.512") Terminal Blocks: Base & Rail Mount L To convert to inches, divide by 25.4 5.08+ _0.1 (0.200") 2.54+ _0.3 (0.100") 8.2+ _0.3 (0.323") 10.16 15.24 20.32 25.40 30.48 35.56 40.64 25.8+ _0.3 (1.016") 2 3 4 5 6 7 8 29.1+ _0.3 (1.146") L (mm) Power Distribution Blocks Poles Wire Management Products Edge Connectors, One-Sided Boards Part Numbering System Series # of Poles E M 2 4 88    Mating Header: EM2575 pg. 101 02 to 08 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 99 EM3108 Series Euro-Mag Terminal Blocks Pluggable Block; Front Entry (Mates with EM2575 Series); 5.08 Centers SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.20” (5.08mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.6 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 4.5 lb-in. Construction: Mold-to-Length Agency Information: File E62622; CE Certified Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 10.16 15.24 20.32 25.40 30.48 35.45 40.64 45.72 50.80 55.88 60.96 66.04 14 15 16 17 18 19 20 21 22 23 24 71.12 76.20 81.28 86.36 91.44 96.52 101.60 106.68 111.76 116.84 121.92 Edge Connectors, One-Sided Boards L+ _0.5 5.08+ _0.1 2.54+ _0.2 8.2+ _0.3 Wire Management Products To convert to inches, divide by 25.4 Dimensions - mm (in) 14.9+ _0.3 L (mm) EM310808 27.1+ _0.3 Poles Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Pluggable Terminal Blocks Part Numbering System Series # of Poles E M 3 1 0 8   Mating Header: EM2575 pg. 101 Compliance References 02 to 24 100 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Pluggable Terminal Blocks EM257512HC SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.20” (5.08mm) Consult factory for 0.40” (10.16mm) Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified 14 15 16 17 18 19 20 21 22 23 24 71.12 76.20 81.28 86.36 91.44 96.52 101.60 106.68 111.76 116.84 121.92 73.04 78.12 83.20 88.28 93.36 98.44 103.52 105.60 113.68 118.76 123.84 Dimensions - mm (in) HORIZONTAL OPEN HORIZONTAL CLOSED L+ _0.5 L+ _0.5 12+ _0.3 (0.472") 8.3+ _0.3 (0.327") 1.8+ _0.3 (0.071") To convert to inches, divide by 25.4 1+ _0.1 (0.039") 1.00+ _0.1 (0.039") 5.08+ _0.1 (0.200") 5.08+ _0.1 (0.200") Ø1.5 (Ø 0.059") 12+ _0.3 (0.472") 12.08 17.16 22.24 27.32 32.40 37.48 42.66 47.64 62.72 67.80 62.88 67.96 EM257506VO 4.5+ _0.3 (0.177") 10.16 15.24 20.32 25.40 30.48 35.56 40.64 45.72 50.80 55.88 60.96 66.04 Closed L (mm) Power Distribution Blocks 2 3 4 5 6 7 8 9 10 11 12 13 Poles Open L (mm) EM257512VC Terminal Blocks: Base & Rail Mount Closed L (mm) EM257506HO EuroMag Series Poles Open L (mm) Terminal Blocks: Single & Double Row EM2575 Series Euro-Mag Terminal Blocks Header (Mates with EM2565, EM2488, EM3108 Series); 5.08 Centers 1.8+ _0.3 (0.071") PCB Hole Layout 5.08+ _0.1 (0.200") 12±0.3 (0.472") 5.08±0.1 (0.200") L±0.5 L±0.5 4.5±0.3 (0.177") Edge Connectors, One-Sided Boards 8.3±0.3 (0.327") 1±0.1 (0.039") 3.8±0.3 (0.150") 1.00±0.1 [0.039] Wire Management Products VERTICAL CLOSED VERTICAL OPEN Ø1.5 (Ø 0.059") 5.08±0.1 (0.200") 8.3±0.3 (0.327") 3.8±0.3 (0.150") PCB Hole Layout Part Numbering System # of Poles E M 2 5 7 5   02 to 24 Orientation Side Base   H - horizontal V - vertical O - open C - closed Compliance References Series Mating Plugs: EM2565 pg. 98 EM2488 pg. 99 EM3108 pg. 100 For additional product information, visit www.cooperbussmann.com/magnum 101 EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Pluggable Terminal Blocks Series EM2115 Series Pluggable Terminal Block with Flanges; (Mates with EM2215 Series);5.00 Centers SPECIFICATIONS: Rating: 16A, 300V Center Spacing: 0.197" (5.00mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Phosphor Bronze Screw Size: M2x6 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -55°C (-67°F) min. Torque Rating: 4.5 lb-in. Construction: Mold-to-Length Agency Information: File E62622; CE Certified EM211514VL Dimensions - mm (in) Vertical Ø.11" (2.70) Poles A (mm) A (Inch) Poles A (mm) A (Inch) 2 3 4 5 6 7 8 9 10 11 12 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 70.0 0.787 0.984 1.181 1.378 1.575 1.772 1.969 2.165 2.362 2.559 2.756 13 14 15 16 17 18 19 20 21 22 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 2.952 3.149 3.346 3.543 3.740 3.937 4.133 4.330 4.527 4.724 L 0.197" (5.00) Edge Connectors, One-Sided Boards 0.10" (2.50) 1.02" (25.8) WIRE ENTRY WIRE ENTRY 1.02" (25.8) 0.32" (8.20) 0.32" (8.20) LEFT RIGHT Horizontal Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount 0.49" (12.5) 0.71" (18.00) L 0.32" (8.20) 0.59" (15.0) Ø.11" (2.70) Part Numbering System Series Compliance References E M 2 1 1 5  102 # of Poles 0.197" (5.00) 0.10" (2.50) 0.39" (9.80) Inches (Millimeters) Orientation Wire Entry    02 to 22 V - Vertical H - Horizontal L - Left wire entry R - Right wire entry (specify for V orientation) Mating Header: EM2215 pg. 104 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Pluggable Terminal Blocks EuroMag Series EM311503 Dimensions - mm (in) L 14.9+ _0.3 Terminal Blocks: Base & Rail Mount SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.197” (5.00mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.6 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 4.5 lb-in. Construction: Mold-to-Length Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM3115 Series Euro-Mag Terminal Blocks Pluggable Block; Top Entry (Mates with EM2215 Series); 5.00 Centers 2 3 4 5 6 7 8 9 10 11 12 13 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 70.0 75.0 14 15 16 17 18 19 20 21 22 23 24 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 125.0 130.0 5+ _0.1 2.5+ _0.2 8.2+ _0.3 L (mm) 6.5+ _0.3 Poles 27.1+ _0.3 L (mm) Power Distribution Blocks Poles To convert to inches, divide by 25.4 Wire Management Products Edge Connectors, One-Sided Boards Part Numbering System Series # of Poles E M 3 1 1 5   Mating Header: EM2215 pg. 104 02 to 22 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 103 Series EM2215 Header with Flanges; (Mates with EM2115, EM3115 Series); 5.00 Centers SPECIFICATIONS: Rating: 16A, 300V Center Spacing: 0.197" (5.00mm) Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Operating Temperature: 105°C (221°F) max., -55°C (-67°F) min. Construction: Mold-to-Length Agency Information: File E62622; CE Certified EM221503V Dimensions - mm (in) Horizontal Poles A (mm) A (Inch) Poles A (mm) A (Inch) 2 3 4 5 6 7 8 9 10 11 12 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 0.393 0.590 0.787 0.984 1.181 1.378 1.575 1.772 1.969 2.165 2.362 13 14 15 16 17 18 19 20 21 22 65.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 2.559 2.953 3.150 3.346 3.543 3.740 3.937 4.133 4.331 4.528 L 0.10" (2.50) 0.47" (12.00) 0.33" (8.30) 0.18" (4.50) M2.6 0.04" (1.00) 0.07" (1.80) 0.47" (12.00) PCB Hole Layout 0.07" (1.80) 0.197" (5.00) Wire Management Products Vertical 0.15" 0.04" (3.80) (1.00) 0.47" (12.00) L 0.10" (2.50) 0.33" (8.30) 0.197" (5.00) 0.18" (4.50) Edge Connectors, One-Sided Boards M2.6 Ø.06" (1.50) 0.15" (3.80) 0.33" (8.30) PCB Hole Layout 0.197" (5.00) Part Numbering System Compliance References 0.197" (5.00) Ø.06" (1.50) Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Pluggable Terminal Blocks Series EM 2 2 1 5   104 # of Poles Inches (Millimeters) Orientation   02 to 22 H - Horizontal V - Vertical Mating Plugs: EM2115 pg. 102 EM3115 pg. 103 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Pluggable Terminal Blocks Terminal Blocks: Single & Double Row Series EM2118 Series Pluggable Terminal Block with Flanges; (Mates with EM2218 Series); 5.08 Centers Poles A (mm) A (Inch) 2 3 4 5 6 7 8 9 10 11 12 20.32 25.40 30.48 35.56 40.64 45.72 50.80 55.88 60.96 66.04 71.12 0.8 1.0 1.2 1.4 1.6 1.8 2.0 2.2 2.4 2.6 2.8 13 14 15 16 17 18 19 20 21 22 76.20 81.28 86.36 91.44 96.52 101.60 106.68 111.76 116.84 121.92 3.0 3.2 3.4 3.6 3.8 4.0 4.2 4.4 4.6 4.8 0.49" (12.5) L 0.20" (5.08) 0.10" (2.54) 1.02" (25.8) WIRE ENTRY WIRE ENTRY 1.02" (25.8) 0.32" (8.20) 0.32" (8.20) LEFT RIGHT Power Distribution Blocks A (Inch) Terminal Blocks: Base & Rail Mount A (mm) EM211814VL Ø.11" (2.70) VERTICAL Poles EuroMag Series SPECIFICATIONS: Rating: 16A, 300V EM211803H Center Spacing: 0.20" (5.08mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Phosphor Bronze Screw Size: M 3x0 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -55°C (-67°F) min. Torque Rating: 4.5 lb-in. Construction: Mold-to-Length Dimensions - mm (in) Agency Information: File E62622; CE Certified HORIZONTAL Wire Management Products 0.71" (18.00) L 0.32" (8.20) Ø.11" (2.70) Part Numbering System EM 2 1 1 8   # of Positions 0.10" (2.54) 0.39" (9.80) Inches (Millimeters) Orientation   02 to 22 V - Vertical H - Horizontal Compliance References Series 0.20" (5.08) Edge Connectors, One-Sided Boards 0.59" (15.0) Mating Header: EM2218 pg. 107 For additional product information, visit www.cooperbussmann.com/magnum 105 EM3118 Series Euro-Mag Terminal Blocks Pluggable Block, Top Entry (Mates with EM2218 Series); 5.08 Centers Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 20.32 25.40 30.48 35.45 40.64 45.72 50.80 55.88 60.96 66.04 71.12 13 14 15 16 17 18 19 20 21 22 76.20 81.28 86.36 91.44 96.52 101.60 106.68 111.76 116.84 121.92 L 14.9±0.3 L (mm) Dimensions - mm (in) 5.08+ _0.1 2.54+ _0.2 27.1+ _0.3 Poles EM311803 6.5+ _0.3 SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.20” (5.08mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Clamp: Brass, Nickel-Plated Screw Size: M2.6 Nickel-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 4.5 lb-in. Construction: Mold-to-Length Agency Information: File E62622; CE Certified Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Pluggable Terminal Blocks Edge Connectors, One-Sided Boards Wire Management Products 8.2+ _0.3 To convert to inches, divide by 25.4 Part Numbering System Series # of Poles E M 3 1 1 8   Mating Header: EM2218 pg. 107 Compliance References 02 to 22 106 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Pluggable Terminal Blocks EM221804H EuroMag Series SPECIFICATIONS: Rating: 12A, 300V Center Spacing: 0.20" (5.08mm) Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Operating Temperature: 105°C (221°F) max., -55°C (-67°F) min. Recommended PCB Hole Diameters: 0.059" (1.50mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row Series EM2218 Header with Flanges; (Mates with EM2118, EM3118 Series); 5.08 Centers EM221804V Dimensions - mm (in) Horizontal L (Inch) Poles L (mm) L (Inch) 2 3 4 5 6 7 8 9 10 11 20.32 25.40 30.48 35.56 40.64 45.72 50.80 55.88 60.95 66.04 0.8 1.0 1.2 1.4 1.6 1.8 2.0 2.2 2.4 2.6 12 13 14 15 16 17 18 19 20 71.12 76.20 81.28 86.36 91.44 96.52 101.60 106.68 111.76 2.8 3.0 3.2 3.4 3.6 3.8 4.0 4.2 4.4 L 0.47" (12.00) 0.18" (4.50) 0.10" (2.54) 0.33" (8.30) M2.6 0.20" (5.08) 0.04" (1.00) 0.07" (1.80) Power Distribution Blocks L (mm) Terminal Blocks: Base & Rail Mount Poles Ø.06" (1.50) PCB Hole Layout 0.47" (12.00) 0.07" (1.80) 0.20" (5.08) Vertical L 0.47" (12.00) Wire Management Products 0.15" 0.04" (3.80) (1.00) 0.10" (2.54) 0.33" (8.30) 0.20" (5.08) 0.18" (4.50) Ø.06" (1.50) Edge Connectors, One-Sided Boards 0.15" (3.80) M2.6 0.33" (8.30) PCB Hole Layout 0.20" (5.08) Part Numbering System Series E M 2 2 1 8  # of Poles Inches (Millimeters) Orientation  02 to 22 H - Horizontal V - Vertical Mating Plugs: EM2118 pg. 105 EM3118 pg. 106 For additional product information, visit www.cooperbussmann.com/magnum Compliance References  107 EM3516 Series Euro-Mag Terminal Blocks Pluggable Block (Mates with EM3526 Series); 7.62 Centers SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.30” (7.62mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Cage Clamp: Brass, Nickel-Plated Screw Size: M3.0 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5.0 lb-in. Construction: Mold-to-Length Agency Information: File E62622; CE Certified Dimensions - mm (in) L (mm) 2 3 4 5 6 7 8 9 10 11 12 8.41 12.22 16.03 19.84 23.65 27.46 31.27 35.08 38.89 42.70 46.51 Wire Management Products 18+ _0.3 8.2+ _0.3 15+ _0.3 Poles To convert to inches, divide by 25.4 Edge Connectors, One-Sided Boards EM351603 L Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Pluggable Terminal Blocks 2.8+ _0.3 9.8+ _0.3 7.62+ _0.1 Part Numbering System Series # of Poles Mating Header: EM3526 pg. 109 E M 3 5 1 6   Compliance References 02 to 12 108 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Pluggable Terminal Blocks Terminal Blocks: Single & Double Row EM3526 Series Euro-Mag Terminal Blocks Closed and Open Header (Mates with EM3516 Series); 7.62 Centers EM352610HO EuroMag Series SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.30” (7.62mm) Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified EM352604VC Dimensions - mm (in) HORIZONAL CLOSED L+ _0.5 L±0.5 12+ _0.3 (0.472") 15.24 22.86 30.48 38.10 45.72 53.34 60.96 68.58 76.20 83.82 91.44 HORIZONTAL OPEN 7.62+ _0.1 (0.300") 12+ _0.3 (0.472") 8.3+ _0.3 (0.327") 13.44 21.06 28.68 36.60 43.92 51.54 59.16 66.78 74.40 82.02 89.64 1.8+ _0.3 (0.071") 2 3 4 5 6 7 8 9 10 11 12 PCB Hole Layout Ø1.5 (Ø 0.059") 4.5+ _0.3 (0.177") Closed L (mm) To convert to inches, divide by 25.4 7.62+ _0.1 (0.300") 1+ _0.1 ( 0.039") 1.8+ _0.3 (0.071") 8.3+ _0.3 (0.327") 7.62+ _0.1 (0.300") 12+ _0.3 (0.472") L+ _0.5 7.62±0.1 (0.300") 1±0.1 ( 0.039") L±0.5 8.3+ _0.3 (0.327") 1+ _0.1 ( 0.039") 1+ _0.1 ( 0.039") Edge Connectors, One-Sided Boards 3.8+ _0.3 (0.150") 3.8+ _0.3 (0.150") Ø1.5 (Ø 0.059") VERTICAL CLOSED 7.62+ _0.1 (0.300") Wire Management Products VERTICAL OPEN PCB Hole Layout 7.62±0.1 (0.300") 1±0.1 ( 0.039") Power Distribution Blocks Open L (mm) Terminal Blocks: Base & Rail Mount Poles 4.5+ _0.3 (0.177") Part Numbering System # of Poles E M 3 5 2 6   02 to 24 Orientation Side Base   H - horizontal V - vertical O - open C - closed Mating Plug: EM3516 pg. 108 For additional product information, visit www.cooperbussmann.com/magnum Compliance References Series 109 EM2416 Series Euro-Mag Terminal Blocks Pluggable Block with Flanges (Mates with EM2426 Series); 7.62 Centers SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.30” (7.62mm) Wire Range: #14-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Cage Clamp: Brass, Nickel-Plated Screw Size: M3.0 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5.0 lb-in. Construction: Mold-to-Length Agency Information: File E62622; CE Certified EM241602 Dimensions - mm (in) L L (mm) 2 3 4 5 6 7 8 9 10 11 12 24.90 32.50 40.10 47.80 55.40 63.00 70.60 78.20 89.90 93.50 101.10 18+ _0.3 8.2+ _0.3 15+ _0.3 Poles Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Pluggable Terminal Blocks Ø2 To convert to inches, divide by 25.4 Edge Connectors, One-Sided Boards Wire Management Products 2.8+ _0.3 9.8+ _0.3 7.62+ _0.1 Part Numbering System Series # of Poles Mating Header: EM2426 pg. 111 E M 2 4 1 6   Compliance References 02 to 12 110 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Pluggable Terminal Blocks Terminal Blocks: Single & Double Row EM2426 Series Euro-Mag Terminal Blocks Header with Flanges (Mates with EM2416 Series); 7.62 Centers EM242603V EuroMag Series SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.30” (7.62mm) Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.059" (1.50mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified EM242606H Dimensions - mm (in) HORIZONTAL Terminal Blocks: Base & Rail Mount L+ _0.5 2 3 4 5 6 7 25.62 33.24 40.86 48.48 56.10 63.72 8 9 10 11 12 71.34 78.96 86.58 94.20 101.80 7.62+ _0.1 (0.300") 1+ _0.1 ( 0.039") 1.8+ _0.3 (0.071") Ø1.5 (Ø 0.059") 12±0.3 (0.472") L (mm) 2.9+ _0.2 (0.114") 8.3+ _0.3 (0.327") Poles PCB Hole Layout 1.8+ _0.3 (0.071") L (mm) 2.9+ _0.2 (0.114") To convert to inches, divide by 25.4 7.62+ _0.1 (0.300") 7.62+ _0.1 (0.300") 1±.1 ( 0.039") VERTICAL Power Distribution Blocks Poles 4.5+ _0.3 (0.177") 12+ _0.3 (0.472") Wire Management Products 2.9+ _0.2 (0.114") 2.9+ _0.2 (0.114") 8.3+ _0.3 (0.327") 1+ _0.1 ( 0.039") 3.8+ _0.3 (0.150") L+ _0.5 12+ _0.3 (0.472") Ø1.5 (Ø 0.059") 12+ _0.3 (0.472") 3.8+ _0.3 (0.150") Edge Connectors, One-Sided Boards M2.6 4.5+ _0.3 (0.177") PCB Hole Layout 7.62+ _0.1 (0.300") Part Numbering System # of Poles E M 2 4 2 6   02 to 12 Orientation Mating Plug: EM2416 pg. 110 Compliance References Series  H - horizontal V - vertical For additional product information, visit www.cooperbussmann.com/magnum 111 EM5015 Series Euro-Mag Terminal Blocks Pluggable Block (Mates with EM5025 Series); 5.00 Centers EM501508 SPECIFICATIONS Rating: 15A, 300V Center Spacing: 0.197” (5.00mm) Wire Range: #16-24 AWG Housing Material: Blue UL 94V0 Thermoplastic Contact Material: Tin-Plated Brass Screw Size: M2x6 Chromatized Steel Operating Temperature: 120°C (221°F) max., -40°C (-40°F) min. Torque Rating: 3.0 lb-in. Construction: Modular design features dovetails for interlocking to achieve longer lengths Connector Style: Spring Clamp Agency Information: File E62622; CE Certified Poles L (mm) Poles L (mm) 2* 3* 4 5 6 7 8 9 10 11 12 13 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 Wire Management Products Edge Connectors, One-Sided Boards Dimensions - mm (in) 0.197 (5.00) 0.10 (2.5) 0.37 (9.3) 0.53 (13.5) L 0.43 (11.0) To convert to inches, divide by 25.4 *Mold-to-Length WIRE ENTRY WIRE ENTRY Mating orientations Part Numbering System Series Compliance References EM501504 TEST POINT Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Pluggable Terminal Blocks # of Poles Mating Header: EM5025 pg. 113 E M 5 0 1 5   02 to 24 112 For additional product information, visit www.cooperbussmann.com/magnum EuroMag Series PCB Mount Pluggable Terminal Blocks Terminal Blocks: Single & Double Row EM5025 Series Euro-Mag Terminal Blocks Header (Mates with EM5015 Series); 5.00 Centers EM502512 SPECIFICATIONS Rating: 15A, 300V Center Spacing: 0.197” (5.00mm) Housing Material: Black UL 94V0 Thermoplastic Contact Material: Tin-Plated Brass Operating Temperature: 120°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.059" (1.50mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified EM502506 EuroMag Series Terminal Blocks: Base & Rail Mount Dimensions - mm (in) L (mm) Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 0.05 DIA. (1.3) 0.197 (5.00) 0.49 (12.5) 0.08 (2.0) 0.11 (2.8) L 0.18 (4.5) Power Distribution Blocks Poles To convert to inches, divide by 25.4 WIRE ENTRY Wire Management Products ø1.50 (ø0.059") WIRE ENTRY PCB Hole Layout Mating orientations 580 (0.197") Edge Connectors, One-Sided Boards Part Numbering System Series # of Poles Mating Plug: EM5015 pg. 112 E M 5 0 2 5   02 to 24 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 113 EM5035 Series Euro-Mag Terminal Blocks Pluggable Block, Stackable (Mates with EM5045 Series) 5.00 Centers SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.197” (5.00mm) Wire Range: #16-24 AWG Housing Material: Black UL 94V0 Thermoplastic Contact Material: Tin-Plated Brass Wire Protector: Phosphor Bronze, Tin-Plated Screw Size: M2.6 Chromatized Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 3.0 lb-in. Construction: Modular design features doveails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Wire Management Products Edge Connectors, One-Sided Boards EM503503 EM503502 Shown with EM5045series header - order seperately Dimensions - mm (in) 2.5±0.3 [0.098] 5.0±0.1 [0.197] 6.2±0.3 [0.244] Poles L (mm) Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row EuroMag Series PCB Mount Pluggable Terminal Blocks 5.00 [0.197] 12.5±0.3 [0.492] L ±0.5 3.50 [0.138] 4.40 [0.173] 10.5±0.3 [0.413] 12.5±0.3 [0.492] 1.30 [0.051] 3.0 [0.118] 2.20 [0.087] 14.8±0.3 [0.583] To convert to inches, divide by 25.4 Part Numbering System Series # of Poles Mating Plug: EM5045 pg. 115 E M 5 03 5    Compliance References 02 to 24 114 For additional product information, visit www.cooperbussmann.com/magnum 3.50 [0.138] EuroMag Series PCB Mount Pluggable Terminal Blocks EM504513 EuroMag Series Dimensions - mm (in) L ±0.5 Ø1.12 [Ø0.044] 16.5±0.3 [0.650] Poles L (mm) Poles L (mm) 2.5±0.3 [0.098] 5.0 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 14 15 16 17 18 19 20 21 22 23 24 65.0 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 2.7±0.3 [0.106] 5.0±0.1 [0.197] PCB Hole Layout 5.0±0.1 [0.197] Ø1.20 [Ø0.047] Wire Management Products To convert to inches, divide by 25.4 Edge Connectors, One-Sided Boards Part Numbering System Series Power Distribution Blocks 2 3 4 5 6 7 8 9 10 11 12 13 Ø1.0±0.1 [Ø0.039] Terminal Blocks: Base & Rail Mount 1.7±0.2 [0.067] SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.197” (5.00mm) Housing Material: Black UL 94V0 Thermoplastic Contact Material: Tin-Plated Brass Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Recommended PCB Hole Diameters: 0.059" (1.50mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified Terminal Blocks: Single & Double Row EM5045 Series Euro-Mag Terminal Blocks Header (Mates with EM5035 Series); 5.00 Centers # of Poles E M 5 0 4 5   02 to 24 Compliance References For additional product information, visit www.cooperbussmann.com/magnum 115 Series NDN Rail Mount Terminal Blocks 35mm DIN Rail Compatible SPECIFICATIONS High Density Design: Up to 48 circuits per foot Clamping Collar: Secures wires Large, Captive, Wire-Ready Screws: Speeds assembly Snap-on Installation to DIN Rail: Fast, easy assembly Fully Shielded Construction: 600V spacings Unique One-Piece Construction: Increases reliability Thermoplastic Moldings: Strong and impact resistant Material: UL Recognized 94V2 thermoplastic Collars: Heat treated stainless steel Terminals: Tin plated copper alloy Screws: zinc-plated steel Agency Information: UL/CSA; CE Certified NDNF1 Single pole fuse holding rail mount terminal block accepts 13/32" x 1-1/2" fuses Compliance References Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Rail Mount Terminal Blocks and Accessories NDN1/NDN111 Heavy-duty 90 Amp block NDN63 Accepts wires larger than standard control circuits NDN3 Space saving 3-pole unit NDNA200 Universal aluminum 35mm DIN mounting rail NDNV4 High Density 48 circuits per foot Series NDN Terminal Block Accessories NDNA 35mm DIN Rail Aluminum NDNA 100 1 meter NDNA 200 2 meters 116 NDNAS 35mm DIN Rail End Stop NFTA C-Rail Aluminum Lengths to 72" NRA C-Rail Low Profile No Flange Aluminum Lengths to 37-1/2" SOA72 72" Long Stand-Off Channel For C-Rail MARKING TAPE See Series Specifications For additional product information, visit www.cooperbussmann.com/magnum JUMPERS See Series Specifications Rail Mount Terminal Blocks and Accessories Terminal Blocks: Single & Double Row Rail Mount Terminal Blocks NDN63 Dimensions - in (mm) 1.50 (38.10) EuroMag Series SPECIFICATIONS: Rating: 65A, 600V Center Spacing: 0.375" (9.52mm) Number of Poles: 3 Circuits Per Foot: 30 Circuit Jumper: JN3, 2 circuits Wire Range: AWG #6-18 CU Screw Size: #10-32 Mounting Options: 35mm DIN rail, C-rail Marking Tape: MT12-1-2 Torque Rating: 35 lb-in Operating Temperature: 105°C Agency Information: UL File E62622, CSA File 15364 1.67 (42.41) 1.45 (36.83) 1.17 (29.71) Terminal Blocks: Base & Rail Mount NDN1 Dimensions - in (mm) 1.32 (33.68) 1.71 (43.48) 0.59 (14.99) 1.43 (36.31) Wire Management Products Dovetail Option Power Distribution Blocks SPECIFICATIONS: Rating: 90A, 600V Center Spacing: 0.635" (16.13mm) Number of Poles: 1 Circuits Per Foot: 18 Wire Range: AWG #2-18 CU Screw Size: #1/4-28 Mounting Options: 35mm DIN rail, C-rail * Dove-tail option is available for mounting side-by-side. Order part no. NDN1A-WH Marking Tape: MT12-1-2 Torque Rating: 32 lb-in Operating Temperature: 105°C Agency Information: UL File E62622, CSA File 47235 NDN111 Dimensions - in (mm) Mtg. holes 0.18 (4.57) dia. 0.28 (7.11) c'bores 1.46 (37.13) 1.71 (43.48) Dovetail Option 0.62 (15.75) 1.87 (47.50) 1.44 (36.57) 117 Compliance References For additional product information, visit www.cooperbussmann.com/magnum Edge Connectors, One-Sided Boards SPECIFICATIONS: Rating: 90A, 600V Center Spacing: 0.635" (16.13mm) Number of Poles: 3 Circuits Per Foot: 18 Circuit Jumper: JN1, 2 circuits Wire Range: AWG #2-18 CU Screw Size: #1/4-28 Mounting Options: 35mm DIN rail, C-rail, Base Mount * Dove-tail option is available for mounting side-by-side. Order part no. NDN111-A Marking Tape: MT12-1-2 Torque Rating: 32 lb-in Operating Temperature: 105°C Agency Information: UL File E62622, CSA File 47235 Rail Mount Terminal Blocks NDNV4 SPECIFICATIONS: Rating: NDNV4 30A, 600V Center Spacing: 0.25" (6.35mm) Number of Poles: 4 Circuits Per Foot: 48 Circuit Jumper: JN4, 4 circuits Wire Range: AWG #10-22 CU Screw Size: #6-32 Mounting Options: 35mm DIN rail, C-rail Marking Tape: MTC6 Torque Rating: 18 lb-in Operating Temperature: 105°C Agency Information: UL File E62622, CSA File 15364 Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Rail Mount Terminal Blocks and Accessories Dimensions - in (mm) 1.00 (25.40) Marking Tape 1.67 1.47 1.23 (42.41) (37.33) (31.24) NDN3 SPECIFICATIONS: Rating: 30A - field wiring: 40A - factory wiring 600V Center Spacing: 0.300" (7.62mm) Number of Poles: 3 Circuits Per Foot: 38 Circuit Jumper: JNDN3, 2 circuits Wire Range: AWG #10-22 CU Screw Size: #6-32 Mounting Options: 35mm DIN rail, C-rail Marking Tape: MT12-1-2 Torque Rating: 18 lb-in Operating Temperature: 105°C Agency Information: UL File E62622, CSA File 15364 Dimensions - in (mm) Compliance References 1.47 (37.33) 1.67 (42.41) 0.94 (23.87) 118 1.31 (33.27) For additional product information, visit www.cooperbussmann.com/magnum 1.34 (34.04) Rail Mount Terminal Blocks and Accessories Rail Mount Terminal Blocks Terminal Blocks: Single & Double Row N512 Dimensions - in (mm) 2.40 (60.96) 1.09 (27.68) 0.88 (22.35) Terminal Blocks: Base & Rail Mount NFT2 Dimensions - in (mm) 0.07 (1.78) 0.60 (15.44) 1.29 (32.94) 0.93 (23.80) 0.36 (9.14) 1.68 (42.82) 1.23 (31.34) Wire Management Products 0.65 (16.51) NFT3 Edge Connectors, One-Sided Boards Dimensions - in (mm) 1.18 (29.97) 1.29 (32.94) 1.23 (31.37) For additional product information, visit www.cooperbussmann.com/magnum Compliance References SPECIFICATIONS: Rating: 40A, 600V 55A Factory Wired Center Spacing: 0.390" (9.91 mm) Number of Poles: 3 Circuits Per Foot: 28 Circuit Jumper: JN3, 2 circuits Wire Range: AWG #8-22 CU Screw Size: #8-32 Mounting Options: C-rail Marking Tape: MT12-1-2 Torque Rating: 18 lb-in Operating Temperature: 105°C Agency Information: UL File E62622, CSA File 47235 Power Distribution Blocks SPECIFICATIONS: Rating: 40A, 600V; 55A Factory Wired Center Spacing: 0.281" (7.13mm) Number of Poles: 2 Circuits Per Foot: 38 Circuit Jumper: JN2, 2 circuits Wire Range: AWG #8-22 CU Screw Size: #8-32 Mounting Options: C-rail Marking Tape: MT12-1-2 Torque Rating: 18 lb-in Operating Temperature: 105°C Agency Information: UL File E62622, CSA File 15364 EuroMag Series SPECIFICATIONS: Rating: 5A, 600V; 20A, 300V Center Spacing: 0.197" (5.00mm) Number of Poles: 12 Circuits Per Foot: 60 Circuit Jumper: JN512, 12 circuits Wire Range: AWG #12-22 CU Screw Size: #4-48 Mounting Options: C-rail, 15mm DIN rail Marking Tape: AT512 Torque Rating: 12 lb-in Operating Temperature: 105°C Agency Information: CSA File 15364 119 Compliance References Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Rail Mount Terminal Blocks and Accessories Rail & Base Mount Terminal Blocks NC3 SPECIFICATIONS: Rating: 175A, 600V Center Spacing: 1.06" (26.92mm) Number of Poles: 3 Circuits Per Foot: 11 Wire Range: 2/0-#14 CU/AL Screw Size: 5/16-24 Mounting Options: C-rail, Base Mount Marking Tape: MT12-1-2 Torque Rating: 45 lb-in Operating Temperature: 105°C Agency Information: UL File E62622, CSA File 15364 Dimensions - in (mm) 3.12 (79.38) 1.75 (44.45) 1.75 (44.45) 1.25 (31.75) 0.250 x 0.190" mtg. slots NSE3 SPECIFICATIONS: Rating: 115A, 600V Center Spacing: 1.06" (26.92mm) Number of Poles: 3 Circuits Per Foot: 11 Circuit Jumper: JNSE3, 2 circuits Wire Range: For use with wire crimped to ring terminal Screw Size: #1/4-28 Mounting Options: C-rail, Base Mount Marking Tape: MT12-1-2 Torque Rating: 32 lb-in Operating Temperature: 105°C Agency Information: UL File E62622, CSA File 15364 Dimensions - in (mm) 1.25 (31.75) 0.250 x 0.190 mtg. slots 1.75 (44.45) 1.53 (38.86) 3.12 (79.24) NSS3 SPECIFICATIONS: Rating: 30A, 600V Center Spacing: 0.385" (9.77mm) Number of Poles: 3 Circuits Per Foot: 28 Circuit Jumper: JNSS3, 2 circuits Wire Range: For use with wire crimped to ring terminal Screw Size: #6-32 Mounting Options: C-rail Marking Tape: MT12-1-2 Torque Rating: 12 lb-in Operating Temperature: 105°C Agency Information: UL File E62622, CSA File 15364 120 1.24 (31.50) For additional product information, visit www.cooperbussmann.com/magnum 1.25 (31.75) 1.32 (33.73) Deplugable Rail Mount Terminal Blocks Terminal Blocks: Single & Double Row Depluggable Rail Mount Terminal Blocks PLU3 Dimensions - in (mm) 1.25 (31.75) 0.59 (14.98) 1.25 (31.75) 1.79 (45.64) 1.25 (31.75) 1.85 (46.99) Terminal Blocks: Base & Rail Mount PLU1 Series Dimensions - in (mm) 1.85 (46.99) 1.48 (37.59) 1.87 (47.49) Power Distribution Blocks 1.25 (31.75) PSU1 Series Dimensions - in (mm) 1.93 (49.12) 1.48 (37.64) 0.625 (15.88) 0.43 (11.10) For additional product information, visit www.cooperbussmann.com/magnum 1.30 (33.00) 121 Compliance References 2.44 (62.10) Edge Connectors, One-Sided Boards SPECIFICATIONS: Rating: 45A*, 600V *45A rating achieved with ring terminal crimped to wire. Center Spacing: 0.625" (15.88 mm) Number of Poles: 1-3 Part Number: • PSU1 (1-pole) • PSU11 (2-pole) • PSU111 (3-pole) Circuits Per Foot: 19 Wire Range: For use with crimp on connectors only. Screw Size: #10-32 Mounting Options: C-rail, Stackable Marking Tape: MT12-1-2 Torque Rating: 24 lb-in Operating Temperature: 105°C Agency Information: UL File E62622, CSA File 15364 Wire Management Products SPECIFICATIONS: Rating: 70A, 600V Center Spacing: 0.625" (15.88mm) Number of Poles: 1-3 Part Numbers: • PLU1 (1-pole) • PLU11 (2-pole) • PLU111 (3-pole) Circuits Per Foot: 19 Circuit Jumper: JN1, 2 circuits Wire Range: AWG #4-18 CU Screw Size: #1/4-28 Mounting Options: C-rail, Stackable Marking Tape: MT12-1-2 Torque Rating: 32 lb-in Operating Temperature: 105°C Agency Information: UL File E62622, CSA File 15364 EuroMag Series SPECIFICATIONS: Rating: 40A, 600V Center Spacing: 0.390" (9.91mm) Number of Poles: 3 Circuits Per Foot: 28 Circuit Jumper: JN3, 2 circuits Wire Range: AWG #8-22 CU Screw Size: #8-32 Mounting Options: C-rail, Stackable Marking Tape: MT12-1-2 Torque Rating: 18 lb-in Operating Temperature: 105°C Agency Information: UL File E62622, CSA File 15364 Fuse Holding Rail Mount Terminal Blocks NDNF1 SPECIFICATIONS: Rating: 30A, 600V; UL/CSA Number Of Poles: 1 Fuse Size: 13/32" x 1-1/2" Circuit Jumper: JF1, 2 Circuits Wire Range: AWG #8-22 CU Mounting Options: 35mm DIN rail, C-rail Fuse Pullers: • PF1 (standard) • neon or incandescent bulb *LPF1 (lighted neon or incandescent bulb). Torque Rating: 18 lb-in Operating Temperature: 105°C Agency Information: CSA File 15364 Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Rail Mount Fuse Holding Terminal Blocks PF1 Fuse Puller Dimensions - in (mm) 1.93 (49.02) 0.62 (15.74) 0.46 (11.68) 2.00 (50.80) 1.25 (31.75) LPF1 Lighted Fuse Puller *Visual indicator for open fuse is neon or incandescent bulb, depending on voltage. Specify voltage required. NDND1 non-fused terminal block enables isolation of individual circuits for testing NDNLFD1 fused terminal block with visual indicator* for open fuse SPECIFICATIONS: Ratings: NDND1: 30A, 600V NDNFD1: 15A, 600V NDNLFD1: 15A, 600V Number of Poles: 1 Fuse size: 1/4" x 1-1/4" Circuit Jumper: JF1, 2 circuits Wire Range: AWG #8-22 CU Mounting Options: 35mm DIN rail, C-rail Marking Tape: MT12-1-2 Torque Rating: 18 lb-in Operating Temperature: 105°C Agency Information: CSA File 15364 Dimensions - in (mm) 2.31 (58.67) 1.25 (31.75) 2.06 (52.32) Compliance References Edge Connectors, One-Sided Boards Wire Management Products NDNFD1 fused terminal block 2.68 (68.07) *Visual indicator for open fuse is neon or incandescent bulb, depending on voltage. Specify voltage required. 122 For additional product information, visit www.cooperbussmann.com/magnum 0.62 (15.74) Quick Connect Terminal Blocks Terminal Blocks: Single & Double Row Quick Connect Terminal Blocks NTQ23 Dimensions - in (mm) 1.31 (33.32) 1.25 (31.75) 1.25 (31.75) 1.25 (31.75) Terminal Blocks: Base & Rail Mount BNQ21 Dimensions - in (mm) #BQE (end mtg. adaptor) #8 mtg. screw 0.56 (14.28) 1.47 (37.33) 1.41 (35.81) B A B Wire Management Products A BQE End Mounting Adapter Required (N+2) x 0.437 (N+1) x 0.437 N = Number of circuits BQQ41 Dimensions - in (mm) #BQE (end mtg. adaptor) #8 mtg. screw 0.56 (14.28) 1.47 (37.33) B A BQE End Mounting Adapter Required Compliance References 1.41 (35.81) A B (N+2) x 0.437 (N+1) x 0.437 N = Number of circuits For additional product information, visit www.cooperbussmann.com/magnum Edge Connectors, One-Sided Boards SPECIFICATIONS: Rating: 30A, 600V Center Spacing: 0.437" (11.10mm) Number of Poles: 1 Circuits Per Foot: 24 Wire Range: For use with quick connect terminals only. Quick Connects: 0.250" x 0.031" Mounting Options: Base Mount, Stackable; End Piece (Part No. BQE) is required for mounting. Mounting screws recommended every 8 circuits. Operating Temperature: 105°C Agency Information: UL File E62622, CSA File 15364 Power Distribution Blocks SPECIFICATIONS: Rating: 40A, 600V Center Spacing: 0.437" (11.10mm) Number of Poles: 1 Circuits Per Foot: 24 Wire Range: AWG #8-22 CU Screw Size: #8-32 Quick Connects: 0.250" x 0.031" Mounting Options: Base Mount Stackable; End Piece (Part No. BQE) is required for mounting. Mounting screws recommended every 8 circuits. Torque Rating: 18 lb-in Operating Temperature: 105°C Screw Size: #8-32 Agency Information: UL File E62622, CSA File 15364 EuroMag Series SPECIFICATIONS: Rating: 40A, 600V Center Spacing: 0.390" (9.91mm) Number of Poles: 3 Circuits Per Foot: 28 Wire Range: AWG #8-22 CU Screw Size: #8-32 Quick Connects: 0.250” x 0.031” Mounting Options: C-rail Marking Tape: MT12-1-2 Torque Rating: 18 lb-in Operating Temperature: 105°C 123 Base Mount Terminal Blocks EuroMag Series Terminal Blocks: Single & Double Row Base Mount Terminal Blocks KT3 SPECIFICATIONS: Rating: 40A, 600V Center Spacing: 0.390" (9.91mm) Number of Poles: 3 Circuits Per Foot: 28 Circuit Jumper: JN3, 2 circuits Wire Range: AWG #8-22 CU Screw Size: #8-32 Mounting Options: Base Mount, Stackable Marking Tape: MT12-1-2 Torque Rating: 18 lb-in Operating Temperature: 105°C Agency Information: UL File KAD End Mount Adapter Required E62622, CSA File 15364 Compliance References Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount KT3-A01 includes KAD Dimensions - in (mm) 1.87 (47.63) 1.25 (31.75) 0.25 (6.35) 1.22 (31.04) #8 screw clearance KAD end mtg. adapter 1.25 (31.75) 1.25 (31.75) 2.34 (59.51) KT4 SPECIFICATIONS: Rating: 30A, 600V Center Spacing: 0.25" (6.35mm) Number of Poles: 4 Part Number: •KT4-WH-A •KT4-WH-B Dimensions - in (mm) 0.98 (24.99) 0.62 (15.88) 0.37 (9.40) 1.26 (32.23) Note: When used in series must order A and B Circuits Per Foot: 48 Circuit Jumper: JN4, 4 circuits Wire Range: AWG #10-22 CU Screw Size: #6-32 Mounting Options: Base Mount Mounting screws recommended every 12 circuits Marking Tape: MTC6 Torque Rating: 18 lb-in Operating Temperature: 105°C Agency Information: UL File E62622, CSA File 15364 1.34 (34.04) PLK3 SPECIFICATIONS: Rating: 40A, 600V Center Spacing: 0.39" (9.91mm) Number of Poles: 3 Circuits Per Foot: 28 Circuit Jumper: JN3, 2 circuits Wire Range: AWG #8-22 CU Screw Size: #8-32 Mounting Options: Base Mount, Stackable; End Piece (Part No. KAD) is required for mounting. Mounting screws recommended every 15 circuits. Marking Tape: MT12-1-2 Torque Rating: 18 lb-in Operating Temperature: 105°C Agency Information: UL File E62622 124 Dimensions - in (mm) 1.46 (37.22) 0.56 (14.22) 1.79 (45.52) 1.84 (46.86) KAD End Mount Adapter Required For additional product information, visit www.cooperbussmann.com/magnum Disconnect Terminal Blocks Terminal Blocks: Single & Double Row Series 15188 Disconnect Terminal Blocks for 35mm DIN Rail Mount EuroMag Series SPECIFICATIONS Rating: 30A, 600V* Center Spacing: 0.375” (9.52mm) Wire Range: #12-16 AGW CU Screw Size: #6-32 zinc-plated philslot Number of Poles: 3- and 4-pole only Mounting: 35mm DIN Rail Optional End Stop NDNAS Jumpers: 2- through 4-pole available Materials: Molded Base: UL rated 94V-2 thermoplastic. Tin plated copper alloy contacts. Torque Rating: 12 lb-in Operating Temperature: 105°C Agency Information: UL File E62622, CSA File 47235 Terminal Blocks: Base & Rail Mount * 30A rating achieved with #10AWG wire crimped to ring terminal; 25A without. REVERSE WIRING DIRECTION 3 Pole = 1.19 (30.22) 4 Pole = 1.56 (39.62) IN-LINE WIRING DIRECTION 3 Pole = 1.19 (30.22) 4 Pole = 1.56 (39.62) 0.375 (9.52) 1.94 (49.27) Edge Connectors, One-Sided Boards Part Numbering System Series – Wiring    3 to 4 blank - inline R - reverse S - locking snap For additional product information, visit www.cooperbussmann.com/magnum Compliance References 1 5 1 8 8  Poles Wire Management Products 1.94 (49.27) 0.22 (5.58) Power Distribution Blocks Dimensions - in (mm) 125 Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Disconnect Terminal Blocks 15288 Series Disconnect Terminal Blocks for DIN Rail Mount 15288-R-STSS SPECIFICATIONS Rating: 65A, 600V* Center Spacing: 0.54” (13.7mm) Wire Range: #6-16 AWG Screw Size: #8-32 zinc-plated philslot Number of Poles: 3-pole only Mounting: 35mm DIN Rail Optional Accessories: Optional End Stop NDNAS (order optional accessories seperately) Materials: Molded Base: UL rated 94V2 thermoplastic. Tin-plated copper alloy contacts. Torque Rating: 20 lb-in (30 lb-in for 8AWG bare wire) Operating Temperature: 105°C (221°F) Agency Information: UL File E62622 *CSA rating achieved with #6AWG wire crimped to ring terminal 50A without. 15288-S Dimensions - in (mm) 1.70 (43.2) 2.30 (58.4) for ST option 0.54 (13.7) REVERSE WIRING DIRECTION Power Distribution Blocks 1.94 (49.27) Compliance References Edge Connectors, One-Sided Boards Wire Management Products 1.70 (43.2) INLINE WIRING DIRECTION 1.94 (49.27) Part Numbering System Series Wiring Options 1 5 2 8 8    blank - inline R - reverse S - snap ST - screw together SS - solid DIN rail snap 126 For additional product information, visit www.cooperbussmann.com/magnum Base Mount Double Row Terminal Blocks Series KU Base Mount Double Row Terminal Blocks Terminal Blocks: Single & Double Row SPECIFICATIONS Rating: 60A, 600V* Center Spacing: 0.625” (15.88mm) Number of Poles: 2- to 12-poles Wire Range: #6-22 AWG CU Screw Size: #10-32 Torque Rating: 20 lb-in. Distance Between Barriers: 0.437” (11.09mm) Mounting: Base mount Material: Molded base: Black, UL rated 94V1 Nuclear Grade Noryl Terminal plating: Nickel over brass Operating Temperature: 105°C max. Agency Information: UL File E62622, CSA File 47235 KUXSC Series EuroMag Series KUX Series Dimensions - in (mm) * 60A rating achieved with #6 copper wire crimped to ring terminal. B Poles A B KUX only A 02 03 04 05 06 07 08 09 10 11 12 2.50 3.12 3.75 4.37 5.00 5.62 6.25 6.87 7.50 8.12 8.75 1.62 2.25 2.87 3.50 4.12 4.75 5.37 6.00 6.62 7.25 7.87 2.00 2.62 3.25 3.87 4.50 5.12 5.75 6.37 7.00 7.62 8.25 0.62 (15.9) 1.50 (38.1) 2.00 (50.8) #10 screw clearance 1.25 (31.8) 0.43 (11.1) Power Distribution Blocks 0.50 (12.7) * Dimensions in inches. To convert to millimeters, multiply by 25.4. A Part Numbering System Series Poles KU KUX KURL KUXRL -  standard block 02 to 12 short block standard w/removable link short block w/removable link Covers Marking Strip   WC - top cover & 2 end plates MT NU WC - top cover & 2 end plates PT - screws shipped bulk - brass washer head, nickel-plated P - steel screw w/pressure plate zinc-plated B - brass washer head, no plating BP - brass philslot, nickel-plated - matte finish - white - numbered 1 to 12, horizontal NUV - numbered 1 to 12, vertical PT - marker strip for cover Part Numbering System - SC Series KUSC - standard w/shortring strap & 4 shorting screws KUXSC - short block w/shorting strap & 4 shorting screws 02 to 12 00 W - screws shipped bulk - brass washer head, nickel-plated P - steel screw w/pressure plate zinc-plated B - brass washer head, no plating BP - brass philslot, nickel-plated - marker strip for cover Edge Connectors, One-Sided Boards  00 W Wire Management Products K U   Screw Options Terminal Blocks: Base & Rail Mount KU Accessories Compliance References MTMU## Molded Marking Tape - Matte Finish NUM## Molded Marking Tape JU12 Jumper - 12 Circuits NUE End Piece for NUC For additional product information, visit www.cooperbussmann.com/magnum NUC## Cover 127 EuroMag Series Terminal Blocks: Single & Double Row Quick-Connect Power Distribution Blocks Series 11675 Quick-Connect Power Distribution Blocks SPECIFICATIONS Rating: 40A, 250V Poles: 2- to 6-poles with (3) 0.25" quick-connect terminals per pole Wire Range: #8-14 AWG CU Torque Rating: 18 lb-in. Operating Temperature: 150°C Design: Screw connections for field wiring. Quick connects reduce cost of internal wiring. Agency Information: UL File E62622, CSA File 47235 Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount Part Number 11675-2 11675-3 11675-4 11675-5 11675-6 Dimensions - in (mm) 0.20 (5.1) 0.56 (14.2) B 0.20 (5.08) I.D. eyelets 0.50 (12.7) 0.20 (5.1) dia. holes A 2.09 2.66 3.22 3.78 4.34 B 1.68 2.25 2.81 3.37 3.93 C 0.56 1.12 1.68 2.25 2.81 1.37 (34.79) D 1.15 1.71 2.28 2.84 3.40 0.76 (19.3) C 0.46 (11.7) A D 0.37 (9.4) 0.43 (11.0) 1.03 (26.1) * Dimensions in inches. To convert to millimeters, multiply by 25.4. Series 11725 Quick-Connect Power Distribution Blocks SPECIFICATIONS Rating: 70A, 600V Poles: 2-, 3- or 4-poles with (4) 0.25" quick-connect terminals per pole Wire Range: #2-14 AWG CU / #2-8 AWG AL Torque Rating: 45 lb-in. Operating Temperature: 150°C Design: Screw connections for field wiring. Quick connects reduce cost of internal wiring. Agency Information: UL File E62622, CSA File 47235 Part Number A B C D 11725-2 11725-3 11725-4 2.50 3.18 3.87 2.06 2.75 3.43 0.68 1.37 2.06 1.37 2.06 2.75 Dimensions - in (mm) 0.21 (5.3) 0.68 (17.3) Compliance References 0.19 (5.0) I.D. eyelets 0.62 (15.7) 0.19 (5.0) dia. holes 1.84 (46.7) 0.90 (22.9) C 0.56 (14.2) A D * Dimensions in inches. To convert to millimeters, multiply by 25.4. 128 B For additional product information, visit www.cooperbussmann.com/magnum 0.59 (15.0) 0.43 (10.9) 1.12 (28.4) Barrier Terminal Blocks Dead Front Terminal Blocks Terminal Blocks: Single & Double Row Series 14002 Barrier Terminal Blocks A B 14002-2 14002-3 14002-4 14002-5 14002-6 1.75 2.37 3.34 3.96 4.59 – – 1.59 2.21 2.84 1.25 (31.8) 1.50 (38.1) 0.96 (24.38) Terminal Blocks: Base & Rail Mount Part Number 0.75 (19.1) EuroMag Series SPECIFICATIONS Rating: 115A, 600V Poles: 2- to 6-poles Wire Range: #2-14 AWG CU / #2-8 AWG AL Torque Rating: 2-3, 50 lb-in; 4-6, 45 lb-in; 8, 40 lb-in; 10-14, 35 lb-in. Operating Temperature: 150°C Dimensions - in (mm) Marking: Marking strip optional, consult factory. Options: CP = pressure plate, rated 60A, 600V A 0.87 Q = quick-connect, rated 50A, 600V B (22.1) To order enter letter code in front of part number: ie; CP14002-2 Agency Information: UL File E62622, CSA File 47235 0.37 (9.4) 0.62 (15.74) 0.39 (9.90) A* 0.17 (4.3) dia. holes with .34 (8.6) dia. x 0.75 (19.1) deep c'bore Power Distribution Blocks * Dimensions in inches. To convert to millimeters, multiply by 25.4. Note: “A” dimension for 14002-2 & 14002-3 only. (14002-2 & 14002-3 have only two mounting holes.) Series 14004 Dead Front Terminal Blocks B 14004-2 14004-3 14004-4 14004-5 14004-6 14004-7 14004-8 14004-9 14004-10 14004-11 14004-12 1.81 2.31 2.81 3.31 3.81 4.31 4.81 5.31 5.81 6.31 6.81 1.43 1.93 2.43 2.93 3.43 3.93 4.43 4.93 5.43 5.93 6.43 Dimensions - in (mm) 0.65 (16.5) 0.50 (12.7) 0.21 (5.3) dia. holes 1.50 (38.1) 0.50 (12.7) 0.18 (4.8) B 0.75 (19.1) Compliance References A Edge Connectors, One-Sided Boards Part Number Wire Management Products SPECIFICATIONS Rating: 90A, 600V Poles: 2- to 12-poles Wire Range: #4-14 AWG CU / #4-8 AWG AL Torque Rating: Cu AWG AL AWG Lb-in 4-6 4-6 35 8 8 25 10-14 10-12 20 16-18* – 20 *Solid conductor only Operating Temperature: 75°C Marking: Marking strip optional, consult factory. Agency Information: UL File E62622, CSA File 47235 1.12 (28.4) A * Dimensions in inches. To convert to millimeters, multiply by 25.4. For additional product information, visit www.cooperbussmann.com/magnum 129 Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Splicer Terminal Blocks Series 160, 162, 163 & 165 Splicer Terminal Blocks SPECIFICATIONS Rating: To 620A, 600V; UL/CSA. See table. Materials: Molded material: Black, UL rated 94V0 thermoplastic Operating Temperature: 150°C Marking: Marker strip is optional, consult factory. Agency Information: UL 221592; General Industrial Class per UL 1059; CSA LR053787; CE Certified Covers: See page 134 Connector Material & Agency Ampacity Approvals Part Number Line Connection Load Connection *16000 *16003 *16005 16200 16201 16204 16301 16303 16306 16500 16504 2/0-#8CU-AL 250k cmil-#6CU only 350k cmil-#6CU/AL #2-#14CU, #2-#8AL 1/0-#14CU Only 2/0-#8CU-AL 250cmil-#6CU Only 350cmil-#6CU/AL 500cmil-#6CU/AL (2) 350cmil-#4CU/AL (2) 500Mcmil-#6CU/AL 2/0-#8CU-AL 250k cmil-#6CU only 350k cmil-#6CU/AL #2-#14CU, #2-#8AL 1/0-#14CU Only 2/0-#8CU-AL 250cmil-#6CU Only 350cmil-#6CU/AL 500cmil-#6CU/AL ((2) 350cmil-#4CU/AL (2) 500Mcmil-#6CU/AL AL-175A CU-255A AL-310A AL-115A CU-150A AL-175A CU-255A AL-310A AL-380A AL-620A AL-760A UL – UL – UL – UL/CSA UL/CSA UL/CSA UL/CSA UL/CSA UL/CSA UL/CSA UL/CSA * 160 Series Bases have mounting holes outside the barriers. Other bases (162 through 165) have mounting holes within barriers. See dimensional drawings. (2) Openings per pole. No. of Poles A B 2 3 4 4.12 5.37 6.62 3.62 4.87 6.12 Dimensions - in A 0.37 2.00 1.00 2.75 1.37 B 0.50 2.06 0.68 Series A B C 1-pole C 2-pole C 3-pole 162 163 165 2.87 4.00 5.50 2.25 3.37 4.75 1.06 1.98 3.12 1.87 3.60 5.81 2.68 5.21 8.50 G Series D E F G H J 162 163 165 1.75 3.32 3.12 0.81 1.62 2.68 0.53 0.97 1.56 0.31 0.31 0.37 0.84 0.87 1.37 0.31 0.35 0.62 Dimensions - in A B D A H G D B H F F E E C C E Compliance References 0.21 x 0.37 slots 0.26 dia. holes Dimensions - in Edge Connectors, One-Sided Boards 160 Series only 0.20 dia. hole w/ 0.40 dia. c'bore 162 Series 130 E J J MTG. HOLES 0.21 x 0.41 C'BORE 0.42 x 0.62 x 0.12 DEEP 163 Series For additional product information, visit www.cooperbussmann.com/magnum Power Distribution Blocks- Series PDBFS Mechanical • DIN rail or panel mount; PDBFS330 & PDBFS504 panel mount only • Captive termination screws; screws do not get misplaced • Wire ready: captive termination screws shipped backed out to save time on conductor installations • Sliding DIN rail latch for easy mounting • Single pole, gang mountable for multiple pole applications with interlocking dovetail accessory (optional) • Flammability, UL 94V0 • Tin-plated AL connectors suitable for CU conductors • Elongated hole for panel mounting; easier mounting with greater flexibility in matching up with drilled panel holes • Part 2A1279: Interlocking dovetail pin accessory One pin interlocks two units, two pins to interlock three units • DIN rail end anchors required to prevent damage to block when torquing Terminal Copper Conductor Capability Line Load Configuration Catalog Number (All Single Pole) Openings per Pole Amps Wire Range Wire Range Line Load Short-Circuit Current Rating Data Conductors Max Fuse Class & Amp** T RK1 RK5 AWG or kcmil AWG or kcmil LPJ JJS JJN LPS-RK LPN-RK FRS-R FRN-R 2/0 - 8 200 200 100 60 200kA 4 - 12 200 200 175† 175† 200† 200† 100† 100† 100† 60† 60† 60† 200kA 100kA 50kA 350 - 6 400 400 200 100 200kA 2-6 4-8 4 4 - 14 400 200† 175† 600 600† 200† 400 200† 175† 600 600† 200† 200† 100† 100† 400† 400† 100† 100† 30† 30† 200† 200† 30† 200kA 50kA 100kA 200kA 50kA 50kA 350 350 600 600 400 200 200kA 350 - 4 350 - 4 600 800 600 200 100kA 500 500 500 - 6 500 - 6 600 600 600 800* 800* 600 600 600 400 400 600 200 200kA 100kA 100kA PDBFS204 175A 2/0 - 8 AWG 70 - 10 mm2 2/0 - 8 AWG 70 - 10 mm2 2/0 - 8 PDBFS220 175A 2/0 - 8 AWG 70 - 10 mm2 4 - 14 AWG 25 - 2.5 mm2 2/0 - 8 PDBFS303 310A 350kcmil - 6 AWG 350kcmil - 6 AWG 150 - 16 mm2 150 - 16 mm2 350 - 6 PDBFS330 380A 500kcmil - 6 AWG 240 - 16 mm2 2 - 14 AWG 35 - 2.5 mm2 500 - 6 PDBFS377 570A 300kcmil - 4 AWG 150 - 12 mm2 4 - 14 AWG 25 - 2.5 mm2 PDBFS500 620A 350kcmil - 4 AWG 350kcmil - 4 AWG 185 - 12 mm2 185 - 12 mm2 PDBFS504 760A 500kcmil - 6 AWG 500kcmil - 6 AWG 240 - 16 mm2 240 - 16 mm2 300 300 - 4 4 - 14 2 - 14 SCCR Ampacities 75C per NEC® Table 310.16 and UL508A Table 28.1 *Class L 800A (KRP-C 800_SP) or less fuses suitable for this particular SCCR case. ** Class G 60A (SC-60) or less or Class CC 30A (LP-CC-30, FNQ-R-30, KTK-R-30) or less are suitable for all these SCCRs in this table. † Higher SCCR may be available, check latest datasheet 1149. For additional product information, visit www.cooperbussmann.com/magnum 131 Compliance References J Edge Connectors, One-Sided Boards Load Wire Management Products Line Power Distribution Blocks Series PDBFS Terminal Blocks: Base & Rail Mount Agency/Standards • UL Listed 1953, Guide QPQS, File E256146 • CSA Certified, Class 6228-01, File 15364 • CE component IEC 60947-7-1 • IEC 60529, IP-20 (Finger Safe) under specific wiring conditions Electrical • 600Vac or dc (UL 1953), 690Vac or dc (IEC) • IP-20 Finger Safe under specific conditions • Short-Circuit Current Ratings up to 200,000kA, see table • Ampacities up to 760 Amps • CU Wire range 14 AWG to 500 kcmil or 2.5 to 240 mm2 EuroMag Series Feature/Benefits • Enclosed, safer installation; IP-20 finger-safe under specific conditions • High Short-Circuit Current Ratings up to 200,000A: PDBs do not have to be the weak link in achieving high SCCR for an industrial control panel • Small footprint saves panel space • Listed to UL1953 which has minimum spacing requirements at 600V of at least 1” through air and 2” over surface required for feeders in UL UL508A Industrial Control Panels • For 2D CAD drawings visit www.cooperbussmann.com Terminal Blocks: Single & Double Row Series PDBFS Power Distribution Blocks Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Power Distribution Blocks Series 160, 162, 163 & 165 Power Distribution Blocks SPECIFICATIONS Rating: To 840A, 600V; UL/CSA. See table. Materials: Molded material: Black, UL rated 94V0 thermoplastic Operating Temperature: 150°C Marking: Marker strip is optional, consult factory. Agency Information: UL 221592; General Industrial Class per UL 1059; CSA LR053787; CE Certified Covers: See page 134 Part Number Line Connection *16021 *16023 16220 16321 16323 16325 16330 16332 2/0-#14CU,2/0-#8AL 350kcmil-#6CU/AL 2/0-#14CU, 2/0-#8AL 2/0-#14CU, 2/0-#8AL 350kcmil-#6CU/AL (2) 2/0-#14CU, 2/0-#8AL 500kcmil-#6CU/AL 350kcmil-#6CU/AL 16335 500kcmil-#6CU/AL 16370 350kcmil-#6CU/AL 16371 350kcmil-#6CU/AL 16372 350kcmil-#6CU/AL 16373 350kcmil-#6CU/AL 16375 600kcmil-#2CU/AL 16376 600cmil-#2CU/AL 16377 16528 (2) 16530 (2) (2) Connector Agency Material & Ampacity Approvals Load Connection 300kcmil-#4CU/AL 600kcmil-#2CU/AL 500kcmil-#6CU/AL #4-14CU, #4-#8AL (6) #4-14CU, #4-#12AL (4) #4-14CU, #4-#8AL (6) #4-14CU, #4-#8AL (6) #4-14CU, #4-#12AL (6) #4-14CU, #4-#8AL (6) #2-#14CU, #2-#12AL (3) #2-#14CU,#2-#8AL (2) 1/0-#14CU, 1/0-#8AL (3) #2-#14CU, #2-#8AL (2) 1/0-#14CU, 1/0-#8AL (12) #4-#14CU, #4-#12AL (6) #2-#14CU, #2-#8AL (3) 1/0-#14CU, 1/0-#8AL (21) #10-#14CU, #10AL (3) 1/0-#14CU/AL (14) #10-#14CU, #10AL (12) #4-#14CU, #4-#12AL (6) #2-#14CU, #2-8AL (3) #1/0-#14CU, 1/0-#8AL (12) #4-#14CU, #4-#12AL (4) 3/0-#6CU/AL (4) #4-#14CU/AL (12) #4-#14CU/AL (6) AL-175A AL-310A AL-175A AL-175A AL-310A AL-350A AL-380A AL-310A UL/CSA UL/CSA UL/CSA UL/CSA UL/CSA UL/CSA UL/CSA UL/CSA AL-380A AL-310A AL-310A UL/CSA UL/CSA UL/CSA UL/CSA AL-310A AL-310A UL/CSA UL/CSA AL-420A AL-420A UL/CSA UL/CSA AL-570A AL-840A UL/CSA UL/CSA AL-760A UL/CSA 160 Series only No. of Poles A B 2 3 4 4.12 5.37 6.62 3.62 4.87 6.12 A 0.21 x 0.37 slots 0.37 2.00 1.00 2.75 1.37 B 0.26 dia. holes 0.50 2.06 * 160 Series Bases have mounting holes outside the barriers. Other bases (162 through 165) have mounting holes within barriers. See dimensional drawings. () Openings per pole. Series A B C 1-pole C 2-pole C 3-pole 162 163 165 2.87 4.00 5.50 2.25 3.37 4.75 1.06 1.98 3.12 1.87 3.60 5.81 2.68 5.21 8.50 0.68 Series D E F G H J 162 163 165 1.75 3.32 3.12 0.81 1.62 2.68 0.53 0.97 1.56 0.31 0.31 0.37 0.84 0.87 1.37 0.31 0.35 0.62 A G A B D B G D H F F E E C Compliance References C E E J 0.20 dia. hole w/ 0.40 dia. c'bore J 132 MTG. HOLES 0.21 x 0.41 C'BORE 0.42 x 0.62 x 0.12 DEEP For additional product information, visit www.cooperbussmann.com/magnum Connector/Stud Power Distribution Blocks Terminal Blocks: Single & Double Row Series 162, 163 & 165 Connector/Stud Power Distribution Blocks Part Number Connector Material & Ampacity 1/4-20x3/4 Stud 1/4-20 Tapped hole (2) 1/4-20x1 Stud (1) 3/8-16x1 Stud (2) 3/8-16x15/8 Stud AL-175A AL-175A AL-380A AL-380A AL-760A UL UL UL/CSA UL/CSA UL/CSA 1/4-20x3⁄4 Stud 3/8-16x11/8 Stud 1/2-13x11/16 Stud (2) 1/4-20x 9/16 Stud (2) 3/8-16x17/16 Stud 1/2-13x1 Stud Cu-175A CU-250A CU-400A CU-310A CU-400A CU-600A UL UL/CSA UL/CSA UL/CSA UL/CSA UL/CSA Agency Approvals Terminal Blocks: Base & Rail Mount Connector to Stud 16280 2/0-#14CU/AL 16281 2/0-#14CU/AL 16378 500kcmil-#6CU/AL 16383 500kcmil-#6CU/AL (2) 500lcmil-#6CU/AL 16582 Stud to Stud 1/4-20x3⁄4 Stud 16290 3/8-16x11/8 Stud 16390 1/2-13x11/16 Stud 16394 3/8-16x17/16 Stud 16395 3/8-16x17/16 Stud 16591 1/2-13x1 Stud 16593 () Load Connection Line Connection EuroMag Series SPECIFICATIONS Rating: To 760A, 600V; UL/CSA. See table. Materials: Molded material: Black, UL rated 94V0 thermoplastic Operating Temperature: 150°C Marking: Marker strip is optional, consult factory. Agency Information: UL 221592; General Industrial Class per UL 1059; CSA LR053787; CE Certified Covers: See page 134 A Openings per pole. D Power Distribution Blocks B G H F Series A B C 1-pole C 2-pole C 3-pole E 162 163 165 2.87 4.00 5.50 2.25 3.37 4.75 1.06 1.98 3.10 1.87 3.60 5.79 2.68 5.21 8.48 Series D E F G H J 162 163 165 1.75 3.32 2.93 0.81 1.62 2.68 0.53 0.97 1.55 0.31 0.31 0.37 0.84 0.87 1.19 0.31 0.35 0.44 C E G Wire Management Products J MTG. HOLES 0.21 x 0.41 C'BORE 0.42 x 0.62 x 0.12 DEEP A B D H Edge Connectors, One-Sided Boards F E C E For additional product information, visit www.cooperbussmann.com/magnum J Compliance References 0.20 dia. hole w/ 0.40 dia. c'bore 133 Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Power Blocks Series EN Power Blocks 1.78" Centers SPECIFICATIONS Rating: 285A, 600V; UL/CSA Wire Range: Line Connection: #300MCM-#4 CU/AL Load Connection: (6) #6-14AWG CU (6) #8-14 AWG AL Material: Molded material; Black, UL rated 94V2 thermoplastic Poles: 1-3 Operating Temperature: 125°C Torque Rating: 200 lb-in. line terminal, 20 lb-in. load terminal Agency Information: UL File E62622, CSA File 47235 Covers: Not available Series A B EN61- (1-pole) EN62- (2-pole) EN63- (3-pole) 1.38 3.15 4.93 1.78 3.62 5.37 Dimensions - in (mm) 1.68 (42.67) A 0.50 (12.70) 0.20 x 0.37 mtg. slot Power Distribution Blocks 2.12 (53.84) B Part Numbering System Series C P B   160 162 165  1 2 3 4 - One Pole Block (162, 165 Series only) Two Pole Block Three Pole Block Four Pole Block (160 Series only) SUPPLIED WITH (4) #4 THREAD-CUTTING SCREWS ASSEMBLED AS SHOWN Covers (163 Series) Part Numbering System Series Compliance References - C P D B  -  1 - One Pole Block 2 - Two Pole Block 3 - Three Pole Block 4.14 TEXTURED SURFACE Edge Connectors, One-Sided Boards Wire Management Products Covers (160, 162, 165 Series) ® BUSS CPDB CPDB-1=2.10" CPDB-2=3.72" CPDB-3=5.34" Clear with write on surface 134 For additional product information, visit www.cooperbussmann.com/magnum Wire Management Products Terminal Blocks: Single & Double Row Photo Control Receptacle Series Wire Management Products EuroMag Series  3-pole, 3-wire receptacles for plug-in, locking type photo controls used in outdoor areas and roadway lighting.  Receptacle configuration, terminals and limiting dimensions are in accordance with Figure 3 of EE Pub. No. TDJ-146, NEMA Pub. No. SH 16-1962 and UL 773.  Wire types and sizes ranging from #12 AWG through 16 AWG rated at 600V with temperature ratings from 105° to 200°C. Consult factory for other wire colors.  Hook-up wires are an integral part of the assembly with lengths furnished to customer specification.  UL Recognized under file E65288 for a rating of 1kW or 1800VA for potentials up to 480V.  CSA certified under file LR21295 for 15 amps at 125V.  CE Certified. Terminal Blocks: Base & Rail Mount Dimensions - in 1.45 2.56 DIA. 0.55 A 0.08 BLACK (B) B Power Distribution Blocks 1.37 DIA. R RED (R) 1.93 1.37 DIA. 0.96 COM WHITE (COM) Wire Management Products "Z" (WIRE LENGTH IN INCHES) A Part Numbering System Series - Wire Type Wire Gauge Wire Length W     W - wire See Table I See Table II Dimension “Z”* * Min 4" TABLE I (Wire Type) Ass’y No. 13661-W3XX 13661-W4XX 13661-W5XX Min. of 26 Strands, Copper Conductor, 125°C-600V Crosslinked Polyethylene. Min. of 26 Strands, Copper Conductor, Silicone Rubber Insulation and Fiber Glass Braid Jacket, Nec. Type SFF-2(150°C) Min. of 26 Strands, Copper Conductor, Type TW, 105°C-600V Insulation (16 gauge only) Min. of 7 Strands, Copper Conductor of 0.0192 Silicone Rubber Insulation and Fiber Glass Braid Jacket, Nec. Type SF-2 (200°C) Min of 19 Strands, Copper Conductor, Type AWM. 105°C-600V Insulation Ass’y No. Wire Gauge 13661-W2XX 13661-W4XX 13661-W6XX 12 Gauge 14 Gauge 16 Gauge For additional product information, visit www.cooperbussmann.com/magnum 135 Compliance References 13661-W1XX 13661-W2XX Wire Description TABLE II (Wire Gauge) Edge Connectors, One-Sided Boards 1 3 6 6 1  Terminal Type Stud Type Junction Blocks Stud Type Junction Blocks (Non-Feed Thru) EuroMag Series Terminal Blocks: Single & Double Row Series C4559 & C6083 SPECIFICATIONS Rating: 30A, 600V Operating Temperature: 250°F (120°C) Standards: 2 to 16 steel studs with #10-24 threads on 0.750" centers and a “dog point” to guide nut onto thread. Torque Rating: 20 lb-in (25 lb-in). Marking: Numbers and arrows molded on top of barriers indicate terminals. Agency Information: CSA File 15364 0.84" (21.34) Dimensions - in (mm) 1.05" (26.67) Terminal Blocks: Base & Rail Mount A 0.75" (19.05) 1.12" (28.45) C C4559 0.31" (7.87) Mtg. holes 9/32"x 3/8" slot 0.375" (9.53) 0.375" (9.53) 0.75" (19.05) B 0.84" (21.34) #10-32 zinc plated steel studs 1.09" (27.69) 0ther series available with 0.750" centers: C6083 Power Distribution Blocks 0.31" (7.87) (A,B,C Dimensions are the same as C4559) B 2.25 (57.1) 3.00 (76.2) 3.75 (95.2) 4.50 (114.3) 5.25 (133.3) 6.00 (152.4) 6.75 (171.4) 7.50 (190.5) 8.25 (209.5) 9.00 (228.6) 9.75 (247.6) 10.50 (266.7) 11.25 (285.7) 12.00 (308.4) 12.75 (323.8) C 0.75 (19.0) 1.50 (38.1) 2.25 (57.1) 3.00 (76.2) 3.75 (95.2) 4.50 (114.3) 5.25 (133.3) 6.00 (152.4) 6.75 (171.4) 7.50 (190.5) 8.25 (209.5) 9.00 (288.6) 9.75 (247.6) 10.50 (266.7) 11.25 (285.7) Series C5237 & JB1032 SPECIFICATIONS Rating: UL: 30A, 300V; CSA: 30A, 600V. Operating Temperature: 250°F (120°C) Standards: 1 to 15 brass studs on 0.625" centers with #10-32 thread and a “dog point” to guide nut onto thread. Torque Rating: 20 lb-in (25 lb-in). Marking: Numbers and arrows molded on top of barriers indicate terminals. Agency Information: CSA File 15364 Wire Management Products Edge Connectors, One-Sided Boards Part No.-Poles A C4559-2 3.00 (76.2) C4559-3 3.75 (95.2) C4559-4 4.50 (114.3) C4559-5 5.25 (133.3) C4559-6 6.00 (152.4) C4559-7 6.75 (171.4) C4559-8 7.50 (190.5) C4559-9 8.25 (209.5) C4559-10 9.00 (228.6) C4559-11 9.75 (247.6) C4559-12 10.50 (266.7) C4559-13 11.25 (285.7) C4559-14 12.00 (308.4) C4559-15 12.75 (323.8) C4559-16 13.50 (342.9) 0.81" Dimensions - in (mm) 1.16" A 1.0" C 0.75" 0.375" 0.5" 0.625" 0.375" B Compliance References C5237 0.31" Mtg. holes 9/32"X3/8" slot 1.16" 0.31" JB1032-120-XX (No bosses between studs) (A,B,C Dimensions ars the same as C5237) 136 Part No.-Poles A C5237-1 2.00 (50.8) C5237-2 2.62 (66.7) C5237-3 3.25 (82.5) C5237-4 3.87 (98.4) C5237-5 4.50 (114.3) C5237-6 5.12 (130.8) C5237-7 5.75 (146.0) C5237-8 6.37 (161.9) C5237-9 7.00 (177.8) C5237-10 7.62 (193.7) C5237-11 8.25 (209.5) C5237-12 8.87 (225.4) C5237-13 9.50 (241.3) C5237-14 10.12 (257.2) C5237-15 10.75 (273.0) For additional product information, visit www.cooperbussmann.com/magnum B 1.25 (31.7) 1.87 (47.5) 2.50 (63.4) 3.12 (79.4) 3.75 (95.2) 4.37 (111.1) 5.00 (127.0) 5.62 (142.9) 6.25 (158.7) 6.87 (174.6) 7.50 (190.5) 8.12 (206.4) 8.75 (222.2) 9.37 (238.1) 10.00 (254.0) C – 0.625 (15.9) 1.25 (31.7) 1.87 (47.5) 2.50 (63.4) 3.12 (79.4) 3.75 (95.2) 4.37 (111.1) 5.00 (127.0) 5.62 (142.9) 6.25 (158.7) 6.87 (174.6) 7.50 (190.5) 8.12 (206.4) 8.75 (222.2) Stud Type Junction Blocks Stud Type Junction Blocks Terminal Blocks: Single & Double Row SPECIFICATIONS Material: Studs on non-feed-thrus are steel plated; feed-thrus are copper alloy. Applications: Heavy-duty ground or power connection points in AC or DC circuits. Feed-thru or stand alone mount options available for transformers, communication and computer power sections along with various vehicle electrical systems. Benefits: Modular design offers design and manufacturing flexibility. Dimensions - in (mm) F H J 0.75" (19.1) 0.75" (19.1) EuroMag Series Suggested Max. Termination Ratings: 1.87" (47.6) 1.12" (28.6) M (thread size) Thread/Stud Sz. Max. Amps #10 #1/4 & M6 #5/16 #3/8 #1/2 50 100 200 250 400 C B 1 C1925-1B* 1 C1925-2* 1 C1925-2B* 1 C1933 1 C1933-1 1 C1938* 2 C1938R* 2 C1938-1* 2 C1938-1R* 2 C2791* 3 C2791-R* 3 C2909* 3 C2909-1* 3 C4044* 2 C4044-1* 2 C4044-1R* 2 C5898* 2 C6344-2 2 C7018* 3 C7020* 2 JB3816-2 2 JB3816-3 2 *Feed-thru D 1.25 (31.7) 1.25 (31.7) 1.25 (31.7) 1.25 (31.7) 1.25 (31.7) 1.25 (31.7) 1.5 (38.1) 1.5 (38.1) .87 (22.2) .87 (22.2) .87 (22.2) .87 (22.2) .62 (15.9) .62 (15.9) .62 (15.9) .62 (15.9) .62 (15.9) .62 (15.9) .62 (15.9) .87 (22.2) .62 (15.9) .47 (11.9) .88 (22.2) .87 (22.2) .87 (22.2) E 1.12 (28.6) 1.12 (28.6) 1.12 (28.6) 1.12 (28.6) 1.12 (28.6) 1.12 (28.6) 1.12 (28.6) 1.12 (28.6) .69 (17.5) .69 (17.5) .69 (17.5) .69 (17.5) .69 (17.5) .69 (17.5) 1.0 (25.4) 1.0 (25.4) 1.12 (28.6) 1.12 (15.9) 1.12 (15.9) .69 (17.5) 1.12 (15.9) .69 (17.5) .69 (17.5) .69 (17.5) .69 (17.5) F .37 (9.5) .37 (9.5) .37 (9.5) .37 (9.5) .37 (9.5) .37 (9.5) .37 (9.5) .37 (9.5) .31 (7.9) .31 (7.9) .31 (7.9) .31 (7.9) .31 (7.9) .31 (7.9) .31 (7.9) .31 (7.9) .31 (7.9) .31 (7.9) .31 (7.9) .31 (7.9) .31 (7.9) .31 (7.9) .31 (8.0) .31 (7.9) .31 (7.9) G 1.12 (28.6) 1.12 (28.6) 1.12 (28.6) 1.12 (28.6) 1.12 (28.6) 1.12 (28.6) None None .94 (23.8) .94 (23.8) .94 (23.8) .94 (23.8) .69 (17.5) .69 (17.5) .69 (17.5) .69 (17.5) .94 (23.8) .94 (23.8) .94 (23.8) .94 (23.8) None .53 (13.5) 1.25 (31.8) None None H .19 (4.8) .19 (4.8) .19 (4.8) .19 (4.8) .19 (4.8) .19 (4.8) .19 (4.8) .19 (4.8) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) J .19 (4.8) .19 (4.8) .19 (4.8) .19 (4.8) .19 (4.8) .19 (4.8) None None .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) .06 (1.6) None .06 (1.6) .06 (1.6) None None K 2.0 (50.8) 2.0 (50.8) 2.0 (50.8) 2.0 (50.8) 2.0 (50.8) 2.0 (50.8) 2.0 (50.8) 2.0 (50.8) 1.31 (33.3) 1.31 (33.3) 1.31 (33.3) 1.31 (33.3) 1.31 (33.3) 1.31 (33.3) 1.31 (33.3) 1.31 (33.3) 1.31 (33.3) 1.31 (33.3) 1.31 (33.3) 1.31 (33.3) 1.31 (33.3) 1.31 (33.3) 1.31 (33.3) 1.37 (34.9) 1.37 (34.9) L .22 dia. w/.44 dia. C’bore x .16 deep .22 dia. w/.44 dia. C’bore x .16 deep .22 dia. w/.44 dia. C’bore x .16 deep .22 dia. w/.44 dia. C’bore x .16 deep .22 dia. w/.44 dia. C’bore x .16 deep .22 dia. w/.44 dia. C’bore x .16 deep .22 dia. .22 dia. L(2 MTG. HOLES) L(2 MTG. HOLES) Fig. 2 M Max. Torque (in-lb) 1/2-13 300 1/2-13 300 1/2-13 300 1/2-13 300 3/8-16 150 3/8-16 150 1/2-13 300 5/16-18 75 .22 dia. w/.41 dia. 3/8-16 C’bore x 14 deep .22 dia. w/.41 dia. 3/8-16 C’bore x 14 deep .22 dia. w/.41 dia. 5/16-18 C’bore x 14 deep .22 dia. w/.41 dia. 5/16-18 C’bore x 14 deep .22 dia. w/.41 dia. 1/4-20 C’bore x .14 deep .22 dia. w/.41 dia. 1/4-20 C’bore x .14 deep .22 dia. w/.41 dia. 10-32 C’bore x 14 deep .22 dia. w/.41 dia. 1/4-20 C’bore x 14 deep .22 dia. w/.41 dia. 3/8-16 C’bore x .14 deep .22 dia. w/.41 dia. 3/8-16 C’bore x .14 deep .22 dia. w/.41 dia. 3/8-16 C’bore x .14 deep .22 dia. w/.41 dia. 3/8-16 C’bore x .14 deep .22 dia. w/.41 dia. 1/2-20 C’bore x .14 deep .22 dia. w/.41 dia. M6 C’bore x 14 deep .22 dia. w/.41 dia. 3/8-16 C’bore x 14 deep .22 dia. w/.37 dia. 3/8-16 C’bore x .14 deep .22 dia. w/.37 dia. 3/8-16 C’bore x .14 deep 150 150 75 75 30 30 24 30 150 150 150 150 150 55 150 150 150 Fig. 3 Material Thermoplastic / Zinc-plated Brass Thermoplastic / Zinc-plated Brass Thermoplastic / Tin-plated Brass Thermoplastic / Tin-plated Brass Thermoplastic / Tin-plated Brass Thermoplastic / Tin-plated Brass Thermoplastic / Zinc-plated Brass Thermoplastic / Zinc-plated Brass Thermoplastic / Zinc-plated Brass Thermoplastic / Zinc-plated Brass Thermoplastic / Tin-plated Brass Thermoplastic / Tin-plated Brass Thermoplastic / Zinc-plated Brass Thermoplastic / Zinc-plated Brass Thermoplastic / Zinc-plated Brass Thermoplastic / Zinc-plated Brass Thermoplastic / Zinc-plated Brass Thermoplastic / Tin-plated Brass Thermoplastic / Tin-plated Brass Thermoplastic / Zinc-plated Brass Thermoplastic / Zinc-plated Steel Thermoplastic / Zinc-plated Steel Thermoplastic / Zinc-plated Brass Thermoplastic / Zinc-plated Sleel Thermoplastic / Zinc-plated Sleel Color Red Black Red Black Red Black Black Black Black Red Black Red Black Red Black Black Black Black Red Red Black Black Red Black Red Options – Nuts & washers; consult factory. For additional product information, visit www.cooperbussmann.com/magnum 137 Compliance References C1925-1* C 1.25 (31.7) 1.25 (31.7) 1.25 (31.7) 1.25 (31.7) 1.25 (31.7) 1.25 (31.7) 1.25 (31.7) 1.25 (31.7) .69 (17.5) .69 (17.5) .69 (17.5) .69 (17.5) .44 (11.2) .44 (11.2) .44 (11.2) .44 (11.2) .62 (15.9) .62 (15.9) .62 (15.9) .69 (17.5) .62 (15.9) .44 (11.2) .69 (17.5) .62 (15.9) .62 (15.9) Fig. 1 Edge Connectors, One-Sided Boards 1 B 1.5 (38.1) 1.5 (38.1) 1.5 (38.1) 1.5 (38.1) 1.5 (38.1) 1.5 (38.1) 1.44 (36.6) 1.44 (36.3) .94 (23.8) .94 (23.8) .94 (23.8) .94 (23.8) .69 (17.5) .69 (17.5) .69 (17.5) .69 (17.5) .87 (22.2) .87 (22.2) .87 (22.2) .94 (23.8) .87 (22.2) .69 (17.5) .94 (23.8) .98 (24.9) .98 (24.9) L (4 MTG. HOLES) Wire Management Products C1925B* A 2.75 (69.8) 2.75 (69.8) 2.75 (69.8) 2.75 (69.8) 2.75 (69.8) 2.75 (69.8) 2.75 (69.8) 2.75 (69.8) 2.06 (52.4) 2.06 (52.4) 2.06 (52.4) 2.06 (52.4) 2.06 (52.4) 2.06 (52.4) 2.06 (52.4) 2.06 (52.4) 2.06 (52.4) 2.06 (52.4) 2.06 (52.4) 2.06 (52.4) 2.06 (52.4) 2.06 (52.4) 2.06 (52.4) 2.12 (54.0) 2.12 (54.0) D Power Distribution Blocks Fig. 1 E K A K A A Terminal Blocks: Base & Rail Mount Part C1925* G K Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Power Feed Thru Terminal Blocks Series C7021 Power Feed Thru Terminal Block APPLICATIONS The C7021 terminal block is intended for use in applications requiring up to 175A utilizing a 2-hole compression lug on 5/8" centers. It is ideal for use as an input/output block for telecommunications power panels, or anywhere in which eliminating busbars would be an advantage. SPECIFICATIONS Ratings: 175A* per pole, 300V. Center Spacing: 0.690" (17.5mm) Wire Range: AWG #2/0-8 Material: UL 94V0 Thermoplastic Number of Poles: 2- to 6-pole Bolt Hole Spacing: 0.625" (15.88mm) Stud: Standard 1/4-20 stud or optional M6 stud. Mounting: Optional mounting ears. Stud Material: Brass, Tin-Plated. Torque Rating: 36 lb-in Operating Temperature: 130°C Accessories: Dead-Front covers (CSB7021-XX) Agency Information: UL File E62622 Dimensions - mm (in) Part No. Power Distribution Blocks *175 achieved using both studs in parallel, 115A using a single stud per line. C7021-01-X C7021-02-X C7021-03-X C7021-04-X C7021-05-X C7021-06-X C7021-01N-X C7021-02N-X C7021-03N-X C7021-04N-X C7021-05N-X C7021-06N-X A B C D E 17.5 (0.69) 34.9 (1.37) 52.3 (2.06) 69.8 (2.75) 87.2 (3.44) - 37 (1.45) 54.4 (2.14) 70.9 (2.83) 89.3 (3.52) 106.8 (4.20) 124.2 (4.89) 49.5 (1.95) 67.3 (2.65) 84.8 (3.34) 102.2 (4.02) 119.7 (4.71) 134.1 (5.40) 15 (0.6) 31.8 (1.25) 49.2 (1.94) 66.7 (2.63) 84.2 (3.31) 101.7 (4.00) 17.5 (0.69) 34.9 (0.69) 52.3 (2.06) 69.8 (2.75) 87.2 (3.44) 36.1 (1.42) 53.5 (2.11) 71.0 (2.80) 88.4 (3.48) 105.9 (4.17) - - 31.8 (1.25) 49.2 (1.94) 66.7 (2.63) 84.2 (3.31) 101.7 (4.00) D C 9.6 28.0 (0.38) (1.10) 15.8 (0.62) 5.4 (0.21) Wire Management Products 15.8 (0.62) 7.9 (0.31) Edge Connectors, One-Sided Boards 12.5 (0.49) Ø 9.0 TYP (0.35) 1/4-20 UNC-2A Thread TYP A ø12.2 TYP (0.48) B 17.5 TYP (0.69) 24.0 (0.94) 12.7 (0.50) 33.0 (1.30) 14.5 TYP (0.57) 30.0 (1.18) Blind Hole for #6 Thread Cutting Screw OPTION 2 POTION 1 14.5 TYP (0.57) OPTION 1 Part Numbering System Series Poles C 7 0 2 1 –   01 – 1 pole (2 studs) 02 – 2 pole (4 studs) 03 – 3 pole (6 studs) 04 – 4 pole (8 studs) 05 – 5 pole (10 studs) 06 – 6 pole (12 studs) 138 E 14.2 ( ø.56) A 15.0 TYP (0.59) Compliance References 55.7 (2.19) PANEL CUTOUTS Inches (Millimeters) Mount Ends  Studs Hardware  –  Blank – Mount ends N – No mount ends Blank – Standard M6 – M6 studs Blank – No hardware 0 – Bulk pack, one set 1 – Bulk pack, two sets 2 – Assembled, bottom 3 – Assembled, top 4 – Assembled, both sets For additional product information, visit www.cooperbussmann.com/magnum 1.6 (R.06) Power Feed Thru Terminal Blocks Terminal Blocks: Single & Double Row Series C7024 Power Feed Thru Terminal Block APPLICATIONS The C7024 terminal block is intended for use in applications requiring up to 115A utilizing a 2-hole compression lug on 3/4" centers. It is ideal for use as an input/output block for telecommunications power panels, or anywhere in which eliminating busbars would be an advantage. EuroMag Series SPECIFICATIONS Ratings: 115A per pole, 600V. Center Spacing: 0.75" (19.1mm) Material: UL 94V0 Thermoplastic Wire Range: AWG #28 Number of Poles: 1- to 12-poles Bolt Hole Spacing: 0.75" (19.1mm) Stud: Standard 1/4-28 stud Stud Material: Tin-Plated Bronze. Torque Rating: 36 lb-in Operating Temperature: 130°C Agency Information: UL File E62622 Dimensions - mm (in) Terminal Blocks: Base & Rail Mount Ø17.780 TYP [0.700] MIN. AT STUD PAD 13.2TYP [0.52] Power Distribution Blocks 0.5 TYP [0.02 ] Part Number “A” Dimension ±0.4(±0.02) “B” Dimension C7024-01 21.6(0.85) - 40.6(1.60) C7024-03 59.7(2.35) 38.10(1.500) C7024-04 78.7(3.10) 57.15±0.26(2.250±0.010) 19.05±0.08(0.750±0.003) 97.8(3.85) 76.2(3.00) C7024-06 116.8(4.60) 95.25±0.26(3.750±0.010) C7024-07 135.9(5.35) 114.30±0.38(5.250±0/015) C7024-08 154.9(6.10) 133.35±0.38(5.25±0.015) C7024-09 174.0(6.85) 152.40±0.38(6.00±0.015) C7024-10 193.0(7.60) 171.45±0.38(6.750±0.015) C7024-11 212.1(8.35) 190.50±0.38(7.500±0.015) C7024-12 231.1(9.10) 209.55±0.38(8.250±0.015) 28.0 [1.10] 17.8TYP [0.70] 2.70TYP [ 0.106 ] 3.16TYP [0.124] Ø14.4 [0.57] 19.06 ±0.08 [ 0.750 0.003] Edge Connectors, One-Sided Boards C7024-05 16.53TYP [0.651] Wire Management Products C7024-02 B A 40.6 [1.60] Part Numbering System Series Inches (Millimeters) Poles Compliance References C 7 0 2 4 –   01 – 12 For additional product information, visit www.cooperbussmann.com/magnum 139 Wire Management Products Power Distribution Blocks Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Depluggable PCB Mount Terminal Blocks Series 15133 Depluggable PCB Mount Terminal Blocks SPECIFICATIONS Rating: 20A, 300V Center Spacing: 0.375” or 3/8” (9.52mm) Wire Range: #12-22 AWG Number of Poles: 7- to 10-poles PC Board: For soldering to PCB (.00015” tin over copper flash) Material: Black, UL Rated 94V0 Thermoplastic Screws: #6-32 zinc-plated steel SEMS Torque Rating: 12 lb-in Terminals: 15133-XX-10-X – Tin or gold plated brass 15133-XX-20-X – Nickel-or gold-plated copper alloy plug terminal, tin-or gold-plated female terminal Operating Temperature: 221°F (105°C) Agency Information: UL File E62622 15133-06-20-T Dimensions - in (mm) 15133-XX-10-X 6 0.19 (4.8) APPLICATIONS The 15133 is a series of input/output circuit board connectors. Available in a 1-piece or 2-piece design, they stack side-by-side with self-aligning housings to prevent incorrect mating. Both designs feature an integral, living hinge cover that saves the labor of attaching a separate cover. The cover provides a dead front for prevention of electrical contact, yet it also has test probe holes for easy circuit testing. 0.25 (6.3) 0.37 (9.4) 0.81 (20.6) 0.83 (21.0) 0.875 (22.2) 0.03 (0.8) 0.06 (1.6) 0.04 (1.0) 0.16 (3.9) 0.44 (11.1) 0.70 (17.8) 15133-XX-20-X The 1-piece design is for applications not requiring deplugging the connector. It solders to the printed circuit board. Molded stand-offs ensure good solderability. 0.12 DIA. (3.17) 6 The 2-piece design enables quick connect and disconnect of several circuits at once. It allows fast board changing in the field without shutting down the entire system. The bottom section of the connector solders to the board. Male contacts are shrouded while the female has stand-offs; both are molded into the block. The top section of the connector plugs into the bottom section. 0.19 (4.8) 6 0.25 (6.4) 0.828 (21.0) 0.81 (20.6) Edge Connectors, One-Sided Boards 0.97 (24.6) 0.04 (1.0) 0.156 (3.96) 0.375 (9.52) Compliance References Part Numbering System Series 1 5 1 3 3   02 to 10 0.70 (17.8) Style –  1 - One piece 2 - Two piece Mounting  Terminal Plating – 0 - No mtg. holes  T - Tin G - Gold* * Consult Factory 140 0.02 (0.5) 0.52 (13.2) Inches (Millimeters) Poles – 0.062 (1.57) For additional product information, visit www.cooperbussmann.com/magnum Edge Connectors 1 Sided Boards/Vertical Mount Terminal Blocks: Single & Double Row Series 1384X Edge Connectors – 1 Sided Boards/Vertical Mount 13848-08G02B EuroMag Series SPECIFICATIONS Rating: 10A, 250V Center Spacing: 0.375” or 3/8” (9.52mm) Wire Range: #14-22 AWG CU; entry to PC board at 90° angle. Number of Poles: 4- to 16-poles PC Board: Edge contact accepts standard 1/16” (0.0625) PCB. Contacts: Cantilever design 0.02” thick phosphorus bronze with mating surface tin-plated (0.0002) over copper (0.00005). Terminals: Pressure plate terminals. Material: Black, UL Rated 94V0 Thermoplastic (125°C) Operating Temperature: -55°C to 105°C (212°F) Agency Information: CSA File 47235 13847-08TO2B Dimensions - in (mm) A B C Terminal Blocks: Base & Rail Mount Poles 13847 Series D A 2.25 2.62 3.00 3.37 3.75 4.12 4.50 4.87 5.25 5.62 6.00 6.37 6.75 1.87 2.25 2.62 3.00 3.37 3.75 4.12 4.50 4.87 5.25 5.62 6.00 6.37 1.12 1.50 1.87 2.25 2.62 3.00 3.37 3.75 4.12 4.50 4.87 5.25 5.62 1.53 1.90 2.28 2.65 3.03 3.40 3.78 4.15 4.53 4.90 5.28 5.65 6.03 C 0.89 (22.6) 0.15 (3.9) D Power Distribution Blocks 04 05 06 07 08 09 10 11 12 13 14 15 16 B 1.03 (26.2) 13848 Series * Dimensions in inches. To convert to millimeters, multiply by 25.4. Optional polarizing key (Part No. C5971) consult with factory. A B C Wire Management Products 0.15 (3.9) 1 1.03 (26.2) 2 3 4 5 6 11 12 13 14 15 D Ø.06 (Ø1.5) Part Numbering System Series Block Style 1 3 8 4   Inches (Millimeters) Poles –  Screw Style Block Color Special Options  0 2  B   T - Tin over copper G - Gold* 02 - #6-32 pan head. w/ SEMS wire clamp B - Black M - Marking strip Compliance References 7 - Flat mtg. ears 04 to 16 w/ 2 slots 8 - Mtg. ears w/2 standoffs with hole for mounting strip Terminal Plating * Consult Factory For additional product information, visit www.cooperbussmann.com/magnum Edge Connectors, One-Sided Boards Ø.09 (Ø 2.3) 141 Terminal Blocks: Base & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Edge Connectors 1 Sided Boards/Right Angle Mount Series 15104 Edge Connectors – 1 Sided Boards / Right Angle Mount 15104-082T2 SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.375” or 3/8” (9.52mm) Wire Range: #12-22 AWG CU Number of Poles: 6- to 28-poles Screw Size: #6-32 Torque Rating: 12 lb-in Terminals: Pressure plate terminals with screws set at 45° or 90° angle PC Board: Edge contact accepts standard 1/16” (0.0625) PCB Contacts: Tuning fork design of 0.021” thick phosphorus bronze with 0.0001” bright tin-plating Material: Black, UL Rated 94V0 Thermoplastic Operating Temperature: 95°C max. Agency Information: UL File E62622, CSA File 47235 15104-061T1 Poles A B C D E Board Width 06 08 10 12 14 16 18 20 22 24 26 28 3.00 3.75 4.50 5.25 6.00 6.75 7.50 8.25 9.00 9.75 10.50 11.25 2.62 3.37 4.12 4.87 5.62 6.37 7.12 7.87 8.62 9.37 10.12 10.87 2.00 2.75 3.50 4.25 5.00 5.75 6.50 7.25 8.00 8.75 9.50 10.25 2.16 2.91 3.66 4.41 5.16 5.91 6.66 7.41 8.16 8.91 9.66 10.41 2.36 3.11 3.86 4.61 5.36 6.11 6.86 7.61 8.36 9.11 9.86 10.61 1.99 2.74 3.49 4.24 4.99 5.74 6.49 7.23 7.98 8.73 9.48 10.23 Dimensions - in (mm) Wire Management Products Power Distribution Blocks 15104 Series A B 0.62 (15.7) 0.17 0.34 (4.3) (8.6) C D 0.56 (14.2) 1.31 (33.3) * Dimensions in inches. To convert to millimeters, multiply by 25.4. Integral standoffs for mounting marker strips - consult factory. 0.32 (8.1) 0.375 (9.53) E 0.17 (4.3) 0.15 (3.8) dia. hole Edge Connectors, One-Sided Boards Tolerance plus or minus 1/64 (0.4) 6-32 x 3/8 long terminal screw/pressure plate 45∞ Style Compliance References Part Numbering System Series 1 5 1 0 4  Poles –  06 to 28 (Increments of 2) Terminal Plating Screw    1 - 90° angle 2 - 45° angle T - Tin G - Gold* 1 - #6-32 pan head. w/wire clamp * Consult Factory 142 For additional product information, visit www.cooperbussmann.com/magnum Compliance References CLASS B Commercial appliances, including business equipment, electronic data processing equipment, etc. CLASS C General industrial, including machine tool controls, which can further be defined as equipment governed by UL508. Magnum Series CLASS A 151-300 Volts 301-600 Volts 51-150 Volts CLASS B 151-300 Volts Spacing Over Surface 51 - 150 151 - 300 301 - 600 0.50 0.75 1.00 0.75 1.25 2.00 51 - 150 151 - 300 301 - 600 0.06 0.09 0.38 0.06 0.09 0.50 51 - 150 151 - 300 301 - 600 0.13 0.25 0.38 0.25 0.38 0.50 51 - 300 301 - 600 0.06 0.19 0.13 0.38 301-600 Volts X X X 51-150 Volts CLASS C 151-300 Volts X CLASS D 51-300 301-600 Volts Volts X X X X X X X X X 301-600 Volts Edge Connectors, One-Sided Boards X X X X X X X X X X X X X X X X X For additional product information, visit www.cooperbussmann.com/magnum X X X 143 Compliance References A/CB1000 A/CB2000 LP2000 A/CB3000 LP3000 A/B4000 A/CB5000 7000 TB100 TB200 TB200HB TB300 TB400 51-150 Volts Spacing Through Air Wire Management Products CLASS D Industrial devices having limited ratings. Voltage Rating Power Distribution Blocks CLASS A Service equpment, including dead-front switchboards, panelboards, service entrance devices, etc. CE In 1998, Cooper Bussmann received CE certification on all Magnum products. For terminal blocks, CE is a self-certification mark applied to products that have met safety and performance requirements set forth by the European Union (EU). This mark is required for free movement of product in the European market. Terminal Blocks: Base & Rail Mount Application IEC Compliance Some Magnum Terminal Blocks comply with the requirements in IEC Publication 60947-7-1 Terminal Blocks for Copper Conductors. these blocks are concurrently recognized and certified under the UL Classification Program. Ratings, except where indicated, are concurrent with UL 1059. EuroMag Series UL1059 & CSA 22.2 No. 158 Voltage Rating Voltage ratings of terminal blocks are based on the minimum spacing between electrically conductive parts and a minimum withstand voltage. The spacings are measured under two conditions: 1) through air, defined as the shortest distance an arc must travel through an air path from one electrically conductive part to another at opposite polarity or from an electrically conductive part to a grounded surface; and 2) over surface, defined as the shortest distance an arc must travel as it tracks along the surface of an insulating material from one electrically conductive part to another at opposite polarity or from an electrically conductive part to a grounded surface. The withstand voltage, termed dielectric withstand, is dependent on the voltage rating. The value is 1000V plus twice the rated voltage for one minute. this is tested under both conditions listed above. The following chart shows the UL 1059 and CSA 22.2 No. 158 spacing requirements, in inches. Terminal Blocks: Single & Double Row Cooper Bussmann Compliance References Customer Satisfaction Team Available to answer questions regarding Magnum products Monday-Friday, 8:00 a.m. – 6:00 p.m. Central Time for all US time zones. Contact: • Phone: 636-527-3877 • Toll-free fax: 800-544-2570 • E-mail: busscustsat@cooperindustries.com C3 – the Enhanced, Online Cooper Customer Center Provides real time product availability, net pricing, order status & shipment tracking across six Cooper divisions: B-line, Bussmann, Crouse-hinds, Lighting, Power Systems & Wiring Devices. Call 877-995-5955 for log-in assistance. Available at: • www.cooperc3.com Application Engineering Technical assistance is available to all customers. Staffed by degreed electrical engineers, this application support is available Monday-Friday, 8:00 a.m. – 5:00 p.m. Central Time. Contact: • • • • Phone: 636-527-1270 Fax: 636-527-1607 E-mail: fusetech@cooperindustries.com Live Chat: www.cooperbussmann.com Online Resources Visit www.cooperbussmann.com for the following resources: • Product search & cross-reference • Product & technical materials • Solutions centers for information on topical issues including arc-flash, selective coordination & short-circuit current rating • Technical tools, like our arc-flash calculator © 2009 Cooper Bussmann St. Louis, MO 63178 636-394-2877 www.cooperbussmann.com Your Authorized Magnum Distributor is: Cooper Industries, Ltd. 600 Tra vis, Ste. 5800 Houston, TX 77002-1001 P: 713-209-8400 www.cooperindustries.com Reorder # 7001 0809 PDF Only
KU10-BPWCMT 价格&库存
很抱歉,暂时无法提供与“KU10-BPWCMT”相匹配的价格&库存,您可以联系我们找货
KU10-BPWCMT
  • 1+580.025361+75.06829
  • 10+426.2528310+55.16668
  • 25+387.9239225+50.20606
  • 50+365.6690650+47.32578
  • 100+348.14107100+45.05726
库存:89
