Series SE/SEI .250" (1/4") 6.35mm Center-to-Center Spacing
Single Row
Features:
Miniature Feed-Thru, Printed Circuit and Surface
Connection – SE Series miniature terminal blocks are
designed for applications requiring the compactness and
versatility of the SEI Series without full feed-thru insulation.
Barrier-Type Construction – Blocks are made of highimpact, break-resistant thermoplastic molding with integrally
mounted .116" diameter mounting holes. One thru 26
terminals on 1/4" center-to-center spacing.
Terminal Flexibility – External terminals available in two
No. 2-56 screw designs. Internal terminals include an .047"
diameter printed circuit pin, and turret-type solder pins.
Wire Sizes – No. 2-56 screws. UL recognized for No.
22AWG to No. 16AWG.
Recognition and Listing – UL recognized
Standoffs – SEPX and SEFX are now supplied with .020"
standoffs for ease in cleaning after soldering.
VARIATIONS
SEIPX
.047" dia.
printed
circuit pin,
external
screw
SEPX
.047" dia.
printed
circuit pin,
external
screw
.151
(3,84)
BARRIER STYLE
.198
(5,03)
SEPX, SEIPX
SEIFX
turret-type
solder pin
external
screw
SEIPCX
external
clamp
added to
SEIPX
.167
(4,24)
SEIFCX
external
clamp
added to
SEIFX
SEFCX
external
clamp
added to
SEFX
SEFX, SEIFX
printed circuit board design with .047" tinplated brass pin
tin-plated brass turret-type solder pin
External Terminal Designations
SEPX, SEFX,
SEIPX, SEIFX
SEPCX, SEFCX,
SEIPCX, SEIFCX
.198
(5,03)
SEPCX
external
clamp
added to
SEPX
Guide No. 22.2 No. 158, Report No. LR39186-1.
Internal Terminal Designations
.167
(4,24)
SEFX
turret-type
solder pin
external
screw
Recognized under the Components Program of
Underwriters Laboratories, Inc. Standard 1059,
Guide No. XCFR2, File No. E62557.
No. 2-56 plated steel* terminal
screw accepting up to No. 16
AWG wire
Nickel-plated brass surface
clamp with No. 2-56 plated
steel screw to eliminate lugging. Accepts
wire up to No. 16AWG
PC BOARD DRILLING DIMENSIONS
.250
Typ.
2-16 Terminals
T
Ø.064 (No. 52 Drill)
17 T
Terminals and Over
Ø.079 (No. 47 Drill)
.198
(5,03)
6
www.curtisind.com
Curtis Industries
A Division of Powers Holdings, Inc.
6SHci¿cDtionssuEMHcttocKDnJH.
Dimensions are shown for
reference purposes only.
SSeFi¿Fations:
Without
Mounting
Ends
Series SE/SEI With
Mounting Ends
Center-to-Center Spacing: .250" (6.35mm)
Wire Range: UL recognized for No. 22AWG to No. 16AWG.
Models SEIPX, SEIFX, SEPX and SEFX with standard No.
2-56 plated steel screws are UL recognized “for factory
wiring only.” Models SEPCX, SEFCX, SEIPCX and SEIFCX
are UL recognized “for ¿eld wiring” when ordered with
special No. 2-56 stainless steel screw.
No. of Terminals: 1 thru 26
Voltage Rating: UL & CSA – 150 volts – General Industrial
250 volts – Commercial
Appliance
Tightening Torque: Wire Clamp with stainless steel screw 3
in.-lbs.
Current Rating: 5 amps UL
Housing:
Material
Polyphenylene Oxide
Continuous Use
Temp. (UL Index)
110° C (230° F)
Flammability Rating
94V-0
Water Absorption
(24 hrs. % wt. gain) .06%
Chemical Resistance
Resistant to inorganic bases and
acids – for organic substances
contact factory for speci¿c
resistances.
Breakdown Voltage:
Terminal - Terminal
3,600 Typ.
Terminal - Ground
4,700 Typ.
Dimensions
Number
of
Terminals
A ± .031 Overall
Dimensions
(O.D.)
Inches
Inches
Metric
(mm)
C ± .031
Less Mounting
Positions
Metric
(mm)
Inches
1
.781
19.84
.500
12.70
.375
9.52
2
1.031
26.19
.750
19.05
.625
15.87
3
1.281
32.54 1.000
25.40
.875
22.22
4
1.531
38.89 1.250
31.75 1.125
28.57
5
1.781
45.24 1.500
38.10 1.375
34.92
6
2.031
51.59 1.750
44.45 1.625
41.27
7
2.281
57.94 2.000
50.80 1.875
47.62
8
2.531
64.29 2.250
57.15 2.125
53.97
9
2.781
70.64 2.500
63.50 2.375
60.32
10
3.031
76.99 2.750
69.85 2.625
66.67
3.281
83.34 3.000
76.20 2.875
73.02
3.531
89.69 3.250
82.55 3.125
79.37
13
3.781
96.04 3.500
88.90 3.375
85.72
14
4.031 102.39 3.750
95.25 3.625
92.07
15
4.281 108.74 4.000 101.60 3.875
98.42
16
4.531
17
4.781 121.44 4.500
114.30 4.375
111.12
117.47
115.09 4.250 107.95 4.125 104.77
18
5.031 127.79 4.750 120.65 4.625
SEI and SE Series terminal blocks are ordered by listing a
composite number made up of the model designation followed
by the number of poles required for the application.
Suffixes are used as follows:
R denotes model less mounting positions
* The SEPX and SEFX are made with .020" standoffs for ease
in cleaning after the soldering operation
19
5.281 134.14 5.000 127.00 4.875 123.82
5.531 140.49 5.250 133.35 5.125 130.17
21
5.781 146.84 5.500 139.70 5.375 136.52
22
6.031 153.19 5.750 146.05 5.625 142.87
23
6.281 159.54 6.000 152.40 5.875 149.22
24
6.531 165.89 6.250 158.75 6.125 155.57
Series SE/SEI Dimensions
25
6.781 172.24 6.500 165.10 6.375 161.92
26
7.031 178.59 6.750 171.45 6.625 168.27
NOTE: mm dim. are shown in parentheses
BARRIER STYLE
11
12
Single Row
How to Order
Metric
(mm)
B ± .031 Mounting
Dimensions
(M.D.)
Dimensions shown are ± 0.030"
“A” O.D.
.437
(11,11)
“B” M.D.
.116 Dia. Hole Both Ends
.120
Recommended MTG Screws
No. 2 BD. or PAN HD
No. 3 MAX RD HD
No. 4 MAX. FIL. HD
“C” Less End Mountings
.531
(13,48)
.890
(22,62)
.250
(6,35)
.250 Typ.
(6,35)
.145 Max. Lug Access
(3,68)
.171 Dia.
(4,34)
.192 Max. Lug Width
(4,87)
Dimensions are in inches and millimeters
unless otherwise speci¿ed.
Values in parentheses are metric equivalents.
Curtis Industries
1-800-657-0853
7
很抱歉,暂时无法提供与“SEFX-13”相匹配的价格&库存,您可以联系我们找货
