KU12-WMT
KU12-WMT
    EATON(伊顿)
    12 电路 0.625"(15.88mm) 阻隔块 连接器, 螺钉
KU12-WMT 数据手册
Series KU Base Mount Double Row Terminal Blocks GET CONNECTED WITH US SPECIFICATIONS Rating: 60A, 600V* Center Spacing: .625” (15.88 mm) Number of poles: 2 - 12 Wire Size: AWG #6 CU max. Screw Size: #10-32 brass nickel plated Torque Rating: 20 in/lb max. Distance Between Barriers: .437” (11.09 mm) Mounting: Base mount. For 35mm DIN rail mountable, consult factory. Material: Molded base: Black, UL rated 94V-0 thermoplastic. Terminal plating: Nickel over brass. Screws: Nickel plated brass. Operating Temperature: 105°C max. Approvals: UL E62622; CSA LR15364; CE Pending No. of Poles A KU B KUX only A 2 3 4 5 6 7 8 9 10 11 12 2.50 3.12 3.75 4.37 5.00 5.62 6.25 6.87 7.50 8.12 8.75 1.62 2.25 2.87 3.50 4.12 4.75 5.37 6.00 6.62 7.25 7.87 2.00 2.62 3.25 3.87 4.50 5.12 5.75 6.37 7.00 7.62 8.25 KUSC4 KU12 B .62 (15.88) 1.50 (38.10) 2.00 (50.80) #10 screw clearance 1.25 (31.75) .43 (11.09) Dimensions in inches. To convert to millimeters, multiply by 25.4. .50 (12.70) *60A rating achieved with #6 copper wire crimped to ring terminal A Part Numbering System Series Poles Screw Options Covers Marking Strip K■ U ■■■ ■ ■■ ■■ ■■ ■■■ 00 - screws shipped bulk W - brass washer head, nickel plated P - Steel screw w/pressure plate zinc plated B - brass washer head, no plating WC - Top cover & 2 end plates MT - Matte finish NU - Numbered 1 to 12, horizontal NUV - Numbered 1 to 12, vertical PT - Marker strip for cover KU KUX KUSC - Standard block 2 to 12 - Short block - Standard w/shorting strap & 4 shorting screws KURL - Standard w/removable link KUXSC - Short block w/shorting strap & 4 shorting screws KUXRL - Short block w/removable link Accessories MTMU## Molded Marking Tape Matte Finish NUM## Molded Marking Tape JU12 Jumper 12 Circuits NUE End Piece for NUC NUC## Cover BIF document: 1421 For complete specification data, call Bussmann Information Fax ~ 314.527.1450 14
KU12-WMT 价格&库存
很抱歉,暂时无法提供与“KU12-WMT”相匹配的价格&库存,您可以联系我们找货
