Edge Connectors - 1 Sided Boards/Right Angle Mount
Terminal Blocks:
Single Row
Series 15104
Edge Connectors – 1 Sided Boards / Right Angle Mount
15104-082T2
EuroMag Series
SPECIFICATIONS
Rating: 10A, 300V
Center Spacing: 0.375” or 3⁄8” (9.52mm)
Wire Range: #12-22 AWG Cu
Number of Poles: 6- to 28-poles
Screw Size: #6-32
Torque Rating: 12 lb-in
Terminals: Pressure plate terminals with screws set
at 45° or 90° angle
PC Board: Edge contact accepts standard 1⁄16” (0.0625) PCB
Contacts: Tuning fork design of 0.021” thick phosphorus
bronze with 0.0001” bright tin-plating
Material: Black, UL Rated 94V0 Thermoplastic
Operating Temperature: 95°C max.
Agency Information: UL File E62622, CSA File 47235
Edge Connectors,
One-Sided Boards
15104-061T1
Poles
A
B
C
D
E
Board
Width
06
08
10
12
14
16
18
24
26
28
3.00
3.75
4.50
5.25
6.00
6.75
7.50
8.25
9.00
9.75
10.50
11.25
2.62
3.37
4.12
4.87
5.62
6.37
7.12
7.87
8.62
9.37
10.12
10.87
2.00
2.75
3.50
4.25
5.00
5.75
6.50
7.25
8.00
8.75
9.50
10.25
2.16
2.91
3.66
4.41
5.16
5.91
6.66
7.41
8.16
8.91
9.66
10.41
2.36
3.11
3.86
4.61
5.36
6.11
6.86
7.61
8.36
9.11
9.86
10.61
1.99
2.74
3.49
4.24
4.99
5.74
6.49
7.23
7.98
8.73
9.48
10.23
Dimensions - in (mm)
15104 Series
A
B
Compliance
References
0.62
(15.7)
0.17 0.34
(4.3) (8.6)
C
D
0.56
(14.2)
1.31
(33.3)
* Dimensions in inches. To convert to millimeters, multiply by 25.4.
Integral standoffs for mounting marker strips - consult factory.
0.32
(8.1)
0.375
(9.53)
E
0.17
(4.3)
0.15 (3.8)
dia. hole
Tolerance plus or minus 1/64 (0.4)
6-32 x 3/8 long
terminal screw/pressure plate
45∞ Style
Part Numbering System
1n
5n
1n
0n
4
n
Series
Poles
Terminal
n
n
n
06 to 28 (Increments of 2)
nn
1 - 90° angle
2 - 45° angle
T - Tin
G - Gold*
1 - #6-32 pan head. w/wire clamp
Plating
Screw
* Consult Factory
For additional product information, visit www.eaton.com/connectors
109
很抱歉,暂时无法提供与“15104-161T1-GA”相匹配的价格&库存,您可以联系我们找货
