15104-182G1
15104-182G1
    EATON(伊顿)
15104-182G1 数据手册
Edge Connectors - 1 Sided Boards/Right Angle Mount Terminal Blocks: Single Row Series 15104 Edge Connectors – 1 Sided Boards / Right Angle Mount 15104-082T2 EuroMag Series SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.375” or 3⁄8” (9.52mm) Wire Range: #12-22 AWG Cu Number of Poles: 6- to 28-poles Screw Size: #6-32 Torque Rating: 12 lb-in Terminals: Pressure plate terminals with screws set at 45° or 90° angle PC Board: Edge contact accepts standard 1⁄16” (0.0625) PCB Contacts: Tuning fork design of 0.021” thick phosphorus bronze with 0.0001” bright tin-plating Material: Black, UL Rated 94V0 Thermoplastic Operating Temperature: 95°C max. Agency Information: UL File E62622, CSA File 47235 Edge Connectors, One-Sided Boards 15104-061T1 Poles A B C D E Board Width 06 08 10 12 14 16 18 20 22 24 26 28 3.00 3.75 4.50 5.25 6.00 6.75 7.50 8.25 9.00 9.75 10.50 11.25 2.62 3.37 4.12 4.87 5.62 6.37 7.12 7.87 8.62 9.37 10.12 10.87 2.00 2.75 3.50 4.25 5.00 5.75 6.50 7.25 8.00 8.75 9.50 10.25 2.16 2.91 3.66 4.41 5.16 5.91 6.66 7.41 8.16 8.91 9.66 10.41 2.36 3.11 3.86 4.61 5.36 6.11 6.86 7.61 8.36 9.11 9.86 10.61 1.99 2.74 3.49 4.24 4.99 5.74 6.49 7.23 7.98 8.73 9.48 10.23 Dimensions - in (mm) 15104 Series A B Compliance References 0.62 (15.7) 0.17 0.34 (4.3) (8.6) C D 0.56 (14.2) 1.31 (33.3) * Dimensions in inches. To convert to millimeters, multiply by 25.4. Integral standoffs for mounting marker strips - consult factory. 0.32 (8.1) 0.375 (9.53) E 0.17 (4.3) 0.15 (3.8) dia. hole Tolerance plus or minus 1/64 (0.4) 6-32 x 3/8 long terminal screw/pressure plate 45∞ Style Part Numbering System 1n 5n 1n 0n 4 n Series – Poles Terminal n n n 06 to 28 (Increments of 2) nn 1 - 90° angle 2 - 45° angle T - Tin G - Gold* 1 - #6-32 pan head. w/wire clamp Plating Screw * Consult Factory For additional product information, visit www.eaton.com/connectors 109
15104-182G1 价格&库存
很抱歉,暂时无法提供与“15104-182G1”相匹配的价格&库存,您可以联系我们找货
15104-182G1
  • 1+1705.441441+213.41796
  • 5+1508.015535+188.71220
  • 10+1422.1792710+177.97070
  • 17+1385.3754017+173.36508
库存:20
