A20740207CARC
A20740207CARC
    EATON(伊顿)
    CONNBARRIERSTRIP2CIRC0.375"
A20740207CARC 数据手册
Edge Connectors, One-Sided Boards EuroMag Series Terminal Blocks: Single Row Terminal Blocks - Single Row Series A2000, LP2000 & CB2000 Single Row Terminal Blocks A20110807WR SPECIFICATIONS 30A, 300V* Rating: A2: LP2: 30A, 150V* CB2: 30A, 300V* Center Spacing: 0.375” or 3/8” (9.52mm) Wire Range: #12-22 AWG Cu Screw Size: #6-32 zinc-plated philslot LP202110 Torque Rating: 9 lb-in. Base: Standoffs standard for easy flux washing Distance Between Barriers: 0.32” (8.1mm) Recommended PCB Hole Diameter: 0.076” (1.93mm) Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Molded Material: Black, UL Rated 94V0 Thermoplastic Breakdown Voltage: 3400V (A2 & LP2); 4100V (CB2). Agency Information: UL File E62622, CSA File 47235; IEC Compliance; CE Certified *30A Rating achieved with a #10 copper wire crimped to a ring terminal.; 20A Rating without ring terminal. Dimensions - in (mm) A2000 & LP2000 Series Poles Compliance References CB20210507 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 MOUNTING ENDS ONLY A C Mount Ctrs. Length 1.13 1.50 1.88 2.25 2.63 3.00 3.38 3.75 4.13 4.50 4.88 5.25 5.63 6.00 6.38 6.75 7.13 7.50 7.88 8.25 8.63 9.00 9.38 9.75 10.13 10.50 10.88 11.25 11.63 – – 1.56 1.93 2.30 2.68 3.06 3.43 3.81 4.18 4.56 4.93 5.31 5.69 6.06 6.43 6.81 7.18 7.56 7.93 8.31 8.68 9.06 9.43 9.81 10.18 10.56 10.93 11.31 11.68 12.05 – – BARRIER & MOUNTING ENDS B Pole Ctrs. 0.38 0.75 1.13 1.50 1.88 2.25 2.63 3.00 3.38 3.75 4.13 4.50 4.88 5.25 5.63 6.00 6.38 6.75 7.13 7.50 7.88 8.25 8.63 9.00 9.38 9.75 10.13 10.50 10.88 11.25 11.63 BARRIER ENDS ONLY C Length 0.81 1.18 1.56 1.93 2.31 2.68 3.06 3.43 3.81 4.18 4.56 4.93 5.31 5.68 6.06 6.43 6.81 7.18 7.56 7.93 8.31 8.68 9.06 9.43 9.81 10.18 10.55 10.93 11.31 11.68 12.05 0.375 (9.53) 0.15 (3.8) Ø 0.65 (16.5) C Mount End Barrier End 0.76 (19.3) 0.565 (14.35) on LP2000 0.40 (10.2) 0.02 (0.5) B Pole Centers A Mount Centers Mount End Barrier End CB2000 Series 0.375 (9.53) 0.19 (4.8) Ø 0.32 (8.1) 0.70 (17.8) C Mount End Barrier End * Dimensions in inches. To convert to millimeters, multiply by 25.4. 0.60 (15.2) 0.02 (0.5) B Pole Centers A Mount Centers Mount End For additional product information, visit www.eaton.com/connectors Barrier End 8 Terminal Blocks - Single Row Terminal Blocks: Single Row Series A2000 & LP2000 Single Row Terminal Blocks Part Numbering System Terminal Style Base/End qq Poles q qq Options qqqq 1 - std. base/mnt. end 02 to 32 2 - std. base/barrier end 02 to 30 on mount 3 - insulator base/mnt. end end base 4 - insulator base/ barrier end 5 - closed base/ mount end 6 - closed base/ molded mount end qqq AB* - angle mnt. options (pg 11) A1 to A9 - 0.250˝ QC B1 to B9 - 0.187˝ QC DR* - drilled right angle (pg 11) L1 to L6 marking options (pg 25) MP* mounting plates (pg 11) RC* - retaining clips (pg 11) R30 to R77 - right angle bends (pg 11) S1* - solder lug/flat JA***, JB*** & JC*** - barrier jumpers OJ2*** & OJ4*** - over barrier jumpers (not available w/covers) Blank - std. screw 00 - screws shipped bulk 03* - stainless steel 04 - brass nickel-plated 07 - steel SEMS (not available with hardware options) 09* - brass SEMS nickel-plated (not available with hardware options) CA** - captive screw WR - wire ready (not available on LP2 series) Base/End Note: 6 style not available with covers. 5 & 6 Styles only available with 03 terminals. Covers - (pg 26) Terminal Styles Inches (Millimeters) 0.55 (14.0) 0.031 (0.79) 0.55 (14.0) 0.20 (5.1) 0.110 (2.79) 0.031 (0.79) 01 Handwired 0.062 (1.57) 03 Non Feed-Thru 0.54 (13.7) 0.11 (2.79) 0.055 (1.40) 0.14 (3.6) 0.031 (0.79) 0.33 (8.4) 0.72 (18.3) 0.42 (10.7) 0.031 (0.79) 0.250 (6.35) 0.031 (0.79) 09 0.250˝ QC short 0.30 (7.62) 0.31 (7.9) 0.187 (4.75) 10 0.187˝ QC 0.40 (10.2) 0.062 (1.57) 08 Printed Circuit 07 Extended Pin 06 Handwired 04 Wire Wrap Tail 0.17 (4.3) 0.032 (0.81) 0.062 (1.57) 0.031 (0.79) 02 Printed Circuit 0.30 (7.6) 0.031 (0.79) Compliance References *A2 only. **Not compatible with 03-stainless steel screws. ***Contact factory for configuration. 0.031 (0.79) 0.125 (3.2) 14 Printed Circuit 0.062 (1.57) 0.031 (0.79) 0.250 (6.35) 19 0.250˝ QC long For additional product information, visit www.eaton.com/connectors Edge Connectors, One-Sided Boards A2 - standard barrier 01* - handwired LP2 - low profile 02 - printed circuit barrier 03 - non feed-thru 04 - wire wrap tail 06 - handwired 07 - extended pin 08 - printed circuit 09 - 0.250˝ QC short 10 - 0.187˝ QC 14 - printed circuit 19 - 0.250˝ QC long Screw Options EuroMag Series An 2 n Ln P n 2 n Series 9 EuroMag Series Terminal Blocks: Single Row Terminal Blocks - Single Row Series A2000 & LP2000 Single Row Terminal Blocks Continued Screw Options Standard Zinc-plated Steel (F505-J) (Bulk ordering part numbers are in parentheses) 03 Stainless Steel (F507-J) FIG 1 Edge Connectors, One-Sided Boards Hardware Options 04 Brass Nickel-Plated (F506-J) WR Wire Ready 09 Brass SEMS Nickel-Plated (F524-J) Inches (Millimeters) (Bulk ordering part numbers are in parentheses) Jumpers Solder Lugs 07 Steel SEMS (F523-J) Quick Connects Blade Width A = 0.250” Blade Width B = 0.187” 0.68 (17.3) 0.33 (8.4) FIG 1 0.84 (21.2) FIG 2 FIG 1 †JA (JA2-02-J) S1 (2S1-J) †OJ2 (OJ2-J) A1 & B1 (2A1-J & 2B1-J) A2 & B2 (2A2-J & 2B2-J) A3 & B3 (2A3-J & 2B3-J) †OJ4 (OJ4-J) A4 & B4 (2A4-J & 2B4-J) A5 & B5 (2A5-J & 2B5-J) A6 & B6 (2A6-J & 2B6-J) A7 & B7 (2A7-J & 2B7-J) A8 & B8 (2A8-J & 2B8-J) A9 & B9 (2A9-J & 2B9-J) Compliance References 0.33 (8.4) FIG 2 FIG 3 FIG 2 †JB (JB2-02-J) FIG 1 0.33 (8.4) FIG 3 †JC (JC2-02-J) †Contact factory for configuration. FIG 2 FIG Base/End 1 Options FIG 1 FIG3 4 FIG FIG 2 Inches (Millimeters) Mount End Details B B FIG 4 FIG 3 FIG 2 - Standard base/barrier end FIG 45 1 - Standard base/mount end FIG 2 B B 0.180 (4.57) 0.150 Ø (3.8) mounting holes (2) FIG 3 0.218 (5.54) 0.30 (7.62) 0.30 (7.62) 3 - Insulator base/mount end FIG 5 FIG 4 FIG 3 5 - Closed base/mount end FIG 6 FIG 5 FIG 4 0.40 (10.2) 4 - Insulator base/barrier end FIG 6 FIG 5 0.40 (10.2) 0.095 (2.4) SECTION A–A SECTION B–B FIG 4 6 - Closed base/molded mount end 6 Molded Mount End FIG 6 For additional product information, visit www.eaton.com/connectors FIG 5 1, 3 & 5 Mount End 10 Terminal Blocks - Single Row Terminal Blocks: Single Row Series A2000 & LP2000 Single Row Terminal Blocks Continued Mounting Options Right Angle Bends (A2, LP2 only) 07 Terminal Bend Configurations EuroMag Series Right angle terminals are offered on the A2000 & LP2000 Series. Configurations are defined in these dimensions: X = pin extension beyond the block base; Z = length from block base to centerline of the terminal tip. Standard bends consist of the X and Z dimensions shown in the chart. Specify by adding the selected Bend Option Code to the terminal part number. Z 04 Terminal Bend Configurations 0.82 X Z Bend Option Code Bend Option Code X X (minimum) 0.04 0.01 0.02 0.05 0.08 0.12 0.14 0.16 Available w/insulator base 0.28 0.23 0.22 0.19 0.16 0.12 0.10 0.08 No No No No No No No No R30 R35 R36 R42 R46 R50 R53 R66 R69 R75 R77 0.04 0.01 0.02 0.08 0.12 0.16 0.19 0.32 0.35 0.41 0.43 Z Available w/insulator base 0.55 0.50 0.49 0.43 0.39 0.35 0.32 0.19 0.16 0.10 0.08 Yes Yes Yes Yes Yes No No No No No No Compliance References R30 R35 R36 R39 R42 R46 R48 R50 Z X (minimum) Dimensions in inches. To convert to millimeters, multiply by 25.4. Drilled Right Angle (A2, LP2 only) Angle Brackets (A2, LP2 only) 0.12 5 0.32 0.25 0.04 0.45 0.144 HOLE w/0.312 C' BORE 0.32 0.15 Option AB Angle brackets enable block to be fastened at right angles to normal mount position. Bulk part number 2AB-J. Option DR Counterbored holes across mount ends of block enable fastening with two screws at right angles to normal mount position. Mounting Plates Retaining Clip MOUNTING PLATE MP MT RETAINING CLIP Option MP Metal inserts with 0.150” dia. hole accept #6 screw. Bulk part number 2MP-J. Option RC Use on standoff tubes. Fit panels up to 0.125” thick. Two clips for every five positions. Supplied unassembled. Bulk part number H541-J. For additional product information, visit www.eaton.com/connectors Edge Connectors, One-Sided Boards 0.55 11 Terminal Blocks: Single Row Terminal Blocks - Single Row Series CB2000 Single Row Terminal Blocks Part Numbering System Cn Bn 2 n nn CB2 - closed back 01 - handwired 02 - printed circuit 07 - extended pin 14 - printed circuit Compliance References Edge Connectors, One-Sided Boards EuroMag Series Series Terminal Style Base/End Poles q Screws qq 1 - mount end 2 - barrier end Options qqq qqqq 02 to 32 02 to 30 on mount end base 07 - steel SEMS standard 09 - brass SEMS nickel-plated CA - captive screw 07CA - SEMS captive **Only available on 3-poles and up. ***Contact factory for configuration.. AB** - angle mounting brackets (pg 13) A7 to A9 - 0.250” QC B7 to B9 - 0.187” QC EB - exit back terminals EF - exit front terminals L1 to L6 marking options (pg 25) LT1 to LT6 marking options (pg 25) MP mtg. plates (pg 13) S1 - solder lug/flat JA***, JB*** & JC*** - barrier jumpers OJ2*** & OJ4*** - over barrier jumpers Covers - (pg 26) Terminal Styles 0.40 (10.2) 0.18 (4.6) 0.045 (1.14) 01 Handwired 07 Steel SEMS zinc-plated (B001-7084-J) 0.18 (4.6) 0.031 (0.79) 0.062 (1.57) 02 Printed Circuit Screw Options 0.125 (3.18) 0.70 (17.8) 0.19 (4.8 ) 0.031 (0.79) 0.120 (3.05) Inches (Millimeters) 0.031 (0.79) 0.18 (4.6) 0.045 (1.14) 07 Extended Pin 0.18 (4.6) 0.031 (0.79) 14 Printed Circuit (Bulk ordering part numbers are in parentheses) 09 Brass SEMS nickel-plated (F524-J) * NOTE: Wire ready screws standard on all terminal styles. CB2 Terminal Exit Options Inches (Millimeters) 0.255 (6.48) 0.18 (4.6) Exit Rear (std.) 0.18 (4.6) EF Exit Front X EB Exit Back For additional product information, visit www.eaton.com/connectors 12 Terminal Blocks - Single Row Hardware Options Inches (Millimeters) (Bulk ordering part numbers are in parentheses) Jumpers Solder Lugs Terminal Blocks: Single Row Series CB2000 Single Row Terminal Blocks Quick Connects Blade Width A = 0.250”. Blade Width B = 0.187”. 0.68 (17.3) 0.84 (21.2) S1 (2S1-J) †OJ2 (OJ2-J) †JA (JA2-XX-J) A7 & B7 (2A7-J & 2B7-J) A8 & B8 (2A8-J & 2B8-J) A9 & B9 (2A9-J & 2B9-J) EuroMag Series 0.33 (8.4) 0.33 (8.4) Edge Connectors, One-Sided Boards †JB (JB2-XX-J) †OJ4 (OJ4-J) 0.33 (8.4) †JC (JC2-XX-J) †Contact factory for configuration.. Compliance References Mounting Options Inches (Millimeters) Right Angle Mounting Bracket End Positions usable 0.71 (18.0) Snap-in Angle Bracket Chassis or PCB A #6 or #8 mounting screw & nut (Customer supplied.) 0.79 (20.1) 1.02 (25.8) Exit Back (EB) Terminals 0.24 (6.1) 0.45 (11.4) A 0.42 (10.7) Angle Bracket Mounts blocks on PC boards at a right angle. • Protects solder joints. • Recommended for all EB (Exit Back) PCB terminal blocks. • Bracket snaps securely on block (no hardware required). • Minimum strip length (end positions are usable). • Mount with #6-32 or #8-32 screws (not supplied). Option AB Mounting Plates MP MOUNTING PLATE Option MP MP Metal inserts with 0.150” dia. hole accept #6 screw. Bulk part number 2MP-J. MT MT8 For additional product information, visit www.eaton.com/connectors 13
A20740207CARC 价格&库存
很抱歉,暂时无法提供与“A20740207CARC”相匹配的价格&库存,您可以联系我们找货
