Edge Connectors,
One-Sided Boards
EuroMag Series
Terminal Blocks:
Single Row
Terminal Blocks - Single Row
Series A2000, LP2000 & CB2000
Single Row Terminal Blocks
A20110807WR
SPECIFICATIONS
30A, 300V*
Rating: A2:
LP2: 30A, 150V*
CB2: 30A, 300V*
Center Spacing: 0.375” or 3/8” (9.52mm)
Wire Range: #12-22 AWG Cu
Screw Size: #6-32 zinc-plated philslot
LP202110
Torque Rating: 9 lb-in.
Base: Standoffs standard for easy flux washing
Distance Between Barriers: 0.32” (8.1mm)
Recommended PCB Hole Diameter: 0.076” (1.93mm)
Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min.
Molded Material: Black, UL Rated 94V0 Thermoplastic
Breakdown Voltage: 3400V (A2 & LP2); 4100V (CB2).
Agency Information: UL File E62622, CSA File 47235;
IEC Compliance; CE Certified
*30A Rating achieved with a #10 copper wire crimped to a ring terminal.;
20A Rating without ring terminal.
Dimensions - in (mm)
A2000 & LP2000 Series
Poles
Compliance
References
CB20210507
02
03
04
05
06
07
08
09
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
31
32
MOUNTING
ENDS
ONLY
A
C
Mount Ctrs.
Length
1.13
1.50
1.88
2.25
2.63
3.00
3.38
3.75
4.13
4.50
4.88
5.25
5.63
6.00
6.38
6.75
7.13
7.50
7.88
8.25
8.63
9.00
9.38
9.75
10.13
10.50
10.88
11.25
11.63
1.56
1.93
2.30
2.68
3.06
3.43
3.81
4.18
4.56
4.93
5.31
5.69
6.06
6.43
6.81
7.18
7.56
7.93
8.31
8.68
9.06
9.43
9.81
10.18
10.56
10.93
11.31
11.68
12.05
BARRIER &
MOUNTING
ENDS
B
Pole Ctrs.
0.38
0.75
1.13
1.50
1.88
2.25
2.63
3.00
3.38
3.75
4.13
4.50
4.88
5.25
5.63
6.00
6.38
6.75
7.13
7.50
7.88
8.25
8.63
9.00
9.38
9.75
10.13
10.50
10.88
11.25
11.63
BARRIER
ENDS
ONLY
C
Length
0.81
1.18
1.56
1.93
2.31
2.68
3.06
3.43
3.81
4.18
4.56
4.93
5.31
5.68
6.06
6.43
6.81
7.18
7.56
7.93
8.31
8.68
9.06
9.43
9.81
10.18
10.55
10.93
11.31
11.68
12.05
0.375
(9.53)
0.15
(3.8)
Ø
0.65
(16.5)
C
Mount End
Barrier End
0.76 (19.3)
0.565 (14.35)
on LP2000
0.40
(10.2)
0.02
(0.5)
B Pole Centers
A Mount Centers
Mount End
Barrier End
CB2000 Series
0.375
(9.53)
0.19
(4.8)
Ø
0.32
(8.1)
0.70
(17.8)
C
Mount End
Barrier End
* Dimensions in inches. To convert to millimeters, multiply by 25.4.
0.60
(15.2)
0.02
(0.5)
B Pole Centers
A Mount Centers
Mount End
For additional product information, visit www.eaton.com/connectors
Barrier End
8
Terminal Blocks:
Single Row
Series A2000 & LP2000
Part Numbering System
Terminal Style
Base/End
qq
Poles
q
qq
Options
qqqq
1 - std. base/mnt. end 02 to 32
2 - std. base/barrier end 02 to 30 on mount
3 - insulator base/mnt. end
end base
4 - insulator base/
barrier end
5 - closed base/
mount end
6 - closed base/
molded mount end
qqq
AB* - angle mnt. options (pg 11)
A1 to A9 - 0.250˝ QC
B1 to B9 - 0.187˝ QC
DR* - drilled right angle (pg 11)
L1 to L6 marking options (pg 25)
MP* mounting plates (pg 11)
RC* - retaining clips (pg 11)
R30 to R77 - right angle bends (pg 11)
S1* - solder lug/flat
JA***, JB*** & JC*** - barrier jumpers
OJ2*** & OJ4*** - over barrier jumpers
(not available w/covers)
Blank - std. screw
00 - screws shipped bulk
03* - stainless steel
04 - brass nickel-plated
07 - steel SEMS
(not available
with hardware options)
09* - brass SEMS
nickel-plated
(not available with
hardware options)
CA** - captive screw
WR - wire ready
(not available on LP2
series)
Base/End Note: 6
style not available with
covers. 5 & 6 Styles
only available with 03
terminals.
Covers - (pg 26)
Terminal Styles
Inches (Millimeters)
0.55
(14.0)
0.031
(0.79)
0.55
(14.0)
0.20
(5.1)
0.110
(2.79)
0.031
(0.79)
01
Handwired
0.062
(1.57)
03
Non Feed-Thru
0.54
(13.7)
0.11
(2.79)
0.055
(1.40)
0.14
(3.6)
0.031
(0.79)
0.33
(8.4)
0.72
(18.3)
0.42
(10.7)
0.031
(0.79)
0.250
(6.35)
0.031
(0.79)
09
0.250˝ QC short
0.30
(7.62)
0.31
(7.9)
0.187
(4.75)
10
0.187˝ QC
0.40
(10.2)
0.062
(1.57)
08
Printed Circuit
07
Extended Pin
06
Handwired
04
Wire Wrap Tail
0.17
(4.3)
0.032
(0.81)
0.062
(1.57)
0.031
(0.79)
02
Printed Circuit
0.30
(7.6)
0.031
(0.79)
Compliance
References
*A2 only.
**Not compatible with 03-stainless steel screws.
***Contact factory for configuration.
0.031
(0.79)
0.125
(3.2)
14
Printed Circuit
0.062
(1.57)
0.031
(0.79)
0.250
(6.35)
19
0.250˝ QC long
Edge Connectors,
One-Sided Boards
A2 - standard barrier 01* - handwired
LP2 - low profile
02 - printed circuit
barrier
03 - non feed-thru
04 - wire wrap tail
06 - handwired
07 - extended pin
08 - printed circuit
09 - 0.250˝ QC short
10 - 0.187˝ QC
14 - printed circuit
19 - 0.250˝ QC long
Screw Options
EuroMag Series
An
2
n
Ln
P n
2
n
Series
9
EuroMag Series
Terminal Blocks:
Single Row
Single Row Terminal Blocks Continued
Screw Options
Standard
Zinc-plated Steel
(F505-J)
(Bulk ordering part numbers are in parentheses)
03
Stainless Steel
(F507-J)
FIG 1
Edge Connectors,
One-Sided Boards
Hardware Options
04
Brass
Nickel-Plated
(F506-J)
WR
Wire Ready
09
Brass SEMS
Nickel-Plated
(F524-J)
Jumpers
Solder Lugs
07
Steel SEMS
(F523-J)
Quick Connects
Blade Width A = 0.250” Blade Width B = 0.187”
0.68 (17.3)
0.33 (8.4)
FIG 1
0.84 (21.2)
FIG 2
FIG 1
†JA
(JA2-02-J)
S1
(2S1-J)
†OJ2
(OJ2-J)
A1 & B1
(2A1-J & 2B1-J)
A2 & B2
(2A2-J & 2B2-J)
A3 & B3
(2A3-J & 2B3-J)
†OJ4
(OJ4-J)
A4 & B4
(2A4-J & 2B4-J)
A5 & B5
(2A5-J & 2B5-J)
A6 & B6
(2A6-J & 2B6-J)
A7 & B7
(2A7-J & 2B7-J)
A8 & B8
(2A8-J & 2B8-J)
A9 & B9
(2A9-J & 2B9-J)
Compliance
References
0.33 (8.4)
FIG 2
FIG 3
FIG 2
†JB
(JB2-02-J)
FIG 1
0.33 (8.4)
FIG 3
†JC
(JC2-02-J)
†Contact factory for configuration.
FIG 2
FIG Base/End
1
Options
FIG 1
FIG3 4
FIG
FIG 2
Mount End Details
B
B
FIG 4
FIG 3
FIG
2 - Standard
base/barrier end
FIG
45
1 - Standard base/mount end
FIG 2
B
B
0.180 (4.57)
0.150 Ø (3.8)
mounting holes (2)
FIG 3
0.218 (5.54)
0.30
(7.62)
0.30
(7.62)
3 - Insulator base/mount end
FIG 5
FIG 4
FIG 3
5 - Closed base/mount end
FIG 6
FIG 5
FIG 4
0.40
(10.2)
4 - Insulator base/barrier end
FIG 6
FIG 5
0.40
(10.2)
0.095
(2.4)
SECTION A–A
SECTION B–B
FIG 4
6 - Closed base/molded mount end
6
Molded Mount End
FIG 6
FIG 5
1, 3 & 5
Mount End
10
Terminal Blocks:
Single Row
Mounting Options
Right Angle Bends (A2, LP2 only)
07 Terminal Bend Configurations
EuroMag Series
Right angle terminals are offered on the A2000 & LP2000 Series. Configurations
are defined in these dimensions: X = pin extension beyond the block base; Z
= length from block base to centerline of the terminal tip. Standard bends
consist of the X and Z dimensions shown in the chart. Specify by adding the
selected Bend Option Code to the terminal part number.
Z
04 Terminal Bend Configurations
0.82
X
Z
Bend
Option
Code
Bend
Option
Code
X
X
(minimum)
0.04
0.01
0.02
0.05
0.08
0.12
0.14
0.16
Available
w/insulator
base
0.28
0.23
0.22
0.19
0.16
0.12
0.10
0.08
No
No
No
No
No
No
No
No
R30
R35
R36
R42
R46
R50
R53
R66
R69
R75
R77
0.04
0.01
0.02
0.08
0.12
0.16
0.19
0.32
0.35
0.41
0.43
Z
Available
w/insulator
base
0.55
0.50
0.49
0.43
0.39
0.35
0.32
0.19
0.16
0.10
0.08
Yes
Yes
Yes
Yes
Yes
No
No
No
No
No
No
Compliance
References
R30
R35
R36
R39
R42
R46
R48
R50
Z
X
(minimum)
Drilled Right Angle (A2, LP2 only)
Angle Brackets (A2, LP2 only)
0.12
5
0.32
0.25
0.04
0.45
0.144 HOLE
w/0.312 C' BORE
0.32
0.15
Option AB
Angle brackets enable block to be fastened
at right angles to normal mount position.
Bulk part number 2AB-J.
Option DR
Counterbored holes across mount ends of
block enable fastening with two screws at
Mounting Plates
Retaining Clip
MOUNTING
PLATE
MP
MT
RETAINING CLIP
Option
MP Metal inserts with 0.150” dia. hole
accept #6 screw. Bulk part number 2MP-J.
Option RC
Use on standoff tubes. Fit panels up to
0.125” thick. Two clips for every five
positions. Supplied unassembled. Bulk part
number H541-J.
Edge Connectors,
One-Sided Boards
0.55
11
Terminal Blocks:
Single Row
Series CB2000
Cn
Bn
2
n
nn
CB2 - closed back
01 - handwired
07 - extended pin
Compliance
References
Edge Connectors,
One-Sided Boards
EuroMag Series
Series
Terminal Style
Base/End
Poles
q
Screws
qq
1 - mount end
2 - barrier end
Options
qqq
qqqq
02 to 32
02 to 30 on mount
end base
07 -
steel SEMS
standard
09 - brass SEMS
nickel-plated
CA - captive screw
07CA - SEMS captive
**Only available on 3-poles and up.
***Contact factory for configuration..
AB** - angle mounting brackets (pg 13)
A7 to A9 - 0.250” QC
B7 to B9 - 0.187” QC
EB - exit back terminals
EF - exit front terminals
LT1 to LT6 marking options (pg 25)
MP mtg. plates (pg 13)
S1 - solder lug/flat
Covers - (pg 26)
Terminal Styles
0.40
(10.2)
0.18
(4.6)
0.045
(1.14)
01
Handwired
07
Steel SEMS
zinc-plated
(B001-7084-J)
0.18
(4.6)
0.031
(0.79)
0.062
(1.57)
02
Printed Circuit
Screw Options
0.125
(3.18)
0.70
(17.8)
0.19
(4.8 )
0.031
(0.79)
0.120
(3.05)
0.031
(0.79)
0.18
(4.6)
0.045
(1.14)
07
Extended Pin
0.18
(4.6)
0.031
(0.79)
14
Printed Circuit
09
Brass SEMS
nickel-plated
(F524-J)
* NOTE: Wire ready screws standard on all terminal styles.
CB2 Terminal Exit Options
0.255
(6.48)
0.18
(4.6)
Exit Rear (std.)
0.18
(4.6)
EF Exit Front
X
EB Exit Back
12
Hardware Options
Jumpers
Solder Lugs
Terminal Blocks:
Single Row
Series CB2000
Quick Connects
Blade Width A = 0.250”. Blade Width B = 0.187”.
0.68 (17.3)
0.84 (21.2)
S1
(2S1-J)
†OJ2
(OJ2-J)
†JA
(JA2-XX-J)
A7 & B7
(2A7-J & 2B7-J)
A8 & B8
(2A8-J & 2B8-J)
A9 & B9
(2A9-J & 2B9-J)
EuroMag Series
0.33 (8.4)
0.33 (8.4)
Edge Connectors,
One-Sided Boards
†JB
(JB2-XX-J)
†OJ4
(OJ4-J)
0.33 (8.4)
†JC
(JC2-XX-J)
†Contact factory for configuration..
Compliance
References
Mounting Options
Right Angle Mounting Bracket
End Positions
usable
0.71
(18.0)
Snap-in Angle Bracket
Chassis
or PCB
A
#6 or #8
mounting
screw & nut
(Customer
supplied.)
0.79
(20.1)
1.02
(25.8)
Exit Back (EB)
Terminals
0.24
(6.1)
0.45
(11.4)
A
0.42
(10.7)
Angle
Bracket
Mounts blocks on PC boards at a right angle.
• Protects solder joints.
• Recommended for all EB (Exit Back) PCB terminal blocks.
• Bracket snaps securely on block (no hardware required).
• Minimum strip length (end positions are usable).
• Mount with #6-32 or #8-32 screws (not supplied).
Option AB
Mounting Plates
MP
MOUNTING
PLATE
Option MP
MP Metal inserts with 0.150” dia. hole accept #6 screw.
MT
MT8
13
很抱歉,暂时无法提供与“CB20722807EB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+131.6557350+17.03168
