A30710807R53
A30710807R53
    EATON(伊顿)
    CONNBARRIERSTRIP8CIRC0.437"
A30710807R53 数据手册
Series A3000, LP3000 & CB3000 Single Row Terminal Blocks A31940707WR SPECIFICATIONS Rating: A3: 30A, 600V* #12-22 AWG LP3: 30A, 150V #12-22 AWG CB3: 30A, 600V #12-22 AWG Wire Range: #12-22 AWG Cu Center Spacing: 0.437” or 7/16” (11.10mm) Screw Size: #6-32 zinc-plated philslot screws. Torque Rating: 9 lb-in. Base: Standoffs standard for easy flux washing. Distance Between Barriers: 0.32” (8.1mm) Recommended PCB Hole Diameter: 0.076” (1.93mm) Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Molded Material: Black, UL Rated 94V0 Thermoplastic Breakdown Voltage: 3500V (A3 & LP3); 8200V (CB3) Agency Information: UL File E62622, CSA 47235; IEC Compliance, CE Certified *30A Rating achieved with a #10 copper wire crimped to a ring terminal; 20 Rating without ring terminal. MOUNTING ENDS ONLY Poles A Mount Ctrs. C Length BARRIER & MOUNTING ENDS B Pole Ctrs. BARRIER ENDS ONLY C Length LP301105 CB30220807 Dimesions - in (mm) A3000 & LP3000 Series 0.437 (11.10) 0.15 (3.8) Ø 0.65 (16.5) C Mount End 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 Edge Connectors, One-Sided Boards Wire Management Products Power Distribution Blocks Terminal Blocks: Panel & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Terminal Blocks - Single Row 1.31 1.75 2.18 2.62 3.06 3.50 3.93 4.37 4.81 5.25 5.68 6.12 6.56 7.00 7.43 7.87 8.31 8.75 9.18 9.62 10.06 10.50 10.93 11.37 11.81 – – 1.73 2.17 2.61 3.05 3.48 3.92 4.36 4.80 5.23 5.67 6.11 6.55 6.98 7.42 7.86 8.30 8.73 9.17 9.60 10.05 10.48 10.92 11.36 11.80 12.23 – – 0.43 0.87 1.31 1.75 2.18 2.62 3.06 3.50 3.93 4.37 4.81 5.25 5.68 6.12 6.56 7.00 7.43 7.87 8.31 8.50 9.18 9.62 10.06 10.50 10.93 11.37 11.81 0.98 1.43 1.87 2.31 2.75 3.18 3.62 4.06 4.50 4.93 5.37 5.81 6.25 6.68 7.12 7.56 8.00 8.43 8.87 9.31 9.75 10.18 10.62 11.06 11.50 11.93 12.37 Barrier End 0.565 (19.3) 0.76 (14.35) 0.40 (10.2) 0.02 (0.5) B Pole Centers A Mount Centers Mount End Barrier End CB3000 Series 0.437 (11.10) 0.19 (4.8) Ø 0.70 (17.8) 0.32 (8.1) C Mount End Barrier End Dimensions in inches. To convert to millimeters, multiply by 25.4. Compliance References 0.61 (15.5) 0.02 (0.5) B Pole Centers A Mount Centers Mount End 16 For additional product information, visit www.bussmann.com Barrier End Terminal Blocks - Single Row Terminal Blocks: Single & Double Row Series A3000 Single Row Terminal Blocks Part Numbering System n nn nnnn nnn A3 - standard barrier 01 - handwired 02 - printed circuit 03 - non feed-thru 04 - wire wrap tail 05 - extended handwired 07 - extended pin 09 - 0.250 QC short 10 - 0.187 QC 19 - 0.250 QC long 1 - std. base/mount end 2 - std. base/barrier end 3* - insulator base/ mount end 4* - insulator base/ barrier end 5** - closed base/ mount end 02 to 28 02 to 26 on mount end base AB - angle mnt. options (pg 20) A1 to A9 - 0.250” QC B1 to B9 - 0.187” QC L1 to L6 marking options (pg 27) MP, MT mounting plates (pg 20) RC - retaining clips (pg 20) R30 to R77 - right angle bends (pg 20) S1 - solder lug/flat J201*** - flat slip-on jumper OJ3***, OJ5*** & OJ7*** - over barrier jumpers Poles Screw Options Options (Views pg. 15) Blank - std. screw 00 - screws shipped bulk 03 - stainless steel 04 - brass nickel-plated 07 - steel SEMS zinc-plated (not available with hardware options) 09 - brass SEMS nickel-plated (not available with hardware options) 07WR - steel SEMS wire ready (A3 only) CA† - captive screw *Base/End Styles 3 and 4 not available with 02, 03, and 09 terminals. **Base/End Note: 5 Style only available with 03 terminals. ***Contact factory for configuration. Covers - (pg 28) †Not compatible with 03 stainless steel screw option. Inches (Millimeters) 0.20 (5.1) 0.031 (0.79) 0.110 (2.79) 02 Printed Circuit 03 Non Feed-Thru 04 Wire Wrap Tail 0.33 (8.4) 0.062 (1.57 ) 07 Extended Pin 0.031 (0.79) 0.250 (6.35) 19 0.250˝ QC Long (Bulk ordering part numbers are in parentheses) 03 Stainless Steel (F507-J) 04 Brass Nickel-Plated (F506-3) 07 Steel SEMS Zinc-Plated (F523-J) 09 Brass SEMS Nickel-Plated (F524-J) For additional product information, visit www.bussmann.com Compliance References Standard Zinc-Plated Steel (F505-J) 0.187 (4.75) 10 0.187˝ QC Screw Options 0.031 (0.79) 0.31 (7.9) 0.031 (0.79) 09 0.250˝ QC Short 0.110 (2.79) 05 Extended Handwired Edge Connectors, One-Sided Boards 0.250 (6.35) 0.031 (0.79) 0.031 (0.79) 0.41 (10.4) 0.72 (18.3) 0.42 (10.7) 0.40 (10.2) 0.062 (1.57) 0.031 (0.79) 01 Handwired 0.82 (20.8) 0.66 (16.8) 0.55 (14.0) 0.062 (1.57) Wire Management Products 0.031 (.79) Power Distribution Blocks Terminal Styles 0.55 (14.0) Terminal Blocks: Panel & Rail Mount nn Base/End EuroMag Series 3 nA n nnn Terminal Style Series 07WR Wire Ready (A3 only) 17 Series LP3000 Single Row Terminal Blocks Part Numbering System Series Terminal Style Base/End Poles Ln Pn 3 n nn (Views pg. 15) n nn nnnn LP3 - low profile barrier 01 - handwired 02 - printed circuit 03 - non feed-thru 04 - wire wrap tail 05 - extended handwired 06 - handwired 07 - extended pin 1 - std. base/mount end 2 - std. base/barrier end 3* - insulator base/ mount end 4* - insulator base/ barrier end 5** - closed base/ mount end 02 to 28 02 to 26 on mount end base Terminal Blocks: Panel & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Terminal Blocks - Single Row Screw Options Options n nn Blank - std. screw 00 - screws shipped bulk 04 - brass nickel-plated 07 - steel SEMS zinc-plated (not available with hardware options) 07WR - steel SEMS wire ready (A3 only) CA - captive screw A1 to A9 - 0.250” QC B1 to B9 - 0.187” QC L1 to L6 marking options (pg 27) MP mounting plates (pg 20) R30 to R77 - right angle bends (pg 20) J201*** - flat slip-on jumper †OJ3***, OJ5*** & OJ7*** - over barrier jumpers Covers - (pg 28) *Base/End Style 3 and 4 only available with 01 and 05 terminals **Base/End Style 5 only available with 03 terminals. ***Contact factory for configuration. 0.031 (.79) 0.031 (0.79) 01 Handwired 0.062 (1.57) 0.031 (0.79) 02 Printed Circuit 0.66 (16.8) 0.55 (14.0) 0.062 (1.57) 0.110 (2.79) 03 Non Feed-Thru 04 Wire Wrap Tail 0.031 (0.79) 0.062 (1.57 ) Edge Connectors, One-Sided Boards 07 Extended Pin Screw Options Standard Zinc-Plated Steel (F505-J) 18 (Bulk ordering part numbers are in parentheses) 04 Brass Nickel-Plated (F506-J) 07 Steel SEMS Zinc-Plated (F523-J) 0.30 (7.6) 0.110 (2.79) 05 Extended Handwired 0.82 (20.8) 0.031 (0.79) Compliance References 0.20 (5.1) 0.55 (14.0) Wire Management Products Power Distribution Blocks Terminal Styles 07WR Wire Ready (A3 only) For additional product information, visit www.bussmann.com 0.031 (0.79) 0.11 (2.79) 06 Handwired Terminal Blocks - Single Row Hardware Options FIG 1 Inches (Millimeters) (Bulk ordering part numbers are in parentheses) Jumpers Solder Lugs* Terminal Blocks: Single & Double Row Series A3000 & LP3000 Single Row Terminal Blocks Continued Quick Connects Blade Width A = 0.250” Blade Width B = 0.187” 0.68 (17.3) 0.84 (21.2) S1 (2S1-J) †J201 †OJ3 (OJ3-J) A1 & B1 (2A1-J & 2B1-J) A2 & B2 (2A2-J & 2B2-J) A3 & B3 (2A3-J & 2B3-J) †OJ7 LP3 Only (OJ7-J) A4 & B4 (2A4-J & 2B4-J) A5 & B5 (2A5-J & 2B5-J) A6 & B6 (2A6-J & 2B6-J) †OJ5 (OJ5-J) A7 & B7 (2A7-J & 2B7-J) A8 & B8 (2A8-J & 2B8-J) A9 & B9 (2A9-J & 2B9-J) Flat slip-on (J201-J) FIG 2 FIG 2 FIG 1 3 FIG 3 †Contact factory for pole configuration. Terminal Blocks: Panel & Rail Mount FIG 1 only *A3FIG EuroMag Series FIG 1 FIG 2 Power Distribution Blocks Base/End Options Inches (Millimeters) FIG 2 FIG 1 Mount End Details FIG 4 FIG 3 B 1 - Standard base/mount end FIG 2 0.41 (10.4) FIG 5 FIG 4 FIG 3 Wire Management Products FIG 3 0.41 (10.4) 3 - Insulator base/mount end B 2 - Standard base/barrier end FIG 4 0.150 Ø (3.8) mounting holes (2) 4 - Insulator base/barrier end FIG 5 0.40 (10.2) 0.095 (2.4) FIG 4 Edge Connectors, One-Sided Boards SECTION B–B 5 - Closed base/mount end 1, 3 & 5 Mount End FIG 6 FIG 6 FIG 5 FIG 4 FIG 5 Compliance References FIG 6 FIG 5 FIG 6 For additional product information, visit www.bussmann.com 19 EuroMag Series Terminal Blocks: Single & Double Row Terminal Blocks - Single Row Series A3000 & LP3000 Single Row Terminal Blocks Continued Mounting Options Inches (Millimeters) Right Angle Bends (A3, LP3 only) Right angle terminals are offered on the A3000 & LP3000 Series. Configurations are defined in these dimensions: X = pin extension beyond the block base; Z = length from block base to centerline of the terminal tip. Standard bends consist of the X and Z dimensions shown in the chart. Specify by adding the selected Bend Option Code to the terminal part number. 07 Terminal Bend Configurations 04 Terminal Bend Configurations Z Z 0.55 Bend Option Code Edge Connectors, One-Sided Boards Z Available w/insulator base 0.04 0.01 0.02 0.05 0.08 0.12 0.14 0.16 0.28 0.23 0.22 0.19 0.16 0.12 0.10 0.08 No No No No No No No No Bend Option Code R30 R35 R36 R50 R53 R66 R69 R75 R77 X (minimum) 0.04 0.01 0.02 0.16 0.19 0.32 0.35 0.41 0.43 Z Available w/insulator base 0.55 0.50 0.49 0.35 0.32 0.19 0.16 0.10 0.08 Yes Yes Yes No No No No No No Dimensions in inches. To convert to millimeters, multiply by 25.4. Angle Brackets (A3 only) 0.25 0.04 0.45 0.32 0.15 Option AB Angle brackets enable block to be fastened at right angles to normal mount position. Bulk part number 2AB-J. Retaining Clip Mounting Plates MOUNTING PLATE MP MT Compliance References X X X (minimum) R30 R35 R36 R39 R42 R46 R48 R50 Wire Management Products Power Distribution Blocks Terminal Blocks: Panel & Rail Mount 0.82 RETAINING CLIP Options MP & MT MP Metal inserts with 0.150” dia. hole accept #6 screw. MT Metal inserts with tapped hole accept #6-32 screw. Bulk part numbers: 2MP-J 2MT-J 20 Option RC Use on standoff tubes. Fit panels up to 0.125” thick. Two clips for every five positions. Supplied unassembled. Bulk part number H541-J. For additional product information, visit www.bussmann.com Terminal Blocks - Single Row Terminal Blocks: Single & Double Row Series CB3000 Single Row Terminal Blocks Part Numbering System Cn Bn 3 n Terminal Style nn Base/End n Poles nn Screws nnnn Options CB3 - closed back 01 - handwired #6-32 screw 02 - printed circuit #6-32 screw 07 - extended pin #6-32 screw 51* - handwired #8-32 52* - printed circuit #8-32 1 - mount end 2 - barrier end 02 to 28 02 to 26 on mount end base 07 - steel SEMS (standard) 09 - brass SEMS nickel-plated CA - SEMS captive AB - angle mounting brackets (pg 22) A7 to A9 - 0.250” QC B7 to B9 - 0.187” QC EB - exit back terminals L1 to L6 marking options (pg 27) LT1 to LT6 marking options (pg 27) MP mtg. plates (pg 22) OJ3** & OJ7** - over barrier jumpers Terminal Styles Inches (Millimeters) 01 Handwired #6-32 screw 51 #8-32 screw 0.045 (1.14) 0.18 (4.6) 0.031 (0.79) 0.062 (1.57) 02 Printed Circuit #6-32 screw 52 #8-32 screw 0.18 (4.6) 0.031 (0.79) 07 Extended Pin #6-32 screw Wire Management Products Screw Options (Bulk ordering part numbers are in parentheses) 09 Brass SEMS Nickel-Plated (F524-J) CB3 Terminal Exit Options Edge Connectors, One-Sided Boards 07 Steel SEMS Zinc-Plated (standard) (B001-7084-J) 0.70 (17.8) 0.19 (4.8 ) 0.18 (4.6) Power Distribution Blocks 0.40 (10.2) 0.120 (3.05) Terminal Blocks: Panel & Rail Mount Covers - (pg 28) *Note: #8-32 screw is a special with #6-32 head. **Contact factory for configuration. 0.031 (0.79) nnn Inches (Millimeters) Compliance References 0.255 (6.48) 0.18 (4.6) Exit Rear (std.) EB Exit Back For additional product information, visit www.bussmann.com EuroMag Series Series 21 Series CB3000 Single Row Terminal Blocks Continued Hardware Options Jumpers EuroMag Series Terminal Blocks: Single & Double Row Terminal Blocks - Single Row Terminal Blocks: Panel & Rail Mount †OJ3 (OJ3-J) Inches (Millimeters) (Bulk ordering part numbers are in parentheses) Quick Connects Blade Width A = 0.250”. Blade Width B = 0.187”. A7 & B7 (2A7-J & 2B7-J) A8 & B8 (2A8-J & 2B8-J) A9 & B9 (2A9-J & 2B9-J) †OJ7 (OJ7-J) Power Distribution Blocks †Contact factory for pole configuration. Mounting Options Inches (Millimeters) Right Angle Mounting Bracket End Positions usable 0.71 (18.0) Snap-in Angle Bracket Chassis or PCB A Edge Connectors, One-Sided Boards Wire Management Products 0.79 (20.1) 1.02 (25.8) Exit Back (EB) Terminals 0.24 (6.1) Angle Bracket A 0.42 (10.7) Mounts blocks on PC boards at a right angle. • Protects solder joints. • Recommended for all EB (Exit Back) PCB terminal blocks. • Bracket snaps securely on block (no hardware required). • Minimum strip length (end positions are usable). • Mount with #6-32 or #8-32 screws (not supplied). Option AB Mounting Plates MP Option MP MP Metal inserts with 0.150” dia. hole accept #6 screw. Compliance References #6 or #8 mounting screw & nut (Customer supplied.) MOUNTING PLATE 22 MT MT8 For additional product information, visit www.bussmann.com 0.45 (11.4)
A30710807R53 价格&库存
很抱歉,暂时无法提供与“A30710807R53”相匹配的价格&库存,您可以联系我们找货
