A403511S1
A403511S1
    EATON(伊顿)
    CONNBARRIERSTRP11CIRC0.562"
A403511S1 数据手册
Terminal Blocks - Single Row A481307 EuroMag Series B484304 A40110407 A4000 Series Dimensions - in (mm) Terminal Blocks: Panel & Rail Mount SPECIFICATIONS Rating: See table. Center Spacing: 0.562” or 9/16” (14.28mm) Wire Range: See rating table. Screw Size: #8-32 or #10-32 zinc-plated slotted screws Torque Rating: #8 screw size 16 lb-in.; #10 screw size 20 lb-in. Distance Between Barriers: 0.47” (11.9mm) Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Molded Material: Black, UL Rated 94V0 Thermoplastic Hardware: Bottom studs supplied with nuts assembled. Cup washers are optional on bottom studs but are not recommended with ring terminals. Extended Hex Nuts: Optional extended, slotted hex nuts enable easier installation and removal with hex wrench or screwdriver. Available in bulk for the #10-32 studs on Series A4953 blocks. Specify part number F582 and quantity. Breakdown Voltage: 6100V Agency Information: UL File E62622, CSA File 47235; CE Certified Terminal Blocks: Single & Double Row Series A4000 & Series B4000 Single Row Terminal Blocks 0.31 (7.9) 0.562 (14.27) 0.87 (22.1) A B 0.21 (5.3) Terminal Top # 8 Screw # 8 Screw # 8 Screw # 8 Screw #10 Screw #10 Screw #10 Screw #10 Screw #10 Screw #10 Stud #10 Screw Terminal Bottom #8 Stud Solder Solder Closed Solder Solder #8 Stud SolderTurret #8 Screw #10 Stud #8 Screw Wire* Range Cu 8-16 AWG 10-16 AWG 10-16 AWG 8-16 AWG 10-16 AWG 10-16 AWG 8-16 AWG 10-16 AWG 8-16 AWG 8-16 AWG 8-16 AWG Ratings* Volts/Amps 150V/50A 600V/35A 600V/35A 600V/50A 600V/35A 600V/35A 150V/50A 600V/35A 150V/50A 150V/50A 600V/50A #8-32 or #10-32 THD’S 0.31 (7.9) 1.05 (26.7) 0.57 (14.5) 0.36 dia. (9.1) Wire Management Products Part Number A4003XX A4011XX A4013XX A4035XX A4041XX A4043XX A4803XX A4813XX A4843XX A4953XX B4843XX Power Distribution Blocks RATING TABLE Note: Above unit supplied with nuts assembled. Cup washers are optional. * All models 30A Max. with 10 AWG; 35-50A ratings with 8 AWG using ring or fork type terminals. Note: 50A rating achieved with #8 copper wire crimped to ring terminal. B (in.) Length 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 1.69 2.25 2.81 3.37 3.93 4.50 5.06 5.62 6.18 6.74 7.31 7.87 8.43 8.99 9.55 10.12 10.68 2.12 2.68 3.24 3.80 4.36 4.93 5.34 6.05 6.61 7.17 7.74 8.30 8.86 9.44 9.98 10.55 11.11 Optional Cup Washers Assembled Available on A4003, A4803, A4843, A4953 & B4843. CUP WASHERS Reference Panel Cutout for 6 Position Block 0.20 DIA. (5.1) Compliance References A (in.) Mount Centers Edge Connectors, One-Sided Boards Poles 0.75 (19.1) * Dimensions in inches. To convert to millimeters, multiply by 25.4. 3.31 (84.1) 3.93 (99.8) For additional product information, visit www.bussmann.com 25 Terminal Blocks - Single Row Terminal Blocks: Panel & Rail Mount EuroMag Series Terminal Blocks: Single & Double Row Part Numbering System An 4 n Bn 4 n Series nn n 00 - screw top; stud bottom 01 - screw top; solder bottom 03 - screw top only 04 - #10 screw top; solder term. b. 80 - screw top; stud bottom #10-32 top, #8-32 bottom insulated base 81 - screw top; solder turret bottom #10-32 84 - screw top; screw bottom #10-32 *1 - flat base/ 02 to 18 Blank - std. screw mount end 00 - screws shipped bulk 3 - insulator base04 - brass nickel-plated (not available 07 - steel SEMS zinc in 03 plated (not available terminal style) with hardware options; /mount end only available on A4011, 5 - closed base/ A4013, A4021 and A4035) mount end (available in 03 terminal only *Available in 01, 02, 04 & 05 terminal style only. **Consult factory for configuration. Terminal Style A4 - standard B4 - barrier (only available in 84 terminal style) nn Base/End 95 - stud top; stud bottom #10-32 nn Screw Options Options Terminal Styles A1 to A9 - 0.250” QC †CW - cup washer (pg 25) L1 to L6 marking options (pg 27) S1 & S2 - solder lugs/flat J301** - flat slip-on jumper (2 position only) Covers - (pg 28) † Available only on A4003, A4803, A4843, A4953 & B4843. Inches (Millimeters) #8-32 SCREW #8-32 or #10-32 SCREW #8-32 or #10-32 SCREW 0.94 (23.9) 0.43 (10.9) 0.04 (1.0) 0.41 (10.4) A4003XX Power Distribution Blocks 1.41 (35.8) 1.41 (35.8) 1.99 (50.6) #8-32 HEX NUT 0.17 (4.3) 0.04 (1.0) A4011XX (#8-32) A4041XX (#10-32) 0.43 (10.9) 0.36 (9.1) A4013XX (#8-32) A4043XX (#10-32) #10-32 SCREW #10-32 SCREW #8-32 SCREW (TYP) 0.80 (20.3) 0.94 (23.9) 1.85 (47.0) 1.99 (50.6) #8-32 HEX NUT Wire Management Products A4035XX 0.41 (10.4) A4813XX #10-32 STUD #10-32 SCREW #10-32 SCREW 1.05 (26.7) 1.55 (39.4) 0.49 (12.5) #10-32 HEX NUT A4843XX Solder Lugs 0.41 (10.4) 1.99 (50.6) 0.79 (20.1) 0.30 (7.6) 0.94 (23.9) 1.84 (46.7) 0.09 (2.4) A4953XX Hardware Options Jumpers 0.36 (9.1) TURRET A4803XX #8-32 SCREW Edge Connectors, One-Sided Boards nn Poles #8-32 SCREW 0.41 (10.4) B4843XX Inches (Millimeters) (Bulk ordering part numbers are in parentheses) Quick Connects Blade Width A = 0.250”. (For other orientations, contact factory.) 1.12 (28.4) Compliance References *S1 (2S1-J) J301 (J301-J) A1 (4A1-J) A2 (4A2-J) A3 (4A3-J) A6 (4A6-J) A7 (4A7-J) A8 (4A8-J) A4 (4A4-J) 0.56 (14.3) *S2 (2S2-J) *Not available for A4843 26 For additional product information, visit www.bussmann.com A9 (4A9-J) A5 (4A5-J)
A403511S1 价格&库存
很抱歉,暂时无法提供与“A403511S1”相匹配的价格&库存,您可以联系我们找货
