Terminal Blocks - Single Row
A481307
EuroMag Series
B484304
A40110407
A4000 Series Dimensions - in (mm)
Terminal Blocks:
Panel & Rail Mount
SPECIFICATIONS
Rating: See table.
Center Spacing: 0.562” or 9/16” (14.28mm)
Wire Range: See rating table.
Screw Size: #8-32 or #10-32 zinc-plated slotted screws
Torque Rating: #8 screw size 16 lb-in.; #10 screw size
20 lb-in.
Distance Between Barriers: 0.47” (11.9mm)
Operating Temperature: 105°C (221°F) max., -40°C
(-40°F) min.
Molded Material: Black, UL Rated 94V0 Thermoplastic
Hardware: Bottom studs supplied with nuts assembled.
Cup washers are optional on bottom studs but are not
recommended with ring terminals.
Extended Hex Nuts: Optional extended, slotted hex nuts
enable easier installation and removal with hex wrench or
screwdriver. Available in bulk for the #10-32 studs on
Series A4953 blocks. Specify part number F582 and
quantity.
Breakdown Voltage: 6100V
Agency Information: UL File E62622, CSA File 47235;
CE Certified
Terminal Blocks:
Single & Double Row
Series A4000 & Series B4000
Single Row Terminal Blocks
0.31
(7.9)
0.562
(14.27)
0.87
(22.1)
A
B
0.21
(5.3)
Terminal
Top
# 8 Screw
# 8 Screw
# 8 Screw
# 8 Screw
#10 Screw
#10 Screw
#10 Screw
#10 Screw
#10 Screw
#10 Stud
#10 Screw
Terminal
Bottom
#8 Stud
Solder
Solder
Closed
Solder
Solder
#8 Stud
SolderTurret
#8 Screw
#10 Stud
#8 Screw
Wire*
Range Cu
8-16 AWG
10-16 AWG
10-16 AWG
8-16 AWG
10-16 AWG
10-16 AWG
8-16 AWG
10-16 AWG
8-16 AWG
8-16 AWG
8-16 AWG
Ratings*
Volts/Amps
150V/50A
600V/35A
600V/35A
600V/50A
600V/35A
600V/35A
150V/50A
600V/35A
150V/50A
150V/50A
600V/50A
#8-32 or #10-32 THD’S
0.31
(7.9)
1.05
(26.7)
0.57
(14.5)
0.36 dia.
(9.1)
Wire Management
Products
Part
Number
A4003XX
A4011XX
A4013XX
A4035XX
A4041XX
A4043XX
A4803XX
A4813XX
A4843XX
A4953XX
B4843XX
Power Distribution
Blocks
RATING TABLE
Note: Above unit supplied with nuts
assembled. Cup washers are optional.
* All models 30A Max. with 10 AWG;
35-50A ratings with 8 AWG using ring or fork type terminals.
Note: 50A rating achieved with #8 copper wire crimped to ring terminal.
B (in.)
Length
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
1.69
2.25
2.81
3.37
3.93
4.50
5.06
5.62
6.18
6.74
7.31
7.87
8.43
8.99
9.55
10.12
10.68
2.12
2.68
3.24
3.80
4.36
4.93
5.34
6.05
6.61
7.17
7.74
8.30
8.86
9.44
9.98
10.55
11.11
Optional Cup Washers
Assembled
Available on A4003, A4803,
A4843, A4953 & B4843.
CUP
WASHERS
Reference Panel Cutout for 6 Position Block
0.20 DIA.
(5.1)
Compliance
References
A (in.)
Mount Centers
Edge Connectors,
One-Sided Boards
Poles
0.75
(19.1)
* Dimensions in inches. To convert to millimeters, multiply by 25.4.
3.31
(84.1)
3.93
(99.8)
For additional product information, visit www.bussmann.com
25
Terminal Blocks:
Panel & Rail Mount
EuroMag Series
Terminal Blocks:
Single & Double Row
Part Numbering System
An
4
n
Bn
4
n
Series
nn
n
00 - screw top; stud bottom
01 - screw top; solder bottom
03 - screw top only
04 - #10 screw top; solder term. b.
80 - screw top; stud bottom
#10-32 top, #8-32 bottom
insulated base
81 - screw top; solder turret bottom
#10-32
84 - screw top; screw bottom #10-32
*1 - flat base/
02 to 18
Blank - std. screw
mount end
00 - screws shipped bulk
3 - insulator base04 - brass nickel-plated
(not available
07 - steel SEMS zinc
in 03
plated (not available
terminal style)
with hardware options;
/mount end
only available on A4011,
5 - closed base/
A4013, A4021 and A4035)
mount end
(available
in 03
terminal only
*Available in 01, 02, 04 & 05 terminal style only.
**Consult factory for configuration.
Terminal Style
A4 - standard
B4 - barrier
(only
available
in 84
terminal
style)
nn
Base/End
95 - stud top; stud bottom #10-32
nn
Screw Options
Options
Terminal Styles
A1 to A9 - 0.250” QC
†CW - cup washer (pg 25)
L1 to L6 marking options (pg 27)
S1 & S2 - solder lugs/flat
J301** - flat slip-on jumper
(2 position only)
Covers - (pg 28)
† Available only on A4003, A4803,
Inches (Millimeters)
#8-32 SCREW
#8-32 or #10-32 SCREW
0.94
(23.9)
0.43
(10.9)
0.04
(1.0)
0.41
(10.4)
A4003XX
Power Distribution
Blocks
1.41
(35.8)
1.41
(35.8)
1.99
(50.6)
#8-32 HEX NUT
0.17
(4.3)
0.04
(1.0)
A4011XX (#8-32)
A4041XX (#10-32)
0.43
(10.9)
0.36
(9.1)
A4013XX (#8-32)
A4043XX (#10-32)
#10-32 SCREW
#10-32 SCREW
#8-32 SCREW
(TYP)
0.80
(20.3)
0.94
(23.9)
1.85
(47.0)
1.99
(50.6)
#8-32 HEX NUT
Wire Management
Products
A4035XX
0.41
(10.4)
A4813XX
#10-32 STUD
#10-32 SCREW
#10-32 SCREW
1.05
(26.7)
1.55
(39.4)
0.49
(12.5)
#10-32 HEX NUT
A4843XX
Solder Lugs
0.41
(10.4)
1.99
(50.6)
0.79
(20.1)
0.30
(7.6)
0.94
(23.9)
1.84
(46.7)
0.09
(2.4)
A4953XX
Hardware Options
Jumpers
0.36
(9.1)
TURRET
A4803XX
#8-32 SCREW
Edge Connectors,
One-Sided Boards
nn
Poles
#8-32 SCREW
0.41
(10.4)
B4843XX
(Bulk ordering part numbers are in parentheses)
Quick Connects Blade Width A = 0.250”. (For other orientations, contact factory.)
1.12 (28.4)
Compliance
References
*S1
(2S1-J)
J301
(J301-J)
A1
(4A1-J)
A2
(4A2-J)
A3
(4A3-J)
A6
(4A6-J)
A7
(4A7-J)
A8
(4A8-J)
A4
(4A4-J)
0.56 (14.3)
*S2
(2S2-J)
*Not available for A4843
26
A9
(4A9-J)
A5
(4A5-J)
很抱歉,暂时无法提供与“A480305”相匹配的价格&库存,您可以联系我们找货
