C5237-12
C5237-12
    EATON(伊顿)
    BLOCKJUNCTION
C5237-12 数据手册
Technical Data 2072 Effective December 2016 Supersedes December 1998 C5237 non-feed-through stud type junction blocks Agency information • UL® E62622 • CSA® LR15364 Marking Numbers and arrows molded on the top of the barriers to indicate terminal Stud size • #10-32 Terminal torque • Catalog symbol: • C5237-(poles) Description: Bussmann™ series non-feed-through stud type junction blocks with 1 to 15 brass studs on 0.625 inch centers. Studs feature a “dog point” to guide the nut onto the thread. Specifications: Ratings • Volts • 300 V UL • • 600 V CSA Amps – 30 A 20 lb-in (25 lb-in max.) Technical Data 2072 C5237 non-feed-through stud type junction blocks Effective December 2016 A 0.81" 1.0" C 1.16" 0.75" 0.375" 0.625" 0.375" B 0.31" Mtg. holes 9/32"X3/8" slot Catalog numbers and dimensions — in (mm) Catalog no. (poles) C5237-1 C5237-2 C5237-3 C5237-4 C5237-5 C5237-6* C5237-7 C5237-8 C5237-9 C5237-10* C5237-11 C5237-12 C5237-13 C5237-14 C5237-15 A 2.00 (50.8) 2.62 (66.7) 3.25 (82.5) 3.87 (98.4) 4.50 (114.3) 5.12 (130.8) 5.75 (146.0) 6.37 (161.9) 7.00 (177.8) 7.62 (193.7) 8.25 (209.5) 8.87 (225.4) 9.50 (241.3) 10.12 (257.2) 10.75 (273.0) B 1.25 (31.7) 1.87 (47.5) 2.50 (63.4) 3.12 (79.4) 3.75 (95.2) 4.37 (111.1) 5.00 (127.0) 5.62 (142.9) 6.25 (158.7) 6.87 (174.6) 7.50 (190.5) 8.12 (206.4) 8.75 (222.2) 9.37 (238.1) 10.00 (254.0) C – 1.25 (31.7) 1.87 (47.5) 2.50 (63.4) 3.12 (79.4) 3.75 (95.2) 4.37 (111.1) 5.00 (127.0) 5.62 (142.9) 6.25 (158.7) 6.87 (174.6) 7.50 (190.5) 8.12 (206.4) 8.75 (222.2) 9.37 (238.1) * RoHS compliant. The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2016 Eaton All Rights Reserved Printed in USA Publication No. 2072 — BU-SB98107 December 2016 Eaton.com/bussmannseries Eaton and Bussmann are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information.
C5237-12 价格&库存
很抱歉,暂时无法提供与“C5237-12”相匹配的价格&库存,您可以联系我们找货
