EM250502V
EM250502V
    EATON(伊顿)
    插件
    TERM BLOCK 16A 300V 12-26AWG
EM250502V 数据手册
EuroMag Series PCB Mount Terminal Blocks L (mm) 10.16 15.24 20.32 25.40 30.48 35.56 40.64 45.72 50.80 55.88 60.96 66.04 14 15 16 17 18 19 20 21 22 23 24 71.12 76.20 81.28 86.36 91.44 96.52 101.60 106.68 111.76 116.84 121.92 0.24 (6.1) 0.44 (11.2) 0.10 (2.54) 0.20 (5.08) 0.13 (3.3) L 0.59 (15.0) 0.35 (9.0) 0.031 (0.8) To convert to inches, divide by 25.4 0.17 (4.2) 0.035 (0.9) EM2505V Part Numbering System En Mn 2n 5n 0n 5 nn n Series n # of Positions Orientation 02 to 24 V - vertical EuroMag Series Position Dimensions - in (mm) Compliance References 02 03 04 05 06 07 08 09 10 11 12 13 L (mm) EM250505V Edge Connectors, One-Sided Boards Position Cage & Screw SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.20” (5.08mm) Wire Range: #12-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Screw Size: M2.6 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5.0 lb-in. Recommended PCB Hole Diameters: 0.055” (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Connector Style: Rising Cage and Screw Agency Information: File E62622; CE Certified Terminal Blocks: Single Row EM2505 Series EuroMag Terminal Blocks 5.08 Centers; Modular For additional product information, visit www.eaton.com/connectors 43
EM250502V 价格&库存
很抱歉,暂时无法提供与“EM250502V”相匹配的价格&库存,您可以联系我们找货
EM250502V
  • 100+3.85042100+0.48285
  • 300+3.76191300+0.47175
  • 1000+3.673391000+0.46065
  • 2000+3.629142000+0.45510
  • 4000+3.540624000+0.44400
