ED3001/6-KD
ED3001/6-KD
    OST
    插件,P=5mm
    接线端子 间距:5.00mm 每排针脚数:6 排数:单排
ED3001/6-KD 数据手册
ED3000/X ED3001/X-KD 1-n poles, Spacing 5.0 mm adjustable to 5.08 mm insert required no. of poles x 1-n poles, Spacing 5.0 mm adjustable to 5.08 mm insert required no. of poles x How to order see page 5 Ratings: Rated Voltage Rated Current Wire Size Test Voltage 250 V 24 A (T60) 2.5 mm 2 2.0 kV Ratings: Rated Voltage Rated Current Wire Size Test Voltage Max. Rated Cross Section Single Wire (solid) Stranded Wire (flexible) Stranded wire with Ferrules 2.5 mm 2 2.5 mm 1.5 mm 2 Max. Rated Cross Section Single Wire (solid) Stranded Wire (flexible) Stranded wire with Ferrules 2.5 mm 2 2.5 mm 1.5 mm 2 Dimensions Spacing PCB Hole Diameter Stripped Length 5.0 mm (5.08 mm) 1.0 mm (2x) 6.0 mm Dimensions Spacing PCB Hole Diameter Stripped Length 5.0 mm (5.08 mm) 1.0 mm (2x) 6.0 mm Materials Insulating Material Flammability Class Temperature Range Cage Clamp Wire Guard PA UL94 V-0 -30 C/+105 C Stainless Steel Cu Materials Insulating Material Flammability Class Temperature Range Contact Pin PA UL94 V-0 -30 C/+105 C Cu Color Slade Grey 51 How to order see page 5 300 V 16 A AWG 28-14 2 300 V 16 A AWG 28-14 250 V 24 A (T60) 2.5 mm 2 2.0 kV 2 Color Slade Grey ON-SHORE TECHNOLOGY INC 1917 West Third Street Tempe, Arizona USA 85281 Tel. (480)921-3000 Fax(480) 968-4444 51
ED3001/6-KD 价格&库存
很抱歉,暂时无法提供与“ED3001/6-KD”相匹配的价格&库存,您可以联系我们找货
ED3001/6-KD
  • 50+21.8717250+2.82566
