ED104/3DS
ED104/3DS
    OST
    插件,P=5mm
    5MM 排数:1 每排P数:3 直插
ED104/3DS 数据手册
ED104/XDS ED105/XDS 2-12 poles, Spacing 5.0 mm insert required no. of poles x 2-12 poles, Spacing 5.0 mm insert required no. of poles x How to order see page 5 Ratings: Rated Voltage Rated Current Wire Size Test Voltage Rated Torque/ScrewSize 250 V 32 A (T60) 2 4.0 mm 2.0 kV 0.8 Nm/M3 Ratings: Rated Voltage Rated Current Wire Size Test Voltage Rated Torque/ScrewSize Max. Rated Cross Section Single Wire (solid) Stranded Wire (flexible) Stranded wire with Ferrules 4.0 mm 2 2.5 mm 2 1.5 mm Max. Rated Cross Section Single Wire (solid) Stranded Wire (flexible) Stranded wire with Ferrules 2.5 mm 2 1.5 mm 2 1.5 mm 2 Dimensions Spacing PCB Hole Diameter Stripped Length 5.0 mm 2.0 mm x 2.8 mm 7.0 mm Dimensions Spacing PCB Hole Diameter Stripped Length 5.0 mm 1.3 mm 6.0 mm Materials Insulating Material Flammability Class Temperature Range Terminal Block Wire Guard PA UL94 V-0 -30 C/+105 C CuZn Stainless Steel Materials Insulating Material Flammability Class Temperature Range Terminal Block Wire Guard PA UL94 V-0 -30 C/+105 C CuZn Stainless Steel Color Grey 7 How to order see page 5 300V 15 A AWG 22-14 2 300V 15 A AWG 22-14 250 V 24 A (T60) 2.5 mm 2 2.0 kV 0.5 Nm/M3 Color Blue ON-SHORE TECHNOLOGY INC 1917 West Third Street Tempe, Arizona USA 85281 Tel. (480)921-3000 Fax(480) 968-4444 7
ED104/3DS 价格&库存
很抱歉,暂时无法提供与“ED104/3DS”相匹配的价格&库存,您可以联系我们找货
