EM292902-UL
EM292902-UL
    EATON(伊顿)
    插件,P=10.16mm
    TERM BLOCK 65A 600V 6-20AWG
EM292902-UL 数据手册
EuroMag Series PCB Mount Terminal Blocks Terminal Blocks: Single Row EM2929 Series EuroMag Terminal Blocks Hi-Current; 10.16 Centers EM292908 Edge Connectors, One-Sided Boards Dimensions - mm L (mm) 2 3 4 5 6 7 8 20.34 30.50 40.66 50.82 60.98 71.14 81.30 Test Points 20.0 L 0.50 1.3 10.16 0.8 10.16 4.5 29.5 To convert to inches, divide by 25.4 Compliance References Poles 2.5 Part Numbering System En Mn 2n 9n 2n 9 nn n Series EuroMag Series High Current SPECIFICATIONS Rating: 65A, 300V Center Spacing: 0.40” (10.16mm) Wire Range: #6-20 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Copper Cage Material: Steel, Chromate Plated Screw Size: M4 Stainless Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 15 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Mold to length Agency Information: File E62622; CE Certified # of Poles – UL 02 to 08 For additional product information, visit www.eaton.com/connectors 61
EM292902-UL 价格&库存
很抱歉,暂时无法提供与“EM292902-UL”相匹配的价格&库存,您可以联系我们找货
EM292902-UL
  • 1+57.430811+7.14960
  • 10+40.7738010+5.07596
  • 25+35.8047625+4.45736
  • 50+32.7415750+4.07602
  • 100+30.22735100+3.76302
  • 300+27.20813300+3.38716
  • 500+26.13955500+3.25413
  • 1000+24.963771000+3.10776
库存:887
