EM367502
EM367502
    EATON(伊顿)
    插件,P=5mm
    TERM BLOCK 10A 300V 14-26AWG
EM367502 数据手册
EuroMag Series PCB Mount Terminal Blocks l i e t v un i t t c n r e fe 1 o . f m E d e 2 , c e t 0 d a l e , 2 ple ep u n 28 de r i t d n ry is e o sc rua ory end i D eb nt F ve omm 5 in ec 366 R M E SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.197” (5.00mm) Wire Range: #14-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Screw Size: M2.6 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 4.0 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Mold to Length Connector Style: Spring and Screw Agency Information: File E62622; CE Certified EM367512 15 16 17 18 19 20 21 22 23 24 L L (mm) 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 0.39 (10.0) 0.039 (1.00) 0.15 (3.7) 0.19 (4.8) 0.197 (5.00) 0.10 (2.5) 0.024 (0.60) To convert to inches, divide by 25.4 EM3675 Part Numbering System Series # of Poles E M 3 6 7 5 qq qqqqqq For additional product information, visit www.eaton.com/connectors 33 Compliance References 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 70.0 EuroMag Series Poles Edge Connectors, One-Sided Boards 2 3 4 5 6 7 8 9 10 11 12 13 14 L (mm) Spring & Screw Dimensions - (in) mm 0.32 (8.0) Poles Terminal Blocks: Single Row EM3675 Series EuroMag Terminal Blocks 5.00 Centers
EM367502 价格&库存
很抱歉,暂时无法提供与“EM367502”相匹配的价格&库存,您可以联系我们找货
