EM266102
EM266102
    EATON(伊顿)
    插件,P=10mm
    TERM BLOCK 10A 300V 14-26AWG
EM266102 数据手册
EuroMag Series PCB Mount Terminal Blocks EM266106 Dimensions - mm (in) 8.0 (0.315") Poles 15.0 25.0 35.0 45.0 55.0 65.0 8 9 10 11 12 13 L (mm) 75.0 85.0 95.0 105.0 115.0 125.0 0.6 (0.024") 0.9 (0.035") 4.8 (0.189") 2.5 (0.098") 10.0 (0.394") Compliance References 2 3 4 5 6 7 L (mm) 3.8 (0.156") 10.0 (0.394") L Edge Connectors, One-Sided Boards Poles Ø 1.4 ( Ø 0.005"0 4.8 (0.189") PCB Hole Layout 8.0 (0.315") To convert to inches, divide by 25.4 10.0 (0.394") Part Numbering System En Mn 2n 6n 6n 1 nn n Series EuroMag Series Spring & Screw SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.394” (10.00mm) Wire Range: #14-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Tin-Plated Brass Wire Protector: Stainless Steel Screw Size: M2.6 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -55°C (-40°F) min. Torque Rating: 3.0 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Mold-to-Length Agency Information: File E62622; CE Certified Terminal Blocks: Single Row EM2661 Series EuroMag Terminal Blocks 10.00 Centers # of Poles 02 to 13 For additional product information, visit www.eaton.com/connectors 35
EM266102 价格&库存
很抱歉,暂时无法提供与“EM266102”相匹配的价格&库存,您可以联系我们找货
