ED300/2DG
ED300/2DG
    OST
    插件,P=5mm
    接线端子 1x2P 5mm 直插 排数:单排 每排Pin数:2
ED300/2DG 数据手册
ED300/X (5.0mm) EDZ300/X (5.08 mm) ED350/X (5.0 mm) EDZ350/X (5.08 mm) 2-12 poles, Spacing 5.0 mm or 5.08 mm insert required no. of poles x 2-12 poles, Spacing 5.0 mm and 5.08 mm insert required no. of poles x How to order see page 5 How to order see page 5 *factory wiring Ratings: Rated Voltage Rated Current Wire Size Test Voltage Rated Torque/ScrewSize 250 V 24 A (T60) 2.5 mm 2 2.0 kV 0.5 Nm/M2.6 Ratings: Rated Voltage Rated Current Wire Size Test Voltage Rated Torque/ScrewSize Max. Rated Cross Section Single Wire (solid) Stranded Wire (flexible) Stranded wire with Ferrules 2.5 mm 2 1.5 mm 2 1.5 mm 2 Max. Rated Cross Section Single Wire (solid) Stranded Wire (flexible) Stranded wire with Ferrules 2.5 mm 2 1.5 mm 2 1.5 mm 2 Dimensions Spacing PCB Hole Diameter Stripped Length 5.0 mm (5.08 mm) 1.3 mm 7.0 mm Dimensions Spacing PCB Hole Diameter Stripped Length 5.0 mm (5.08 mm) 1.3 mm 6.0 mm Materials Insulating Material Flammability Class Temperature Range Terminal Block Wire Guard PA UL94 V-0 -30 C/+105 C CuZn Cu Materials Insulating Material Flammability Class Temperature Range Terminal Block Wire Guard PA UL94 V-0 -30 C/+105 C CuZn Cu Color Blue, (Grey) 14 300V 15 A AWG 22-12 300V 16 A AWG* 28-12 250 V 24 A (T60) 2.5 mm 2 2.0 kV 0.5 Nm/M3 Color Green ON-SHORE TECHNOLOGY INC 1917 West Third Street Tempe, Arizona USA 85281 Tel. (480)921-3000 Fax(480) 968-4444 14
ED300/2DG 价格&库存
很抱歉,暂时无法提供与“ED300/2DG”相匹配的价格&库存,您可以联系我们找货
