EM322502
EM322502
    EATON(伊顿)
    插件,P=5mm
    接线端子 1x2P 5mm 直插 排数:单排 每排Pin数:2
EM322502 数据手册
EuroMag Series PCB Mount Terminal Blocks 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 To convert to inches, divide by 25.4 0.8+ _0.1 (0.031") 7+ _0.3 (0.276") 2.5+ _0.3 (0.098") 0.9+ _0.1 (0.035") 5+ _0.1 (0.197") 5+ _0.1 (0.197") 13.3+ _0.3 (0.524") 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 3.5+ _0.3 (0.138") 2 3 4 5 6 7 8 9 10 11 12 13 L+ _0.5 15.3+ _0.3 (0.602") L (mm) 7+ _0.3 (0.276") PCB Hole Layout ø1.4~1.5 (ø0.055"~0.059") Part Numbering System En Mn 3n 2n 2n 5 nn n Series # of Poles 02 to 24 For additional product information, visit www.eaton.com/connectors EuroMag Series Poles 13.3+ _0.3 (0.524") Compliance References L (mm) Dimensions - mm (in) Edge Connectors, One-Sided Boards Poles EM322505 Cage & Screw SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.197” (5.00mm) Wire Range: #12-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Material: Brass, Nickel-Plated Screw Size: M2.6 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Terminal Blocks: Single Row EM3225 Series EuroMag Terminal Blocks 35° Angle; 5.00 Centers; Modular 41
EM322502 价格&库存
很抱歉,暂时无法提供与“EM322502”相匹配的价格&库存,您可以联系我们找货
