FAE1WSJR-52-22R
FAE1WSJR-52-22R
    YAGEO(国巨)
    插件电阻 - 22Ω ±5% 1W -
FAE1WSJR-52-22R 数据手册
無法顯示連結的圖像。檔案可能已移動、重新命名或刪除。請驗證連結指向正確的檔案及位置。 DATA SHEET WIREWOUND RESISTORS Fusible, Anti-Explosion FAE Series ±1%, ±5% 1/2W to 5W Product specification – August 13, 2021 V.0 RoHS compliant & Halogen Free Through Hole Resistors Wirewound Resistors Product Specification ORDERING INFORMATION Part number of the fusible anti-explosion wirewound resistor are identified by the series, power rating, tolerance, packing, temperature coefficient, forming and resistance value and suffix. PART NUMBER APPLICATIONS  Chargers & adapters FAE 2WS F T - 73- 10R CM (1) (2) (3) (4) (5) (6) (7) (8) (1) SERIES FAE Series  Home appliance  Lighting (2) POWER RATING  Safety application FEATURES 50S = 1/2W 1WV = 1W, 3WS = 3W 5WS = 5W -50 = 1/2W 2SS = 2W 300 = 3W, 500 = 5W 1SS = 1W 2WS = 2W 3WV = 3W 5WV = 5W 1WS = 1W 200 = 2W 4SS = 4W 100 = 1W 3SS = 3W 4WV = 4W  UL1412 qualified  Safety, anti-explosion  Fusing time 100MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of Marking coatings and markings Robustness of IEC 60115-1 4.16 Terminations Periodic-pulse Overload Direct load for 10 Sec. in the direction of ≥2.5Kg(24.5N) the terminal leads IEC 60115-1 4.39 4 times RCWV(or Umax., whichever less) ±2.0%+0.05Ω 10,000 cycles (1 Sec. on, 25 Sec.off) Damp Heat Steady State IEC 60115-1 4.24 40±2°C,90-95% RH for 56 days, loaded ±5.0%+0.05Ω with 0.1 times RCWV (or Umax., whichever less) Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV(or Umax., whichever ±5.0%+0.05Ω less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off) Temperature Cycling IEC 60115-1 4.19 -55°C  Room Temp.  ±2.0%+0.05Ω +155°C Room Temp.(5 cycles) Resistance to Soldering IEC 60115-1 4.18 Heat 260±3°C for 10±1 Sec., immersed to a ±1.0%+0.05Ω point 3±0.5mm from the body Accidental overload test IEC 60115-1 4.26 4 times RCWV for 1 Min. No evidence of flaming or arcing Note:. RCWV (Rated Continuous Working Voltage ): The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω) www.yageo.com Aug. 13, 2021 V.0 5 15 Through Hole Resistors Product Specification Wirewound Resistors FAE AXIAL / REEL TAPE SPECIFICATION Unit: mm Special Normal Miniature Ultra a Miniature A FAE1WV FAE-50 FAE50S FAE1WS FAE1SS FAE2SS 6 ± 0.5 52.4 ± 1.5 1.2 5 52.4 ± 1.5 1.2 FAE3WV FAE100 FAE2WS FAE3SS 6 ± 0.5 5(52-or 73-) 10(52Zor 73Z) B1-B2 (Max.) 73.0 ± 1.5 1.5 FAE4WV S (spacing) FAE3WS FAE500 FAE5WS FAE4SS 6 ± 0.5 T (max. deviation of spacing) 1 mm per 10 spacing, 0.5 mm per 5 spacing 52.4 ± 1.5 1.2 FAE200 FAE300 10 73.0 ± 1.5 1.5 73.0 ± 1.5 1.5 FAF5WV - 6 ± 0.5 10 91.0 ± 1.5 1.5 www.yageo.com Aug. 13, 2021 V.0 6 15 Through Hole Resistors Product Specification Wirewound Resistors FAE TAPE ON REEL PACKING TYPE Unit: mm/piece Special Normal Miniature Ultra Miniature Across Flange(A) B Quantity Per Reel - - FAE50S FAE1SS 66.5 75.5 5,000 FAE1WV FAE-50 FAE1WS FAE2SS 66.5 75.5 2,500 - FAE100 FAE2WS FAE3SS 87 96 2,000 FAE3WV FAE200 FAE3WS FAE4SS 87 96 1,000 FAE4WV FAE300 FAE5WS - 87 96 1,000 FAE5WV - - - 87 96 1,000 www.yageo.com Aug. 13, 2021 V.0 7 15 Through Hole Resistors Product Specification Wirewound Resistors FAE TAPE ON BOX PACKING TYPE DIMENSIONS Unit: mm/piece Special Normal Miniature Ultra Miniature A B C Quantity Per Box - - FAE50S FAE1SS 48 102 255 5,000 - - FAE50S FAE1SS 81 104 260 5,000 FAE1WV FAE-50 FAE1WS FAE2SS 73 45 258 1,000 - FAE100 FAE2WS FAE3SS 81 91 260 1,000 - FAE100 FAE2WS FAE3SS 103 78 260 1,000 FAE3WV FAE200 FAE3WS FAE4SS 81 91 260 1,000 FAE3WV FAE200 FAE3WS FAE4SS 103 94 260 1,000 FAE4WV FAE300 FAE5WS - 81 91 260 500 FAE4WV FAE300 FAE5WS - 103 94 260 500 FAE5WV - - - 103 94 260 250 BULK PACKING Special Normal Miniature Ultra Miniature Piece/Per Inner Box Bag/Per Inner Box Piece Per Bag - - FAE50S FAE1SS 10,000 10 1,000 FAE1WV FAE-50 FAE1WS FAE2SS 5,000 5 1,000 - FAE100 FAE2WS FAE3SS 2,000 4 500 FAE3WV FAE200 FAE3WS FAE4SS 1,000 2 500 FAE4WV FAE300 FAE5WS - 1,000 2 500 FAE5WV - - - 1000 2 500 - FAE500 - - 500 10 50 www.yageo.com Aug. 13, 2021 V.0 8 15 Through Hole Resistors Product Specification Wirewound Resistors FAE FORMING M TYPE TYPE DIMENSIONS Unit: mm Special Normal Miniature Ultra Miniature L ψD ψd - - FAE50A FAE1SS 6.3 ± 0.5 3.0± 0.5 0.55 ± 0.05 10.0 ± 1 10.0 ± 1 - FAE-50 FAE1WS FAE2SS 9.0± 0.5 3.8 ± 0.5 0.55 ± 0.05 12.5 ± 1 10.0 ± 1 0.8 ± 0.05 12.5 ± 1 10.0 ± 1 P H FAE1WV - - - 10.0±1.0 4.31.0 0.5 - FAE100 FAE2WS FAE3SS 11.5 ± 1.0 5.0 ± 0.5 0.8 ± 0.05 15.0 ± 1 12.5 ± 1 0.8 ± 0.05 15.0 ± 1 12.5 ± 1 - - - 13.0± 1.0 5.51.0 0.5 - FAE200 FAE3WS FAE4SS 15.5± 1.0 5.5 ± 0.5 0.8 ± 0.05 20.0 ± 1 15.0 ± 1 FAE4WV - - - 17.0 ± 1.0 5.51.0 0.5 0.8 ± 0.05 20.0 ± 1 15.0 ± 1 - FAE300 FAE25WS - 17.5 ± 1.0 6.7 ± 0.5 0.8 ± 0.05 25.0 ± 1 15.0 ± 1 FAE5WV - - - 17.0± 1.0 7.51.0 0.5 0.8 ± 0.05 25.0 ± 1 15.0 ± 1 - FAE500 - - 24.5± 1.0 8.7 ± 0.5 0.8 ± 0.05 30.0 ± 1 15.0 ± 1 FAE3WV MB TYPE www.yageo.com Aug. 13, 2021 V.0 9 15 Through Hole Resistors Wirewound Resistors Product Specification 15 FAE MB TYPE TYPE DIMENSIONS Unit: mm Special Normal Miniature Ultra L Miniature ψD ψd - - FAE50A FAE1SS 6.3 ± 0.5 3.0± 0.5 - FAE-50 - - 9.0± 0.5 - - H1 H2 t 0.55 ± 0.05 10.0 ± 1 6.0 ± 1 5.0 ± 1 1.2 ± 0.2 3.8 ± 0.5 0.55 ± 0.05 12.5 ± 1 6.0 ± 1 5.0 ± 1 1.2 ± 0.2 FAE1WS FAE2SS 9.0± 0.5 3.8 ± 0.5 0.8± 0.05 12.5 ± 1 6.0 ± 1 5.0 ± 1 1.4 ± 0.2 FAE1WV - - 4.31.0 0.5 0.8 ± 0.05 12.5 ± 1 6.0 ± 1 5.0 ± 1 1.4 ± 0.2 - FAE2WS FAE3SS 11.5 ± 1.0 5.0 ± 0.5 0.8 ± 0.05 15.0 ± 1 6.0 ± 1 5.0 ± 1 1.4 ± 0.2 0.8 ± 0.05 15.0 ± 1 6.0 ± 1 5.0 ± 1 1.4 ± 0.2 0.8 ± 0.05 20.0 ± 1 10.0 ± 1 5.0 ± 1 1.4 ± 0.2 0.8 ± 0.05 20.0 ± 1 10.0 ± 1 5.0 ± 1 1.4 ± 0.2 0.8 ± 0.05 25.0 ± 1 15.0 ± 1 5.0 ± 1 1.4 ± 0.2 0.8 ± 0.05 25.0 ± 1 15.0 ± 1 5.0 ± 1 1.4 ± 0.2 0.8 ± 0.05 30.0 ± 1 15.0 ± 1 5.0 ± 1 1.4 ± 0.2 FAE100 - - - FAE3WS FAE4SS 15.5± 1.0 5.5 ± 0.5 FAE4WV - - - FAE25WS FAE300 - 13.0± 1.0 5.51.0 0.5 FAE3WV FAE200 - 10.0±1.0 17.0 ± 1.0 5.51.0 0.5 17.5 ± 1.0 6.7 ± 0.5 7.51.0 0.5 FAE5WV - - - 17.0± 1.0 - - - 24.5± 1.0 8.7 ± 0.5 FAE500 P www.yageo.com Aug. 13, 2021 V.0 10 Through Hole Resistors Wirewound Resistors Product Specification 11 15 FAE MHA TYPE TYPE DIMENSIONS Normal Miniature Ultra L Miniature 9.0±0.5 FAE-50 FAE1WS FAE2SS P1 7.5±1.0 Unit: mm ψD ψd 3.8±0.3 B H0 HI P P0 0.55±0.05 17.5Max 19.0±1.0 4.0±1.0 30.0±1.0 15.0±0.3 P2 F W W0 W1 ΨD0 3.75±0.5 7.5±0.5 18.0±0.5 5.0Min 9.0±0.5 4.0±0.2 MHB TYPE TYPE Normal FAE200 DIMENSIONS Miniature Ultra L Miniature FAE3WS FAE4SS ψD Unit: mm ψd B H H0 HI H2 H3 15.5±1.0 5.5±0.5 0.8±0.05 21.0Max. 30Max. 18.0±1.0 5.5(Ref.) 8.0±1.5 16Max. P PI W W1 ΨD0 9.0±0.5 4.0±0.3 P0 30.0±1.0 15.0±0.3 7.5±1.0 P2 F 3.75±0.8 7.5±0.5 W0 18.0±0.5 5.0Min. www.yageo.com Aug. 13, 2021 V.0 Through Hole Resistors Wirewound Resistors Product Specification 15 FAE MHC TYPE TYPE Normal FAE200 DIMENSIONS Miniature FAE3WS Ultra L Miniature FAE4SS Unit: mm ψD ψd B H 15.5±1.0 5.5±0.5 0.8±0.05 21.0Max. 19.0±1.0 5.25±1.0 30.0±1.0 15.0±0.3 F W W0 10.0±0.5 18.0±0.5 5.0Min. W1 ΨD0 9.0±0.5 4.0±0.2 HI P P0 www.yageo.com Aug. 13, 2021 V.0 12 Through Hole Resistors Wirewound Resistors Product Specification 15 FAE MARKING 5-BAND-CODE ±5% COLOR BLACK BROWN RED ORANGE YELLOW GREEN BLUE VIOLET GREY WHITE GOLD SILVER 1st BAND 0 1 2 3 4 5 6 7 8 9 2nd BAND 0 1 2 3 4 5 6 7 8 9 3rd BAND 0 1 2 3 4 5 6 7 8 9 MULTIPLIER 1Ω 10Ω 100Ω 1KΩ 10KΩ 100KΩ 1MΩ 10MΩ TOLERANCE 0.1Ω 0.01Ω ±5 % (J) ±1 % (F) FAE Series ±1% 6-BAND-CODE www.yageo.com Aug. 13, 2021 V.0 13 Through Hole Resistors Wirewound Resistors Product Specification 15 FAE REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 0 Aug.2 , 2021 - - First issue of this specification “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itse lf are unchanged. Any product change will be announced by PCN.” www.yageo.com Aug. 13, 2021 V.0 14 Through Hole Resistors Wirewound Resistors Product Specification 15 FAE LEGAL DISCLAIMER Yageo, its distributors and agents (collectively, “Yageo”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. Yageo may make changes, modifications and/or improvements to product related information at any time and without notice. Yageo makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, Yageo disclaims (i) any and all liability arising out of the application or use of any Yageo product, (ii) any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non-infringement and merchantability. Yageo statements regarding the suitability of products for certain types of applications are based on Yageo’s knowledge of typical operating conditions for such types of applications in a generic nature. Such statements are neither binding statements of Yageo nor intended to constitute any warranty concerning the suitability for a specific customer application or use. They are intended for use only by customers with requisite knowledge and experience for determining whether Yageo products are the correct products for their application or use. In addition, unpredicatable and isolated cases of product failure may still occur, therefore, customer application or use of Yageo products which requires higher degree of reliability or safety, shall employ additional protective safeguard measures to ensure that product failure would not result in personal injury or property damage. Yageo products are not designed for application or use in medical, life-saving, or life-sustaining devices or for any other application or use in which the failure of Yageo products could result in personal injury or death. Customers using or selling Yageo products not expressly indicated for above-mentioned purposes shall do so at their own risk and agree to fully indemnify Yageo and hold Yageo harmless. Information provided here is intended to indicate product specifications only. Yageo reserves all the rights for revising this content without further notification, as long as products are unchanged. Any product change will be announced by PCN. www.yageo.com Aug. 13, 2021 V.0 15
FAE1WSJR-52-22R 价格&库存
很抱歉,暂时无法提供与“FAE1WSJR-52-22R”相匹配的价格&库存,您可以联系我们找货
FAE1WSJR-52-22R
