EM250602
EM250602
    EATON(伊顿)
    插件,P=7.62mm
    接线端子 1x2P 7.62mm 插件 排数:单排 每排Pin数:2
EM250602 数据手册
EuroMag Series PCB Mount Terminal Blocks L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 15.24 22.86 30.48 38.10 45.72 53.34 60.96 68.58 76.20 83.82 91.44 99.07 14 15 16 17 18 19 20 21 22 23 24 106.69 114.31 121.93 129.55 137.17 144.79 152.41 160.03 167.65 175.27 182.89 Ø Ø PCB Hole Layout To convert to inches, divide by 25.4 Part Numbering System En Mn 2n 5n 0n 6 nn n Series EuroMag Series Poles Compliance References L (mm) Dimensions - mm (in) Edge Connectors, One-Sided Boards Poles EM250605 Cage & Screw SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.30” (7.62mm) Wire Range: #14-26 2WG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Material: Brass, Nickel-Plated Screw Size: M2.6 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5.0 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Terminal Blocks: Single Row EM2506 Series EuroMag Terminal Blocks 7.62 Centers; Modular # of Poles 02 to 24 For additional product information, visit www.eaton.com/connectors 47
EM250602 价格&库存
很抱歉,暂时无法提供与“EM250602”相匹配的价格&库存,您可以联系我们找货
EM250602
  • 122+6.43604122+0.83507
  • 610+5.78285610+0.75032
库存:800
EM250602
  • 112+4.19558
库存:874
EM250602
  • 100+7.04912100+0.91462
