EuroMag Series PCB Mount Terminal Blocks
14
15
16
17
18
19
22
23
24
70.0
75.0
80.0
85.0
90.0
95.0
100.0
105.0
110.0
115.0
120.0
To convert to inches, divide by 25.4
0.8+
_0.1
(0.031")
7+
_0.3
(0.276")
2.5+
_0.3
(0.098")
0.9+
_0.1
(0.035")
5+
_0.1
(0.197")
5+
_0.1
(0.197")
13.3+
_0.3
(0.524")
10.0
15.0
20.0
25.0
30.0
35.0
40.0
45.0
50.0
55.0
60.0
65.0
3.5+
_0.3
(0.138")
2
3
4
5
6
7
8
9
10
11
12
13
L+
_0.5
15.3+
_0.3
(0.602")
L (mm)
7+
_0.3
(0.276")
PCB Hole Layout
ø1.4~1.5
(ø0.055"~0.059")
Part Numbering System
En
Mn
3n
2n
2n
5 nn
n
Series
# of Poles
02 to 24
For additional product information, visit www.eaton.com/connectors
EuroMag Series
Poles
13.3+
_0.3
(0.524")
Compliance
References
L (mm)
Dimensions - mm (in)
Edge Connectors,
One-Sided Boards
Poles
EM322505
Cage & Screw
SPECIFICATIONS
Rating: 16A, 300V
Center Spacing: 0.197” (5.00mm)
Wire Range: #12-26 AWG
Housing Material: UL rated 94V0 Thermoplastic
Contact Material: Brass Tin-Plated
Cage Material: Brass, Nickel-Plated
Screw Size: M2.6 Zinc-Plated Steel
Operating Temperature: 105°C (221°F) max., -40°C
(-40°F) min.
Torque Rating: 5 lb-in.
Recommended PCB Hole Diameters: 0.055" (1.40mm)
Construction: Modular design features dovetails for interlocking
to achieve longer lengths
Agency Information:
File E62622; CE Certified
Terminal Blocks:
Single Row
EM3225 Series
EuroMag Terminal Blocks
35° Angle; 5.00 Centers; Modular
41
很抱歉,暂时无法提供与“EM322503”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+13.17600
- 200+5.25960
- 500+5.08680
- 1000+5.00040
