Cage & Screw
EM2585 Series
EuroMag Terminal Blocks
5.00 Centers; Modular
SPECIFICATIONS
Rating: 16A, 300V
Center Spacing: 0.197” (5.00mm)
Wire Range: #12-26 AWG
Housing Material: UL rated 94V0 Thermoplastic
Contact Material: Brass Tin-Plated
Screw Size: M2.6 Zinc-Plated Steel
Operating Temperature: 105°C (221°F) max., -40°C
(-40°F) min.
Torque Rating: 5.0 lb-in.
Recommended PCB Hole Diameters: 0.055” (1.40mm)
Construction: Modular design features dovetails for
interlocking to achieve longer lengths
Connector Style: Rising Cage and screw
Agency Information:
File E62622; CE Certified
EM258505V
Dimensions - in (mm)
HORIZONTAL
0.035
(0.90)
0.19
(4.9)
0.40
(10.2)
0.197
(5.00)
0.10
(2.50)
L
0.12
(3.1)
0.10
(2.5)
Position
L (mm)
Position
L (mm)
0.10
(2.6)
02
03
04
05
06
07
08
09
10
11
12
13
Compliance
References
Edge Connectors,
One-Sided Boards
EuroMag Series
Terminal Blocks:
Single Row
EuroMag Series PCB Mount Terminal Blocks
10.0
15.0
20.0
25.0
30.0
35.0
40.0
45.0
50.0
55.0
60.0
65.0
14
15
16
17
18
19
22
23
24
70.0
75.0
80.0
85.0
90.0
95.0
100.0
105.0
110.0
115.0
120.0
0.57
(14.5)
0.33
(8.5)
0.07
(1.8)
0.03
(0.8)
VERTICAL
0.197
(5.00)
0.40
(10.2)
To convert to inches, divide by 25.4
0.10
(2.5)
L
0.12
(3.1)
0.10
(2.5)
0.10
(2.5)
0.57
(14.5)
0.34
(8.5)
0.18
(4.7)
Part Numbering System
En
Mn
2n
5n
8n
5 nn
n
Series
0.031
(0.79)
0.035
(0.90)
# of Positions
n
02 to 24
H - horizontal
V - vertical
Orientation
EM2585V
For additional product information, visit www.eaton.com/connectors
40
很抱歉,暂时无法提供与“EM258502V”相匹配的价格&库存,您可以联系我们找货
