EM266506
EM266506
    EATON(伊顿)
    插件,P=5mm
    接线端子 1x6P 5mm 插件 排数:单排 每排Pin数:6
EM266506 数据手册
Spring & Screw EM2665 Series EuroMag Terminal Blocks 5.00 Centers SPECIFICATIONS Rating: 10A, 300V Center Spacing: 0.197” (5.00mm) Wire Range: #14-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Screw Size: M2.6 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 4 lb-in. Recommended PCB Hole Diameters: 0.055” (1.40mm) Construction: Mold to Length Connector Style: Spring and Screw Agency Information: File E62622; CE Certified Position 02 03 04 05 06 07 08 09 10 11 12 13 Compliance References Edge Connectors, One-Sided Boards EuroMag Series Terminal Blocks: Single Row EuroMag Series PCB Mount Terminal Blocks L (mm) Position L (mm) 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 EM266512 Dimensions - in (mm) 0.15 (3.7) "L" To convert to inches, divide by 25.4 0.16 (4.0) 0.50 (12.8) 0.13 (3.43) 0.33 (8.4) 0.197 (5.00) 0.31 (7.8) 0.16 (4.0) 0.047 (1.20) 0.028 (0.70) Part Numbering System En Mn 2n 6n 6n 5 nn n Series # of Positions 02 to 24 For additional product information, visit www.eaton.com/connectors 30
EM266506 价格&库存
很抱歉,暂时无法提供与“EM266506”相匹配的价格&库存,您可以联系我们找货
