EM258503V
EM258503V
    EATON(伊顿)
    插件,P=5mm
EM258503V 数据手册
Cage & Screw EM2585 Series EuroMag Terminal Blocks 5.00 Centers; Modular SPECIFICATIONS Rating: 16A, 300V Center Spacing: 0.197” (5.00mm) Wire Range: #12-26 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Screw Size: M2.6 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5.0 lb-in. Recommended PCB Hole Diameters: 0.055” (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Connector Style: Rising Cage and screw Agency Information: File E62622; CE Certified EM258505V Dimensions - in (mm) HORIZONTAL 0.035 (0.90) 0.19 (4.9) 0.40 (10.2) 0.197 (5.00) 0.10 (2.50) L 0.12 (3.1) 0.10 (2.5) Position L (mm) Position L (mm) 0.10 (2.6) 02 03 04 05 06 07 08 09 10 11 12 13 Compliance References Edge Connectors, One-Sided Boards EuroMag Series Terminal Blocks: Single Row EuroMag Series PCB Mount Terminal Blocks 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 14 15 16 17 18 19 20 21 22 23 24 70.0 75.0 80.0 85.0 90.0 95.0 100.0 105.0 110.0 115.0 120.0 0.57 (14.5) 0.33 (8.5) 0.07 (1.8) 0.03 (0.8) VERTICAL 0.197 (5.00) 0.40 (10.2) To convert to inches, divide by 25.4 0.10 (2.5) L 0.12 (3.1) 0.10 (2.5) 0.10 (2.5) 0.57 (14.5) 0.34 (8.5) 0.18 (4.7) Part Numbering System En Mn 2n 5n 8n 5 nn n Series 0.031 (0.79) 0.035 (0.90) # of Positions n 02 to 24 H - horizontal V - vertical Orientation EM2585V For additional product information, visit www.eaton.com/connectors 40
EM258503V 价格&库存
很抱歉,暂时无法提供与“EM258503V”相匹配的价格&库存,您可以联系我们找货
