RNS Series
Stackpole Electronics, Inc.
Ultra Miniature Metal Film Resistor
Resistive Product Solutions
Features:
Miniature metal film for tight size constraints
Superior electrical, TCR performances
Flameproof silicone coating is standard
1-watt part in 1/4-watt package
2-watt part in 1/2-watt package
½-watt part in 1/8-watt package
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Electrical Specifications
Power Rating (W)
@ 70°C
Type / Code
Maximum
Working
Voltage (V)(1)
Maximum
Overload
Voltage (V)
RNS12
0.5
400
600
RNS1
1
500
700
RNS2
2
600
800
Ohmic Range (Ω) and Tolerance
TCR (ppm/ºC)
± 100
± 200
± 100
± 200
± 100
± 200
0.5%
1%
5%
100 - 511K
10 - 1M
10 - 1M
100 - 511K
10 - 1M
10 - 1M
100 - 511K
10 - 1M
10 - 1M
(1) Rated voltage = √ P*Ror Maximum Working Voltage, whichever is lower.
Mechanical Specifications
Type / Code
RNS12
RNS1
RNS2
A
Body Length
B
Body Diameter
C
Lead Length (Bulk)
D
Lead Diameter
Unit
0.126 ± 0.008 / -0
3.20 + 0.20 //-0
-0
0.073 ± 0.008
1.85 ± 0.20
1.102 ± 0.118
28.00 ± 3.00
0.018 ± 0.002
0.45 ± 0.05
inches
mm
0.236 ± 0.012
6.00 ± 0.30
0.335 ± 0.020
8.50 ± 0.50
0.094 ± 0.008
2.40 ± 0.20
1.102 ± 0.118
28.00 ± 3.00
0.022 ± 0.002
0.55 ± 0.05
inches
mm
0.110 ± 0.012
2.80 ± 0.30
1.102 ± 0.118
28.00 ± 3.00
0.028 ± 0.002
0.70 ± 0.05
inches
mm
Performance Characteristics
Item
Temperature Coefficient of Resistance
Performance
± 50 ppm/ºC
± 100 ppm/ºC
± 200 ppm/ºC
Voltage Proof
1. Change of Resistance
≤ ± (0.5% + 0.05 Ω)
Insulation Resistance
≥ 1000 Mohm
Rev Date: 10/22/2020
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
1
Test Method
Measure resistance (R0) at room temperature (t), after
that, measure again the resistance (R) at 100ºC higher than
room temperature
R - R0
TCR =
R0
106
X (t + 100) - t (ppm/ºC)
Lay the resistor on the 90º angle metal V block and apply
rated AC voltage for one minute.
500 Vdc between V block and lead wire for a minute. The
insulation resistance shall be measured while applying the
voltage.
www.seielect.com
marketing@seielect.com
RNS Series
Performance Characteristics (cont.)
Item
Solvent Resistance
Performance
There shall be no damage on the
insulating surface.
Overload (Short Time)
≤ ± (1% + 0.05 Ω)
Robustness of Termination
≤ ± (0.2% + 0.05 Ω)
Resistance to
Soldering Heat
≤ ± (0.3% + 0.05 Ω)
Solderability
More than 95% of the surface
of the lead shall be covered by
new solder.
Rapid Change of Temperature
≤ ± (1% + 0.05 Ω)
Vibration
Damp Heat, Steady State
Endurance at 70ºC
≤ ± (0.5% + 0.05 Ω)
≤ ± (3% + 0.05 Ω)
≤ ± (3% + 0.05 Ω)
Test Method
Soak in a Isopropyl alcohol for 5 minutes. After drying up
for 5 minutes, stress of 5 N is added with absorbent cotton
and it does by five round trips at the rate of one round trip a
second.
Apply 2.5 times rated voltage or max. overload voltage
whichever is lower for 5 seconds and leave in room
temperature for one hour after test.
Tensile:
The body of the resistor is fixed, a static load is added in
the direction of drawing out of the terminal,
and it maintains it for 10 ± 1 seconds.
Tensile strength: 10 N
Bend:
Component body shall be fixed so that terminals are
perpendicular to the floor. A static load specified below
shall be applied to the terminal acting in a direction away
from the body. The body of piezoelectric oscillator shall
then be inclined through an angle of 90º in the vertical plane
and then returned to its initial position in 2 or 3 seconds then
the body shall be inclined to the reversed direction through
an angle 90º and then returned to its initial position in 2 or 3
seconds.
Bending strength: 5 N
Dip the lead into a solder bath having a temperature of
260ºC ± 5ºC up to 1.5 ± 0.5 mm from the body of the
resistors and hold it for 10 ± 0.5 seconds and leave in room
245 ± 5ºC up to 1.5 ± 0.5 mm from the body of the
resistors and hold it form 5 ± 0.5 seconds.
The resistor shall be subjected to 5 continuous cycles, each
as show in the table below:
1
2
3
4
Temperature
Minimum Operating Temperature
Standard Atmospheric Condition
Max Operating Temperature
Duration
30 min.
≤ 30 sec.
30 min.
≤ 30 sec.
Apply 1.5 mm amplitude vibration to three directions
perpendicular to each other 2 hours each,
total 6 hours. Vibrating frequency is
10 Hz - 55 Hz - 10 Hz cycle in 1 minute sweeping
and repeat cycle.
In the chamber having temp. 40 ± 2ºC and relative humidity
93 ± 3%, apply one percent of the rated power, 1.5 hour
ON, 0.5 hour OFF for 1000 hours and leave in room
At 70 ± 2ºC, apply rated DC voltage 1.5 hour ON,
0.5 hour OFF for 1000 hours and leave in room temperature
Operating temperature range is -55°C to +155°C
2
www.seielect.com
RNS Series
Power Derating Curve:
Heat Rise:
Recommended Solder Profile
This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should
be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board
density, geometry, packages used, etc., especially those cells labeled with “*”.
100% Matte Tin / RoHS Compliant Terminations
Soldering iron recommended temperatures: 330°C to 350°C with minimum duration.
Maximum number of reflow cycles: 3.
Wave Soldering
Description
Maximum
Recommended
Preheat Time
80 seconds
70 seconds
Temperature Diff.
140°C
120°C
Solder Temp.
260°C
250°C
Dwell Time at Max.
10 seconds
5 seconds
Ramp DN (°C/sec)
N/A
N/A
Temperature Diff. = Defference between final preheat stage and soldering stage.
3
Minimum
60 seconds
100°C
240°C
N/A
www.seielect.com
RNS Series
Convection IR Reflow
Description
Maximum
Recommended
Minimum
Ramp Up (°C/sec)
Dwell Time > 217°C
Solder Temp.
Dwell Time at Max.
Ramp DN (°C/sec)
3°C/sec
150 seconds
260°C
30 seconds
6°C/sec
2°C/sec
90 seconds
245°C
15 seconds
3°C/sec
60 seconds
10 seconds
Recommended Lead Free Resistor Reflow Profile
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
RNS
Description
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
Ultra-Miniature Metal Film Resistor
Axial
YES
100% Matte Sn
Always
Always
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
4
www.seielect.com
RNS Series
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
How to Order
Product Series
RNS Ultra Mini
1
2
3
4
5
6
7
8
9
10
11
R
N
S
1
F
T
D
4
K
7
5
Power Rating
Size
W
12
0.5
1
1
2
2
Code
D
F
J
Tolerance
Tol
Value
0.5%
E96
1%
E96, E24
5%
E24
Code
T
A
B
Packaging
Size
Quantity
RNS12, RNS1
5000
Tape and Reel
RNS2
2500
RNS12
5000
Ammo
RNS1, RNS2
2000
Bulk
RNS12, RNS1, RNS2 1000
Description
5
TCR
Code ppm
D 100
L 200
Resistance Value
Four characters with the
multiplier used as the
decimal holder.
100 ohms = 100R
10.2 Kohm = 10K2
1 Mohm = 1M00
www.seielect.com
很抱歉,暂时无法提供与“RNS1FTD127K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5000+0.423385000+0.05488
