EM291904
EM291904
    EATON(伊顿)
    插件,P=9.53mm
    接线端子 间距P=9.53mm 4Pin(1x4) 插件
EM291904 数据手册
High Current EM2919 Series EuroMag Terminal Blocks 9.52 Centers; Modular SPECIFICATIONS Rating: 30A, 600V Center Spacing: 0.375” (9.52mm) Wire Range: #10-24 AWG Housing Material: UL rated 94V0 Thermoplastic EM291905 Contact Material: Brass Tin-Plated Cage Material: Steel, Nickel-Plated Screw Size: M3.0 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Dimensions - mm (in) Torque Rating: 9.0 lb-in. Recommended PCB Hole Diameters: 0.055" (1.40mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Poles L (mm) Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 19.04 28.56 38.08 47.60 57.12 66.64 76.16 85.68 95.20 104.72 114.24 123.76 14 15 16 17 18 19 20 21 22 23 24 133.28 142.80 152.32 161.84 171.36 180.88 190.40 199.92 209.44 218.96 228.48 Compliance References Edge Connectors, One-Sided Boards EuroMag Series Terminal Blocks: Single Row EuroMag Series PCB Mount Terminal Blocks ø ø PCB Hole Layout To convert to inches, divide by 25.4 Part Numbering System En Mn 2n 9n 1n 9 nn n Series # of Poles 02 to 24 For additional product information, visit www.eaton.com/connectors 60
EM291904 价格&库存
很抱歉,暂时无法提供与“EM291904”相匹配的价格&库存,您可以联系我们找货
