M55 Sect 3 p58
m
10/19/06
11:40 AM
Page 58
PC TERMINAL BLOCKS
These versatile PC terminal blocks provide a quick and easy
method to attach wire leads to a circuit board. Multiple units may
be interlocked for strips as long as 24 positions inline. Because
of accumulating tolerances, we do not recommend longer strips.
• Wire access available in horizontal, 45° or vertical wire entry
• Simplifies termination of removable leads
• Individual leads can be disconnected without
• Wire guard helps prevent damage to conductors
• Accepts 22-16 AWG wire
• Mounts easily in pre-drilled or stamped holes
• 5mm spacing
MODULAR INTERLOCKING PC TERMINAL BLOCKS
disturbing others
SPECIFICATIONS
ELECTRICAL:
MATERIAL:
Contact: Brass, Tin Plate
Housing: Blue PBT, UL Rated 94V-0
Screw: Steel, Zinc Plate
& Clear Chromate (captivated)
MECHANICAL:
Current Rating: 16 Amps
Dielectric Strength: 2500V
Insulation Breakdown:
1500VAC/min.
Rated Voltage: 250V
Operating Temp:
22°F to 248°F (-30°C to 120°C)
Peak Temp: +393°F (+200°C)
Wire Size: Accepts #22-14 AWG
A
.300 [7.6]
.027 [0.69]
HORIZONTAL WIRE ENTRY
.394 [10.0]
5mm SPACING
CAT.
NO.
8718
8719
POSITIONS
2
3
A
DIM.
.394 (10.0)
.591 (15.0)
.100 [2.6]
DIA.
.177 [4.5]
.039 [0.99]
DIA.
.098 [2.5]
8718
Recommended Mtg. Hole Size: .047 (1.19)
A
.492 [12.5]
.024 [0.61]
45° WIRE ENTRY
.492 [12.5]
5mm SPACING
CAT.
NO. POSITIONS
8720
2
8721
3
A
DIM.
.394 (10.0)
.591 (15.0)
.177 [4.5]
.031 [0.79]
.248 [6.3]
8721
.039 [0.99]
.197 [5.0]
.098 [2.5]
Recommended Mtg. Hole Size: .051 (1.30)
8720
A
.394 [10.0]
.027 [0.69]
VERTICAL WIRE ENTRY
.300 [7.6]
5mm SPACING
CAT.
NO.
8738
8739
POSITIONS
2
3
A
DIM.
.394 (10.0)
.591 (15.0)
.039 [1.0] DIA.
.210 [5.3]
8739
.197 [5.0]
.098 [2.5]
.105 [2.7]
8738
SCREWLESS - PUSH BUTTON TYPE
Particularly useful when quick reliable connections are required or when temporary
connections are needed, such as on test sets and bread boards. They may be interlocked
to achieve the required number of positions.
SPECIFICATIONS
MATERIAL:
Terminal: Brass, Tin Plate
Contact: Stainless Steel
Housing: Blue Nylon 6/6,
UL Rated 94V-0
ELECTRICAL:
Current Rating: 10 Amps
Insulation Breakdown: 1500V AC/min.
• Available with two or three terminal positions • Quick reliable connection
• Mounts easily in predrilled or stamped holes • Because of accumulating tolerances,
• Suited for both solid and stranded wire
we recommend a maximum of 24
• Accepts #20-18 AWG wire*
positions per row.
• Stainless Steel spring assures good contact
8728
MECHANICAL:
A
.500 [12.7]
.197 [5.0]
Operating Temp:
Peak Temp: +392°F (+200°C)
.520
[13.2]
.091
[2.3]
REF.
POSITIONS
2
3
A
DIM.
.459 (11.7)
.656 (16.7)
Mounting Detail
for (3) Postions
.197 [5.0]
.753
[19.2]
REF.
.142 [3.6]
DIA.
5mm SPACING
CAT.
NO.
8728
8729
58
8719
.197 [5.0]
50 [3.8]
.197 [5.0]
.197 [5.0]
.142 [3.6]
.118 [3.0]
.197 [5.0]
Tel (718) 956-8900 • Fax (718) 956-9040
(800) 221-5510 • kec@keyelco.com
.065 [1.65]
.086 [2.18]
.051 [1.30] DIA.
(TYP.)
.016 [0.41]
x .032 [.81]
8729
*Recommended wire strip length: .300 (7.6)
RoHS COMPLIANT ~ ISO 9001 CERTIFIED
www.keyelco.com
31-07 20th Road – Astoria, NY 11105-2017
很抱歉,暂时无法提供与“8729”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+27.273901+3.53150
- 10+20.6980010+2.68000
- 25+19.4643025+2.52030
- 100+18.85340100+2.44120
- 500+17.79930500+2.30470
- 1000+17.092601000+2.21320
- 2500+16.745202500+2.16820
- 5000+16.050505000+2.07830
- 国内价格
- 1+31.93560
- 200+12.74400
- 500+12.32280
- 1000+12.10680
