EM912606
EM912606
    EATON(伊顿)
    插件,P=6.35mm
    接线端子 间距P=6.35mm 6Pin(1x6) 直插
EM912606 数据手册
High Current EM9126 Series EuroMag Terminal Blocks 6.35 Centers; Modular SPECIFICATIONS Rating: 30A, 300V Center Spacing: 0.250” (6.35mm) Wire Range: #10-24 AWG Housing Material: UL rated 94V0 Thermoplastic Contact Material: Brass Tin-Plated Cage Material: Brass, Nickel-Plated Screw Size: M3.0 Zinc-Plated Steel Operating Temperature: 105°C (221°F) max., -40°C (-40°F) min. Torque Rating: 5.5 lb-in. Recommended PCB Hole Diameters: 0.071" (1.80mm) Construction: Modular design features dovetails for interlocking to achieve longer lengths Agency Information: File E62622; CE Certified Poles L (mm) Poles L (mm) 2 3 4 5 6 7 8 9 10 11 12 13 12.70 19.05 25.40 31.75 38.10 44.45 50.80 57.15 63.50 69.85 76.20 82.55 14 15 16 17 18 19 20 21 22 23 24 88.90 95.25 101.60 107.95 114.30 120.65 127.00 133.35 139.70 146.05 152.40 Compliance References Edge Connectors, One-Sided Boards EuroMag Series Terminal Blocks: Single Row EuroMag Series PCB Mount Terminal Blocks EM912605 Dimensions - mm (in) Ø Ø PCB Hole Layout To convert to inches, divide by 25.4 Part Numbering System En Mn 9n 1n 2n 6 nn n Series # of Poles 02 to 24 For additional product information, visit www.eaton.com/connectors 56
EM912606 价格&库存
很抱歉,暂时无法提供与“EM912606”相匹配的价格&库存,您可以联系我们找货
EM912606
  • 26+30.1223026+3.89850
  • 100+27.85221100+3.60470
库存:693
EM912606
  • 45+20.63934
  • 100+19.10379
库存:693
