RNS1FTC78K7
RNS1FTC78K7
    SEI
    AXIAL_D2.4X6MM_TM
    插件电阻 - 78.7KΩ ±1% 1W ±50ppm/℃
RNS1FTC78K7 数据手册
RNS Series Stackpole Electronics, Inc. Ultra Miniature Metal Film Resistor Resistive Product Solutions Features: • • • • • • • • • Miniature metal film for tight size constraints Superior electrical, TCR performances Flameproof silicone coating is standard 1-watt part in 1/4-watt package 2-watt part in 1/2-watt package ½-watt part in 1/8-watt package 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Electrical Specifications Power Rating (W) @ 70°C Type / Code Maximum Working Voltage (V)(1) Maximum Overload Voltage (V) RNS12 0.5 400 600 RNS1 1 500 700 RNS2 2 600 800 Ohmic Range (Ω) and Tolerance TCR (ppm/ºC) ± 100 ± 200 ± 100 ± 200 ± 100 ± 200 0.5% 1% 5% 100 - 511K 10 - 1M 10 - 1M 100 - 511K 10 - 1M 10 - 1M 100 - 511K 10 - 1M 10 - 1M (1) Rated voltage = √ P*Ror Maximum Working Voltage, whichever is lower. Mechanical Specifications Type / Code RNS12 RNS1 RNS2 A Body Length B Body Diameter C Lead Length (Bulk) D Lead Diameter Unit 0.126 ± 0.008 / -0 3.20 + 0.20 //-0 -0 0.073 ± 0.008 1.85 ± 0.20 1.102 ± 0.118 28.00 ± 3.00 0.018 ± 0.002 0.45 ± 0.05 inches mm 0.236 ± 0.012 6.00 ± 0.30 0.335 ± 0.020 8.50 ± 0.50 0.094 ± 0.008 2.40 ± 0.20 1.102 ± 0.118 28.00 ± 3.00 0.022 ± 0.002 0.55 ± 0.05 inches mm 0.110 ± 0.012 2.80 ± 0.30 1.102 ± 0.118 28.00 ± 3.00 0.028 ± 0.002 0.70 ± 0.05 inches mm Performance Characteristics Item Temperature Coefficient of Resistance Performance ± 50 ppm/ºC ± 100 ppm/ºC ± 200 ppm/ºC Voltage Proof 1. Change of Resistance ≤ ± (0.5% + 0.05 Ω) Insulation Resistance ≥ 1000 Mohm Rev Date: 10/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 Test Method Measure resistance (R0) at room temperature (t), after that, measure again the resistance (R) at 100ºC higher than room temperature R - R0 TCR = R0 106 X (t + 100) - t (ppm/ºC) Lay the resistor on the 90º angle metal V block and apply rated AC voltage for one minute. Lay the resistor on the 90º angle metal V block and apply 500 Vdc between V block and lead wire for a minute. The insulation resistance shall be measured while applying the voltage. www.seielect.com marketing@seielect.com RNS Series Stackpole Electronics, Inc. Ultra Miniature Metal Film Resistor Resistive Product Solutions Performance Characteristics (cont.) Item Solvent Resistance Performance There shall be no damage on the insulating surface. Overload (Short Time) Change of Resistance ≤ ± (1% + 0.05 Ω) Robustness of Termination Change of Resistance ≤ ± (0.2% + 0.05 Ω) Resistance to Soldering Heat Change of Resistance ≤ ± (0.3% + 0.05 Ω) Solderability More than 95% of the surface of the lead shall be covered by new solder. Rapid Change of Temperature Change of Resistance ≤ ± (1% + 0.05 Ω) Vibration Damp Heat, Steady State Endurance at 70ºC Change of Resistance ≤ ± (0.5% + 0.05 Ω) Change of Resistance ≤ ± (3% + 0.05 Ω) Change of Resistance ≤ ± (3% + 0.05 Ω) Test Method Soak in a Isopropyl alcohol for 5 minutes. After drying up for 5 minutes, stress of 5 N is added with absorbent cotton and it does by five round trips at the rate of one round trip a second. Apply 2.5 times rated voltage or max. overload voltage whichever is lower for 5 seconds and leave in room temperature for one hour after test. Tensile: The body of the resistor is fixed, a static load is added in the direction of drawing out of the terminal, and it maintains it for 10 ± 1 seconds. Tensile strength: 10 N Bend: Component body shall be fixed so that terminals are perpendicular to the floor. A static load specified below shall be applied to the terminal acting in a direction away from the body. The body of piezoelectric oscillator shall then be inclined through an angle of 90º in the vertical plane and then returned to its initial position in 2 or 3 seconds then the body shall be inclined to the reversed direction through an angle 90º and then returned to its initial position in 2 or 3 seconds. Bending strength: 5 N Dip the lead into a solder bath having a temperature of 260ºC ± 5ºC up to 1.5 ± 0.5 mm from the body of the resistors and hold it for 10 ± 0.5 seconds and leave in room temperature for one hour after test. Dip the lead into a solder bath having a temperature of 245 ± 5ºC up to 1.5 ± 0.5 mm from the body of the resistors and hold it form 5 ± 0.5 seconds. The resistor shall be subjected to 5 continuous cycles, each as show in the table below: 1 2 3 4 Temperature Minimum Operating Temperature Standard Atmospheric Condition Max Operating Temperature Standard Atmospheric Condition Duration 30 min. ≤ 30 sec. 30 min. ≤ 30 sec. Apply 1.5 mm amplitude vibration to three directions perpendicular to each other 2 hours each, total 6 hours. Vibrating frequency is 10 Hz - 55 Hz - 10 Hz cycle in 1 minute sweeping and repeat cycle. In the chamber having temp. 40 ± 2ºC and relative humidity 93 ± 3%, apply one percent of the rated power, 1.5 hour ON, 0.5 hour OFF for 1000 hours and leave in room temperature for one hour after test. At 70 ± 2ºC, apply rated DC voltage 1.5 hour ON, 0.5 hour OFF for 1000 hours and leave in room temperature for one hour after test. Operating temperature range is -55°C to +155°C Rev Date: 10/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com RNS Series Stackpole Electronics, Inc. Ultra Miniature Metal Film Resistor Resistive Product Solutions Power Derating Curve: Heat Rise: Recommended Solder Profile This information is intended as a reference for solder profiles for Stackpole resistive components. These profiles should be compatible with most soldering processes. These are only recommendations. Actual numbers will depend on board density, geometry, packages used, etc., especially those cells labeled with “*”. 100% Matte Tin / RoHS Compliant Terminations Soldering iron recommended temperatures: 330°C to 350°C with minimum duration. Maximum number of reflow cycles: 3. Wave Soldering Description Maximum Recommended Preheat Time 80 seconds 70 seconds Temperature Diff. 140°C 120°C Solder Temp. 260°C 250°C Dwell Time at Max. 10 seconds 5 seconds Ramp DN (°C/sec) N/A N/A Temperature Diff. = Defference between final preheat stage and soldering stage. Rev Date: 10/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 Minimum 60 seconds 100°C 240°C * N/A www.seielect.com marketing@seielect.com RNS Series Stackpole Electronics, Inc. Ultra Miniature Metal Film Resistor Resistive Product Solutions Convection IR Reflow Description Maximum Recommended Minimum Ramp Up (°C/sec) Dwell Time > 217°C Solder Temp. Dwell Time at Max. Ramp DN (°C/sec) 3°C/sec 150 seconds 260°C 30 seconds 6°C/sec 2°C/sec 90 seconds 245°C 15 seconds 3°C/sec * 60 seconds * 10 seconds * Recommended Lead Free Resistor Reflow Profile RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series RNS Description Package / Termination Type Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) Ultra-Miniature Metal Film Resistor Axial YES 100% Matte Sn Always Always “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Rev Date: 10/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com RNS Series Stackpole Electronics, Inc. Ultra Miniature Metal Film Resistor Resistive Product Solutions Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order Product Series RNS Ultra Mini 1 2 3 4 5 6 7 8 9 10 11 R N S 1 F T D 4 K 7 5 Power Rating Size W 12 0.5 1 1 2 2 Code D F J Tolerance Tol Value 0.5% E96 1% E96, E24 5% E24 Code T A B Rev Date: 10/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. Packaging Size Quantity RNS12, RNS1 5000 Tape and Reel RNS2 2500 RNS12 5000 Ammo RNS1, RNS2 2000 Bulk RNS12, RNS1, RNS2 1000 Description 5 TCR Code ppm D 100 L 200 Resistance Value Four characters with the multiplier used as the decimal holder. 100 ohms = 100R 10.2 Kohm = 10K2 1 Mohm = 1M00 www.seielect.com marketing@seielect.com
RNS1FTC78K7
物料型号:RNS系列
器件简介:RNS系列是由Stackpole Electronics, Inc.生产的超小型金属膜电阻器,具有迷你尺寸、优越的电气性能和温度系数(TCR)表现。它们有防火硅涂层,符合100% RoHS标准,无卤素,符合REACH标准。
引脚分配:文档中未明确提供引脚分配信息,但根据机械规格表,可以推断电阻器的引脚长度和直径。
参数特性: - 功率额定值:0.5W、1W、2W - 最大工作电压:400V、500V、600V - 最大过载电压:600V、700V、800V - 温度系数(TCR):±100 ppm/°C、±200 ppm/°C - 欧姆范围和公差:100-511K、10-1M,公差为0.5%、1%、5%
功能详解:文档提供了电阻器的性能特性测试方法,包括温度系数、耐电压、绝缘电阻、耐溶剂性、过载(短时间)端子强度、焊接热抗性、焊锡性、快速温度变化、振动和湿热稳定性等。
应用信息:文档未明确提供应用信息,但根据其特性,这些电阻器适用于对尺寸和电气性能有严格要求的场合。
封装信息:提供了详细的机械规格,包括身体长度、身体直径、引脚长度、引脚直径等,以及英寸和毫米两种单位。
RNS1FTC78K7 价格&库存
很抱歉,暂时无法提供与“RNS1FTC78K7”相匹配的价格&库存,您可以联系我们找货
RNS1FTC78K7
  • 5000+0.406115000+0.05249
